path: root/drivers/Makefile
2020-05-29phy: rockchip: Add Rockchip USB2PHY driverJagan Teki
Add Rockchip USB2PHY driver with initial support. This will help to use it for EHCI controller in host mode, and USB 3.0 controller in otg mode. More functionality like charge, vbus detection will add it in future changes. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Frank Wang <frank.wang@rock-chips.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2020-03-03drivers: Descend to drivers/soc unconditionallyVignesh Raghavendra
Descend to drivers/soc directory unconditionally for SPL and U-Boot builds. Individual drivers can have their own config to check what needs to be built for SPL. There should be no increase in SPL code size due to this change. This is required on K3 SoCs to support DMA in SPL. Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2020-01-15Kconfig: Rename CONFIG_SPL_DMA_SUPPORT to CONFIG_SPL_DMAVignesh Raghavendra
Rename CONFIG_SPL_DMA_SUPPORT to CONFIG_SPL_DMA. This allows to use macros such as CONFIG_IS_ENABLED() that allow conditional compilation of code for SPL and U-Boot. Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-01-08Merge tag 'efi-2020-04-rc1' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-efi Pull request for UEFI sub-system for efi-2020-04-rc1 This pull request provides: * support for FIT images for UEFI binaries * drivers for hardware random number generators * an implementation of the EFI_RNG_PROTOCOL * a sub-command for efidebug to display configuration tables
2020-01-08Merge branch 'master' of git://git.denx.de/u-boot-socfpgaTom Rini
2020-01-07dm: rng: Add random number generator(rng) uclassSughosh Ganu
Add a uclass for reading a random number seed from a random number generator device. Signed-off-by: Sughosh Ganu <sughosh.ganu@linaro.org> Reviewed-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-01-07drivers: board: Make the board drivers available in SPLJean-Jacques Hiblot
Make the board driver available in the SPL too. The board driver is a way to provide useful information about the board and that can be useful in the SPL too. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-01-07spl: Allow cache drivers to be used in SPLLey Foon Tan
Add an option for building cache drivers in SPL. Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
2019-12-15x86: sandbox: Add a PMC emulator and testSimon Glass
Add a simple PMC for sandbox to permit tests to run. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-12-10spl: cache: Allow cache drivers in SPLRick Chen
When ax25-ae350 try to enable v5l2 cache driver in SPL configuration, it need this option for cache support in SPL. Signed-off-by: Rick Chen <rick@andestech.com> Cc: KC Lin <kclin@andestech.com> Cc: Alan Kao <alankao@andestech.com>
2019-12-04mtd: Makefile: deep cleanupMiquel Raynal
Move MTD-related lines out of the root Makefile. Put them in their respective directories. Enclose some of these new lines to skip them when building the SPL. MTD core files and some MTD device drivers are compiled in a mtd.o object and included in the final object only if MTD support is required (there are two different symbols for that, one for U-Boot and one for the SPL). Now that all defconfigs have been fixed, we can stop the logic where enabling a command selects the core files to compile. This logic is broken since selecting a symbol with a 'depends on' will not enforce this secondary dependency. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
2019-10-23ufs: Add Initial Support for UFS subsystemFaiz Abbas
Add Support for UFS Host Controller Interface (UFSHCI) for communicating with Universal Flash Storage (UFS) devices. The steps to initialize the host controller interface are the following: - Initiate the Host Controller Initialization process by writing to the Host controller enable register. - Configure the Host Controller base address registers by allocating a host memory space and related data structures. - Unipro link startup procedure - Check for connected device - Configure UFS host controller to process requests Also register this host controller as a SCSI host controller. Taken from Linux Kernel v5.2 (drivers/scsi/ufs/ufshcd.c) and ported to U-boot. Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
2019-08-11Drop PCMCIASimon Glass
This is no-longer used in U-Boot and has not been converted to driver model. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-07-21spl: kconfig: separate sysreset and firmware drivers from miscSimon Goldschmidt
This adds separate kconfig options for drivers/sysreset and drivers/firmware. Up to now, CONFIG_SPL_DRIVERS_MISC_SUPPORT added drivers/misc to SPL build but also added drivers/firmware and drivers/sysreset at the same time. Since that is confusing, this patch uses CONFIG_SPL_SYSRESET for drivers/sysreset and adds CONFIG_SPL_FIRMWARE for drivers/firmware (and accordingly for the TPL options). CONFIG_SPL_DRIVERS_MISC_SUPPORT stays for including drivers/misc into the SPL build (and accordingly for TPL) since there are boards using non-DM (non UCLASS_MISC) files from drivers/misc. Such boards don't have CONFIG_SPL_MISC enabled, so cannot use this to include drivers/misc into the SPL build. Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
2019-07-11drivers: pci_ep: Introduce UCLASS_PCI_EP uclassRamon Fried
Introduce new UCLASS_PCI_EP class for handling PCI endpoint devices, allowing to set various attributes of the PCI endpoint device, such as: * configuration space header * BAR definitions * outband memory mapping * start/stop PCI link Signed-off-by: Ramon Fried <ramon.fried@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-05-07Merge branch 'master' of git://git.denx.de/u-boot-socfpgaTom Rini
- Assorted stratix10 fixes. - DDR driver DM migration.
