* Patch by Josef Baumgartner, 10 Feb 2004:
Fixes for Coldfire port
* Patch by Brad Kemp, 11 Feb 2004:
Fix CFI flash driver problems
1: - board/altera/common/flash.c:flash_erase():
o allow interrupts befor get_timer() call
o check-up each erased sector and avoid unexpected timeouts
- board/altera/dk1c20/dk1s10.c:board_early_init_f():
o enclose sevenseg_set() in cpp condition
- remove the ASMI configuration for DK1S10_standard_32 (never present)
- fix some typed in mistakes in the NIOS documentation
2: - split DK1C20 configuration into several header files:
o two new files for each NIOS CPU description
o U-Boot related part is remaining in DK1C20.h
3: - split DK1S10 configuration into several header files:
o U-Boot related part is remaining in DK1S10.h
4: - Add support for the Microtronix Linux Development Kit
NIOS CPU configuration at the Altera Nios Development Kit,
Stratix Edition (DK-1S10)
5: - Add documentation for the Altera Nios Development Kit,
6: - Add support for the Nios Serial Peripharel Interface (SPI)
(master only)
7: - Add support for the common U-Boot SPI framework at
RTC driver DS1306
ARM memory layout fixes: the abort-stack is now set up in the
correct RAM area, and the BSS is zeroed out as it should be.
Furthermore, the magic variables 'armboot_end' and 'armboot_end_data'
of the linker scripts are replaced by '__bss_start' and '_end',
resp., which is a further step to eliminate unnecessary differences
between the implementation of the CPU architectures.
Add support for IBM PPC440GX. Multiple EMAC Ethernet devices,
select MDI port based on enabled EMAC device.
Add support for XES Inc <http://www.xes-inc.com> XPedite1000 440GX
base PrPMC board.
made CONFIG_SILENT_CONSOLE usable on all architectures
* Disable date command on TQM866M - there is no RTC on MPC866
clock frequency for INCA-IP; fix problem with board hanging when
switching from 150MHz to 100MHz
* Add PCMCIA CS support for BMS2003 board
* Patch by Scott McNutt, 02 Jan 2004:
Add support for the Nios Active Serial Memory Interface (ASMI)
on Cyclone devices
* Patch by Andrea Marson, 16 Dec 2003:
Add support for the PPChameleon ME and HI modules
* Patch by Yuli Barcohen, 22 Dec 2003:
Add support for Motorola DUET ADS board (MPC87x/88x)
- more documentation for NIOS port
- new struct nios_pio_t, struct nios_spi_t
- Reconfiguration for NIOS Development Kit DK1C20:
o move board related code from board/dk1c20
to board/altera/dk1c20
o create a new common source path board/altera/common
and move generic flash access stuff into it
o change/expand configuration file DK1C20.h
- Add support for NIOS Development Kit DK1S10
- Add status LED support for NIOS systems
- Add dual 7-segment LED support for Altera NIOS DevKits
Add support for the Marvell DB64360 / DB64460 development boards
* Patch by Detlev Zundel, 10 Dec 2003:
fix dependency problem in examples/Makefile
Move most of the timer interrupt related PPC code to ppc_lib/interrupts.c
* Patch by Anders Larsen, 17 Sep 2003:
Bring ARM memory layout in sync with the documentation:
stack and malloc-heap are now located _below_ the U-Boot code
Fix AT91RM9200 ethernet driver
* Patch by Nye Liu, 17 Oct 2003:
Fix typo in include/mpc8xx.h
* Patch by Richard Woodruff, 16 Oct 03:
Fixes for cpu/arm925/interrupt.c
- Initialize timestamp & lastdec vars.
- fix timestamp overflows.
- fix lastdec overflow.
- smarter normalization to allow udelay() below 1ms to work.
* Patch by Scott McNutt, 16 Oct
add networking support for the Altera Nios Development Kit,
Cyclone Edition (DK-1C20)
* Patch by Jon Diekema, 14 Oct 2003:
add hint about doc/README.silent to README file
- Added Motorola CPU 8540/8560 support (cpu/85xx)
- Added Motorola MPC8540ADS board support (board/mpc8540ads)
- Added Motorola MPC8560ADS board support (board/mpc8560ads)
* Minor code cleanup
for more information
- add support for Altera Nios-32 CPU
- add support for Nios Cyclone Development Kit (DK-1C20)
* Patch by Steven Scholz, 29 Sep 2003:
- A second parameter for bootm overwrites the load address for
"Standalone Application" images.
