path: root/doc
2012-07-22Minor Coding Style Cleanup.Wolfgang Denk
2012-07-20mx28: Fix elftosb source link in README.mx28_commonAnatolij Gustschin
The documented link to elftosb package tarball is not accessible, change to another working link. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Fabio Estevam <festevam@gmail.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Detlev Zundel <dzu@denx.de> Acked-by: Marek Vasut <marex@denx.de>
2012-07-20doc: README.mx28_common: Add missing entry into ContentsFabio Estevam
commit 419ea2d84 (mx28: Split the README into a common part and a m28 specific part) missed an entry in the Contents section that was part of the original file. Add the missing entry for completeness. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marex@denx.de>
2012-07-10Minor Coding Style cleanupWolfgang Denk
2012-07-08Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: (212 commits) ARM: cache: Move the cp15 CR register read before flushing the cache. ARM: introduce arch_early_init_r() PXA: Enable CONFIG_PREBOOT on zipitz2 ARM: mx28: Remove CONFIG_ARCH_CPU_INIT No need to define CONFIG_ARCH_CPU_INIT. add new board vl_ma2sc MTD: SPEAr SMI: Add write support for length < 4 bytes i2c: designware_i2c.c: Add support for the "i2c probe" command rtc/m41t62: Add support for M41T82 with HT (Halt Update) SPL: ARM: spear: Add SPL support for SPEAr600 platform Makefile: Add u-boot.spr build target (SPEAr) SPL: ARM: spear: Remove some objects from SPL build SPL: lib/Makefile: Add crc32.c to SPL build SPL: common/Makefile: Add image.c to SPL build arm: Don't use printf() in SPL builds GPIO: Add SPEAr GPIO driver net: Multiple updates/enhancements to designware.c cleanup/SPEAr: Define configuration flags more elegantly cleanup/SPEAr: Remove unnecessary parenthesis SPEAr: Correct SoC ID offset in misc configuration space SPEAr: explicitly select clk src for UART SPEAr: Remove CONFIG_MTD_NAND_VERIFY_WRITE to speed up NAND access SPEAr: Enable ONFI nand flash detection for spear3xx and 6xx and evb SPEAr: Enable CONFIG_SYS_FLASH_EMPTY_INFO macro SPEAr: Correct the definition of CONFIG_SYS_MONITOR_BASE SPEAr: Enable CONFIG_SYS_FLASH_PROTECTION SPEAr: Enable dcache for fast file transfer SPEAr: Enable autoneg for ethernet SPEAr: Enable udc and usb-console support only for usbtty configuration SPEAr: Enable usb device high speed support SPEAr: Initialize SNOR in early_board_init_f SPEAr: Change the default environment variables SPEAr: Remove unused flag (CONFIG_SYS_HZ_CLOCK) SPEAr: Add configuration options for spear3xx and spear6xx boards SPEAr: Add basic arch related support for SPEAr SoCs SPEAr: Add interface information in initialization SPEAr: Add macb driver support for spear310 and spear320 SPEAr: Configure network support for spear SoCs SPEAr: Place ethaddr write and read within CONFIG_CMD_NET SPEAr: Eliminate dependency on Xloader table SPEAr: Fix ARM relocation support st_smi: Fixed page size for Winbond W25Q128FV flash st_smi: Change timeout loop implementation st_smi: Fix bug in flash_print_info() st_smi: Change the flash probing method st_smi: Removed no needed dependency on ST_M25Pxx_ID st_smi: Fix smi read status st_smi: Move status register read before modifying ctrl register st_smi: Read status until timeout happens st_smi: Enhance the error handling st_smi: Change SMI timeout values st_smi: Return error in case TFF is not set st_smi: Add support for SPEAr SMI driver mtd/NAND: Remove obsolete SPEAr specific NAND drivers SPEAr: Configure FSMC driver for NAND interface mtd/NAND: Add FSMC driver support arm/km: remove calls to kw_gpio_* in board_early_init_f arm/km: add implementation for read_dip_switch arm/km: support the 2 PCIe fpga resets arm/km: skip FPGA config when already configured arm/km: redefine piggy 4 reg names to avoid conflicts arm/km: cleanup km_kirkwood boards arm/km: enable BOCO2 FPGA download support arm/km: remove portl2.h and use km_kirkwood instead arm/km: convert mgcoge3un target to km_kirkwood arm/km: add kmcoge5un board support arm/km: add kmnusa board support arm: bugfix: