path: root/doc
2007-08-14Coding style cleanup, update CHANGELOGWolfgang Denk
2007-08-14Add MPC8544DS READMEAndy Fleming
Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-08-13Merge with /home/wd/git/u-boot/custodian/u-boot-mpc86xxWolfgang Denk
2007-08-13Minor coding style cleanup. Update CHANGELOG.Wolfgang Denk
2007-08-10Add support for SBC8641D. Config files.Joe Hamman
Add support for Wind River's SBC8641D reference board. Signed-off by: Joe Hamman <joe.hamman@embeddedspecialties.com> Acked-by: Wolfgang Denk <wd@denx.de> Acked-by: Jon Loeliger <jdl@freescale.com>
2007-08-10mpc83xx: Correct the README for DDR ECCDave Liu
Update the README for DDR ECC, change the name to README.mpc83xx.ddrecc. Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-10mpc83xx: add support for the MPC8323E RDBKim Phillips
MPC8323E based board with 64MB fixed SDRAM, 16MB flash, five 10/100 ethernet ports connected via an ICPlus IP175C switch, one PCI slot, and serial. Features not supported in this patch are SD card interface, 2 USB ports, and the two phone ports. Signed-off-by: Michael Barkowski <michael.barkowski@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-10mpc83xx: Revise the MPC8360EMDS readme docDave Liu
When the rev2.x silicon mount on the MPC8360EMDS baord, and if you are using the u-boot version after the commit 3fc0bd159103b536e1c54c6f4457a09b3aba66ca. to make the ethernet interface usable, we have to setup the jumpers correctly. Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-07Merge with git://www.denx.de/git/u-boot.gitMarkus Klotzbuecher
2007-08-06ppc4xx: Update AMCC Bamboo README doc/README.bambooStefan Roese
As suggested by Eugene O'Brien <Eugene.O'Brien@advantechamt.com>, here an updated Bamboo README. Signed-off-by: Stefan Roese <sr@denx.de>
2007-08-06Merge with /home/wd/git/u-boot/custodian/u-boot-testingWolfgang Denk
2007-07-12Update CHANGELOG, minor coding style cleanup.Wolfgang Denk
2007-07-11[PCS440EP] - Show on the DIAG LEDs, if the SHA1 check failedHeiko Schocher
- now the Flash ST M29W040B is supported (not tested) - fix the "led" command - fix compile error, if BUILD_DIR is used Signed-off-by: Heiko Schocher <hs@denx.de>
2007-07-10disk/ doc/ lib_*/ and tools/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09Update README.* to reference new CONFIG_CMD_* names now.Jon Loeliger
2007-07-08Remove references to the old cmd_confdefs.h include file.Jon Loeliger
2007-06-25ppc4xx: Add pci_pre_init() for 405 boardsStefan Roese
This patch removes the CFG_PCI_PRE_INIT option completely, since it's not needed anymore with the patch from Matthias Fuchs with the "weak" pci_pre_init() implementation. Signed-off-by: Stefan Roese <sr@denx.de>
2007-06-06Merge with /home/wd/git/u-boot/custodian/u-boot-mpc86xxWolfgang Denk
2007-06-06USB/OHCI: endianness cleanup in the generic ohci driverMarkus Klotzbuecher
2007-06-05Merge branch 'mpc8641'Jon Loeliger
2007-06-05mpc8641 image size cleanupEd Swarthout
e600 does not have a bootpg restriction. Move the version string to beginning of image at fff00000. Resetvec.S is not needed. Update flash copy instructions. Add tftpflash env variable Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-05-29Merge git://www.denx.de/git/u-boot into 2007_05_15-testingMarkus Klotzbuecher
2007-05-16Merge with /home/wd/git/u-boot/custodian/u-boot-mpc83xxWolfgang Denk
2007-05-07Get rid of duplicated file (see doc/README.SBC8560 instead)Wolfgang Denk
2007-05-07Merge with git://www.denx.de/git/u-boot.gitMarkus Klotzbuecher
2007-04-23mpc83xx: Add MPC8313ERDB support.Scott Wood
2007-04-23Merge with git://www.denx.de/git/u-boot.gitMarkus Klotzbuecher
2007-04-23Remove BOARDLIBS usage completelyStefan Roese
2007-04-18Merge with /home/wd/git/u-boot/custodian/u-boot-mpc86xxWolfgang Denk
2007-04-18Merge with /home/wd/git/u-boot/custodian/u-boot-netWolfgang Denk
2007-04-18Merge with /home/wd/git/u-boot/custodian/u-boot-74xx-7xxWolfgang Denk
2007-04-18[PATCH] icecube/lite5200b: document wakeup from low-power supportDomen Puncer
Signed-off-by: Domen Puncer <domen.puncer@telargo.com>
