Add a sample .its file for booting U-Boot on a nyan-big Chromebook.
Send patch to Kever Yang instead of Lin Huang for Rockchip patches,
for Lin is not always working on upstream U-Boot.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
Changed , to : in subject:
At present lpe/lpss-sio/scc FSP properties are all boolean, but in
fact for "enable-lpe" it has 3 possible options. This adds macros
for these options and change the property from a boolean type to
an integer type, and change their names to explicitly indicate what
the property is really for.
Introduce various meaningful macros for FSP settings and switch over
to use them instead of magic numbers.
"serial-debug-port-address" and "serial-debug-port-type" settings
are actually reserved in the FSP UPD data structure. Remove them.
Adding documentation on the new config properties:
'u-boot,mmc-env-offset' - overrides CONFIG_ENV_OFFSET
'u-boot,mmc-env-offset-redundant'
- overrides CONFIG_ENV_OFFSET_REDUND
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
trini: Make Kconfig SPL_xxx entires only show if SPL, so that we don't
get Kconfig errors on platforms without SPL, ie sandbox (without SPL).
Rather than using CMD_JFFS2 for both the filesystem and its command, we
should have a separate option for each. This allows us to enable JFFS2
support without the command, if desired, which reduces U-Boot's size
slightly.
So far we were not using the FIT image format to its full potential:
The SPL FIT loader was just loading the first image from the /images
node plus one of the listed DTBs.
Now with the refactored loader code it's easy to load an arbitrary
number of images in addition to the two mentioned above.
As described in the FIT image source file format description, iterate
over all images listed at the "loadables" property in the configuration
node and load every image at its desired location.
This allows to load any kind of images:
- firmware images to execute before U-Boot proper (for instance
ARM Trusted Firmware (ATF))
- firmware images for management processors (SCP, arisc, ...)
- firmware images for devices like WiFi controllers
- bit files for FPGAs
- additional configuration data
- kernels and/or ramdisks
The actual usage of this feature would be platform and/or board specific.
Also update the FIT documentation to mention the new SPL feature and
provide an example .its file to demonstrate its features.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Reviewed-by: Lokesh Vutla <lokeshvuta@ti.com>
Tested-by: Heiko Stuebner <heiko@sntech.de>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
Tested-by: Kever Yang <kever.yang@rock-chips.com>
Tested-by: Jagan Teki <jagan@openedev.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
Now that we have ACPI S3 support on Intel MinnowMax board, document
some generic information of S3 and how to test it.
Tested-by: Stefan Roese <sr@denx.de>
While in theory this value could be used in places outside of "omap5"
(such as OMAP4), we only make use of it today in OMAP5, so place the
Kconfig entry there. Given that Kconfig lets us provide a default, we
drop CONFIG_DEFAULT_OMAP_RESET_TIME_MAX_USEC entirely. The contents of
doc/README.omap-reset-time make a good help entry, so adjust them
slightly and delete the file. Move the comment about range to where we
use the value now, and have Kconfig enforce the upper bound.
This adds documentation on the u-boot,spl-payload-offset property
(which overrides CONFIG_SYS_SPI_U_BOOT_OFFS during the SPI loading in
the SPL stage, if present).
This adds a new firefly-rk3399 board, MIPI support for rk3399 and
rk3288, rk818 pmic support, mkimage improvements for rockchip and a few
other things.
This is a copy from kernel.
This driver is a simplified version of linux/drivers/leds/leds-bcm6358.c
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com>
This driver is a simplified version of linux/drivers/leds/leds-bcm6328.c,
simplified to remove HW leds and blink fallbacks.
In some boards like the Raspberry Pi the initial bootloader will pass
a DT to the kernel. When using U-Boot as such kernel, the board code in
U-Boot should be able to provide U-Boot with this, already assembled
device tree blob.
This patch introduces a new config option CONFIG_OF_BOARD to use instead
of CONFIG_OF_EMBED or CONFIG_OF_SEPARATE which will initialize the DT
from a board-specific funtion instead of bundling one with U-Boot or as
a separated file. This allows boards like the Raspberry Pi to reuse the
device tree passed from the bootcode.bin and start.elf firmware
files, including the run-time selected device tree overlays.