save_boot_params_default accesses uninitalized stack when -O0 cm-t35: fix incorrect NAND_ECC layout selection ARM: OMAP4/5: Do not configure non essential pads, clocks, dplls. ARM: OMAP4/5: Move USB pads to essential list. ARM: OMAP4/5: Move USB clocks to essential group. ARM: OMAP4/5: Move gpmc clocks to essential group. ARM: OMAP4+: Move external phy initialisations to arch specific place. omap4: Use a smaller M,N couple for IVA DPLL da850/omap-l138: Enable auto negotiation in RMII mode omap: am33xx: accomodate input clocks other than 24 Mhz omap: emif: fix bug in manufacturer code test omap: emif: deal with rams that return duplicate mr data on all byte lanes OMAP4+: Force DDR in self-refresh after warm reset OMAP4+: Handle sdram init after warm reset ARM: OMAP3+: Detect reset type arm: bugfix: Move vector table before jumping relocated code Kirkwood: Add support for Ka-Ro TK71 arm/km: use spi claim bus to switch between SPI and NAND arm/kirkwood: protect the ENV_SPI #defines ARM: don't probe PHY address for LaCie boards lacie_kw: fix CONFIG_SYS_KWD_CONFIG for inetspace_v2 lacie_kw: fix SDRAM banks number for net2big_v2 Kirkwood: add lschlv2 and lsxhl board support net: add helper to generate random mac address net: use common rand()/srand() functions lib: add rand() function kwboot: boot kirkwood SoCs over a serial link kw_spi: add weak functions board_spi_claim/release_bus kw_spi: support spi_claim/release_bus functions kw_spi: backup and reset the MPP of the chosen CS pin kirkwood: fix calls to kirkwood_mpp_conf kirkwood: add save functionality kirkwood_mpp_conf function km_arm: use filesize for erase in update command arm/km: enable mii cmd arm/km: remove CONFIG_RESET_PHY_R arm/km: change maintainer for mgcoge3un arm/km: fix wrong comment in SDRAM config for mgcoge3un arm/km: use ARRAY_SIZE macro arm/km: rename CONFIG option CONFIG_KM_DEF_ENV_UPDATE arm/km: add piggy mac adress offset for mgcoge3un arm/km: add board type to boards.cfg AT91SAM9*: Change kernel address in dataflash to match u-boot's size ATMEL/PIO: Enable new feature of PIO on Atmel device ehci-atmel: fix compiler warning AT91: at91sam9m10g45ek : Enable EHCI instead OHCI Atmel : usb : add EHCI driver for Atmel SoC Fix: AT91SAM9263 nor flash usage Fix: broken boot message at serial line on AT91SAM9263-EK board i.MX6 USDHC: Use the ESDHC clock mx28evk: Fix boot by adjusting HW_DRAM_CTL29 register i.MX28: Add function to adjust memory parameters mx28evk: Fix PSWITCH key position mx53smd: Remove CONFIG_SYS_I2C_SLAVE definition mx53loco: Remove CONFIG_SYS_I2C_SLAVE definition mx53evk: Remove CONFIG_SYS_I2C_SLAVE definition mx53ard: Remove CONFIG_SYS_I2C_SLAVE definition mx35pdk: Remove CONFIG_SYS_I2C_SLAVE definition imx31_phycore: Remove CONFIG_SYS_I2C_SLAVE definition mx53ard: Remove unused CONFIG_MII_GASKET mx6: Avoid writing to read-only bits in imximage.cfg m28evk: use same notation to alloc the 128kB stack ... Signed-off-by: Wolfgang Denk <wd@denx.de>
2012-07-07SPEAr: Add configuration options for spear3xx and spear6xx boardsVipin KUMAR
This patch adds options for all the below mentioned configurations and subsequently renames the include/configs/spearxxx.h files to spear3xx_evb.h, spear6xx_evb.h etc to depict evaluation board configuration. SPEAr3xx and SPEAr6xx boards can be compiled in following configurations 1. Environment placed in NAND 2. Console on usb device 3. Console on usb device with environment placed in NAND 4. SPEAr310 and SPEAr320 support environment variables in parallel NOR flash. Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com> Signed-off-by: Stefan Roese <sr@denx.de>
2012-07-07SPEAr: Place ethaddr write and read within CONFIG_CMD_NETVipin KUMAR
ethaddr can be optionally read from i2c memory. So, chip_config command supports reading/writing hw mac id into i2c memory. Placing this code within CONFIG_CMD_NET as this would only be needed when network interface is configured Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com> Signed-off-by: Stefan Roese <sr@denx.de>
2012-07-07kwboot: boot kirkwood SoCs over a serial linkLuka Perkov
