Merge TI U-Boot RC Release 08.06.00.007
This adds initial support for the Toradex Verdin AM62 Quad 1GB WB IT
V1.0A module. They are strapped to boot from their on-module eMMC.
U-Boot supports booting from the on-module eMMC, or, via separate
verdin-am62_r5_usbdfu_defconfig from USB DFU based recovery mode.
Upstream-Status: Pending
Initial U-Boot to be used for bring-up and validation of the V1.0
design, we'll decide on the step forward to mainline this once the
bring-up and validation will be done.
Drop Apalis iMX8X platform as it never left sample state and is no
longer supported.
Upstream-Status: Backport [47bcc0d056aa243a31d2a1edb44bdcd155f5335b]
Signed-off-by: Denys Drozdov <denys.drozdov@toradex.com>
Adds DT binding documentation for the TI Error Location Module.
This is picked up from the Linux Kernel.
commit 8993d5f2ac02 ("dt-bindings: mtd: Add ti, elm DT binding documentation") upstream
Signed-off-by: Roger Quadros <rogerq@kernel.org>
Signed-off-by: Michael Trimarchi <michael@amarulasolutions.com>
Signed-off-by: Dario Binacchi <dario.binacchi@amarulasolutions.com>
Link: https://lore.kernel.org/all/20221220102203.52398-8-rogerq@kernel.org
Upstream commit 69076dff2284ed099cc0583e5e64bd8012d1ab5c
This adds support for specifying FDT overlays in an extlinux/pxelinux
configuration file.
Without this, there is no simple way to apply overlays when the kernel
and fdt is loaded by the pxe command.
This change adds the 'fdtoverlays' keyword for a label, supporting multiple
overlay files to be applied on top of the fdt specified in the 'fdt' or
'devicetree' keyword.
Example:
label linux
kernel /Image
fdt /soc-board.dtb
fdtoverlays /soc-board-function.dtbo
append console=ttyS0,115200 root=/dev/mmcblk0p2 rootwait
This code makes usage of a new variable called fdtoverlay_addr_r used to load
the overlay files without overwritting anything important.
Cc: Jernej Å krabec <jernej.skrabec@siol.net>
Cc: Jonas Karlman <jonas@kwiboo.se>
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
Link: https://lists.denx.de/pipermail/u-boot/2019-May/368388.html
[robertcnelson@gmail.com: Backport to TI u-boot]
Signed-off-by: Robert Nelson <robertcnelson@gmail.com>
Signed-off-by: Nishanth Menon <nm@ti.com>
commit 7b8a96e57e1db60f742184822a7d8dc508605f1f upstream
Add DT binding documentation for enabling ECC in the DDR sub system present
on AM64 device.
Signed-off-by: Dave Gerlach <d-gerlach@ti.com>
[g-vlaev@ti.com: backport from upstream]
Signed-off-by: Georgi Vlaev <g-vlaev@ti.com>
The TI K3 J721S2 SoCs have two TM320C71x DSP susbsystems, and does not
have any TMS320C66x DSP subsystems. The C71x DSP subsystems in J721S2
SoCs are similar to the C71x DSP on J721E with some minor core IP
updates.
Compatible info is updated for intuitively matching to the new J721S2
SoCs.
Signed-off-by: Hari Nagalla <hnagalla@ti.com>
The TI K3 J721S2 SoCs have three dual-core Arm R5F clusters/subsystems.
One in MCU voltage domain and the other two in MAIN voltage domain.
These clusters are similar to J7200 R5F clusters. Compatible info is
updated for intuitively matching to the new J721S2 SoCs.
If there is an optional boot notification channel that an SoC uses
separate from the rx path, use the same.
Add DM firmware node which will provide DM services during R5 SPL stage.
Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com>
On J721e and J7200, MCU R5 core (boot master) itself would run Device
Manager (DM) Firmware and interact with TI Foundational Security (TIFS)
firmware to enable DMA and such other Resource Management (RM) services.
So, during R5 SPL stage there is no such RM service available and ti_sci
driver will have to directly interact with TIFS using DM to DMSC
channels to request RM resources.
Therefore add DT binding and driver for the same. This driver will
handle Resource Management services at R5 SPL stage.
Introduce support for the AM64 DDRSS controller through a common driver
for both am64 and j721e. This controller shares much functionality with
the existing J721e support, so this patch refactors the driver such that
the am64 specific comes from "_16bit_" files with headers uner "16bit/"
include path, and j721e support comes from "_32bit_" files with headers
under the "32bit/" include path.
Also add a CONFIG_K3_AM64_DDRSS option to the choice required for use
with CONFIG_K3_DDRSS to allow selecting AM64 support.
commit 468ec2f3ef8fb4e08c01e6d92a530d3632ca6df5 upstream.
The K3 R5F remoteproc driver in U-Boot was upstreamed prior to the
equivalent remoteproc driver in the Linux kernel. Some of the DT
properties used in U-Boot got upstreamed using different names
in Linux kernel.
The modified property names include the R5F cluster mode configuration
property "lockstep-mode"; and three different individual R5F core config
properties - "atcm-enable", "btcm-enable" and "loczrama". The property
names were updated as follows:
lockstep-mode => ti,cluster-mode
atcm-enable => ti,atcm-enable
btcm-enable => ti,btcm-enable
loczrama => ti,loczrama
Update the K3 R5F remoteproc driver, the corresponding binding, and
all the existing usage in AM65x, J721E and J7200 dts files all at
once to use the new properties and to not break any bisectability.
