path: root/doc
2015-04-06video: exynos_fb: configure backlight GPIOs if specified in DTAjay Kumar
Add support to configure PWM_OUT(PWM output) GPIO and BL_EN(backlight enable) GPIO, if provided in FIMD DT node. Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-03-30nand: Remove unused CONFIG_MTD_NAND_ECC_JFFS2 optionPeter Tyser
This option was removed along with legacy NAND support in be33b046b549ad88c204c209508cd7657232ffbd. Clean up some remnants. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2015-03-28armv8: semihosting: add a command to load semihosted imagesLinus Walleij
Instead of sprinkling custom code and calls over the Vexpress64 boardfile, create a command that loads images using semihosting just like we would load from flash memory of over the network, using a special command: smhload <image> <address> This will make it possible to remove some custom calls and code and make the boot easier. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-03-28Document config_distro_bootcmd environment variables for interactive booting.Karsten Merker
config_distro_bootcmd.h defines a common boot environment for multiple platforms, including several environment variables that are intended for interactive use by an end-user. Document which variables are considered public interfaces that must remain compatible in future u-boot versions. Signed-off-by: Karsten Merker <merker@debian.org> Acked-by: Stephen Warren <swarren@nvidia.com>
2015-03-28generic-board: move __HAVE_ARCH_GENERIC_BOARD to KconfigMasahiro Yamada
Move the option to Kconfig renaming it to CONFIG_HAVE_GENERIC_BOARD. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Alexey Brodkin <abrodkin@synopsys.com>
2015-03-24net: Update README.drivers.eth to mention latest APIsBin Meng
README.drivers.eth still refers to the deprecated miiphy_register(). Update the doc to mention new APIs mdio_alloc() and mdio_register(). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-03-24x86: Add queensbay fsp patch information in README.x86Bin Meng
The FSP release version 001 for Intel Queensbay has a bug which could cause random endless loop during the FspInit call. This bug was published by Intel although Intel did not describe any details. Describe this information in the x86 doc so that U-Boot Queensbay support is invulnerable. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-03-17powerpc: ppc4xx: remove korat board supportMasahiro Yamada
This has not been converted to Generic Board, so should be removed. (See doc/README.generic-board for details.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Larry Johnson <lrj@acm.org>
2015-03-17powerpc: mpc5xxx: remove galaxy5200 board supportMasahiro Yamada
This has not been converted to Generic Board, so should be removed. (See doc/README.generic-board for details.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Eric Millbrandt <emillbrandt@dekaresearch.com>
2015-03-17powerpc: ppc4xx: remove W7OLMC/W7OLMG board supportMasahiro Yamada
They have not been converted to Generic Board, so should be removed. (See doc/README.generic-board for details.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Erik Theisen <etheisen@mindspring.com>
2015-03-17powerpc: mpc5xxx: remove aev, TB5200 board supportMasahiro Yamada
2015-03-17powerpc: ppc4xx: remove JSE board supportMasahiro Yamada
This has not been converted to Generic Board, so should be removed. (See doc/README.generic-board for details.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Stephen Williams <steve@icarus.com>
2015-03-17powerpc: mpc5xxx: remove BC3450 board supportMasahiro Yamada
2015-03-15git-mailrc: update Masahiro's email addressMasahiro Yamada
I have transferred to Socionext Inc. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-03-05Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
2015-03-05SECURE BOOT: Add command for validation of imagesgaurav rana
1. esbc_validate command is meant for validating header and signature of images (Boot Script and ESBC uboot client). SHA-256 and RSA operations are performed using SEC block in HW. This command works on both PBL based and Non PBL based Freescale platforms. Command usage: esbc_validate img_hdr_addr [pub_key_hash] 2. ESBC uboot client can be linux. Additionally, rootfs and device tree blob can also be signed. 3. In the event of header or signature failure in validation, ITS and ITF bits determine further course of action. 4. In case of soft failure, appropriate error is dumped on console. 5. In case of hard failure, SoC is issued RESET REQUEST after dumping error on the console. 