path: root/drivers/Makefile
2003-03-26* Patch by Rick Bronson, 16 Mar 2003:wdenk
Add support for Atmel AT91RM9200DK w/NAND * Patches by Robert Schwebel, 19 Mar 2003: - use arm-linux-gcc as default compiler for ARM - fix i2c fixup code - fix missing baudrate setting - added $loadaddr / CFG_LOAD_ADDR support to loadb - moved "ignoring trailing characters" _before_ u-boot wants to print out diagnostics messages; removes bogus characters at the end of transmission * Patch by John Zhan, 18 Mar 2003: Add support for SinoVee Microsystems SC8xx boards * Patch by Rolf Offermanns, 21 Mar 2003: ported the dnp1110 related changes from the current armboot cvs to current u-boot cvs. smc91111 does not work. problem marked in smc91111.c, grep for "FIXME". * Patch by Brian Auld, 25 Mar 2003: Add support for STM flash chips on ebony board * Add PCI support for MPC8250 Boards (PM825 module) * Patch by Stefan Roese, 25 Mar 2003:
2003-03-06* Patches by David Müller, 31 Jan 2003:LABEL_2003_03_06_2255wdenk
- minimal setup for CardBus bridges - add EEPROM read/write support in the CS8900 driver - add support for the builtin I2C controller in the Samsung s3c24x0 chips - add support for MPL's VCMA9 (Samsung s3c2410 based) board * Patch by Steven Scholz, 04 Feb 2003: add support for RTC DS1307 * Patch by Reinhard Meyer, 5 Feb 2003: fix PLPRCR/SCCR init sequence on 8xx to allow for changes of EBDF by software * Patch by Vladimir Gurevich, 07 Feb 2003: "API-compatibility patch" for 4xx I2C driver
2003-02-28* Add support for 16 MB flash configuration of TRAB boardLABEL_2003_02_28_0150wdenk
* Patch by Erwin Rol, 27 Feb 2003: Add support for RTEMS * Add image information to README * Fix dual PCMCIA slot support (when running with just one slot populated) * Add VFD type detection to trab board * extend drivers/cs8900.c driver to synchronize ethaddr environment variable with value in the EEPROM * Start adding MIPS support files
2002-12-03* Fix startup problems with VFD display on TRABLABEL_2002_12_03_2230wdenk
* Patch by Pierre Aubert, 20 Nov 2002 Add driver for Epson SED13806 graphic controller. Add support for BMP logos in cfb_console driver.
2002-10-29Initial revisionwdenk