2019-05-06ddr: altera: Compile ALTERA SDRAM in SPL onlyLey Foon Tan
Compile ALTERA_SDRAM driver in SPL only. Rename ALTERA_SDRAM to SPL_ALTERA_SDRAM. Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
2019-05-05dm: cache: Create a uclass for cacheDinh Nguyen
The cache UCLASS will be used for configure settings that can be found in a CPU's L2 cache controller. Add a uclass and a test for cache. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Dinh Nguyen <dinguyen@kernel.org>
2019-02-20x86: sandbox: pch: Add a CONFIG option for PCHSimon Glass
At present this uclass is selected only on x86. In order to add a test for it, it must also support sandbox. Create a new CONFIG_PCH option and enable it on x86 and sandbox. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-01-26dfu: Make DFU support more SPL friendlyAndrew F. Davis
Do this by using $(SPL_) in Makefiles and CONFIG_IS_ENABLED in C code. This ensures the files and features are only built into the right build for which they are enabled. Using the macros to simplify this patch was made possible by the config symbol rename done in the last patch. Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Lukasz Majewski <lukma@denx.de>
2019-01-26spl: Kconfig: Drop the _SUPPORT postfix from SPL_DFUAndrew F. Davis
The symbol CONFIG_SPL_DFU_SUPPORT in SPL build has the same meaning as CONFIG_DFU in regular U-Boot. Drop the _SUPPORT to allow for cleaner use in code. Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Lukasz Majewski <lukma@denx.de>
2019-01-10Kconfig: rename CONFIG_SPL_USB_GADGET_SUPPORT as CONFIG_SPL_USB_GADGETJean-Jacques Hiblot
The SPL option for USB gadget should be named after the option for u-boot (CONFIG_USB_GADGET) Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2019-01-01Merge tag 'u-boot-imx-20190101' of git://www.denx.de/git/u-boot-imxTom Rini
imx for 2019.01 - introduce support for i.MX8M - fix size limit for Vhybrid / pico boards - several board fixes - w1 driver for MX2x / MX5x
2019-01-01drivers: ddr: introduce DDR driver for i.MX8MPeng Fan
Introduce DDR driver for i.MX8M. The driver will be used by SPL to initialze DDR PHY and DDR Controller. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2018-12-14spl: drivers: Link usb common library to SPL if USB gadget is enabledJean-Jacques Hiblot
Some drivers might need to access common USB functions such as usb_get_maximum_speed() or usb_get_dr_mode(). Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-12-12spl: fix build failure with !CONFIG_SPL_PCI_SUPPORTSekhar Nori
Building U-Boot with CONFIG_PCI and CONFIG_DM_PCI enabled, but CONFIG_SPL_PCI_SUPPORT disabled, results in following linker error: lib/built-in.o: In function `fdtdec_get_pci_bar32': lib/fdtdec.c:305: undefined reference to `dm_pci_read_bar32' fdtdec.c:305:(.text.fdtdec_get_pci_bar32+0x24): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `dm_pci_read_bar32' This is because reference to dm_pci_read_bar32() remains in lib/fdtdec.c while SPL build does not descend into drivers/pci directory in drivers/Makefile if CONFIG_SPL_PCI_SUPPORT is not enabled. Fix this by applying appropriate #define guards in lib/fdtdec.c. It looks like ns16550.c has the same problem, so fixed that too. To simplify this, CONFIG_SPL_PCI_SUPPORT is renamed to CONFIG_SPL_PCI (enables use of CONFIG_IS_ENABLED() macro). Suggested-by: Vignesh R <vigneshr@ti.com> Signed-off-by: Sekhar Nori <nsekhar@ti.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-12-12blk: Rework guard around part_init callTom Rini
The function part_init() will only be built when we have both CONFIG_PARTITIONS and CONFIG_HAVE_BLOCK_DEVICE set. Protect the call to this function with both of these tests now. Cc: Simon Glass <sjg@chromium.org> Cc: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: York Sun <york.sun@nxp.com> Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Cc: Mingkai Hu <mingkai.hu@nxp.com> Cc: Stefan Roese <sr@denx.de> Cc: Marek Behún <marek.behun@nic.cz> Cc: Vanessa Maegima <vanessa.maegima@nxp.com> Cc: Eugen Hristev <eugen.hristev@microchip.com> Cc: Adam Ford <aford173@gmail.com> Cc: Jagan Teki <jagan@amarulasolutions.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-12-06dm: Add Hardware Spinlock classBenjamin Gaignard
