path: root/doc
2005-08-01Major cleanup for AMCC PPC4xx eval boards.Stefan Roese
Patch by Stefan Roese, 01 Aug 2005
2005-04-20Auto-size RAM on canmb board.wdenk
Cleanup.
2005-04-07* Patch by Stefan Roese, 06 Apr 2005:stroese
Updates for OCOTEA board: - Changed U-Boot size from 512kByte to 256kByte - Fixed flash driver to support boot from soldered user flash - Added README for switch from PIBS firmware to U-Boot
2005-04-03* Patch by Richard Klingler, 03 Apr 2005:wdenk
Add call to eth_halt() in net/net.c when called functions fail after eth_init() has been called. * Patch by Sam Song, 3 April 2005: - Update README.Netconsole - Update README
2005-04-02Prepare for SoC rework of ARM code:wdenk
- rename CONFIG_BOOTBINFUNC into CONFIG_INIT_CRITICAL - rename memsetup into lowlevel_init (function name and source files)
2005-04-01* Patch by Masami Komiya, 30 Mar 2005:wdenk
add SNTP support and expand time server and time offset fields of DHCP support. See doc/README.SNTP * Patch by Steven Scholz, 13 Dec 2004: Fix bug in at91rm920 ethernet driver
2005-01-09* Patches by Richard Woodruff, 01 Oct 2004:wdenk
add support for the TI OMAP2420 processor and its H4 reference board * Patch by Christian Pellegrin, 24 Sep 2004: Added support for NE2000 compatible (DP8390, DP83902) NICs.
2005-01-09* Patch by Leif Lindholm, 23 Sep 2004:wdenk
add support for the AMD db1550 board * Patch by Travis Sawyer, 15 Sep 2004: Add CONFIG_SERIAL_MULTI support for ppc4xx, update README.serial_multi
2005-01-09Patch by Florian Schlote, 08 Sep 2004:wdenk
Add support for SenTec-COBRA5272-board (Coldfire).
2004-12-10* Clean up CMC PU2 flash driverwdenk
* Update MAINTAINERS file * Fix bug in MPC823 LCD driver
2004-10-28Patch by TsiChung Liew, 23 Sep 2004:wdenk
- add support for MPC8220 CPU - Add support for Alaska and Yukon boards
2004-10-11CleanupLABEL_2004_10_12_0110wdenk
2004-10-10* Patch by Gridish Shlomi, 30 Aug 2004:wdenk
- Add support to revA version of PQ27 and PQ27E. - Reverted MPC8260ADS baudrate back to original 115200 * Patch by Hojin, 17 Sep 2004: Fix typo in cfi_flash.c * Patch by Mark Jonas, 09 September 2004: mtest's data line test (with CFG_ALT_MEMTEST set) returned a wrong error message * Patch by Mark Jonas, 31 August 2004: Added option CFG_XLB_PIPELINING to enable XLB pipelining. This improves FTP performance for MPC5200 systems. Enabled for IceCube by default.
2004-10-10* Patch by Michael Bendzick, 30 Aug 2004:wdenk
- Improve platform.S code for omap1510inn that detects whether code is running from SDRAM or not. Patch allows SDRAM to be configured if code is running out of SRAM at 0x20000000. * Patch by Frederick Klatt, 30 Aug 2004: Add support for the Wind River SBC8540/SBC8560 boards
2004-10-10Patches by Scott McNutt, 24 Aug 2004:wdenk
- Add support for Altera Nios-II processors. - Add support for Psyent PCI-5441 board. - Add support for Psyent PK1C20 board.