2007-04-09Add PIXIS FPGA support for MPC8641HPCN board.Haiying Wang
Move the 8641HPCN's PIXIS code to the new directory board/freescale/common/ as it will be shared by future boards not in the same processor family. Write a "pixis_reset" command that utilizes the FPGA reset sequencer to support alternate soft-reset options such as using the "alternate" flash bank, enabling the watch dog, or choosing different CPU frequencies. Add documentation for the pixis_reset to README.mpc8641hpcn. Signed-off-by: Haiying Wang <haiying.wang@freescale.com> Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-04-04Update usage of 'nc' in README.NetConsoleIgor Marnat
Added information about usage of NetConsole on systems where the -l and -p switches are mutually exclusive. Signed-off-by: Igor Marnat <marny@rambler.ru> Signed-off-by: Ben Warren <bwarren@qstreams.com>
2007-03-23Merge with git://www.denx.de/git/u-boot.git#testing-USBMarkus Klotzbuecher
2007-03-08Minor cleanup.Wolfgang Denk
2007-03-04Some code cleanup.Wolfgang Denk
2007-03-02mpc83xx: Add support for the MPC8349E-mITX-GPTimur Tabi
Add support for the MPC8349E-mITX-GP, a stripped-down version of the MPC8349E-mITX. Bonus features include support for low-boot (BMS bit in HRCW is 0) for the ITX and a README for the ITX and the ITX-GP. Signed-off-by: Timur Tabi <timur@freescale.com>
2007-03-02mpc83xx: U-Boot support for Wind River SBC8349Paul Gortmaker
I've redone the SBC8349 support to match git-current, which incorporates all the MPC834x updates from Freescale since the 1.1.6 release, including the DDR changes. I've kept all the SBC8349 files as parallel as possible to the MPC8349EMDS ones for ease of maintenance and to allow for easy inspection of what was changed to support this board. Hence the SBC8349 U-Boot has FDT support and everything else that the MPC8349EMDS has. Fortunately the Freescale updates added support for boards using CS0, but I had to change spd_sdram.c to allow for board specific settings for the sdram_clk_cntl (it is/was hard coded to zero, and that remains the default if the board doesn't specify a value.) Hopefully this should be mergeable as-is and require no whitespace cleanups or similar, but if something doesn't measure up then let me know and I'll fix it. Thanks, Paul.
2007-03-02mpc83xx: Add the MPC832XEMDS board readmeDave Liu
Add the MPC832XEMDS board readme Signed-off-by: Dave Liu <daveliu@freescale.com>
2006-12-01Fix the confilcts when merging 'master' into hpc2.roy zang
The conflicts due to a new mpc7448 p3m7448 board is in the main tree. Merge branch 'master' into hpc2 Conflicts: MAKEALL cpu/74xx_7xx/cpu.c cpu/74xx_7xx/cpu_init.c cpu/74xx_7xx/speed.c
2006-12-01Clean up the code according to codestyle:roy zang
(1) remove some C++ comments. (2) remove trailing white space. (3) remove trailing empty line. (4) Indentation by table. (5) remove {} in one line condition. (6) add space before '(' in function call. Remove some weird printf () output. Add necessary comments. Modified Makefile to support building in a separate directory.
2006-11-30Code cleanup.Wolfgang Denk
2006-11-27Merge with /home/mk/git/u-boot-generic_ohci#generic_ohciWolfgang Denk
2006-11-27Add a small README with information on the generic ohci driver.Markus Klotzbuecher
2006-11-03mpc83xx: add the README.mpc8360emdsDave Liu
add doc/README.mpc8360emds to accompany the new board support
2006-11-02Add README file for mpc7448hpc2 board.roy zang
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
2006-10-28[PATCH] NAND: Partition name support added to NAND subsystemStefan Roese
chpart, nboot and NAND subsystem related commands now accept also partition name to specify offset. Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Stefan Roese <sr@denx.de>
2006-10-24Merge with /home/wd/git/u-boot/masterWolfgang Denk
2006-10-24Add AVR32 architecture supportWolfgang Denk
Patch by Haavard Skinnemoen, 6 Sep 2006 16:23:02 +0200 This patch adds common infrastructure code for the Atmel AVR32 architecture. See doc/README.AVR32 for details. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
