ethaddr can be optionally read from i2c memory. So, chip_config command supports
reading/writing hw mac id into i2c memory. Placing this code within
CONFIG_CMD_NET as this would only be needed when network interface is configured
Signed-off-by: Vipin Kumar <vipin.kumar@st.com>
Signed-off-by: Amit Virdi <amit.virdi@st.com>
The kwboot program boots boards based on Marvell's Kirkwood platform
via Xmodem over their integrated UART.
Signed-off-by: Daniel Stodden <daniel.stodden@googlemail.com>
Acked-by: Luka Perkov <uboot@lukaperkov.net>
Tested-By: Holger Brunck <holger.brunck@keymile.com>
Tested-By: David Purdy <david.c.purdy@gmail.com>
Tested-by: Simon Guinot <simon.guinot@sequanux.org>
Fix the position for PSWITCH key.
The good benefit of doing this is that boot time is greatly reduced:
from 5 seconds to less then 1 second.
- change gpio pin settings:
- gpio pin 6[13] (PLC reset) default value low
- gpio pin 6[0] (TPM reset) default value low
- 4 new GPIO pins
pin i/o name
- 3[9] input Board Type
- 2[7] input HW-ID0
- 2[6] input HW-ID1
- 2[3] input HW-ID2
- read board type and hw id from gpio pins on the enbw_cmc board,
and use board type for setting up different gpio pin settings.
- do not pass "davinci_mmc.use_dma=0" to linux, as MMC now
works with DMA.
- update logbuf support:
store post word in RTC scratch register
- add support for configuring KSZ8864RMN switch through
a config file on u-boot startup. For more infos see:
doc/README.switch_config
Cc: Tom Rini <tom.rini@gmail.com>
Cc: Christian Riesch <christian.riesch@omicron.at>
Cc: Sandeep Paulraj <s-paulraj@ti.com>
For syslinux, the initrd can be set in the append string as
"initrd=<file>", so try to find it there if we haven't already set the
initrd.
This driver is unused and obsolete.
Cc: unsik Kim <donari75@gmail.com>
Code based on networking/zcip.c in busybox
commit 8531d76a15890c2c535908ce888b2e2aed35b172
* 'master' of git://git.denx.de/u-boot-nand-flash:
NAND: Remove ONFI detection message to from bootup log
driver/mtd:IFC: Fix possible memory leak
driver/mtd: IFC NAND: Add support of ONFI NAND flash
mtd, nand: move some printfs to debug output.
nand_util: correct YAFFS image write function
powerpc/85xx: fix NAND boot linker scripts for -fpic
nand: extend .raw accesses to work on multiple pages
A use for this is to read, modify, erase, and write an entire block as a
single unit, as a replacement for the biterr command. This way gives
more flexibility in that you can also test multiple bit errors, errors
in the ECC, etc.
With older toolchains it is possible to not fit entirely into the 45KB
that we had assigned to SPL. Adjust to allow for 8KB of stack (which
should be more than required) and 54KB of text/data.
