path: root/doc
2016-05-24mkimage: Report information about fpgaMichal Simek
Add FIT_FPGA_PROP that user can identify an optional entry for fpga. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-05-21drivers: spi: add spi support for QCA/Atheros ath79 SOCsWills Wang
This patch add a compatible spi driver for ath79 series SOC. Signed-off-by: Wills Wang <wills.wang@live.com> Reviewed-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2016-05-21drivers: serial: add serial driver for ar933x SOCWills Wang
This patch add support for ar933x serial. Signed-off-by: Wills Wang <wills.wang@live.com> Reviewed-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-05-05Fix various typos, scattered over the code.Robert P. J. Day
Spelling corrections for (among other things): * environment * override * variable * ftd (should be "fdt", for flattened device tree) * embedded * FTDI * emulation * controller
2016-05-02Change my mailaddressAndreas Bießmann
I'll switch my mails to my own server, so drop all gmail references. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2016-05-02mkimage: fix argument parsing on BSD systemsAndreas Bießmann
The getopt(3) optstring '-' is a GNU extension which is not available on BSD systems like OS X. Remove this dependency by implementing argument parsing in another way. This will also change the lately introduced '-b' switch behaviour. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-04-26Merge branch 'master' of git://git.denx.de/u-boot-samsungTom Rini
2016-04-18doc: Updated README.ext4Robert P. J. Day
Clean up the ext4 README file. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2016-04-14doc: driver-model: Update dm tests run using test.pyJagan Teki
Since all the tests are implemented in pytest infrastructure, So update the dm tests with the same instead of ./test/dm/test-dm.sh Cc: Tom Rini <trini@konsulko.com> Cc: Simon Glass <sjg@chromium.org> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Jagan Teki <jteki@openedev.com>
2016-04-14odroid: Update README with correct firmware link and XU4 supportShawn Guo
The firmware from link [1] only works with U-Boot image that is no bigger than 328KiB. Using it with the default mainline U-Boot today which is already around 500KiB is just not working. Correct the link to be hardkernel_1mb_uboot one [2], so that users can get mainline U-Boot work out of box. While at it, the README is updated to include XU4 support, like DTB file name. [1] https://github.com/hardkernel/u-boot/tree/odroidxu3-v2012.07/sd_fuse/hardkernel [2] https://github.com/hardkernel/u-boot/tree/odroidxu3-v2012.07/sd_fuse/hardkernel_1mb_uboot Signed-off-by: Shawn Guo <shawnguo@kernel.org> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com> Reviewed-by: Anand Moon <linux.amoon@gmail.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2016-04-13i2c: Describe Cadence I2C devicetree bindingsMoritz Fischer
Signed-off-by: Moritz Fischer <moritz.fischer@ettus.com> Reviewed-by: Heiko Schocher <hs@denx.de> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-06armv8: LS2080A: Consolidate LS2080A and LS2085AYork Sun
LS2080A is the primary SoC, and LS2085A is a personality with AIOP and DPAA DDR. The RDB and QDS boards support both personality. By detecting the SVR at runtime, a single image per board can support both SoCs. It gives users flexibility to swtich SoC without the need to reprogram the board. Signed-off-by: York Sun <york.sun@nxp.com> CC: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2016-04-01Add myself as Snapdragon and SPMI maintainerMateusz Kulikowski
- Update MAINTAINERS - Update git-mailrc Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-04-01gpio: Add support for Qualcomm PM8916 gpiosMateusz Kulikowski
This driver supports GPIOs present on PM8916 PMIC. There are 2 device drivers inside: - GPIO driver (4 "generic" GPIOs) - Keypad driver that presents itself as GPIO with 2 inputs (power and reset) Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2016-04-01pmic: Add support for Qualcomm PM8916 PMICMateusz Kulikowski
This PMIC is connected on SPMI bus so needs SPMI support enabled. Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2016-04-01drivers: spmi: Add support for Qualcomm SPMI bus driverMateusz Kulikowski
Support SPMI arbiter on Qualcomm Snapdragon devices. Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2016-04-01spmi: Add sandbox test driverMateusz Kulikowski
This patch adds emulated spmi bus controller with part of pm8916 pmic on it to sandbox and tests validating SPMI uclass. Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-04-01ehci: Add support for Qualcomm EHCIMateusz Kulikowski
This driver is able to reconfigure OTG controller into HOST mode. Board can add board-specific initialization as board_prepare_usb(). It requires USB_ULPI_VIEWPORT enabled in board configuration. Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Acked-by: Marek Vasut <marex@denx.de> Tested-by: Simon Glass <sjg@chromium.org>
2016-04-01mmc: Add support for Qualcomm SDHCI controllerMateusz Kulikowski
Add support for SD/eMMC controller present on some Qualcomm Snapdragon devices. This controller implements SDHCI 2.0 interface but requires vendor-specific initialization. Driver works in PIO mode as ADMA is not supported by U-Boot (yet). Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2016-04-01gpio: Add support for Qualcomm gpio controllerMateusz Kulikowski
