path: root/drivers/ata/sata.c
2017-08-17dm: sata: Update the AHCI uclass to support operationsSimon Glass
At present the AHCI uclass is just a shell and we still use the global functions to access SATA. Fix this by adding operations to the uclass. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-07-11sata: Move drivers into new drivers/ata directorySimon Glass
At present we have the SATA and PATA drivers mixed up in the drivers/block directory. It is better to split them out into their own place. Use drivers/ata which is what Linux does. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