Cc: Vaibhav Hiremath <hvaibhav@ti.com>
Cc: Nagendra T S <nagendra@mistralsolutions.com>
Cc: Thomas Weber <weber@corscience.de>
Cc: Ilya Yanok <yanok@emcraft.com>
Cc: Steve Sakoman <sakoman@gmail.com>
Acked-by: Vaibhav Hiremath <hvaibhav@ti.com>
* 'master' of git://git.denx.de/u-boot-mpc85xx:
powerpc/85xx: don't touch MAS7 on e500v1 when relocating CCSR
powerpc/85xx: don't display address map size (32-bit vs. 36-bit) during boot
cmd_bdinfo: display the address map size (32-bit vs. 36-bit)
PowerPC: correct the SATA for p1/p2 rdb-pc platform
powerpc/corenet_ds: Slave core in holdoff when boot from SRIO
powerpc/corenet_ds: Slave reads ENV from master when boot from SRIO
powerpc/corenet_ds: Slave uploads ucode when boot from SRIO
powerpc/corenet_ds: Slave module for boot from SRIO
powerpc/corenet_ds: Master module for boot from SRIO
powerpc/corenet_ds: Document for the boot from SRIO
powerpc/corenet_ds: Correct the compilation errors about ENV
powerpc/srio: Rewrite the struct ccsr_rio
powerpc/85xx:Fix lds for nand boot debug info
powerpc/p2041rdb: add env in NAND support
powerpc/p2041rdb: add NAND and NAND boot support
powerpc/mpc8xxx: Fix CONFIG_DDR_RAW_TIMING for two boards
powerpc/85xx:Avoid vector table compilation for nand_spl
powerpc/85xx:Fix IVORs addr after vector table relocation
powerpc/85xx:Avoid hardcoded vector address for IVORs
powerpc/p1023rds: Disable nor flash node and enable nand flash node
This document describes the implementation of the boot from SRIO,
includes the introduction of envionment, an example based on P4080DS
platform, an example of the slave's RCW, and the description about
how to use this feature.
Signed-off-by: Liu Gang <Gang.Liu@freescale.com>
board:
Add config file of board adp-ag102
Add adp-ag102 into boards.cfg
Add adp-ag102 into MAINTAINERS
doc:
add README of ag102
Signed-off-by: Macpaul Lin <macpaul@andestech.com>
Add boot switch setting information into the README
Add a README file for mx28evk board.
Split the README into a common part and a m28 specific part.
This will make things easier when adding new README files for other mx28
based boards.
Signed-off-by: Joe Hershberger <joe.hershberger@gmail.com>
* 'agust@denx.de' of git://git.denx.de/u-boot-staging:
lzma: fix printf warnings
Remove CONFIG_SYS_EXTBDINFO from snapper9260.h
cmd_pxe.c: fix strict-aliasing warnings
net: smc91111: use mdelay()
doc: Fix some typos in different files
disk/part.c: Fix device enumeration through API
mkenvimage: Really set the redundant byte when applicable
mkenvimage: Don't try to detect comments in the input file
mkenvimage: Use mmap() when reading from a regular file
mkenvimage: Read/Write from/to stdin/out by default or if the filename is "-"
mkenvimage: More error handling
mkenvimage: Correct an include and add a missing one
mkenvimage: correct and clarify comments and error messages
MAKEALL: display SPL size if present
ARMV7/Vexpress: add missing get_ticks() and get_tbclk()
mkenvimage: fix usage message
cmd_fat: add FAT write command
fs/fat/fat_write.c: Fix GCC 4.6 warnings
FAT write: Fix compile errors
* 'master' of git://git.denx.de/u-boot-arm: (146 commits)
arm: Use common .lds file where possible
arm: add a common .lds link script
arm: Remove unneeded setting of LDCSRIPT
Define CPUDIR for the .lds link script
arm: Remove zipitz2 link script
Allow arch directory to contain .lds without requiring Makefile
OMAP: Remove omap1610inn-based boards