6. KEY REVOCATION Feature: QorIQ platforms like B4/T4 have support of srk key table and key revocation in ISBC code in Silicon. The srk key table allows the user to have a key table with multiple keys and revoke any key in case of particular key gets compromised. In case the ISBC code uses the key revocation and srk key table to verify the u-boot code, the subsequent chain of trust should also use the same. 6. ISBC KEY EXTENSION Feature: This feature allows large number of keys to be used for esbc validation of images. A set of public keys is being signed and validated by ISBC which can be further used for esbc validation of images. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> Signed-off-by: Gaurav Rana <gaurav.rana@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-03-05gpt: support random UUIDs without setting environment variablesRob Herring
Currently, an environment variable must be used to store the randomly generated UUID for each partition. This is not necessary, so make storing the UUID optional. Now passing uuid_disk and uuid are optional when random UUIDs are enabled. Signed-off-by: Rob Herring <robh@kernel.org> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
2015-03-05Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-03-04powerpc/mpc85xx: Add DSP side awareness for Freescale Heterogeneous SoCsShaveta Leekha
The code provides framework for heterogeneous multicore chips based on StarCore and Power Architecture which are chasis-2 compliant, like B4860 and B4420 It will make u-boot recognize all non-ppc cores and peripherals like SC3900/DSP CPUs, MAPLE, CPRI and print their configuration in u-boot logs. Example boot logs of B4860QDS: U-Boot 2015.01-00232-geef6e36-dirty (Jan 19 2015 - 11:58:45) CPU0: B4860E, Version: 2.2, (0x86880022) Core: e6500, Version: 2.0, (0x80400120) Clock Configuration: CPU0:1600 MHz, CPU1:1600 MHz, CPU2:1600 MHz, CPU3:1600 MHz, DSP CPU0:1200 MHz, DSP CPU1:1200 MHz, DSP CPU2:1200 MHz, DSP CPU3:1200 MHz, DSP CPU4:1200 MHz, DSP CPU5:1200 MHz, CCB:666.667 MHz, DDR:933.333 MHz (1866.667 MT/s data rate) (Asynchronous), IFC:166.667 MHz CPRI:600 MHz MAPLE:600 MHz, MAPLE-ULB:800 MHz, MAPLE-eTVPE:1000 MHz FMAN1: 666.667 MHz QMAN: 333.333 MHz Top level changes include: (1) Top level CONFIG to identify HETEROGENUOUS clusters (2) CONFIGS for SC3900/DSP components (3) Global structures like "cpu_type" and "MPC85xx_SYS_INFO" updated for dsp cores and other components (3) APIs to get DSP num cores and their Mask like: cpu_dsp_mask, cpu_num_dspcores etc same as that of PowerPC (5) Code to fetch and print SC cores and other heterogenous device's frequencies (6) README added for the same Signed-off-by: Shaveta Leekha <shaveta@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-03-02MAINTAINERS, git-mailrc: Update my email addressTom Rini
2015-03-02Merge git://git.denx.de/u-boot-usbTom Rini
2015-03-02imx6: Added DEK blob generator commandRaul Cardenas
Freescale's SEC block has built-in Data Encryption Key(DEK) Blob Protocol which provides a method for protecting a DEK for non-secure memory storage. SEC block protects data in a data structure called a Secret Key Blob, which provides both confidentiality and integrity protection. Every time the blob encapsulation is executed, a AES-256 key is randomly generated to encrypt the DEK. This key is encrypted with the OTP Secret key from SoC. The resulting blob consists of the encrypted AES-256 key, the encrypted DEK, and a 16-bit MAC. During decapsulation, the reverse process is performed to get back the original DEK. A caveat to the blob decapsulation process, is that the DEK is decrypted in secure-memory and can only be read by FSL SEC HW. The DEK is used to decrypt data during encrypted boot. Commands added -------------- dek_blob - encapsulating DEK as a cryptgraphic blob Commands Syntax --------------- dek_blob src dst len Encapsulate and create blob of a len-bits DEK at address src and store the result at address dst. Signed-off-by: Raul Cardenas <Ulises.Cardenas@freescale.com> Signed-off-by: Nitin Garg <nitin.garg@freescale.com> Signed-off-by: Ulises Cardenas <ulises.cardenas@freescale.com> Signed-off-by: Ulises Cardenas-B45798 <Ulises.Cardenas@freescale.com>
2015-03-02Merge branch 'master' of git://git.denx.de/u-bootStefano Babic
2015-03-01usb: UniPhier: add UniPhier on-chip xHCI host driver supportMasahiro Yamada
Support xHCI host driver used on Panasonic UniPhier platform. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Marek Vasut <marex@denx.de>
2015-02-25Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
2015-02-25usb: gadget: fastboot: Add fastboot eraseDileep Katta