- bootm sets environment variable "filesize" to the resulting
(uncompressed) data length for "Standalone Application" images
when autostart is set to "no". Now you can do something like
if bootm $fpgadata $some_free_ram ; then
fpga load 0 $some_free_ram $filesize
fi
* Patch by Denis Peter, 25 Sept 2003:
add support for the MIP405 Rev. C board
* Add PCI support for SL8245 board
* Support IceCube board configurations with 1 x AMD AM29LV065 (8 MB)
or 1 x AM29LV652 (two LV065 in one chip = 16 MB);
Run IPB at 133 Mhz; adjust the MII clock frequency accordingly
* Set BRG_CLK on PM825/826 to 64MHz (VCO_OUT / 4, instead of 16 MHz)
to allow for more accurate baudrate settings
(error now 0.7% at 115 kbps, instead of 3.5% before)
* Patch by Andreas Mohr, 4 Sep 2003:
Fix a lot of spelling errors
allow selection of clock frequency as "make" target
* Implement memory autosizing code for IceCube boards
* Configure network port on INCA-IP for autonegotiation
* Fix overflow problem in network timeout code
* Patch by Richard Woodruff, 8 Aug 2003:
Allow crc32 to be used at address 0x000 (crc32_no_comp, too).
Add support for LynuxWorks Kernel Downloadable Images (KDIs).
Both LynxOS and BlueCat linux KDIs are supported.
* Patch by Richard Woodruff, 25 Jul 2003:
use more reliable reset for OMAP/925T
* Patch by Nye Liu, 25 Jul 2003:
fix typo in mpc8xx.h
* Patch by Richard Woodruff, 24 Jul 2003:
Fixes for cmd_nand.c:
- Fixed null dereferece which could result in incorrect ECC values.
- Added support for devices with no Ready/Busy signal hooked up.
- Added OMAP1510 read/write protect handling.
- Fixed nand.h's ECCPOS. A conflict existed with POS5 and badblock
for non-JFFS2.
- Switched default ECC to be JFFS2.
* Provide consistent interface to standalone applications to access
the 'global_data' structure
Provide a doc/README.standalone more useful to users/developers.
* Make IceCube MGT5100 FEC driver work
applications: instead of using (PPC-specific) system calls we now
use a jump table; please see doc/README.standalone for details
* Patch by Dave Westwood, 24 Jul 2003:
added support for Unity OS (a proprietary OS)
- Correct flash and JFFS2 support for MPC8260ADS
- fix PVR values and clock generation for PowerQUICC II family
(8270/8275/8280)
* Patch by Bernhard Kuhn, 08 Jul 2003:
- add support for M68K targets
* Patch by Ken Chou, 3 Jul:
- Fix PCI config table for A3000
- Fix iobase for natsemi.c
(PCI_BASE_ADDRESS_0 is the IO base register for DP83815)
* Allow to enable "slow" POST routines by key press on power-on
* Fix temperature dependend switching of LCD backlight on LWMON
* Tweak output format for LWMON
- remove trailing white space, trailing empty lines, C++ comments, etc.
- split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c)
* Patches by Kenneth Johansson, 25 Jun 2003:
- major rework of command structure
(work done mostly by Michal Cendrowski and Joakim Kristiansen)
Fixed rarp boot method for IA32 and other little-endian CPUs.
* Patch by Marc Singer, 28 May 2003:
Added port I/O commands.
* Patch by Matthew McClintock, 28 May 2003
- cpu/mpc824x/start.S: fix relocation code when booting from RAM
- minor patches for utx8245
* Patch by Daniel Engström, 28 May 2003:
x86 update
* Patch by Dave Ellis, 9 May 2003 + 27 May 2003:
add nand flash support to SXNI855T configuration
fix/extend nand flash support:
- fix 'nand erase' command so does not erase bad blocks
- fix 'nand write' command so does not write to bad blocks
- fix nand_probe() so handles no flash detected properly
- add doc/README.nand
- add .jffs2 and .oob options to nand read/write
- add 'nand bad' command to list bad blocks
- add 'clean' option to 'nand erase' to write JFFS2 clean markers
- make NAND read/write faster
* Patch by Rune Torgersen, 23 May 2003:
Update for MPC8266ADS board
update for CrayL1 board
* Patch by Pantelis Antoniou, 21 Apr 2003:
add boot support for ARTOS (a proprietary OS)
* Patch by Steven Scholz, 11 Apr 2003:
Add support for RTC DS1338
* Patch by Rod Boyce, 24 Jan 2003:
Fix counting of extended partitions in diskboot command
Add lan91c96 driver (tested on Lubbock and custom PXA250 board only)
* MPC823 LCD driver: Fill color map backwards, to allow for steady
display when Linux takes over
* Patch by Erwin Rol, 27 Feb 2003:
Add support for RTEMS (this time for real).
