path: root/doc
2003-12-06* Patch by Gleb Natapov, 19 Sep 2003:wdenk
Move most of the timer interrupt related PPC code to ppc_lib/interrupts.c * Patch by Anders Larsen, 17 Sep 2003: Bring ARM memory layout in sync with the documentation: stack and malloc-heap are now located _below_ the U-Boot code
2003-10-22Fix PCI problems on PPChameleon boardwdenk
2003-10-19* Patch by Steven Scholz, 18 Oct 2003:wdenk
Fix AT91RM9200 ethernet driver * Patch by Nye Liu, 17 Oct 2003: Fix typo in include/mpc8xx.h * Patch by Richard Woodruff, 16 Oct 03: Fixes for cpu/arm925/interrupt.c - Initialize timestamp & lastdec vars. - fix timestamp overflows. - fix lastdec overflow. - smarter normalization to allow udelay() below 1ms to work. * Patch by Scott McNutt, 16 Oct add networking support for the Altera Nios Development Kit, Cyclone Edition (DK-1C20) * Patch by Jon Diekema, 14 Oct 2003: add hint about doc/README.silent to README file
2003-10-10Added config option CONFIG_SILENT_CONSOLE. See doc/README.silentLABEL_2003_10_10_1200wdenk
for more information
2003-10-08* Patch by Scott McNutt, 04 Oct 2003:wdenk
- add support for Altera Nios-32 CPU - add support for Nios Cyclone Development Kit (DK-1C20) * Patch by Steven Scholz, 29 Sep 2003: - A second parameter for bootm overwrites the load address for "Standalone Application" images. - bootm sets environment variable "filesize" to the resulting (uncompressed) data length for "Standalone Application" images when autostart is set to "no". Now you can do something like if bootm $fpgadata $some_free_ram ; then fpga load 0 $some_free_ram $filesize fi * Patch by Denis Peter, 25 Sept 2003: add support for the MIP405 Rev. C board
2003-09-05* Add support for SK98xx driverLABEL_2003_09_06_0055wdenk
* Add PCI support for SL8245 board * Support IceCube board configurations with 1 x AMD AM29LV065 (8 MB) or 1 x AM29LV652 (two LV065 in one chip = 16 MB); Run IPB at 133 Mhz; adjust the MII clock frequency accordingly * Set BRG_CLK on PM825/826 to 64MHz (VCO_OUT / 4, instead of 16 MHz) to allow for more accurate baudrate settings (error now 0.7% at 115 kbps, instead of 3.5% before) * Patch by Andreas Mohr, 4 Sep 2003: Fix a lot of spelling errors
2003-08-17* Make Ethernet autonegotiation on INCA-IP work for all clock rates;U-Boot-0_4_6wdenk
allow selection of clock frequency as "make" target * Implement memory autosizing code for IceCube boards * Configure network port on INCA-IP for autonegotiation * Fix overflow problem in network timeout code * Patch by Richard Woodruff, 8 Aug 2003: Allow crc32 to be used at address 0x000 (crc32_no_comp, too).
2003-07-27* Patch by Scott McNutt, 21 Jul 2003:wdenk
Add support for LynuxWorks Kernel Downloadable Images (KDIs). Both LynxOS and BlueCat linux KDIs are supported. * Patch by Richard Woodruff, 25 Jul 2003: use more reliable reset for OMAP/925T * Patch by Nye Liu, 25 Jul 2003: fix typo in mpc8xx.h * Patch by Richard Woodruff, 24 Jul 2003: Fixes for cmd_nand.c: - Fixed null dereferece which could result in incorrect ECC values. - Added support for devices with no Ready/Busy signal hooked up. - Added OMAP1510 read/write protect handling. - Fixed nand.h's ECCPOS. A conflict existed with POS5 and badblock for non-JFFS2. - Switched default ECC to be JFFS2.