Add support for gpio controllers on Qualcomm Snapdragon devices. This devices are usually called Top Level Mode Multiplexing in Qualcomm documentation. Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2016-04-01serial: Add support for Qualcomm serial portMateusz Kulikowski
This driver works in "new" Data Mover UART mode, so will be compatible with modern Qualcomm chips only. Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2016-04-01doc: clarify openssl-based key and certificate generation processAndreas Dannenberg
Add some basic clarification that the dev.key file generated by OpenSSL contains both the public and private key, and further highlight that the certificate generated here contains the public key only. Signed-off-by: Andreas Dannenberg <dannenberg@ti.com>
2016-04-01doc: fix file extension for flattened image tree blobAndreas Dannenberg
Different sections in the document suggest flattened image tree blob files have a file name extension of .itb. Fix the list of file extensions to reflect that. Signed-off-by: Andreas Dannenberg <dannenberg@ti.com>
2016-04-01arm: clang: Update support slightlyTom Rini
- Move most of the flags required into LLVM_RELFLAGS to test at build time instead of requiring them to be passed in. - Update doc/README.clang to reflect this - Switch to rpi_2 as the example as it's closer to working out of the box than rpi is. Cc: Jeroen Hofstee <jeroen@myspectrum.nl> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-03-27doc/README.clang: Document sandbox instructionsTom Rini
It is possible to compile and run the sandbox target with clang currently, so document that as well. Cc: Jeroen Hofstee <jeroen@myspectrum.nl> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-03-24ARM: uniphier: switch to raw U-Boot imageMasahiro Yamada
Now everything is done to load a raw U-Boot proper image instead of an mkimage-processed one (as far as I tested on NAND, eMMC, NOR). The SPL already knows the load address of the U-Boot proper without parsing its uImage header because the load address is defined by CONFIG_SYS_TEXT_BASE, assuming that the two images are generated from the same build. My main motivation of this switch is to use u-boot-with-spl.bin, a concatenation of u-boot-spl.bin and u-boot.bin. (I wish there were a concatenation of u-boot-spl.bin and u-boot.img...) Anyway, this commit would be useful for one-shot image burn. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-03-24ARM: uniphier: fix README instruction for updating U-Boot via TFTPMasahiro Yamada
Commit 3cb9abc9c512 ("ARM: uniphier: update U-Boot file names in workflow") missed to update these two sentences. Fix them now. Replace u-boot-spl-dtb.bin and u-boot-dtb.img with u-boot-spl.bin and u-boot.img, respectively. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-03-22Fix spelling of "transferred".Vagrant Cascadian
Signed-off-by: Vagrant Cascadian <vagrant@debian.org> Acked-by: Marek Vasut <marex@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-21driver/ddr/fsl: Add address parity support for DDR4 UDIMM/discreteShengzhou Liu
Add support of address parity for DDR4 UDIMM or discrete memory. It requires to configurate corresponding MR5[2:0] and TIMING_CFG_7[PAR_LAT]. Parity can be turned on by hwconfig, e.g. hwconfig=fsl_ddr:parity=on. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-03-17x86: Add support for the samus chromebookSimon Glass
This adds basic support for chromebook_samus. This is the 2015 Pixel and is based on an Intel broadwell platform. Supported so far are: - Serial - SPI flash - SDRAM init (with MRC cache) - SATA - Video (on the internal LCD panel) - Keyboard Various less-visible drivers are provided to make the above work (e.g. PCH, power control and LPC). The platform requires various binary blobs which are documented in the README. The major missing feature is USB3 since the existing U-Boot support does not work correctly with Intel XHCI controllers. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-03-17x86: Update README for new developmentsSimon Glass
Update a few points which have become out-of-date. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-03-17x86: broadwell: Add a pinctrl driverSimon Glass
GPIO pins need to be set up on start-up. Add a driver to provide this, configured from the device tree. The binding is slightly different from the existing ICH6 binding, since that is quite verbose. The new binding should be just as extensible. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Bin Meng <bmeng.cn@gmail.com>
2016-03-17x86: dts: Update the pinctrl binding a littleSimon Glass
Make a few minor updates to make the meaning clearer. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-03-17x86: Add an ICH6 pin configuration driverSimon Glass
Add a driver which sets up the pin configuration on x86 devices with an ICH6 (or later) Platform Controller Hub. The driver is not in the pinctrl uclass due to some oddities of the way x86 devices work: - The GPIO controller is not present in I/O space until it is set up - This is done by writing a register in the PCH - The PCH has a driver which itself uses PCI, another driver - The pinctrl uclass requires that a pinctrl device be available before any other device can be probed It would be possible to work around the limitations by: - Hard-coding the GPIO address rather than reading it from the PCH - Using special x86 PCI access to set the GPIO address in the PCH However it is not clear that this is better, since the pin configuration driver does not actually provide normal pin configuration services - it simply sets up all the pins statically when probed. While this remains the case, it seems better to use a syscon uclass instead. This can be probed whenever it is needed, without any limitations. Also add an 'invert' property to support inverting the input. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-03-17x86: Add a script to aid code conversion from corebootSimon Glass
