2007-06-07 | cosmetic changes to bcm570x driver | Vadim Bendebury | |
This is a cosmetic only changes submission. It affects files relevant to bcm570x driver. the commands used to generate this change was cd drivers Lindent -pcs -l80 bcm570x.c bcm570x_lm.h bcm570x_mm.h tigon3.c tigon3.h The BMW target (the only one using this chip so far) builds cleanly, the `before and after' generated object files for drivers/bcm570x.c and drivers/tigon3.o are identical as reported by objdump -d Signed-off-by: Vadim Bendebury <vbendeb@google.com> Signed-off-by: Ben Warren <bwarren@qstreams.com> | |||
2003-06-27 | * Code cleanup:LABEL_2003_06_27_2340 | wdenk | |
- remove trailing white space, trailing empty lines, C++ comments, etc. - split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c) * Patches by Kenneth Johansson, 25 Jun 2003: - major rework of command structure (work done mostly by Michal Cendrowski and Joakim Kristiansen) | |||
2002-11-03 | Initial revision | wdenk | |