2003-07-26* Allow crc32 to be used at address 0x000wdenk
* Provide consistent interface to standalone applications to access the 'global_data' structure Provide a doc/README.standalone more useful to users/developers. * Make IceCube MGT5100 FEC driver work
2003-07-24* Implement new mechanism to export U-Boot's functions to standalonewdenk
applications: instead of using (PPC-specific) system calls we now use a jump table; please see doc/README.standalone for details * Patch by Dave Westwood, 24 Jul 2003: added support for Unity OS (a proprietary OS)
2003-07-16Incorporate Patch by Lutz Dennig, 15 Jul 2003.wdenk
2003-07-14* Patches by Yuli Barcohen, 13 Jul 2003:wdenk
- Correct flash and JFFS2 support for MPC8260ADS - fix PVR values and clock generation for PowerQUICC II family (8270/8275/8280) * Patch by Bernhard Kuhn, 08 Jul 2003: - add support for M68K targets * Patch by Ken Chou, 3 Jul: - Fix PCI config table for A3000 - Fix iobase for natsemi.c (PCI_BASE_ADDRESS_0 is the IO base register for DP83815) * Allow to enable "slow" POST routines by key press on power-on * Fix temperature dependend switching of LCD backlight on LWMON * Tweak output format for LWMON
2003-07-01Patch by Kenneth Johansson, 30 Jun 2003:wdenk
2003-05-31* Patch by Marc Singer, 29 May 2003:LABEL_2003_05_31_2115wdenk
Fixed rarp boot method for IA32 and other little-endian CPUs. * Patch by Marc Singer, 28 May 2003: Added port I/O commands. * Patch by Matthew McClintock, 28 May 2003 - cpu/mpc824x/start.S: fix relocation code when booting from RAM - minor patches for utx8245 * Patch by Daniel Engström, 28 May 2003: x86 update * Patch by Dave Ellis, 9 May 2003 + 27 May 2003: add nand flash support to SXNI855T configuration fix/extend nand flash support: - fix 'nand erase' command so does not erase bad blocks - fix 'nand write' command so does not write to bad blocks - fix nand_probe() so handles no flash detected properly - add doc/README.nand - add .jffs2 and .oob options to nand read/write - add 'nand bad' command to list bad blocks - add 'clean' option to 'nand erase' to write JFFS2 clean markers - make NAND read/write faster * Patch by Rune Torgersen, 23 May 2003: Update for MPC8266ADS board
2003-05-20* Patch by David Updegraff, 22 Apr 2003:LABEL_2003_05_20_1630wdenk
update for CrayL1 board * Patch by Pantelis Antoniou, 21 Apr 2003: add boot support for ARTOS (a proprietary OS) * Patch by Steven Scholz, 11 Apr 2003: Add support for RTC DS1338 * Patch by Rod Boyce, 24 Jan 2003: Fix counting of extended partitions in diskboot command
2003-05-12Patch by Mathijs Haarman, 08 May 2003:LABEL_2003_05_12_2355wdenk
Add lan91c96 driver (tested on Lubbock and custom PXA250 board only)
2003-05-12Add default switch settings.wdenk
2003-04-20* Make sure Block Lock Bits get cleared in R360MPI flash driverwdenk
* MPC823 LCD driver: Fill color map backwards, to allow for steady display when Linux takes over * Patch by Erwin Rol, 27 Feb 2003: Add support for RTEMS (this time for real). * Add support for "bmp info" and "bmp display" commands to load bitmap images; this can be used (for example in a "preboot" command) to display a splash screen very quickly after poweron. * Add support for 133 MHz clock on INCA-IP board
2003-04-08Prepare for 0.3.0 releaseU-Boot-0_3_0wdenk
* Add support for Purple Board (MIPS64 5Kc) * Add support for MIPS64 5Kc CPUs
2003-04-05* Patch by Arun Dharankar, 4 Apr 2003:LABEL_2003_04_05_0300wdenk
