path: root/doc
2018-05-11Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
2018-05-10SPDX: Convert a few files that were missed beforeTom Rini
As part of the main conversion a few files were missed. These files had additional whitespace after the '*' and before the SPDX tag and my previous regex was too strict. This time I did a grep for all SPDX tags and then filtered out anything that matched the correct styles. Fixes: 83d290c56fab ("SPDX: Convert all of our single license tags to Linux Kernel style") Reported-by: Heinrich Schuchardt <xypron.debian@gmx.de> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-05-09armv8: sec_firmware: Add support for multiple loadablesSumit Garg
Enable support for multiple loadable images in SEC firmware FIT image. Also add example "sec_firmware_ppa.its" file. Signed-off-by: Sumit Garg <sumit.garg@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-05-08power: regulator: Add support for stm32-vrefbufFabrice Gasnier
Add regulator driver for STM32 voltage reference buffer which can be used as voltage reference for ADCs, DACs and external components through dedicated VREF+ pin. Signed-off-by: Fabrice Gasnier <fabrice.gasnier@st.com> Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-05-07git-mailrc: Update some addresses and aliasesTom Rini
- Based on commit 08ae21af9671 ("MAINTAINERS: Switch nxp.com domain") update or drop some formerly Freescale addresses. - Update a few aliases to reflect current custodians Signed-off-by: Tom Rini <trini@konsulko.com>
2018-05-02doc: rmobile: Update the READMEMarek Vasut
Synchronize the README with the current state of U-Boot, unify the build instructions to avoid duplication. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-04-28distro: use imply to enable DISTRO_DEFAULTS as SoC defaultMasahiro Yamada
The default of DISTRO_DEFAULTS is messy. Using the 'imply' keyword is equivalent and cleaner. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-04-27clang: Update documentationTom Rini
As of clang-5.0, things have changed a bit. First, we cannot automatically guess -target values as if we do not pass one with CC then cc-option will fail. Second, to disable movt/movw relocations the argument has become -mno-movt. Related to the target part, we cannot use arm-none-eabi as that ends up being too generic of an ARM target for things like say rpi_3_32b to work. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-23efi_loader: no support for ARMV7_NONSEC=yHeinrich Schuchardt
We do not support bootefi booting ARMv7 in non-secure mode. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-04-16doc: Update git-mailrc entry for lukma (lukma@denx.de)Lukasz Majewski
Signed-off-by: Lukasz Majewski <lukma@denx.de>
2018-04-16x86: Rename coreboot-x86 to corebootSimon Glass
We only use coreboot as a target on x86 platforms, since on ARM platforms U-Boot always runs as the primary boot loader. Rename the coreboot-x86 platform to reflect this. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2018-04-16doc: vxworks: Update x86 specific instructionsBin Meng
This updates the doc of booting VxWorks, like loading an x64 kernel, and how to make VxWorks graphics console driver work. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2018-04-16bootvx: x86: Prepare e820 related stuff from the given kernel memory base ↵Bin Meng
address At present two environment variables 'e820data'/'e820info' are required to boot a VxWorks x86 kernel, but this is superfluous. The offset of these two tables are actually at a fixed offset from the kernel memory base address and we can provide the kernel memory base address to U-Boot via only one variable 'vx_phys_mem_base'. Note as it name indicates, the physical address should be provided. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2018-04-16doc: vxworks: Minor update for clarityBin Meng
This corrects a typo and updates several places for clarity. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2018-04-15Merge git://git.denx.de/u-boot-imxTom Rini
2018-04-15tools/imximage: use 0x prefix in HAB Blocks lineRasmus Villemoes
The u-boot-ivt.img.log file contains 0x prefixes in the HAB Blocks line, while the SPL.log does not. For consistency, and to make it easier to extract and put into a .csf file for use with NXP's code signing tool, add 0x prefixes here. Signed-off-by: Rasmus Villemoes <rasmus.villemoes@prevas.dk> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Tested-by: Breno Lima <breno.lima@nxp.com>
2018-04-11Merge git://git.denx.de/u-boot-i2cTom Rini
2018-04-11dm: i2c: dts: Add gpios and pinctrl device tree propertiesAlexander Kochetkov
The commit describe usage of gpios and pinctrl device tree properties in order to enable gpio-based software deblocking. Signed-off-by: Alexander Kochetkov <al.kochet@gmail.com>