2004-10-10Patches by Jon Loeliger, 24 Aug 2004:wdenk
- Add support for the MPC8541 and MPC8555 CDS boards - Cleanup eth?addr handling: make dependent on CONFIG_ETH?ADDR
2004-10-09Patch by Steven Scholz, 16 Aug 2004:wdenk
- Introducing the concept of SoCs "./cpu/$(CPU)/$(SOC)" - creating subdirs for SoCs ./cpu/arm920t/imx and ./cpu/arm920t/s3c24x0 - moving SoC specific code out of cpu/arm920t/ into cpu/arm920t/$(SOC)/ - moving drivers/s3c24x0_i2c.c and drivers/serial_imx.c out of drivers/ into cpu/arm920t/$(SOC)/
2004-09-28* Patch by Yuli Barcohen, 13 Jul 2004:wdenk
Allow clock setting on MPC866/MPC885 series chips according to environment variable `cpuclk' * Patch by Yuli Barcohen, 20 Apr 2004: Remove unnecessary redefine of CPM_DATAONLY_SIZE for MPC826x
2004-09-08* Patch by Detlev Zundel, 08 Sep 2004:LABEL_2004_09_09_0000wdenk
Update etags build target * Improve NetConsole support: add support for broadcast destination address and buffered input. * Cleanup compiler warnings for GCC 3.3.x and later * Fix problem in cmd_jffs2.c introduced by CFG_JFFS_SINGLE_PART patch
2004-08-02Add support for console over UDP (compatible to Ingo Molnar'swdenk
netconsole patch under Linux)
2004-08-01Patch by Jon Loeliger, 16 Jul 2004:wdenk
- support larger DDR memories up to 2G on the PC8540/8560ADS and STXGP3 boards - Made MPC8540/8560ADS be 33Mhz PCI by default. - Removed moldy CONFIG_RAM_AS_FLASH, CFG_FLASH_PORT_WIDTH_16 and CONFIG_L2_INIT_RAM options. - Refactor Local Bus initialization out of SDRAM setup. - Re-implement new version of LBC11/DDR11 errata workarounds. - Moved board specific PCI init parts out of CPU directory. - Added TLB entry for PCI-1 IO Memory - Updated README.mpc85xxads
2004-08-01* Code cleanupwdenk
* Patch by Sascha Hauer, 28 Jun: - add generic support for Motorola i.MX architecture - add support for mx1ads, mx1fs2 and scb9328 boards * Patches by Marc Leeman, 23 Jul 2004: - Add define for the PCI/Memory Buffer Configuration Register - corrected comments in cpu/mpc824x/cpu_init.c * Add support for multiple serial interfaces (for example to allow modem dial-in / dial-out)
2004-08-01* Fix NSCU config; add ethernet wakeup code.wdenk
* Add link for preloader for Motorola Coldfire to RAEDME.m68k
2004-07-10* Patch by Fred Klatt, 25 Jun 2004:wdenk
Add support for WindRiver's SBC8560 board * Patch by Nicolas Lacressonniere, 24 Jun 2004 Small Bugs fixes for "at91rm9200dk" board: - Timing modifications for SPI DataFlash access - Fix NAND flash detection bug * Patch by Nicolas Lacressonniere, 24 Jun 2004: Add Support for Flash AT49BV6416 for AT91RM9200DK board
2004-07-09Patch by Jon Loeliger, 17 June 2004:wdenk
Completion of the 8540ADS/8560ADS updates: Fix some PCI and Rapid I/O memory maps, Initialize both TSEC 1 and 2, Initialize SDRAM Update MAINTAINER for 85xx boards and README.mpc85xxads
2004-06-09* Patch by Paul Ruhland, 17 May 2004:wdenk
- Add support for the Logic Zoom LH7A40x based SDK board(s), specifically the LPD7A400. * Patches by Robert Schwebel, 15 May 2004: - call MAC address reading code also for SMSC91C111; - make SMSC91C111 timeout configurable, remove duplicate code - fix get_timer() for PXA - update doc/README.JFFS2 - use "bootfile" env variable also for jffs2
2004-06-09Patch by Robert Schwebel, 13 May 2004:wdenk
Add 'imgextract' command: extract one part of a multi file image.