Signed-off-by: Alex Deymo <deymo@google.com>
Also added DT binding doc for stm32 fmc(flexible memory controller).
Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
cc: Christophe KERELLO <christophe.kerello@st.com>
DT binding documentation for atmel HLCDC driver.
Signed-off-by: Songjun Wu <songjun.wu@microchip.com>
This patch adds the steps to manually (re)build a Quartus FPGA project,
generate the required BSP glue, and update u-boot handoff files for
mainline SPL support. Requires Quartus toolchain and current U-Boot.
Signed-off-by: Steve Arnold <stephen.arnold42@gmail.com>
Cc: Dinh Nguyen <dinguyen@kernel.org>
Cc: Stefan Roese <sr@denx.de>
Drop CONFIG_STACKSIZE from include/configs/imx6_logic.h
This allows us to use the same DRAM init function on all archs. Add a
dummy function for arc, which does not use DRAM init here.
[trini: Dummy function on nios2]
Add a section describing the secure boot image used on
Keystone2 secure devices.
Signed-off-by: Madan Srinivas <madans@ti.com>
Signed-off-by: Andrew F. Davis <afd@ti.com>
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
The board is now manufactured by Aries Embedded GmbH , rename it.
MiQi is rk3288 based development board with 1 or 2 GB SDRAM, 16 GB eMMC,
micro SD card interface, 4 USB 2.0 ports, HDMI, gigabit Ethernet and
expansion ports.
Signed-off-by: Jernej Skrabec <jernej.skrabec@siol.net>
Reviewed-by: Eddie Cai <eddie.cai.linux@gmail.com>
Sort rk3288 boards in alphabetical order.
The RK3399 does not have any boot selection pins and the BootROM probes
the boot interfaces using the following boot-order:
1. SPI
2. eMMC (sdhci in DTS)
3. SD card (sdmmc in DTS)
4. USB loader
For ease of deployment, the SPL stage should mirror the boot order of
the ROM and use the same probing order (assuming that valid images can
be detected by SPL) unless instructed otherwise. The boot-order can
then be configured via the 'u-boot,spl-boot-order' property in the
chosen-node of the DTS.
While this approach is easily extensible to other boards, it is only
implemented for the RK3399 for now, as the large SRAM on the RK3399
makes this easy to fit the needed infrastructure into SPL and our
production setup already runs with DM, OF_CONTROL and BLK in SPL.
The new boot-order property is expected to be used in conjunction with
FIT images (and all legacy image formats disabled via Kconfig).
A boot-sequence with probing and fallthroughs from SPI via eMMC to SD
card (i.e. &spiflash, &sdhci, &sdmmc) has been validated on the RK3399-Q7.
Tested-by: Klaus Goger <klaus.goger@theobroma-systems.com>
Tested-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Building sd images for rk3188 requires more steps due to the needed split
into TPL and SPL as loaders. Describe how to build an image for it in a
separate paragraph in the READER.rockchip file.
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
This patch adds support for having a "fixed-link" to some other MAC
(like some embedded switch-device).
For this purpose we introduce a new phy-driver, called "Fixed PHY".
Fixed PHY works only with CONFIG_DM_ETH enabled, since the fixed-link is
described with a subnode below ethernet interface.
Most ethernet drivers (unfortunately not all are following same scheme
for searching/attaching phys) are calling "phy_connect(...)" for getting
a phy-device.
At this point we link in, we search here for a subnode called "fixed-
link", once found we start phy_device_create(...) with the special phy-
id PHY_FIXED_ID (0xa5a55a5a).
During init the "Fixed PHY" driver has registered with this id and now
gets probed, during probe we get all the details about fixed-link out of
dts, later on the phy reports this values.
Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
This replaces legacy arch/arc/lib/timer.c implementation and allows us
to describe ARC Timers in Device Tree. Among other things that way we
may properly inherit Timer's clock from CPU's clock s they really run
synchronously.
This commit introduces timer driver for ARC.
ARC timers are configured via ARC AUX registers so we use special
functions to access timer control registers.