2018-04-10log: Add units to code-size stats in README.logSimon Glass
Without the units these numbers are confusing. Add a comment about the unit being 'bytes' and mention 'buildman' as the source. Suggested-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2018-04-04git: mailrc: Add myself and efi to listAlexander Graf
I wasn't listed in the mailrc before, let's fix that. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-04-04efi_loader: provide new doc/README.uefiHeinrich Schuchardt
Provides information about - usage of the bootefi command - overview of UEFI - interaction between U-Boot and EFI drivers Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Leif Lindholm <leif.lindholm@linaro.org> Acked-by: Leif Lindholm <leif.lindholm@linaro.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-04-04efi_loader: delete doc/README.efiHeinrich Schuchardt
Delete README.efi. It is replaced by a further patch. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-03-30Merge git://git.denx.de/u-boot-marvellTom Rini
2018-03-30doc: a37xx: Introduce pinctrl device tree bindingKen Ma
Reviewed-on: http://vgitil04.il.marvell.com:8080/43289 Tested-by: iSoC Platform CI <ykjenk@marvell.com> Reviewed-by: Kostya Porotchkin <kostap@marvell.com> Reviewed-by: Igal Liberman <igall@marvell.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Ken Ma <make@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de>
2018-03-30doc: ae250: Describe riscv-linux booting via u-bootRick Chen
Simply record riscv-linux booting steps and messages from bbl via u-boot on QEMU in README.ae250. Signed-off-by: Rick Chen <rick@andestech.com> Signed-off-by: Rick Chen <rickchen36@gmail.com>
2018-03-19clk: stm32mp1: add clock tree initializationPatrick Delaunay
add binding and code for clock tree initialization from device tree Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2018-03-19ram: stm32mp1: add driverPatrick Delaunay
Add driver and binding for stm32mp1 ddr controller and phy Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2018-03-16post: remove reference to power functionsPatrick Delaunay
The 2 functions board_power_mode and board_poweroff are no more existing in U-Boot code (check with grep) This patch updates the documentation and removes the unnecessary prototypes. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2018-03-16dm: MIGRATION: Add migration plan for DM_SPI & DM_SPI_FLASHJagan Teki
Due to adding various new functionalities with SPI and SPI-FLASH subsystems which are rounding in Mailing list for year these long term supporting spi driver which never seen any update with driver-model conversion. So added migration plan for DM_SPI and DM_SPI_FLASH with deadline v2018.09 Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2018-03-11doc: mxc_hab: Update i.MX HAB documentationBreno Lima
The README.mxc_hab is outdated and need improvements, add the following modifications: - Reorganize document and remove duplicate content - Add CST download link - Update CST package name - Align command lines with CST v2.3.3 - Update U-Boot binary name - Remove CSF padding since is not documented in AN4581 Signed-off-by: Breno Lima <breno.lima@nxp.com>
2018-03-11doc: mxc_hab: Move HAB related info to the appropriate docBreno Lima
Currently the High Assurance Boot procedure is documented in two places: - doc/README.imx6 - doc/README.mxc_hab It is better to consolidate all HAB related information into README.mxc_hab file, so move the content from README.imx6 to README.mxc_hab. Signed-off-by: Breno Lima <breno.lima@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2018-02-23Remove config_distro_defaults.hAdam Ford
With the contents of config_distro_defaults.h migrated to Kconfig, we can remove this header file completely Signed-off-by: Adam Ford <aford173@gmail.com>
2018-02-10efi_loader: split README.efi into two separate documentsHeinrich Schuchardt
README.efi describes two different concepts: * U-Boot exposing the UEFI API * U-Boot running on top of UEFI. This patch splits the document in two. Religious references are removed. The separation of the concepts makes sense before detailing the internals of U-Boot exposing the UEFI API in a future patch. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-02-07doc: watchdog: Remove Blackfin related documentation entryLukasz Majewski
This commit cleans up the README.watchdog by removing the reminescent of ADI's Blackfin architecture removed some time ago. Signed-off-by: Lukasz Majewski <lukma@denx.de>
2018-02-04Merge git://git.denx.de/u-boot-dmTom Rini
2018-02-04doc: mxc_hab: Improve the config option listFabio Estevam