The kwboot program boots boards based on Marvell's Kirkwood platform via Xmodem over their integrated UART. Signed-off-by: Daniel Stodden <daniel.stodden@googlemail.com> Acked-by: Luka Perkov <uboot@lukaperkov.net> Tested-By: Holger Brunck <holger.brunck@keymile.com> Tested-By: David Purdy <david.c.purdy@gmail.com> Tested-by: Simon Guinot <simon.guinot@sequanux.org>
2012-07-07mx28evk: Fix PSWITCH key positionFabio Estevam
Fix the position for PSWITCH key. The good benefit of doing this is that boot time is greatly reduced: from 5 seconds to less then 1 second. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marex@denx.de>
2012-07-07arm,davinci: update for enbw_cmc boardHeiko Schocher
- change gpio pin settings: - gpio pin 6[13] (PLC reset) default value low - gpio pin 6[0] (TPM reset) default value low - 4 new GPIO pins pin i/o name - 3[9] input Board Type - 2[7] input HW-ID0 - 2[6] input HW-ID1 - 2[3] input HW-ID2 - read board type and hw id from gpio pins on the enbw_cmc board, and use board type for setting up different gpio pin settings. - do not pass "davinci_mmc.use_dma=0" to linux, as MMC now works with DMA. - update logbuf support: store post word in RTC scratch register - add support for configuring KSZ8864RMN switch through a config file on u-boot startup. For more infos see: doc/README.switch_config Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Tom Rini <tom.rini@gmail.com> Cc: Christian Riesch <christian.riesch@omicron.at> Cc: Sandeep Paulraj <s-paulraj@ti.com>
2012-07-06PATCH 1/4][v4] doc:Add documentation for e500 external debugger supportPrabhakar Kushwaha
This describes requirement of e500 and e500v2 processor to support external debugger. It also provide an insight of the configuration switch required and their description. Signed-off-by: Radu Lazarescu <radu.lazarescu@freescale.com> Signed-off-by: Marius Grigoras <marius.grigoras@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
2012-06-21pxe: parse initrd file from append stringRob Herring
For syslinux, the initrd can be set in the append string as "initrd=<file>", so try to find it there if we haven't already set the initrd. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-06-21Block: Remove MG DISK supportMarek Vasut
This driver is unused and obsolete. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: unsik Kim <donari75@gmail.com>
2012-05-23net: Add link-local addressing supportJoe Hershberger
Code based on networking/zcip.c in busybox commit 8531d76a15890c2c535908ce888b2e2aed35b172 Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-20Merge branch 'master' of git://git.denx.de/u-boot-nand-flashWolfgang Denk
* 'master' of git://git.denx.de/u-boot-nand-flash: NAND: Remove ONFI detection message to from bootup log driver/mtd:IFC: Fix possible memory leak driver/mtd: IFC NAND: Add support of ONFI NAND flash mtd, nand: move some printfs to debug output. nand_util: correct YAFFS image write function powerpc/85xx: fix NAND boot linker scripts for -fpic nand: extend .raw accesses to work on multiple pages
2012-05-18nand: extend .raw accesses to work on multiple pagesScott Wood
A use for this is to read, modify, erase, and write an entire block as a single unit, as a replacement for the biterr command. This way gives more flexibility in that you can also test multiple bit errors, errors in the ECC, etc. Signed-off-by: Scott Wood <scottwood@freescale.com>
2012-05-15ARM: omap3: Set SPL stack size to 8KB, image to 54KB.Tom Rini
With older toolchains it is possible to not fit entirely into the 45KB that we had assigned to SPL. Adjust to allow for 8KB of stack (which should be more than required) and 54KB of text/data. Cc: Vaibhav Hiremath <hvaibhav@ti.com> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Thomas Weber <weber@corscience.de> Cc: Ilya Yanok <yanok@emcraft.com> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Signed-off-by: Tom Rini <trini@ti.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Vaibhav Hiremath <hvaibhav@ti.com>
2012-04-30Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