It is useful to automate the process of converting code from coreboot a little. Add a sed script which performs some common transformations. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Bin Meng <bmeng.cn@gmail.com>
2016-03-17x86: Document how to play with SeaBIOSBin Meng
Boting SeaBIOS is done via U-Boot's bootelf command. Document this. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-03-15efi_loader: Add README section in README.efiAlexander Graf
To preserve all cover letter knowledge of the status on UEFI payload support, let's add some sections to README.efi. Signed-off-by: Alexander Graf <agraf@suse.de> v3 -> v4: - Add section about config options - s/10kb/10KB/
2016-03-15arm64: Remove non-full-va map codeAlexander Graf
By now the code to only have a single page table level with 64k page size and 42 bit address space is no longer used by any board in tree, so we can safely remove it. To clean up code, move the layerscape mmu code to the new defines, removing redundant field definitions. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-03-15Merge branch 'master' of git://git.denx.de/u-boot-videoTom Rini
2016-03-14mkimage: Support placing data outside the FITSimon Glass
One limitation of FIT is that all the data is 'inline' within it, using a 'data' property in each image node. This means that to find out what is in the FIT it is necessary to scan the entire file. Once loaded it can be scanned and then the images can be copied to the correct place in memory. In SPL it can take a significant amount of time to copy images around in memory. Also loading data that does not end up being used is wasteful. It would be useful if the FIT were small, acting as a directory, with the actual data stored elsewhere. This allows SPL to load the entire FIT, without the images, then load the images it wants later. Add a -E option to mkimage to request that it output an 'external' FIT. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-03-14mkimage: Support adding device tree files to a FITSimon Glass
To make the auto-FIT feature useful we need to be able to provide a list of device tree files on the command line for mkimage to add into the FIT. Add support for this feature. So far there is no support for hashing or verified boot using this method. For those cases, a .its file must still be provided. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-03-14mkimage: Support automatic creating of a FIT without a .itsSimon Glass
At present, when generating a FIT, mkimage requires a .its file containing the structure of the FIT and referring to the images to be included. Creating the .its file is a separate step that makes it harder to use FIT. This is not required for creating legacy images. Often the FIT is pretty standard, consisting of an OS image, some device tree files and a single configuration. We can handle this case automatically and avoid needing a .its file at all. To start with, support automatically generate the FIT using a new '-f auto' option. Initially this only supports adding a single image (e.g. a linux kernel) and a single configuration. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-03-14tools: Add a function to obtain the size of a fileSimon Glass
This will be used in mkimage when working out the required size of the FIT based on the files to be placed into it. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-03-14doc: dt-bindings: Describe rockchip LVDS interfaceJacob Chen
I didn't have a common board to enable LVDS. So add this dcocument to help others who want to enable LVDS in their board. Signed-off-by: Jacob Chen <jacob-chen@iotwrt.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-03-09ARM: uniphier: document how-to-build for Ace and Sanji boardsMasahiro Yamada
2016-02-29ARM: uniphier: merge two defconfig filesMasahiro Yamada
PH1-Pro5 support and ProXstream2/PH1-LD6b support can coexist in one image and there is bit more room in SPL to accommodate all of them. Merge uniphier_pro5_defconfig into uniphier_pxs2_defconfig. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-02-29ARM: uniphier: add emmcupdate commandMasahiro Yamada
The Boot ROM expects the boot image (SPL) in the Boot Partition 1. So, updating images involves the hardware partition switch. It might be a bit advanced for some users. To be user-friendly, this commit adds a useful command to update the images; just put SPL and U-Boot proper into the public directory of the TFTP server and execute "run emmcupdate" from the command line. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-02-29mmc: uniphier: add driver for UniPhier SD/MMC host controllerMasahiro Yamada
Add a driver for the on-chip SD/eMMC host controller used by UniPhier SoC family. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-02-29gpio: uniphier: add driver for UniPhier GPIO controllerMasahiro Yamada
This GPIO controller device is used on UniPhier SoCs. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-02-24dm: Remove ARM dcc from the listMichal Simek
Remove ARM Debug communication channel driver from the list of not converted drivers to DM. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