2004-06-09Patches by Jon Loeliger, 11 May 2004:wdenk
(partially, as they contained a lot of crap)
2004-06-08* Patch by Rishi Bhattacharya, 08 May 2004:wdenk
Add support for TI OMAP5912 OSK Board * Patch by Sam Song May, 07 May 2004: Fix typo of UPM table for rmu board
2004-06-06* Patch by Dave Peverley, 30 Apr 2004:wdenk
Add support for OMAP730 Perseus2 Development board * Patch by Alan J. Luse, 29 Apr 2004: Fix flash chip-select (OR0) option register setting on FADS boards. * Patch by Alan J. Luse, 29 Apr 2004: Report MII network speed and duplex setting properly when auto-negotiate is not enabled. * Patch by Jarrett Redd, 29 Apr 2004: Fix hang on reset on Ocotea board due to flash in wrong mode.
2004-05-19Patch by Scott McNutt, 25 Apr 2004:LABEL_2004_05_19_2335wdenk
Add Nios GDB/JTAG Console support: - Add stubs to support gdb via JTAG. - Add support for console over JTAG. - Minor cleanup.
2004-04-18* Temporarily disabled John Kerl's extended MII command code becausewdenk
"miivals.h" is missing * Patches by Mark Jonas, 13 Apr 2004: - Remove CS0 chip select timing setting from cpu/mpc5xxx/start.S - Add sync instructions to IceCube SDRAM init code - Move SDRAM chip constants into seperate include files - Unify DDR and SDR initialization code - Unify all IceCube (Lite5xxx) target names
2004-04-18* Configure PPChameleon board to use redundand environment in flashLABEL_2004_04_18_2135wdenk
* Configure PPChameleon board to use JFFS2 NAND support. * Added support for JFFS2 filesystem (read-only) on top of NAND flash
2004-04-15* Patch by George G. Davis, 02 Apr 2004:wdenk
add support for Intel Assabet board
2004-04-15* Patch by Stephen Williams, 01 Apr 2004:wdenk
Add support for Picture Elements JSE board * Patch by Christian Pell, 01 Apr 2004: Add CompactFlash support for PXA systems.
2004-04-15Patches by Pantelis Antoniou, 30 Mar 2004:wdenk
add networking support for VLANs (802.1q), and CDP (Cisco Discovery Protocol)
2004-04-10Release version 1.1.0U-Boot-1_1_0wdenk
2004-03-14Code cleanup; make several boards compile & link.LABEL_2004_03_14_2340wdenk
2004-03-14* Patch by Stephan Linz, 09 Mar 2004wdenk
- Add support for the SSV ADNP/ESC1 (Nios Softcore) * Patch by George G. Davis, 9 Mar 2004: fix recent build failure for SA1100 target * Patch by Travis Sawyer, 09 Mar 2004: Support native interrupt mode for the IBM440GX. Previously it was running in 440GP compatibility mode.
2004-03-14* Patch by Yuli Barcohen, 4 Mar 2004:wdenk
Fix problems with GCC 3.3.x which changed handling of global variables explicitly initialized to zero (now in .bss instead of .data as before). * Patch by Leon Kukovec, 02 Mar 2004: add strswab() to fix IDE LBA capacity, firmware and model numbers on little endian machines * Patch by Masami Komiya, 02 Mar 2004: - Remove get_ticks() from NFS code - Add verification of RPC transaction ID * Patch by Pierre Aubert, 02 Mar 2004: cleanup for IDE and USB drivers for MPC5200
2004-02-26* Patch by Markus Pietrek, 24 Feb 2004:wdenk
NS9750 DevBoard added * Patch by Pierre AUBERT, 24 Feb 2004 add USB support for MPC5200 * Patch by Steven Scholz, 24 Feb 2004: - fix MII commands to use values from last command * Patch by Torsten Demke, 24 Feb 2004: Add support for the eXalion platform (SPSW-8240, F-30, F-300)
2004-02-23* Patch by Peter Ryser, 20 Feb 2004:wdenk
Add support for the Xilinx ML300 platform * Patch by Stephan Linz, 17 Feb 2004: Fix watchdog support for NIOS * Patch by Josh Fryman, 16 Feb 2004: Fix byte-swapping for cfi_flash.c for different bus widths * Patch by Jon Diekema, 14 Jeb 2004: Remove duplicate "FPGA Support" notes from the README file