* 'master' of git://git.denx.de/u-boot-mpc85xx: powerpc/85xx: don't touch MAS7 on e500v1 when relocating CCSR powerpc/85xx: don't display address map size (32-bit vs. 36-bit) during boot cmd_bdinfo: display the address map size (32-bit vs. 36-bit) PowerPC: correct the SATA for p1/p2 rdb-pc platform powerpc/corenet_ds: Slave core in holdoff when boot from SRIO powerpc/corenet_ds: Slave reads ENV from master when boot from SRIO powerpc/corenet_ds: Slave uploads ucode when boot from SRIO powerpc/corenet_ds: Slave module for boot from SRIO powerpc/corenet_ds: Master module for boot from SRIO powerpc/corenet_ds: Document for the boot from SRIO powerpc/corenet_ds: Correct the compilation errors about ENV powerpc/srio: Rewrite the struct ccsr_rio powerpc/85xx:Fix lds for nand boot debug info powerpc/p2041rdb: add env in NAND support powerpc/p2041rdb: add NAND and NAND boot support powerpc/mpc8xxx: Fix CONFIG_DDR_RAW_TIMING for two boards powerpc/85xx:Avoid vector table compilation for nand_spl powerpc/85xx:Fix IVORs addr after vector table relocation powerpc/85xx:Avoid hardcoded vector address for IVORs powerpc/p1023rds: Disable nor flash node and enable nand flash node
2012-04-24powerpc/corenet_ds: Document for the boot from SRIOLiu Gang
This document describes the implementation of the boot from SRIO, includes the introduction of envionment, an example based on P4080DS platform, an example of the slave's RCW, and the description about how to use this feature. Signed-off-by: Liu Gang <Gang.Liu@freescale.com>
2012-04-22board/adp-ag102: add configuration of adp-ag102Macpaul Lin
board: Add config file of board adp-ag102 Add adp-ag102 into boards.cfg Add adp-ag102 into MAINTAINERS doc: add README of ag102 Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2012-04-16Prepare v2012.04-rc2; minor Coding Style cleanupv2012.04-rc2Wolfgang Denk
2012-04-16mx6qsabrelite: Add boot switch setting information into the READMEFabio Estevam
Add boot switch setting information into the README Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-04-16mx28evk: Add a README fileFabio Estevam
Add a README file for mx28evk board. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marex@denx.de>
2012-04-16mx28: Split the README into a common part and a m28 specific partFabio Estevam
Split the README into a common part and a m28 specific part. This will make things easier when adding new README files for other mx28 based boards. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marex@denx.de>
2012-04-03Update net subsystem maintainer in doc/git-mailrcJoe Hershberger
Signed-off-by: Joe Hershberger <joe.hershberger@gmail.com>
2012-03-30Merge branch 'agust@denx.de' of git://git.denx.de/u-boot-stagingWolfgang Denk
* 'agust@denx.de' of git://git.denx.de/u-boot-staging: lzma: fix printf warnings Remove CONFIG_SYS_EXTBDINFO from snapper9260.h cmd_pxe.c: fix strict-aliasing warnings net: smc91111: use mdelay() doc: Fix some typos in different files disk/part.c: Fix device enumeration through API mkenvimage: Really set the redundant byte when applicable mkenvimage: Don't try to detect comments in the input file mkenvimage: Use mmap() when reading from a regular file mkenvimage: Read/Write from/to stdin/out by default or if the filename is "-" mkenvimage: More error handling mkenvimage: Correct an include and add a missing one mkenvimage: correct and clarify comments and error messages MAKEALL: display SPL size if present ARMV7/Vexpress: add missing get_ticks() and get_tbclk() mkenvimage: fix usage message cmd_fat: add FAT write command fs/fat/fat_write.c: Fix GCC 4.6 warnings FAT write: Fix compile errors