Adds the fastboot erase functionality, to erase a partition specified by name. The erase is performed based on erase group size, to avoid erasing other partitions. The start address and the size is aligned to the erase group size for this. Currently only supports erasing from eMMC. Signed-off-by: Dileep Katta <dileep.katta@linaro.org> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2015-02-24ARM: davinci: remove hawkboard supportMasahiro Yamada
This is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Sughosh Ganu <urwithsughosh@gmail.com> Cc: Syed Mohammed Khasim <sm.khasim@gmail.com> Acked-by: Marek Vasut <marex@denx.de>
2015-02-24ARM: remove tnetv107x board supportMasahiro Yamada
This is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Chan-Taek Park <c-park@ti.com> Acked-by: Marek Vasut <marex@denx.de>
2015-02-24ARM: remove a320evb board supportMasahiro Yamada
This is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Po-Yu Chuang <ratbert@faraday-tech.com> Acked-by: Marek Vasut <marex@denx.de>
2015-02-24ARM: remove cm4008 and cm41xx board supportMasahiro Yamada
These are still non-generic boards. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Greg Ungerer <greg.ungerer@opengear.com> Acked-by: Marek Vasut <marex@denx.de>
2015-02-24ARM: remove dkb board supportMasahiro Yamada
This is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Lei Wen <leiwen@marvell.com> Acked-by: Marek Vasut <marex@denx.de>
2015-02-24ARM: remove jadecpu board supportMasahiro Yamada
This is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Matthias Weisser <weisserm@arcor.de> Acked-by: Marek Vasut <marex@denx.de>
2015-02-24kconfig: switch to single .config configurationMasahiro Yamada
When Kconfig for U-boot was examined, one of the biggest issues was how to support multiple images (Normal, SPL, TPL). There were actually two options, "single .config" and "multiple .config". After some discussions and thought experiments, I chose the latter, i.e. to create ".config", "spl/.config", "tpl/.config" for Normal, SPL, TPL, respectively. It is true that the "multiple .config" strategy provided us the maximum flexibility and helped to avoid duplicating CONFIGs among Normal, SPL, TPL, but I have noticed some fatal problems: [1] It is impossible to share CONFIG options across the images. If you change the configuration of Main image, you often have to adjust some SPL configurations correspondingly. Currently, we cannot handle the dependencies between them. It means one of the biggest advantages of Kconfig is lost. [2] It is too painful to change both ".config" and "spl/.config". Sunxi guys started to work around this problem by creating a new configuration target. Commit cbdd9a9737cc (sunxi: kconfig: Add %_felconfig rule to enable FEL build of sunxi platforms.) added "make *_felconfig" to enable CONFIG_SPL_FEL on both images. Changing the configuration of multiple images in one command is a generic demand. The current implementation cannot propose any good solution about this. [3] Kconfig files are getting ugly and difficult to understand. Commit b724bd7d6349 (dm: Kconfig: Move CONFIG_SYS_MALLOC_F_LEN to Kconfig) has sprinkled "if !SPL_BUILD" over the Kconfig files. [4] The build system got more complicated than it should be. To adjust Linux-originated Kconfig to U-Boot, the helper script "scripts/multiconfig.sh" was introduced. Writing a complicated text processor is a shell script sometimes caused problems. Now I believe the "single .config" will serve us better. With it, all the problems above would go away. Instead, we will have to add some CONFIG_SPL_* (and CONFIG_TPL_*) options such as CONFIG_SPL_DM, but we will not have much. Anyway, this is what we do now in scripts/Makefile.spl. I admit my mistake with my apology and this commit switches to the single .config configuration. It is not so difficult to do that: - Remove unnecessary processings from scripts/multiconfig.sh This file will remain for a while to support the current defconfig format. It will be removed after more cleanups are done. - Adjust some makefiles and Kconfigs - Add some entries to include/config_uncmd_spl.h and the new file scripts/Makefile.uncmd_spl. Some CONFIG options that are not supported on SPL must be disabled because one .config is shared between SPL and U-Boot proper going forward. I know this is not a beautiful solution and I think we can do better, but let's see how much we will have to describe them. - update doc/README.kconfig More cleaning up patches will follow this. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-02-24fsl-ch3/lowlevel: TZPC and TZASC programming to configure non-secure accessesBhupesh Sharma