arch/arm/cpu/armv7/omap-common/clocks-common.c: Fix build warnings
board/ti/beagle/beagle.c: Fix build warnings
sdrc.c: Fix typo in do_sdrc_init() for SPL
tegra: i2c: Add I2C driver
tegra: fdt: i2c: Add extra I2C bindings for U-Boot
tegra: i2c: Select I2C ordering for Seaboard
tegra: i2c: Enable I2C on Seaboard
tegra: i2c: Select number of controllers for Tegra2 boards
tegra: i2c: Initialise I2C on Nvidia boards
tegra: Enhance clock support to handle 16-bit clock divisors
fdt: Add function to allow aliases to refer to multiple nodes
tegra: Rename NV_PA_PMC_BASE to TEGRA2_PMC_BASE
tegra: fdt: Enable FDT support for Ventana
tegra: fdt: Enable FDT support for Seaboard
tegra: usb: Enable USB on Seaboard
tegra: usb: Add common USB defines for tegra2 boards
tegra: usb: Add USB support to nvidia boards
arm: Check for valid FDT after console is up
fdt: Avoid early panic() when there is no FDT present
tegra: usb: Add support for Tegra USB peripheral
tegra: fdt: Add function to return peripheral/clock ID
usb: Add support for txfifo threshold
tegra: usb: fdt: Add USB definitions for Tegra2 Seaboard
tegra: usb: fdt: Add additional device tree definitions for USB ports
tegra: fdt: Add clock bindings for Tegra2 Seaboard
tegra: fdt: Add additional USB binding
fdt: Add tegra-usb bindings file from linux
fdt: Add staging area for device tree binding documentation
tegra: fdt: Add device tree file for Tegra2 Seaboard from kernel
tegra: fdt: Add Tegra2x device tree file from kernel
arm: fdt: Add skeleton device tree file from kernel
fdt: Add basic support for decoding GPIO definitions
fdt: Add functions to access phandles, arrays and bools
fdt: Tidy up a few fdtdec problems
fdt: Add tests for fdtdec
fdt: Add fdtdec_find_aliases() to deal with alias nodes
arm: Tegra2: Fix ELDK42 gcc failure with inline asm stack pointer load
net: fec_mxc: allow use with cache enabled
net: force PKTALIGN to ARCH_DMA_MINALIGN
i.MX28: Enable caches by default
i.MX28: Make use of the bounce buffer
i.MX28: Do data transfers via DMA in MMC driver
MMC: Implement generic bounce buffer
i.MX28: Add cache support to MXS NAND driver
i.MX28: Add cache support into the APBH DMA driver
ARM926EJS: Implement cache operations
board/vpac270/onenand.c: Fix build errors
nhk8815: fix build errors
atmel-boards: add missing atmel_mci.h
ARM: highbank: setup env from boot source register
ARM: highbank: change env config to use nvram
ARM: highbank: add reset support
ARM: highbank: Add boot counter support
ARM: highbank: change TEXT_BASE to 0x8000
ARM: highbank: fix us_to_tick calculation
ARM: highbank: add missing get_tbclk
ARM: highbank: fix warning for calxedaxgmac_initialize
net: calxedaxgmac: fix build due to missing __aligned definition
EXYNOS: Add structure for Exynos4 DMC
EXYNOS: SMDK5250: Support all 4 UARTs
ARM: fix s3c2410 timer code
ARM: davinci: fixes for cam_enc_4xx board
omap3_spi: receive transmit mode
calimain, enbw_cmc: Fix typo in comments
Davinci: ea20: use gpio framework to access gpios
OMAP3: mt_ventoux: sets its own mtdparts
OMAP3: mt_ventoux: updated timing for FPGA
twl4030: fix potential power supply handling issues
NAND: TI: fix warnings in omap_gpmc.c
cam_enc_4xx: Rename 'images' to 'imgs'
arm: Add Prep subcommand support to bootm
OMAP3: twister: add support to boot Linux from SPL
SPL: call cleanup_before_linux() before booting Linux
OMAP3: SPL: do not call I2C init if no I2C is set.