Add IDMA example code (tested on 8260 only) * Add support for Purple Board (MIPS64 5Kc) * Add support for MIPS64 5Kc CPUs * Fix missing setting of "loadaddr" and "bootfile" on ARM and MIPS * Patch by Denis Peter, 04 Apr 2003: - update MIP405-4 board * Patches by Denis Peter, 03 April 2003: - fix PCI IRQs on MPL boards - fix two more un-relocated pointer problems * Fix behaviour of "run" command: - print error message iv variable does not exist - terminate processing of arguments in case of error * Patches by Peter Figuli, 10 Mar 2003 - Add support for BTUART on PXA platform - Add support for WEP EP250 (PXA) board * Fix flash problems on INCA-IP; add tool to allow bruning images to flash using a BDI2000 * Implement fix for I2C Edge Conditions problem for all boards that use the bit-banging driver (common/soft_i2c.c) * Add patches by Robert Schwebel, 31 Mar 2003: - csb226 board: bring in sync with innokom/memsetup.S - csb226 board: fix MDREFR handling - misc doc fixes / extensions - innokom board: cleanup, MDREFR fix in memsetup.S, config update - add BOOT_PROGRESS to armlinux.c
2003-03-31* Patch by Martin Winistoerfer, 23 Mar 2003wdenk
- Add port to MPC555/556 microcontrollers - Add support for cmi customer board with Intel 28F128J3A, 28F320J3A or 28F640J3A flash. * Patch by Rick Bronson, 28 Mar 2003: - fix common/cmd_nand.c
2003-03-14* Avoid flicker on the TRAB's VFD by synchronizing the enable withwdenk
the HSYNC/VSYNC. Requires new CPLD code (Version 101 for Rev. 100 boards, version 153 for Rev. 200 boards). * Patch by Vladimir Gurevich, 12 Mar 2003: Fix relocation problem of statically initialized string pointers in common/cmd_pci.c * Patch by Kai-Uwe Blöm, 12 Mar 2003: Cleanup & bug fixes for JFFS2 code: - the memory mangement was broken. It caused havoc on malloc by writing beyond the block boundaries. - the length calculation for files was wrong, sometimes resulting in short file reads. - data copying now optionally takes fragment version numbers into account, to avoid copying from older data. See doc/README.JFFS2 for details.
2003-03-06* Patch by Robert Schwebel, 21 Jan 2003:LABEL_2003_03_06_0050wdenk
- Add support for Innokom board - Don't complain if "install" fails - README cleanup (remove duplicated lines) - Update PXA header files * Add documentation for existing POST code (doc/README.POST) * Patch by Laudney Ren, 15 Jan 2003: Fix handling of redundand environment in "tools/envcrc.c" * Patch by Detlev Zundel, 28 Feb 2003: Add bedbug support for 824x systems * Add support for 16 MB flash configuration of TRAB board * Patch by Erwin Rol, 27 Feb 2003: Add support for RTEMS * Add image information to README * Fix dual PCMCIA slot support (when running with just one slot populated) * Add VFD type detection to trab board * extend drivers/cs8900.c driver to synchronize ethaddr environment variable with value in the EEPROM
2002-11-18* Patch by Daniel Engström, 13 Nov 2002:LABEL_2002_11_18_0115wdenk
Add support for i386 architecture and AMD SC520 board * Patch by Pierre Aubert, 12 Nov 2002: Add support for DOS filesystem and booting from DOS floppy disk
2002-11-11* Patch by Jim Sandoz, 07 Nov 2002:LABEL_2002_11_11_2211wdenk
Increase number of network RX buffers (PKTBUFSRX in "include/net.h") for EEPRO100 based boards (especially SP8240) which showed "Receiver is not ready" errors when U-Boot was processing the receive buffers slower than the network controller was filling them. * Get rid of obsolete include/mpc74xx.h
2002-09-18Initial revisionwdenk
2002-03-08Initial revisionwdenk
2001-12-27Initial revisionwdenk