Signed-off-by: Suman Anna <s-anna@ti.com>
[s-anna@ti.com: cherry-pick commit '468ec2f3ef8f' from v2021.04-rc2]
make htmldocs results in an error:
doc/android/boot-image.rst:33:
WARNING: Unparseable C cross-reference: 'struct andr_img_hdr'
Invalid C declaration: Expected identifier in nested name, got keyword:
struct [error at 6]
Follow the style prescribed in
https://www.kernel.org/doc/html/latest/doc-guide/kernel-doc.html#highlights-and-cross-references
Add missing definite article.
xFSTK sources got a new home under Edison Firmware Group on GitHub [1].
Update Intel Edison documentation accordingly.
While here, fix couple of typos.
[1]: https://github.com/edison-fw
Acked-by: Bin Meng <bmeng.cn@gmail.com>
https://gitlab.denx.de/u-boot/custodians/u-boot-efi
Pull request for UEFI sub-system for efi-2021-01-rc4
* Provide a tool to create a file with UEFI variables to preseed UEFI
variable store.
* Make size of UEFI variable store configurable.
* Add man pages for commands 'bootefi' and 'button'.
Provide a description of the bootefi command.
Provide a description of the 'button' command.
This documentation has been taken from Linux commit 3d7db0f11c7a ("spi: dw:
Refactor mid_spi_dma_setup() to separate DMA and IRQ config"), immediately
before the file was deleted and replaced with a yaml version. Additional
compatible strings from newer versions have been added, as well as a few
U-Boot-specific ones.
Signed-off-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
u_boot should be u-boot
Use the same formatting for all bash commands.
Convert README.bootmenu to reStructured text and move it to
usage/bootmenu.rst.
Adjust the text concerning configuration settings as these now are managed
via Kconfig.
Reviewed-by: Pali Rohár <pali@kernel.org>
Convert README.trace to reStructured text and move it to develop/trace.rst.
Convert README.NetConsole to reStructured text and move it to
doc/usage/netconsole.rst.
Use syntax highlighting for a Linux console session.
Let's have a separate chapter dedicated to using U-Boot.
Reformat README.commands as reStructured text and add it to the HTML
documentation as develop/commands.rst.
Due to removed function c_funcptr_sig_re building with Sphinx 3 fails.
With the patch building succeeds with a lot of warnings if the '-W' flag is
removed from doc/Makefile. Most of the documentation is correct
This follows the approach taken by the Linux kernel.
On x86 the global data pointer is stored in register fs.
On x86_64 no register is used for the global data pointer.
Describe the packages required to build U-Boot on SUSE.
Use the full name of firmware self extracting file to make it run.
Also, don't use sudo when not needed.
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
Convert README to reStructuredText format.
Signed-off-by: Oliver Graute <oliver.graute@kococonnector.com>
This reverts commit f1a43c84a960265309fa8365759de271a70c5a7e.
This documents the u-boot build and deployment procedure.
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
This patch adds support for optional vbus regulator.
It is managed on phy_power_on/off calls and may be needed for host mode.
Reviewed-by: Patrice Chotard <patrice.chotard@st.com>
This renames power domains to match the names on the k210 datasheet.
Reported-by: Damien Le Moal <Damien.LeMoal@wdc.com>
Reviewed-by: Rick Chen <rick@andestech.com>
How to add an emulated disk to QEMU may not be known to the user.
Reviewed-by: Bin Meng <bin.meng@windriver.com>
patman status subcommand to collect tags from Patchwork
patman showing email replies from Patchwork
sandbox poweroff command
minor fixes in binman, tests
https://gitlab.denx.de/u-boot/custodians/u-boot-amlogic
- meson64_android: don't show logo on ROM USB boot
- doc: update support matrix and fix vim3/l build instructions
- meson64: relocate config_distro_bootcmmd header
- Add a new SMBIOS parser and enable it when booting from coreboot
- Fix up various driver names to avoid dtoc warnings
- Fully enable ACPI support on Google Chromebook Coral
- Add a way to set SMBIOS properties using the devicetree
- Update existing boards to use devicetree for SMBIOS using a new
default sysinfo driver
Add information about how to set SMBIOS properties using the devicetree.
Add a simple binding file for this, so that it is clear what this binding
directory is for.
This uclass is intended to provide a way to obtain information about a
U-Boot board. But the concept of a U-Boot 'board' is the whole system,
not just one circuit board, meaning that 'board' is something of a
misnomer for this uclass.
In addition, the name 'board' is a bit overused in U-Boot and we want to
use the same uclass to provide SMBIOS information.
The obvious name is 'system' but that is so vague as to be meaningless.
Use 'sysinfo' instead, since this uclass is aimed at providing information
on the system.
Rename everything accordingly.
Note: Due to the patch delta caused by the symbol renames, this patch
shows some renamed files as being deleted in one place and created in
another.
Add sandbox API to generated HTML documentation
The build instructions were buggy and changed a little since they
were written.
Update the matrix table with new supported features and
new SoC features to support.
Convert plain text documentation to reStructuredText format and add
it to Sphinx TOC tree. No essential content change.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