2012-03-30Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: (146 commits) arm: Use common .lds file where possible arm: add a common .lds link script arm: Remove unneeded setting of LDCSRIPT Define CPUDIR for the .lds link script arm: Remove zipitz2 link script Allow arch directory to contain .lds without requiring Makefile OMAP: Remove omap1610inn-based boards arch/arm/cpu/armv7/omap-common/clocks-common.c: Fix build warnings board/ti/beagle/beagle.c: Fix build warnings sdrc.c: Fix typo in do_sdrc_init() for SPL tegra: i2c: Add I2C driver tegra: fdt: i2c: Add extra I2C bindings for U-Boot tegra: i2c: Select I2C ordering for Seaboard tegra: i2c: Enable I2C on Seaboard tegra: i2c: Select number of controllers for Tegra2 boards tegra: i2c: Initialise I2C on Nvidia boards tegra: Enhance clock support to handle 16-bit clock divisors fdt: Add function to allow aliases to refer to multiple nodes tegra: Rename NV_PA_PMC_BASE to TEGRA2_PMC_BASE tegra: fdt: Enable FDT support for Ventana tegra: fdt: Enable FDT support for Seaboard tegra: usb: Enable USB on Seaboard tegra: usb: Add common USB defines for tegra2 boards tegra: usb: Add USB support to nvidia boards arm: Check for valid FDT after console is up fdt: Avoid early panic() when there is no FDT present tegra: usb: Add support for Tegra USB peripheral tegra: fdt: Add function to return peripheral/clock ID usb: Add support for txfifo threshold tegra: usb: fdt: Add USB definitions for Tegra2 Seaboard tegra: usb: fdt: Add additional device tree definitions for USB ports tegra: fdt: Add clock bindings for Tegra2 Seaboard tegra: fdt: Add clock bindings tegra: fdt: Add additional USB binding fdt: Add tegra-usb bindings file from linux fdt: Add staging area for device tree binding documentation tegra: fdt: Add device tree file for Tegra2 Seaboard from kernel tegra: fdt: Add Tegra2x device tree file from kernel arm: fdt: Add skeleton device tree file from kernel fdt: Add basic support for decoding GPIO definitions fdt: Add functions to access phandles, arrays and bools fdt: Tidy up a few fdtdec problems fdt: Add tests for fdtdec fdt: Add fdtdec_find_aliases() to deal with alias nodes arm: Tegra2: Fix ELDK42 gcc failure with inline asm stack pointer load net: fec_mxc: allow use with cache enabled net: force PKTALIGN to ARCH_DMA_MINALIGN i.MX28: Enable caches by default i.MX28: Make use of the bounce buffer i.MX28: Do data transfers via DMA in MMC driver MMC: Implement generic bounce buffer i.MX28: Add cache support to MXS NAND driver i.MX28: Add cache support into the APBH DMA driver ARM926EJS: Implement cache operations board/vpac270/onenand.c: Fix build errors nhk8815: fix build errors atmel-boards: add missing atmel_mci.h ARM: highbank: setup env from boot source register ARM: highbank: change env config to use nvram ARM: highbank: add reset support ARM: highbank: Add boot counter support ARM: highbank: change TEXT_BASE to 0x8000 ARM: highbank: fix us_to_tick calculation ARM: highbank: add missing get_tbclk ARM: highbank: fix warning for calxedaxgmac_initialize net: calxedaxgmac: fix build due to missing __aligned definition EXYNOS: Add structure for Exynos4 DMC EXYNOS: SMDK5250: Support all 4 UARTs ARM: fix s3c2410 timer code ARM: davinci: fixes for cam_enc_4xx board omap3_spi: receive transmit mode calimain, enbw_cmc: Fix typo in comments Davinci: ea20: use gpio framework to access gpios OMAP3: mt_ventoux: sets its own mtdparts OMAP3: mt_ventoux: updated timing for FPGA twl4030: fix potential power supply handling issues NAND: TI: fix warnings in omap_gpmc.c cam_enc_4xx: Rename 'images' to 'imgs' arm: Add Prep subcommand support to bootm OMAP3: twister: add support to boot Linux from SPL SPL: call cleanup_before_linux() before booting Linux OMAP3: SPL: do not call I2C init if no I2C is set. Add cache functions to SPL for armv7 devkit8000: Implement and activate direct OS boot omap/spl: change output of spl_parse_image_header omap-common/spl: Add linux boot to SPL devkit8000/spl: init GPMC for dm9000 in SPL omap-common: Add NAND SPL linux booting devkit8000: add config for spl command Add cmd_spl command mx53ard: Initialize return code with error mx53: Make PLL2 to be the parent of UART clock configs: imx: Use CONFIG_SF_DEFAULT_CS mx28evk: Provide default values for SPI bus and chip select USB: ehci-mx6: Add proper IO accessors mx6: Read silicon revision from register i.MX28: Drop __naked function from spl_mem_init mxs_spi: Return proper timeout error i.MX28: Make the stabilization delays shorter pmic_i2c: Return error in case of invalid pmic_i2c_tx_num mx6: Remove duplicate definition