The nios-32 arch is obsolete and broken. So it is removed.
The "-ffixed-r15" option doesn't work well for gcc4. Since we
don't use gp for small data with option "-G0", we can use gp
as global data pointer. This allows compiler to use r15. It
is necessary for gcc4 to work properly.
Signed-off-by: Scott McNutt <smcnutt@psyent.com>
Add a new function to the eth_device struct for programming a network
controller's hardware address.
After all network devices have been initialized and the proper MAC address
for each has been determined, make a device driver call to program the
address into the device. Only device instances with valid unicast addresses
will be programmed.
Acked-by: Detlev Zundel <dzu@denx.de>
Tested-by: Prafulla Wadaskar <prafulla@marvell.com>
Tested-by: Heiko Schocher <hs@denx.de>
Tested-by: Thomas Chou <thomas@wytron.com.tw>
As discussed on the list, move "arch/ppc" to "arch/powerpc" to
better match the Linux directory structure.
Please note that this patch also changes the "ppc" target in
MAKEALL to "powerpc" to match this new infrastructure. But "ppc"
is kept as an alias for now, to not break compatibility with
scripts using this name.
Acked-by: Wolfgang Denk <wd@denx.de>
Acked-by: Kim Phillips <kim.phillips@freescale.com>
Cc: Peter Tyser <ptyser@xes-inc.com>
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk
This change is intended to clean up the top-level directory structure
and more closely mimic Linux's directory organization.
The CPUDIR variable points to the location of a target's CPU directory.
Currently, it is set to cpu/$CPU. However, using $CPUDIR will allow for
more flexibility in the future. It lays the groundwork for reorganizing
U-Boot's directory structure to support a layout such as:
arch/$ARCH/cpu/$CPU/* (architecture with multiple CPU types)
arch/$ARCH/cpu/* (architecture with one CPU type)
Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
Because adds support the GPIO Interface, README file is updated.
As this seems unclear, document how the flow of setting up
the MAC address is correct.
Text changed slightly, adding input from Mike Frysinger.
The ramdisk sections in doc/uImage.FIT/multi.its lack
load address and entry point properties. Using examples
from this file will result in unbootable image, u-boot
will issue the following error messages:
Can't get ramdisk subimage load address!
Ramdisk image is corrupt or invalid
This patch adds missing properties to ramdisk sections.
Signed-off-by: Felix Radensky <felix@embedded-sol.com>
The ml300 board has a number of issues, but nobody cares about this
long-orphaned board any more. Remove it.
Acked-by: Michal Simek <monstr@monstr.eu>
Coding style cleanup, update CHANGELOG.
This patch corrects small mistake in the register list in
doc/README.mpc8536ds. These registers are 32 bits and this one starts
at ....c not ....e
When using the ...c address I can boot from sd, when using the ...e
address I cannot.
Signed-off-by: Frans Meulenbroeks <fransmeulenbroeks@gmail.com>
Acked-by: Hu Mingkai <B21284@freescale.com>
* prepare joining at91 and at91rm9200
* add modified copy of soc files to cpu/arm920t/at91 to make
possible to compile at91rm9200 boards in at91 tree instead
of at91rm9200
* add header files with c structure defs for AT91 MC, ST and TC
* the new cpu files are using at91 c structure soc access
* please read README.soc-at91 for details
Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
* add's the new temporary CONFIG_AT91_LEGACY to all board configs
This will need for backward compatiblity, while change the SoC access
to c structures. If CONFIG_AT91_LEGACY is defined, the deprecated
SoC is used.
This patch adds support for "imximage" (MX Boot Image)
to the mkimage utility. The imximage is used on the Freescales's
MX.25, MX.35 and MX.51 processors.
Further details under doc/README.imximage.
This patch was tested on a Freescale mx51evk board.
README.spear contains information about SPEAr architecture and
build options etc
Signed-off-by: Vipin <vipin.kumar@st.com>
The core support for NAND booting is there already, so this patch
is pretty straightforward.