The original text is from the time that the config options were not converted to Kconfig. After the conversion to Kconfig only CONFIG_SECURE_BOOT and CONFIG_CMD_DEKBLOB need to be selected by the user. The other config options are automatically selected by the Kconfig logic. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Breno Lima <breno.lima@nxp.com>
2018-02-03log: add category LOGC_EFIHeinrich Schuchardt
The EFI implementation does not fit into any of the existing categories. Provide LOGC_EFI so that EFI related message can be filtered. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-02-03log: Add a way to log error-return valuesSimon Glass
When functions return an error it propagates up the stack to the point where it is reported. Often the error code provides enough information about the root cause of the error that this is obvious what went wrong. However in some cases the error may be hard to trace. For example if a driver uses several devices to perform an operation, it may not be obvious which one failed. Add a log_ret() macro to help with this. This can be used to wrap any error-return value. The logging system will then output a log record when the original error is generated, making it easy to trace the call stack of the error. This macro can significantly impact code size, so its use is controlled by a Kconfig option, which is enabled for sandbox. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-02-03log: Add documentation for commands and formattingSimon Glass
Add some notes about recent new features. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-01-31Merge tag 'xilinx-for-v2018.03' of git://git.denx.de/u-boot-microblazeTom Rini
Xilinx changes for v2018.03 - Several Kconfig fixes (also moving configs to defconfigs) - Some DTS updates - ZynqMP psu rework based on Zynq concept - Add low level initialization for zc770 and zcu102 - Add support for Zynq zc770 x16 nand configuration - Add mini nand/emmc ZynqMP targets - Some arasan nand changes
2018-01-30doc: zynq: Describe status of zc770-xm011Michal Simek
zc770-xm011 is also added and supported. Reflect this in README. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-01-28efi_loader: add a README.iscsi describing booting via iSCSIHeinrich Schuchardt
The appended README explains how U-Boot and iPXE can be used to boot a diskless system from an iSCSI SAN. The maintainer for README.efi and README.iscsi is set. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> [agraf: s/Adress/Address/] Signed-off-by: Alexander Graf <agraf@suse.de>
2018-01-26Merge git://git.denx.de/u-boot-spiTom Rini
2018-01-24doc: Update the zynq u-boot statusEzequiel Garcia
NAND and QSPI devices are now supported, so mark them as such. Cc: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Ezequiel Garcia <ezequiel@vanguardiasur.com.ar> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-01-24dts: cadence_spi: Update documentation for DT bindingsJason Rush
Update documentation to reflect adopting the Linux DT bindings. Tested on TI K2G platform: Tested-by: Vignesh R <vigneshr@ti.com> Tested on a socfpga-cyclonev board: Tested-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com> Signed-off-by: Jason Rush <jarush@gmail.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Acked-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com> Acked-by: Marek Vasut <marex@denx.de>
2018-01-22fs: Migrate ext4 to KconfigTuomas Tynkkynen
Migrate the following symbols to Kconfig: CONFIG_FS_EXT4 CONFIG_EXT4_WRITE The definitions in config_fallbacks.h can now be expressed in Kconfig. Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2018-01-19m68k: Drop unreferenced CONFIG_* definesTuomas Tynkkynen
The following config symbols are only defined once and never referenced anywhere else: CONFIG_AMCORE CONFIG_ASTRO5373L CONFIG_M52277EVB CONFIG_M5253DEMO CONFIG_M5253EVBE CONFIG_M5275EVB CONFIG_M54418TWR CONFIG_STMARK2 Most of them are config symbols named after the respective boards which seems to have been a standard practice at some point. Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2018-01-19ARM: Document AArch64 version of qemu-armTuomas Tynkkynen
It's mostly obvious, except that QEMU is annoying and requires an explicit '-cpu cortex-a57' (or some other 64-bit core) to actually run in 64-bit mode. While at it, remove the references to setting the ARCH environment variable; that is not used in U-Boot. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-01-15doc: fix incorrect usage of DT node unit addressAndre Przywara
The DT spec demands a unit-address in a node name to match the "reg" property in that node. Newer dtc versions will throw warnings if this is not the case. Fix all occurences in various documentation files where this was not observed, to not give bad examples to the reader. Signed-off-by: Andre Przywara <andre.przywara@arm.com>