This patch ensures that the TZPC (BP147) and TZASC-400 programming happens for LS2085A SoC only when the desired config flags are enabled and ensures that the TZPC programming is done to allow Non-secure (NS) + secure (S) transactions only for DCGF registers. The TZASC component is not present on LS2085A-Rev1, so the TZASC-400 config flag is turned OFF for now. Signed-off-by: Bhupesh Sharma <bhupesh.sharma@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-02-23mmc: fsl_esdhc: Add support to force VSELECT setOtavio Salvador
Some boards cannot do voltage negotiation but need to set the VSELECT bit forcely to ensure it to work at 1.8V. This commit adds CONFIG_SYS_FSL_ESDHC_FORCE_VSELECT flag for this use. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2015-02-19Documentation: gpio: fix bindings documentMasahiro Yamada
[ imported from Linux Kernel, commit 74981fb81d83 ] Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Simon Glass <sjg@chromium.org>
2015-02-13Merge git://git.denx.de/u-boot-samsungTom Rini
2015-02-13samsung: board: support eMMC reset using DTJoonyoung Shim
Some exynos boards require special handling of nRESET_OUT line for eMMC memory to perform complete reboot e.g. Odroid X2/U3/XU3 boards. This will support eMMC reset using DT from reset_misc of samsung common board file. Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-02-12dm: Expand and complete Kconfig in drivers/Simon Glass
Expand the help messages for each driver. Add missing Kconfig for I2C, SPI flash and thermal. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-02-10Merge branch 'master' of git://git.denx.de/u-boot-x86Tom Rini
2015-02-10Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-02-06x86: Add Intel Galileo instructions in README.x86Bin Meng
Add some instructions about building U-Boot for Intel Galileo board. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-02-06x86: Add support for Intel Minnowboard MaxSimon Glass
This is a relatively low-cost x86 board in a small form factor. The main peripherals are uSD, USB, HDMI, Ethernet and SATA. It uses an Atom 3800 series CPU. So far only the dual core 2GB variant is supported. This uses the existing FSP support. Binary blobs are required to make this board work. The microcode update is included as a patch (all 3000 lines of it). Change-Id: I0088c47fe87cf08ae635b343d32c332269062156 Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-02-06x86: Add some documentation on how to port U-Boot on x86Simon Glass
Some information has been gleaned on tools and procedures for porting U-Boot to different x86 platforms. Add a few notes to start things off. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-02-07ARM: UniPhier: add a simple README file for UniPhier platformMasahiro Yamada
2015-02-05x86: Add an option to enabling building a ROM fileSimon Glass
Rather than requiring the Makefile to be modified, provide a build option to enable the ROM to be built. We cannot do this by default since it requires binary blobs. Without these the build will fail. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-01-30Merge branch 'master' of git://git.denx.de/u-boot-dmTom Rini
2015-01-30add README.distro fileDennis Gilmore
Add documentation on how to setup a system to use the generic distro configs and boot commands. This spells out what is needed to make a system conformant, but does not limit the board to only the defaults. Signed-off-by: Dennis Gilmore <dennis@ausil.us> [swarren, added concept, user config, BOOT_TARGET_DEVICES sections. edited the rest] Signed-off-by: Stephen Warren <swarren@nvidia.com>
2015-01-29dm: i2c: dts: Support an offset-len device tree propertySimon Glass
Since U-Boot can support different offset lengths (0-4 bytes), add a device tree property to specify this. This avoids hard-coding it in the driver. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-29Export redesignMartin Dorwig
this is an atempt to make the export of functions typesafe. I replaced the jumptable void ** by a struct (jt_funcs) with function pointers. The EXPORT_FUNC macro now has 3 fixed parameters and one variadic parameter The first is the name of the exported function, the rest of the parameters are used to format a functionpointer in the jumptable, the EXPORT_FUNC macros are expanded three times, 1. to declare the members of the struct 2. to initialize the structmember pointers 3. to call the functions in stubs.c Signed-off-by: Martin Dorwig <dorwig@tetronik.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> (resending to the list since my tweaks are not quite trivial)