There is one trick though: top level Makefile expects nand_spl to
be in nand_spl/board/$(BOARDDIR), but we can fully reuse the code
from mpc8313erdb boards, and so to not duplicate the code we just
symlink nand_spl/board/freescale/mpc8315erdb to mpc8313erdb.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
o silence make during ln echo
o update documentation
o and avoid:
$ ./MAKEALL MPC8315ERDB_NAND
Configuring for MPC8315ERDB board...
sdram.o: In function `fixed_sdram':
/home/r1aaha/git/u-boot/nand_spl/board/freescale/mpc8313erdb/sdram.c:72: undefined reference to `udelay'
by renaming udelay -> __udelay in the spirit of commit
3eb90bad651fab39cffba750ec4421a9c01d60e7 "Generic udelay() with watchdog
support".
board/esd/plu405/plu405.c
drivers/rtc/ftrtc010.c
Adding an initial README for the DaVinci series of SOC's
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
The example FIT image source files do not compile with the latest dtc and
mkimage. The following error message is produced:
DTC: dts->dtb on file "kernel.its"
Error: kernel.its 7:0 - 1:0 syntax error
FATAL ERROR: Unable to parse input tree
./mkimage: Can't read kernel.itb.tmp: Invalid argument
The FIT image source files are missing the "/dts-v1/;" directive at the
beginning of the file. Add the directive to the examples.
Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu>
The dev->halt() func can be called at any time, and the dev->recv() func
does not need to use NetRxPackets[] when calling NetReceive().
Adds new board SMDKC100 that uses s5pc100 SoC
Signed-off-by: HeungJun, Kim <riverful.kim@samsung.com>
arbitrary number of mii buses.
This feature is useful when your board uses different mii buses for different
phys and all (or a part) of these buses are implemented via bit-banging mode.
The driver requires that the following macros should be defined into the board
configuration file:
CONFIG_BITBANGMII - Enable the miiphybb driver
CONFIG_BITBANGMII_MULTI - Enable the multi bus support
If the CONFIG_BITBANGMII_MULTI is not defined, the board's config file needs
to define at least the following macros:
MII_INIT - Generic code to enable the MII bus (optional)
MDIO_DECLARE - Declaration needed to access to the MDIO pin (optional)
MDIO_ACTIVE - Activate the MDIO pin as out pin
MDIO_TRISTATE - Activate the MDIO pin as input/tristate pin
MDIO_READ - Read the MDIO pin
MDIO(v) - Write v on the MDIO pin
MDC_DECLARE - Declaration needed to access to the MDC pin (optional)
MDC(v) - Write v on the MDC pin
The previous macros make the driver compatible with the previous version
(that didn't support the multi-bus).
When the CONFIG_BITBANGMII_MULTI is also defined, the board code needs to fill
the bb_miiphy_buses[] array with a record for each required bus and declare
the bb_miiphy_buses_num variable with the number of mii buses.
The record (struct bb_miiphy_bus) has the following fields/callbacks (see
miiphy.h for details):
char name[] - The symbolic name that must be equal to the MII bus
registered name
int (*init)() - Initialization function called at startup time (just
before the Ethernet initialization)
int (*mdio_active)() - Activate the MDIO pin as output
int (*mdio_tristate)() - Activate the MDIO pin as input/tristate pin
int (*set_mdio)() - Write the MDIO pin
int (*get_mdio)() - Read the MDIO pin
int (*set_mdc)() - Write the MDC pin
int (*delay)() - Delay function
void *priv - Private data used by board specific code
The board code will look like:
struct bb_miiphy_bus bb_miiphy_buses[] = {
{ .name = miibus#1, .init = b1_init, .mdio_active = b1_mdio_active, ... },
{ .name = miibus#2, .init = b2_init, .mdio_active = b2_mdio_active, ... },
int bb_miiphy_buses_num = sizeof(bb_miiphy_buses) /
sizeof(bb_miiphy_buses[0]);
Signed-off-by: Luigi 'Comio' Mantellini <luigi.mantellini@idf-hit.com>
As discussed on mailing list, <0 indicates failure, >=0 indicates number
of interfaces found.
Also added blurb about private data
Add boot from NAND/eSDHC/eSPI description
Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com>
By nature of being based off the MPC8548CDS board, this
board inherited an ENV_SIZE setting of 256k. But since
it has a smaller flash device (8MB soldered on), it has
a native sector size of 128k, and hence the ENV_SIZE was
causing 2 sectors to be used for the environment.