Add cache functions to SPL for armv7
devkit8000: Implement and activate direct OS boot
omap/spl: change output of spl_parse_image_header
omap-common/spl: Add linux boot to SPL
devkit8000/spl: init GPMC for dm9000 in SPL
omap-common: Add NAND SPL linux booting
devkit8000: add config for spl command
Add cmd_spl command
mx53ard: Initialize return code with error
mx53: Make PLL2 to be the parent of UART clock
configs: imx: Use CONFIG_SF_DEFAULT_CS
mx28evk: Provide default values for SPI bus and chip select
USB: ehci-mx6: Add proper IO accessors
mx6: Read silicon revision from register
i.MX28: Drop __naked function from spl_mem_init
mxs_spi: Return proper timeout error
i.MX28: Make the stabilization delays shorter
pmic_i2c: Return error in case of invalid pmic_i2c_tx_num
mx6: Remove duplicate definition of ANATOP_BASE_ADDR
mx6: Fix reset cause for Power On Reset case
i.MX6: mx6qsabrelite: add MACH_TYPE_MX6Q_SABRELITE
i.MX6: mx6q_sabrelite: add CONFIG_REVISION_TAG
i.MX28: Enable additional DRAM address bits
mx6q: mx6qsabrelite: setup_spi() should be called in board_init to allow use for environment
mx31: add "ARM11P power gating" to get_reset_cause
mx31pdk: Fix CONFIG_SYS_MEMTEST_END
efikamx: Fix CONFIG_SYS_MEMTEST_END
mx53smd: Fix CONFIG_SYS_MEMTEST_END
mx53evk: Fix CONFIG_SYS_MEMTEST_END
mx51evk: Fix CONFIG_SYS_MEMTEST_END
i.MX6: mx6qsabrelite: add ext2 support
imximage: Remove overwriting of flash_offset
IXP: Fix GPIO_INT_ACT_LOW_SET()
IXP: Fix NAND build warning on PDNB3 and SCPU
IXP: Move PDNB3 and SCPU from Makefile to boards.cfg
IXP: Squash warnings in IXP NPE
IXP: Fix missing MACH_TYPE_{ACTUX?,PNB3,DVLHOST}
IXP: Make IXP buildable with arm-linux- toolchains
Examples: Properly append LDFLAGS to LD command
SPL: Enable YMODEM support on BeagleBone and AM335x EVM
SPL: Add YMODEM over UART load support
SPL: Add README.omap3
README: document more SPL config options
spl.c: Use __noreturn decorator
config.mk: Check for -fstack-usage support
config.mk: Make cc-option create a file under include/generated
Add U-Boot's peripheral clock information to the Tegra20 device tree file.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
Signed-off-by: Tom Warren <twarren@nvidia.com>
This adds a basic binding for the oscillator and peripheral clocks. The
second cell is the clock number, defined as the bit number within the clock
enable register if the peripheral clock.
This uses the RFC clock bindings from Grant Likely so may change later:
https://lkml.org/lkml/2011/12/12/498
It is taken from Stephen Warren's patch here:
http://patchwork.ozlabs.org/patch/141359/
This adds a property to indicate a port which can switch between host and device
mode.
This file is taken from the Linux mailing list.
Add a directory to hold device tree binding files, to permit easy review
of this material in U-Boot patches.
This adds a spl command to the u-boot.
Related config:
CONFIG_CMD_SPL
activate/deactivate the command
CONFIG_CMD_SPL_NAND_OFS
Offset in NAND to use
Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com>
CC: Tom Rini <tom.rini@gmail.com>
CC: Wolfgang Denk <wd@denx.de>
adresses/addresses
alernate/alternate
asssuming/assuming
calcualted/calculated
enviroment/environment
evalutation/evaluation
falsh/flash
labled/labeled
paramaters/parameters
Signed-off-by: Thomas Weber <thomas@tomweber.eu>
Acked-by: Anatolij Gustschin <agust@denx.de>
This document describes the SPL process for OMAP3 (and related) boards
as well as a partial memory map and how to verify certain aspects
outside of running on the target.
The SD loader binary is now downloadable at
https://wiki.linaro.org/Boards/MX6QSabreLite
under a open-source 3-clause BSD license. Update the README
for this.
The discussion shows that it's hard to change the hardware
regarding the default SPI NOR boot of the SabreLite boards.
I.e. this will stay the default boot. Therefore remove the
'early version of' statement.
Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com>
CC: Stefano Babic <sbabic@denx.de>
CC: Jason Liu <liu.h.jason@gmail.com>
Say good bye to some ancient, very broken and unused code.