of ANATOP_BASE_ADDR mx6: Fix reset cause for Power On Reset case i.MX6: mx6qsabrelite: add MACH_TYPE_MX6Q_SABRELITE i.MX6: mx6q_sabrelite: add CONFIG_REVISION_TAG i.MX28: Enable additional DRAM address bits mx6q: mx6qsabrelite: setup_spi() should be called in board_init to allow use for environment mx31: add "ARM11P power gating" to get_reset_cause mx31pdk: Fix CONFIG_SYS_MEMTEST_END efikamx: Fix CONFIG_SYS_MEMTEST_END mx53smd: Fix CONFIG_SYS_MEMTEST_END mx53evk: Fix CONFIG_SYS_MEMTEST_END mx51evk: Fix CONFIG_SYS_MEMTEST_END i.MX6: mx6qsabrelite: add ext2 support imximage: Remove overwriting of flash_offset IXP: Fix GPIO_INT_ACT_LOW_SET() IXP: Fix NAND build warning on PDNB3 and SCPU IXP: Move PDNB3 and SCPU from Makefile to boards.cfg IXP: Squash warnings in IXP NPE IXP: Fix missing MACH_TYPE_{ACTUX?,PNB3,DVLHOST} IXP: Make IXP buildable with arm-linux- toolchains Examples: Properly append LDFLAGS to LD command SPL: Enable YMODEM support on BeagleBone and AM335x EVM SPL: Add YMODEM over UART load support SPL: Add README.omap3 README: document more SPL config options spl.c: Use __noreturn decorator config.mk: Check for -fstack-usage support config.mk: Make cc-option create a file under include/generated ...
2012-03-29tegra: fdt: i2c: Add extra I2C bindings for U-BootSimon Glass
Add U-Boot's peripheral clock information to the Tegra20 device tree file. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-03-29tegra: fdt: Add clock bindingsSimon Glass
This adds a basic binding for the oscillator and peripheral clocks. The second cell is the clock number, defined as the bit number within the clock enable register if the peripheral clock. This uses the RFC clock bindings from Grant Likely so may change later: https://lkml.org/lkml/2011/12/12/498 It is taken from Stephen Warren's patch here: http://patchwork.ozlabs.org/patch/141359/ Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-03-29tegra: fdt: Add additional USB bindingSimon Glass
This adds a property to indicate a port which can switch between host and device mode. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-03-29fdt: Add tegra-usb bindings file from linuxSimon Glass
This file is taken from the Linux mailing list. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-03-29fdt: Add staging area for device tree binding documentationSimon Glass
Add a directory to hold device tree binding files, to permit easy review of this material in U-Boot patches. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-03-27Add cmd_spl commandSimon Schwarz
This adds a spl command to the u-boot. Related config: CONFIG_CMD_SPL activate/deactivate the command CONFIG_CMD_SPL_NAND_OFS Offset in NAND to use Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com> Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Tom Rini <tom.rini@gmail.com> CC: Wolfgang Denk <wd@denx.de>
2012-03-27doc: Fix some typos in different filesThomas Weber
adresses/addresses alernate/alternate asssuming/assuming calcualted/calculated enviroment/environment evalutation/evaluation falsh/flash labled/labeled paramaters/parameters Signed-off-by: Thomas Weber <thomas@tomweber.eu> Acked-by: Anatolij Gustschin <agust@denx.de>
2012-03-26SPL: Add README.omap3Tom Rini
This document describes the SPL process for OMAP3 (and related) boards as well as a partial memory map and how to verify certain aspects outside of running on the target. Signed-off-by: Tom Rini <trini@ti.com>
2012-03-26mx6q: mx6qsabrelite: Update the READMEDirk Behme
The SD loader binary is now downloadable at https://wiki.linaro.org/Boards/MX6QSabreLite under a open-source 3-clause BSD license. Update the README for this. The discussion shows that it's hard to change the hardware regarding the default SPI NOR boot of the SabreLite boards. I.e. this will stay the default boot. Therefore remove the 'early version of' statement. Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com> CC: Stefano Babic <sbabic@denx.de> CC: Jason Liu <liu.h.jason@gmail.com>
2012-03-26PXA: Remove PXA PCMCIA supportMarek Vasut