* Add support for "bmp info" and "bmp display" commands to load
bitmap images; this can be used (for example in a "preboot"
command) to display a splash screen very quickly after poweron.
* Add support for 133 MHz clock on INCA-IP board
* Add support for Purple Board (MIPS64 5Kc)
* Add support for MIPS64 5Kc CPUs
Add IDMA example code (tested on 8260 only)
* Fix missing setting of "loadaddr" and "bootfile" on ARM and MIPS
* Patch by Denis Peter, 04 Apr 2003:
- update MIP405-4 board
* Patches by Denis Peter, 03 April 2003:
- fix PCI IRQs on MPL boards
- fix two more un-relocated pointer problems
* Fix behaviour of "run" command:
- print error message iv variable does not exist
- terminate processing of arguments in case of error
* Patches by Peter Figuli, 10 Mar 2003
- Add support for BTUART on PXA platform
- Add support for WEP EP250 (PXA) board
* Fix flash problems on INCA-IP; add tool to allow bruning images to
flash using a BDI2000
* Implement fix for I2C Edge Conditions problem for all boards that
use the bit-banging driver (common/soft_i2c.c)
* Add patches by Robert Schwebel, 31 Mar 2003:
- csb226 board: bring in sync with innokom/memsetup.S
- csb226 board: fix MDREFR handling
- misc doc fixes / extensions
- innokom board: cleanup, MDREFR fix in memsetup.S, config update
- add BOOT_PROGRESS to armlinux.c
- Add port to MPC555/556 microcontrollers
- Add support for cmi customer board with
Intel 28F128J3A, 28F320J3A or 28F640J3A flash.
* Patch by Rick Bronson, 28 Mar 2003:
- fix common/cmd_nand.c
the HSYNC/VSYNC. Requires new CPLD code (Version 101 for Rev. 100
boards, version 153 for Rev. 200 boards).
* Patch by Vladimir Gurevich, 12 Mar 2003:
Fix relocation problem of statically initialized string pointers
in common/cmd_pci.c
* Patch by Kai-Uwe Blöm, 12 Mar 2003:
Cleanup & bug fixes for JFFS2 code:
- the memory mangement was broken. It caused havoc on malloc by
writing beyond the block boundaries.
- the length calculation for files was wrong, sometimes resulting
in short file reads.
- data copying now optionally takes fragment version numbers into
account, to avoid copying from older data.
See doc/README.JFFS2 for details.
- 16/32 MB and 50/80 MHz support with auto-detection for IP860
- ETH05 and BEDBUG support for CU824
- added support for MicroSys CPC45
- new BOOTROM/FLASH0 and DOC base for PM826
* Patch by Robert Schwebel, 12 Mar 2003:
Fix the chpart command on innokom board
* Name cleanup:
mv include/asm-i386/ppcboot-i386.h include/asm-i386/u-boot-i386.h
s/PPCBoot/U-Boot/ in some files
s/pImage/uImage/ in some files
* Patch by Detlev Zundel, 15 Jan 2003:
Fix '' command line quoting
* Patch by The LEOX team, 19 Jan 2003:
- add support for the ELPT860 board
- add support for Dallas ds164x RTC
- Add support for Innokom board
- Don't complain if "install" fails
- README cleanup (remove duplicated lines)
- Update PXA header files
* Add documentation for existing POST code (doc/README.POST)
* Patch by Laudney Ren, 15 Jan 2003:
Fix handling of redundand environment in "tools/envcrc.c"
* Patch by Detlev Zundel, 28 Feb 2003:
Add bedbug support for 824x systems
* Add support for 16 MB flash configuration of TRAB board
* Add image information to README
* Fix dual PCMCIA slot support (when running with just one
slot populated)
* Add VFD type detection to trab board
* extend drivers/cs8900.c driver to synchronize ethaddr environment
variable with value in the EEPROM
Add code for AmigaOne board
(preliminary merge to U-Boot, still WIP)
* Patch by Jon Diekema, 12 Nov 2002:
- Adding URL for IEEE OUI lookup
- Making the autoboot #defines dependent on CONFIG_AUTOBOOT_KEYED
being defined.
- In the CONFIG_EXTRA_ENV_SETTINGS #define, the root-on-initrd and
root-on-nfs macros are designed to switch how the default boot
method gets defined.
Add support for i386 architecture and AMD SC520 board
* Patch by Pierre Aubert, 12 Nov 2002:
Add support for DOS filesystem and booting from DOS floppy disk
Increase number of network RX buffers (PKTBUFSRX in
"include/net.h") for EEPRO100 based boards (especially SP8240)
which showed "Receiver is not ready" errors when U-Boot was
processing the receive buffers slower than the network controller
was filling them.
* Get rid of obsolete include/mpc74xx.h