2004-02-23* Patches by Reinhard Meyer, 14 Feb 2004:wdenk
- update board/emk tree; use common flash driver - Corrected tested bits in machine check exception in cpu/mpc5xxx/traps.c [adapted for other PPC CPUs -- wd] - Added support for the M48T08 on the EVAL5200 board in rtc/mk48t59.c * Patch by Jon Diekema, 13 Feb 2004: Call show_boot_progress() whenever POST "FAILED" is printed. * Patch by Nishant Kamat, 13 Feb 2004: Add support for TI OMAP1610 H2 Board Fixes for cpu/arm926ejs/interrupt.c (based on Richard Woodruff's patch for arm925, 16 Oct 03) Fix for a timer bug in OMAP1610 Innovator Add support for CS0 (ROM)/CS3 (Flash) boot in OMAP1610 Innovator and H2 * Patches by Stephan Linz, 12 Feb 2004: - add support for NIOS timer with variable period preload counter value - prepare POST framework support for NIOS targets * Patch by Denis Peter, 11 Feb 2004: add POST support for the MIP405 board
2004-02-23* Patch by Laurent Mohin, 10 Feb 2004:wdenk
Fix buffer overflow in common/usb.c * Patch by Tolunay Orkun, 10 Feb 2004: Add support for Cogent CSB272 board * Code cleanup
2004-02-23* Patch by Thomas Elste, 10 Feb 2004:wdenk
Add support for NET+50 CPU and ModNET50 board * Patch by Sam Song, 10 Feb 2004: Fix typos in cfi_flash.c * Patch by Leon Kukovec, 10 Feb 2004 Fixed long dir entry slot id calculation in get_vfatname * Patch by Robin Gilks, 10 Feb 2004: add "itest" command (operators: -eq, -ne, -lt, -gt, -le, -ge, ==, !=, <>, <, >, <=, >=)
2004-02-12* Some code cleanupwdenk
* Patch by Josef Baumgartner, 10 Feb 2004: Fixes for Coldfire port * Patch by Brad Kemp, 11 Feb 2004: Fix CFI flash driver problems
2004-02-09Patches by Stephan Linz, 30 Jan 2004:wdenk
1: - board/altera/common/flash.c:flash_erase(): o allow interrupts befor get_timer() call o check-up each erased sector and avoid unexpected timeouts - board/altera/dk1c20/dk1s10.c:board_early_init_f(): o enclose sevenseg_set() in cpp condition - remove the ASMI configuration for DK1S10_standard_32 (never present) - fix some typed in mistakes in the NIOS documentation 2: - split DK1C20 configuration into several header files: o two new files for each NIOS CPU description o U-Boot related part is remaining in DK1C20.h 3: - split DK1S10 configuration into several header files: o two new files for each NIOS CPU description o U-Boot related part is remaining in DK1S10.h 4: - Add support for the Microtronix Linux Development Kit NIOS CPU configuration at the Altera Nios Development Kit, Stratix Edition (DK-1S10) 5: - Add documentation for the Altera Nios Development Kit, Stratix Edition (DK-1S10) 6: - Add support for the Nios Serial Peripharel Interface (SPI) (master only) 7: - Add support for the common U-Boot SPI framework at RTC driver DS1306
2004-02-08Patch by Anders Larsen, 09 Jan 2004:wdenk
ARM memory layout fixes: the abort-stack is now set up in the correct RAM area, and the BSS is zeroed out as it should be. Furthermore, the magic variables 'armboot_end' and 'armboot_end_data' of the linker scripts are replaced by '__bss_start' and '_end', resp., which is a further step to eliminate unnecessary differences between the implementation of the CPU architectures.
2004-02-06Patch by Travis Sawyer, 30 Dec 2003:wdenk
Add support for IBM PPC440GX. Multiple EMAC Ethernet devices, select MDI port based on enabled EMAC device. Add support for XES Inc <http://www.xes-inc.com> XPedite1000 440GX base PrPMC board.
2004-02-06* Patch by Wolter Kamphuis, 15 Dec 2003:wdenk
made CONFIG_SILENT_CONSOLE usable on all architectures * Disable date command on TQM866M - there is no RTC on MPC866