By removing the unused sector, we can push TEXT_BASE up
closer to the end of address space and reclaim that
sector for any other application. This also fixes the
mismatch between TEXT_BASE and MONITOR_LEN reported by
Kumar earlier.
Since this board also supports the ability to boot off
the 64MB SODIMM flash, this change is forward looking
with that in mind; i.e. the settings for MONITOR_LEN
and ENV_SIZE will work when the 512k sectors of the
SODIMM flash are used for alternate boot in the future.
The previous README.sbc8548 was pretty much content-free. Replace
it with something that actually gives the end user some relevant
hardware details, and also lists the u-boot configuration choices.
Also in the cosmetic department, fix the bogus line in the Makefile
that was carried over from the SBC8560 Makefile, and the typo in
the sbc8548.c copyright.
The more standard 'source' command provides identical functionality to
the autoscr command.
Environment variable names/values on the MVBC_P, MVBML7, kmeter1,
mgcoge, and km8xx boards are updated to no longer refernce 'autoscr'.
The 'autoscript' and 'autoscript_uname' environment variables are
also removed.
Acked-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
Acked-by: Heiko Schocher <hs@denx.de>
The standard netcat, while ubiquitous, doesn't handle broadcast udp packets
properly. The local ncb util does however. So if ncb can be located in
the standard locations, automatically use that instead.
This patch adds support for "kwbimage" (Kirkwood Boot Image)
image types to the mkimage code.
For details refer to docs/README.kwbimage
This patch is tested with Sheevaplug board
Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
Acked-by: Ron Lee <ron@debian.org>
This patch adds support for the DevKit8000 board.
Signed-off-by: Frederik Kriewitz <frederik@kriewitz.eu>
Since the Blackfin ABI favors higher scratch registers by default, use the
last scratch register (P3) for global data rather than the first (P5).
This allows the compiler's register allocator to use higher number scratch
P registers, which in turn better matches the Blackfin instruction set,
which reduces the size of U-Boot by more than 1024 bytes...
Signed-off-by: Robin Getz <robin.getz@analog.com>
The code base adds P1 & P2 RDB platforms support.
The folder and file names can cater to future SOCs of P1/P2 family.
P1 & P2 processors are 85xx platforms, part of Freescale QorIQ series.
Tested following on P2020RDB:
1. eTSECs
2. DDR, NAND, NOR, I2C.
Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com>
Prior to this commit, to enable PCI, you had to go manually
edit the board config header, which isn't really user friendly.
This adds the typical PCI make targets to the toplevel Makefile
in accordance with what is being done with other boards.
Up to this point in time, the sbc8349 board was storing the u-boot
image in flash 2x. One for the HRCW value at the beginning of
flash (0xff80_0000), and once close to the end of flash (0xfff8_0000)
for the actual image that got executed.
This moves the TEXT_BASE to be the beginning of flash, which makes
the second copy of the image redundant, and frees up the flash
from the end of the environment storage to the end of the flash
device itself.
Update CHANGELOG, minor coding style fix.
This patch adds a new video driver
* adds common bus_vcxk framebuffer driver
Signed-off-by: Jens Scharsig <esw@bus-elektronik.de>
[agust@denx.de: fixed lots of style issues before applying]
On 04 Oct 2008 Pieter posted a dns implementation for U-Boot.
http://www.mail-archive.com/u-boot-users@lists.sourceforge.net/msg10216.html
> DNS can be enabled by setting CFG_CMD_DNS. After performing a query,
> the serverip environment var is updated.
> Probably there are some cosmetic issues with the patch. Unfortunatly I
> do not have the time to correct these. So if anybody else likes DNS
> support in U-Boot and has the time, feel free to patch it in the main tree.
Here it is again - slightly modified & smaller:
- update to 2009-06 (Pieter's patch was for U-Boot 1.2.0)
- README.dns is added
- syntax is changed (now takes a third option, the env var to store
the result in)
- add a random port() function in net.c
- sort Makefile in ./net/Makefile
- dns just returns unless a env var is given
- run through checkpatch, and clean up style issues
- remove packet from stack
- cleaned up some comments
- failure returns much faster (if server responds, don't wait for
timeout)
- use built in functions (memcpy) rather than byte copy.
Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org>
Signed-off-by: Pieter Voorthuijsen <pieter.voorthuijsen@prodrive.nl>