The sh7757lcr has 2GByte eMMC chip. This patch supports it.
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
All boards are using the gen_atmel_mci driver now, so no need
to carry the old driver around.
Signed-off-by: Sven Schnelle <svens@stackframe.org>
mention repeatable to README.commands and fix some typos
Signed-off-by: Peter Meerwald <p.meerwald@bct-electronic.com>
Tested-by: Marek Vasut <marek.vasut@gmail.com>
This patch moves hawkboard to the new spl infrastructure from the
older nand_spl one.
Removed the hawkboard_nand_config build option -- The spl code now
gets compiled with hawkboard_config, after building the main u-boot
image, using the CONFIG_SPL_TEXT_BASE. Modified the README.hawkboard
to reflect the same.
Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com>
Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
Cc: Tom Rini <trini@ti.com>
Acked-by: Christian Riesch <christian.riesch@omicron.at>
Based on discussion from this thread [1].
Adding omap-view port that helps us in using the generic ulpi
framework for any ulpi phy ops using the INSNREG05_ULPI viewport
reg available on omap platform.
Currently ehci ports are available on omap3/4 platforms so enable the same
for beagle and panda, patch is tested on the same boards.
Thanks to Igor Grinberg <grinberg@compulab.co.il> for reviewing the
omap-ehci patches and suggesting this approach.
[1]: http://www.mail-archive.com/u-boot@lists.denx.de/msg76076.html
Tested-by: Stefano Babic <sbabic@denx.de>
Signed-off-by: Govindraj.R <govindraj.raja@ti.com>
The i.MX6 processor can boot from NOR flash and SATA disks,
additionally. Add the flash offsets for these additional
boot modes.
Signed-off-by: Fabio Estevam <festevam@gmail.com>
CC: Jason Liu <jason.hui@linaro.org>
Acked-by: Jason Liu <jason.hui@linaro.org>
i.MX53 is supported, too. Add this to the introduction of the
documentation.
CC: Fabio Estevam <festevam@gmail.com>
show a menu on startup instead running the shell.
Cc: Jason Hobbs <jason.hobbs@calxeda.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Acked-by: Jason Hobbs <jason.hobbs@calxeda.com>
add the possibility to show a statusline when printing a menu
This allows a driver to run code between nand_scan_ident() and
nand_scan_tail(), among other things. See the additions to
doc/README.nand for details.
To allow a gradual transition, Boards that don't set
CONFIG_SYS_NAND_SELF_INIT will still be initialized the old way, but
new drivers should not require this, and existing drivers should be
converted when convenient.
Add the initial support for Freescale i.MX6Q Sabre Lite board
Signed-off-by: Jason Liu <jason.hui@linaro.org>
CC: Eric Nelson <eric.nelson@boundarydevices.com>
fsl_lbc: add printout of LCRR and LBCR to local bus regs
sbc8548: Fix up local bus init to be frequency aware
sbc8548: enable support for hardware SPD errata workaround
sbc8548: relocate fixed ddr init code to ddr.c file
sbc8548: Make enabling SPD RAM configuration work
sbc8548: Fix LBC SDRAM initialization settings
sbc8548: enable ability to boot from alternate flash
sbc8548: relocate 64MB user flash to sane boundary
Revert "SBC8548: fix address mask to allow 64M flash"
MPC85xxCDS: Fix missing LCRR_DBYP bits for 66-133MHz LBC
eXMeritus HWW-1U-1A: Add support for the AT24C128N I2C EEPROM
eXMeritus HWW-1U-1A: Minor environment variable tweaks
Existing boards by default have an issue where the LBC SDRAM
SPD EEPROM and the DDR2 SDRAM SPD EEPROM both land at 0x51.
After the hardware modification listed in the README is made,
then the DDR2 SPD EEPROM appears at 0x53. So this implements
a board specific get_spd() by taking advantage of the existing
weak linkage, that 1st tries reading at 0x53 and then if that
fails, it falls back to the old 0x51.