This driver allows utilization of either timer0 or timer1
depending on which one is available in real hardware. Essentially
only existing timers should be mentioned in board's Device Tree
description.
Signed-off-by: Vlad Zakharov <vzakhar@synopsys.com>
Certain boards come in different variations by way of utilizing daughter
boards, for example. These boards might contain additional chips, which
are added to the main board's busses, e.g. I2C.
The device tree support for such boards would either, quite naturally,
employ the overlay mechanism to add such chips to the tree, or would use
one large default device tree, and delete the devices that are actually
not present.
Regardless of approach, even on the U-Boot level, a modification of the
device tree is a prerequisite to have such modular families of boards
supported properly.
Therefore, we add an option to make the U-Boot device tree (the actual
copy later used by the driver model) writeable, and add a callback
method that allows boards to modify the device tree at an early stage,
at which, hopefully, also the application of device tree overlays will
be possible.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
The USB device should linked to VBUS regulator through "vbus-supply"
DTS property.
This patch adds handling for "vbus-supply" property inside the USB
device entry for turning on the VBUS regulator upon the host adapter probe.
Signed-off-by: Konstantin Porotchkin <kostap@marvell.com>
Cc: Nadav Haklai <nadavh@marvell.com>
Cc: Neta Zur Hershkovits <neta@marvell.com>
Cc: Igal Liberman <igall@marvell.com>
Cc: Haim Boot <hayim@marvell.com>
Add support for "marvell,reset-gpio" property to mvebu DW PCIe
driver.
This option is valid when CONFIG_DM_GPIO=y
Change-Id: Ic17c500449050c2fbb700731f1a9ca8b83298986
Signed-off-by: Rabeeh Khoury <rabeeh@solid-run.com>
This adds documentation on the u-boot,efi-partition-entries-offset
property (which overrides CONFIG_EFI_PARTITION_ENTRIES_OFF, if
present).
This moves the description of the /config node from README.fdt-control
into a separate file doc/device-tree-bindings/config.txt.
This includes support for rk3188 from Heiko Stübner and and rk3328 from
Kever Yang. Also included is SPL support for rk3399 and a fix for
rk3288 to get it booting again (spl_early_init()).
This driver uses the same pin control binding as that of linux, binding
document of this patch is copied from linux. One addition done is for
GPIO input and output mode configuration which was missing.
add basic clock driver support for stm32f7 to enable clocks required by
the peripherals.
RK3399 support DDR3, LPDDR3, DDR4 sdram, this patch is porting from
coreboot, support 4GB lpddr3 in this version.
Added rockchip: tag:
Right now the u-boot,dm-pre-reloc flag will make each marked node
always appear in both spl and tpl. But systems needing an additional
tpl might have special constraints for each, like the spl needing to
be very tiny.
So introduce two additional flags to mark nodes for only spl or tpl
environments and introduce a function dm_fdt_pre_reloc to automate
the necessary checks in code instances checking for pre-relocation
flags.
The behaviour of the original flag stays untouched and still marks
a node for both spl and tpl.
Since commit c0efc3140e75 ("ARM: uniphier: change CONFIG_SPL_PAD_TO
to 128KB"), the u-boot.bin should be burned at the offset 0x20000.
I missed to update README.uniphier in that commit. Now updating.
Miniarm is the internal project code. Now it is officially named Tinker board.
So rename it.
Signed-off-by: Eddie Cai <eddie.cai@rock-chips.com>
At present devices use a simple integer offset to record the device tree
node associated with the device. In preparation for supporting a live
device tree, which uses a node pointer instead, refactor existing code to
access this field through an inline function.
The patch implements secure booting for the mvebu architecture.
This includes:
- The addition of secure headers and all needed signatures and keys in
mkimage
- Commands capable of writing the board's efuses to both write the
needed cryptographic data and enable the secure booting mechanism
- The creation of convenience text files containing the necessary
commands to write the efuses
The KAK and CSK keys are expected to reside in the files kwb_kak.key and
kwb_csk.key (OpenSSL 2048 bit private keys) in the top-level directory.
Signed-off-by: Reinhard Pfau <reinhard.pfau@gdsys.cc>