This is uclass for Hardware Spinlocks. It implements two mandatory operations: lock and unlock and one optional relax operation. Signed-off-by: Benjamin Gaignard <benjamin.gaignard@linaro.org> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Patrice Chotard <patrice.chotard@st.com>
2018-11-26spl: Support hash, input, pch, pci, rtc, tpm in SPLSimon Glass
At present these subsystems are only supported in U-Boot proper but it is sometimes necessary to support them in SPL, or even TPL. Update the Kconfig and Makefile to support this. Also adjust GPIO so that it can be used in TPL if required. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2018-11-14dm: Add a new uclass driver for VirtIO transport devicesBin Meng
This adds a new virtio uclass driver for “virtio” [1] family of devices that are are found in virtual environments like QEMU, yet by design they look like physical devices to the guest. The uclass driver provides child_pre_probe() and child_post_probe() methods to do some common operations for virtio device drivers like device and driver supported feature negotiation, etc. [1] http://docs.oasis-open.org/virtio/virtio/v1.0/virtio-v1.0.pdf Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi> Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-10-07Add UCLASS_TEE for Trusted Execution EnvironmentJens Wiklander
Adds a uclass to interface with a TEE (Trusted Execution Environment). A TEE driver is a driver that interfaces with a trusted OS running in some secure environment, for example, TrustZone on ARM cpus, or a separate secure co-processor etc. The TEE subsystem can serve a TEE driver for a Global Platform compliant TEE, but it's not limited to only Global Platform TEEs. The over all design is based on the TEE subsystem in the Linux kernel, tailored for U-Boot. Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Igor Opaniuk <igor.opaniuk@linaro.org> Signed-off-by: Jens Wiklander <jens.wiklander@linaro.org>
2018-10-02Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
This is the PR for SPI-NAND changes along with few spi changes. [trini: Re-sync changes for ls1012afrwy_qspi*_defconfig] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-09-30Merge git://git.denx.de/u-boot-dmTom Rini
2018-09-29drivers: Add board uclassMario Six
Since there is no canonical "board device" that can be used in board files, it is difficult to use DM function for board initialization in these cases. Hence, add a uclass that implements a simple "board device", which can hold devices not suitable anywhere else in the device tree, and is also able to read encoded information, e.g. hard-wired GPIOs on a GPIO expander, read-only memory ICs, etc. that carry information about the hardware. The devices of this uclass expose methods to read generic data types (integers, strings, booleans) to encode the information provided by the hardware. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-09-28W1-EEPROM: Add an W1-EEPROM uclass for 1 wire EEPROMsMaxime Ripard
We might want to access data stored onto one wire EEPROMs. Create a framework to provide a consistent API. Signed-off-by: Maxime Ripard <maxime.ripard@bootlin.com> [eugen.hristev@microchip.com: reworked patch] Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
2018-09-28w1: Add 1-Wire uclassMaxime Ripard
We might want to use 1-Wire devices connected on boards such as EEPROMs in U-Boot. Provide a framework to be able to do that. Signed-off-by: Maxime Ripard <maxime.ripard@bootlin.com> [eugen.hristev@microchip.com: reworked] Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