Say good bye to some ancient, very broken and unused code. Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2012-03-26sh: sh7757lcr: add supporting for MMCIFYoshihiro Shimoda
The sh7757lcr has 2GByte eMMC chip. This patch supports it. Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-03-19git-mailrc: change usb maintainer to MarekMike Frysinger
2012-03-13doc/git-mailrc: add <me> to avr32 aliasAndreas Bießmann
2012-03-13ATMEL: remove old atmel_mci driverSven Schnelle
All boards are using the gen_atmel_mci driver now, so no need to carry the old driver around. Signed-off-by: Sven Schnelle <svens@stackframe.org> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-02-14doc: complete, typosPeter Meerwald
mention repeatable to README.commands and fix some typos Signed-off-by: Peter Meerwald <p.meerwald@bct-electronic.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Tested-by: Marek Vasut <marek.vasut@gmail.com>
2012-02-12Changes to move hawkboard to the new spl infrastructureSughosh Ganu
This patch moves hawkboard to the new spl infrastructure from the older nand_spl one. Removed the hawkboard_nand_config build option -- The spl code now gets compiled with hawkboard_config, after building the main u-boot image, using the CONFIG_SPL_TEXT_BASE. Modified the README.hawkboard to reflect the same. Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com> Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Christian Riesch <christian.riesch@omicron.at> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Cc: Tom Rini <trini@ti.com> Acked-by: Christian Riesch <christian.riesch@omicron.at>
2012-02-12doc: fix typosPeter Meerwald
2012-02-12usb: ulpi: Add omap-ulpi-view port supportGovindraj.R
Based on discussion from this thread [1]. Adding omap-view port that helps us in using the generic ulpi framework for any ulpi phy ops using the INSNREG05_ULPI viewport reg available on omap platform. Currently ehci ports are available on omap3/4 platforms so enable the same for beagle and panda, patch is tested on the same boards. Thanks to Igor Grinberg <grinberg@compulab.co.il> for reviewing the omap-ehci patches and suggesting this approach. [1]: http://www.mail-archive.com/u-boot@lists.denx.de/msg76076.html Tested-by: Stefano Babic <sbabic@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Govindraj.R <govindraj.raja@ti.com>
2012-02-12imximage: Add support for i.MX6Dirk Behme
The i.MX6 processor can boot from NOR flash and SATA disks, additionally. Add the flash offsets for these additional boot modes. Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com> Signed-off-by: Fabio Estevam <festevam@gmail.com> CC: Stefano Babic <sbabic@denx.de> CC: Jason Liu <jason.hui@linaro.org> Acked-by: Jason Liu <jason.hui@linaro.org>
2012-02-12imximage: Add MX53 to the documentationDirk Behme
i.MX53 is supported, too. Add this to the introduction of the documentation. Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com> CC: Fabio Estevam <festevam@gmail.com> CC: Stefano Babic <sbabic@denx.de> CC: Jason Liu <jason.hui@linaro.org>
2012-02-12common, menu: show menu on startup if CONFIG_MENU_SHOW is definedHeiko Schocher
show a menu on startup instead running the shell. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Jason Hobbs <jason.hobbs@calxeda.com> Cc: Mike Frysinger <vapier@gentoo.org> Acked-by: Jason Hobbs <jason.hobbs@calxeda.com>
2012-02-12common, menu: add statusline supportHeiko Schocher
add the possibility to show a statusline when printing a menu Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Jason Hobbs <jason.hobbs@calxeda.com> Cc: Mike Frysinger <vapier@gentoo.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-01-26nand: Introduce CONFIG_SYS_NAND_SELF_INITScott Wood
This allows a driver to run code between nand_scan_ident() and nand_scan_tail(), among other things. See the additions to doc/README.nand for details. To allow a gradual transition, Boards that don't set CONFIG_SYS_NAND_SELF_INIT will still be initialized the old way, but new drivers should not require this, and existing drivers should be converted when convenient. Signed-off-by: Scott Wood <scottwood@freescale.com>