Since the old dependency issue of "SPD implies no LBC SDRAM"
gets removed with the hardware errata fix, remove that restriction
in the code, so both LBC SDRAM and SPD can be selected.
Previously, SPD configuration of RAM was non functional on
this board. Now that the root cause is known (an i2c address
conflict), there is a simple end-user workaround - remove the
old slower local bus 128MB module and then SPD detection on the
main DDR2 memory module works fine.
We make the enablement of the LBC SDRAM support conditional on
being not SPD enabled. We can revisit this dependency as the
hardware workaround becomes available.
Turning off LBC SDRAM support revealed a couple implict dependencies
in the tlb/law code that always expected an LBC SDRAM address.
This has been tested with the default 256MB module, a 512MB
a 1GB and a 2GB, of varying speeds, and the SPD autoconfiguration
worked fine in all cases.
The default configuration remains to go with the hard coded
DDR config, so the default build will continue to work on boards
where people don't bother to read the docs. But the advantage
of going to the SPD config is that even the small default module
gets configured for CL3 instead of CL4.
This board has an 8MB soldered on flash, and a 64MB SODIMM
flash module. Normally the board boots from the 8MB flash,
but the hardware can be configured for booting from the 64MB
flash as well by swapping CS0 and CS6. This can be handy
for recovery purposes, or for supporting u-boot and VxBoot
at the same time.
To support this in u-boot, we need to have different BR0/OR0
and BR6/OR6 settings in place for when the board is configured
in this way, and a different TEXT_BASE needs to be used due
to the larger sector size of the 64MB flash module.
We introduce the suffix _8M and _64M for the BR0/BR6 and the
OR0/OR6 values so it is clear which is being used to map what
specific device.
The larger sector size (512k) of the alternate flash needs
a larger malloc pool, otherwise you'll get failures when
running saveenv, so bump it up accordingly.
The current situation has the 64MB user flash at an awkward
alignment; shifted back from 0xfc00_0000 by 8M, to leave an 8MB hole
for the soldered on boot flash @ EOM. But to switch to optionally
supporting booting off the 64MB flash, the 64MB will then be mapped
at the sane address of 0xfc00_0000.
This leads to awkward things when programming the 64MB flash prior
to transitioning to it -- i.e. even though the chip spans from
0xfb80_0000 to 0xff7f_ffff, you would have to program a u-boot image
into the two sectors from 0xfbf0_0000 --> 0xfbff_ffff so that it was
in the right place when JP12/SW2.8 were switched to make the 64MB on
/CS0. (i.e. the chip is only looking at the bits in mask 0x3ff_ffff)
We also have to have three TLB entries responsible for dealing with
mapping the 64MB flash due to this 8MB of misalignment.
In the end, there is address space from 0xec00_0000 to 0xefff_ffff
where we can map it, and then the transition from booting from one
config to the other will be a simple 0xec --> 0xfc mapping. Plus we
can toss out a TLB entry.
Note that TLB0 is kept at 64MB and not shrunk down to the 8MB boot
flash; this means we won't have to change it when the alternate
config uses the full 64MB for booting, in TLB0.
The new API no longer uses the extra cd parameter that was used to store
the card presence state. Instead, this information is returned via the
function's return value. board_mmc_getcd() returns -1 to indicate that
no card-detection mechanism is implemented; 0 indicates that no card is
present and 1 is returned if it was detected that a card is present.
The rationale for this change can be found in the following email
thread:
http://lists.denx.de/pipermail/u-boot/2011-November/110180.html
In summary, the old API was not consistent with the rest of the MMC API
which always passes a struct mmc as the first parameter. Furthermore the
cd parameter was used to mean "card absence" in some implementations and
"card presence" in others.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
Tested-by: Jason Liu <jason.hui@linaro.org>