2018-09-20mtd: move NAND files into a raw/ subdirectoryMiquel Raynal
NAND flavors, like serial and parallel, have a lot in common and would benefit to share code. Let's move raw (parallel) NAND specific code in a raw/ subdirectory, to ease the addition of a core file in nand/ and the introduction of a spi/ subdirectory specific to SPI NANDs. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
2018-09-11spl: Allow remoteproc drivers to be used within SPLLokesh Vutla
Add an option for building remoteproc drivers within SPL. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-09-11spl: Allow mailbox drivers to be used within SPLLokesh Vutla
Add an option for building mailbox drivers within SPL. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-08-11drivers: Add AXI uclassMario Six
Add a uclass for AXI (Advanced eXtensible Interface) busses, and a driver for the gdsys IHS AXI bus on IHS FPGAs. Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-08-06power: Add CONFIG_SPL_POWER_DOMAIN configPeng Fan
Add CONFIG_SPL_POWER_DOMAIN config entry. Build drivers/power/domain if this config is selected. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-07-19dm: SMEM (Shared memory) uclassRamon Fried
This is a uclass for Shared memory manager drivers. A Shared Memory Manager driver implements an interface for allocating and accessing items in the memory area shared among all of the processors. Signed-off-by: Ramon Fried <ramon.fried@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2018-07-09reset: Rename CONFIG_SPL_RESET_SUPPORT to CONFIG_SPL_DM_RESETLey Foon Tan
Rename CONFIG_SPL_RESET_SUPPORT to CONFIG_SPL_DM_RESET, so can use CONFIG_IS_ENABLED(DM_RESET) checking in reset.h later. Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-06-04Merge branch 'master' of git://git.denx.de/u-boot-sunxiTom Rini
2018-05-30fastboot: Extract fastboot_okay/fail to fb_common.cAlex Kiernan
Add drivers/fastboot/fb_common.c, where fastboot_okay/fail are implemented so we can call them from a non-USB implementation. Introduce fastboot_response which takes varargs parameters so we can use it to generate formatted response strings. Refactor fastboot_okay/fail to use it. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2018-05-30fastboot: Move fastboot to drivers/fastbootAlex Kiernan
Separate CMD_FASTBOOT from FASTBOOT and move code and configuration to drivers/fastboot. Switch dependencies on FASTBOOT to USB_FUNCTION_FASTBOOT as anyone who wants FASTBOOT before this series wants USB_FUNCTION_FASTBOOT. Split USB_FUNCTION_FASTBOOT from FASTBOOT so they retain their existing behaviour. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-05-28phy: Add Allwinner A64 USB PHY driverJagan Teki
USB PHY implementation for Allwinner SOC's can be handling in to single driver with different phy configs. This driver handle all Allwinner USB PHY's start from 4I to 50I(except 9I). Currently added A64 compatibility more will add in next coming patches. Current implementation is unable to get pinctrl, clock and reset details from DT since the dm code on these will add it future. Driver named as phy-sun4i-usb.c since the same PHY logic work for all Allwinner SOC's start from 4I to A64 except 9I with different phy configurations. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Acked-by: Jun Nie <jun.nie@linaro.org>
2018-05-10bootcount: spl: Enable bootcount support in SPLLukasz Majewski
New, SPL related config option - CONFIG_SPL_BOOTCOUNT_LIMIT has been added to allow drivers/bootcount code re-usage in SPL. This code is necessary to use and setup bootcount in SPL in the case of falcon boot mode. Signed-off-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Alex Kiernan <alex.kiernan@gmail.com>
2018-03-19spl: add SPL_RESET_SUPPORTPatrick Delaunay
Add option to include RESET driver and uclass in SPL. That can be useful to handle IP reset with same driver in U-Boot and in SPL. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
