path: root/doc
2010-04-13nios: Move cpu/nios/* to arch/nios/cpu/*Peter Tyser
2010-04-13i386: Move cpu/i386/* to arch/i386/cpu/*Peter Tyser
2010-04-13m68k: Move cpu/$CPU to arch/m68k/cpu/$CPUPeter Tyser
2010-04-13arm: Move cpu/$CPU to arch/arm/cpu/$CPUPeter Tyser
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Create CPUDIR variablePeter Tyser
The CPUDIR variable points to the location of a target's CPU directory. Currently, it is set to cpu/$CPU. However, using $CPUDIR will allow for more flexibility in the future. It lays the groundwork for reorganizing U-Boot's directory structure to support a layout such as: arch/$ARCH/cpu/$CPU/* (architecture with multiple CPU types) arch/$ARCH/cpu/* (architecture with one CPU type) Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-10Add initial support for Matrix Vision mvSMR board based on MPC5200B.Andre Schwarz
Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
2010-04-03s5pc1xx: update the README fileMinkyu Kang
Because adds support the GPIO Interface, README file is updated. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2010-03-31net, doc: How to setup MAC address correctlyHeiko Schocher
As this seems unclear, document how the flow of setting up the MAC address is correct. Signed-off-by: Heiko Schocher <hs@denx.de> Text changed slightly, adding input from Mike Frysinger. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-03-31doc: Fix ramdisk examples in doc/uImage.FIT/multi.itsFelix Radensky
The ramdisk sections in doc/uImage.FIT/multi.its lack load address and entry point properties. Using examples from this file will result in unbootable image, u-boot will issue the following error messages: Can't get ramdisk subimage load address! Ramdisk image is corrupt or invalid This patch adds missing properties to ramdisk sections. Signed-off-by: Felix Radensky <felix@embedded-sol.com>
2010-03-28ml300: remove support for broken, orphaned boardWolfgang Denk
The ml300 board has a number of issues, but nobody cares about this long-orphaned board any more. Remove it. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Michal Simek <monstr@monstr.eu>
2010-03-12Prepare v2010.03-rc1v2010.03-rc1Wolfgang Denk
Coding style cleanup, update CHANGELOG. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-03-12Fix MPC8536DS documentationFrans Meulenbroeks
This patch corrects small mistake in the register list in doc/README.mpc8536ds. These registers are 32 bits and this one starts at ....c not ....e When using the ...c address I can boot from sd, when using the ...e address I cannot. Signed-off-by: Frans Meulenbroeks <fransmeulenbroeks@gmail.com> Acked-by: Hu Mingkai <B21284@freescale.com>
2010-03-12doc: add README for CONFIG_HWCONFIG optionHeiko Schocher
2010-02-12prepare joining at91rm9200 into at91Jens Scharsig
* prepare joining at91 and at91rm9200 * add modified copy of soc files to cpu/arm920t/at91 to make possible to compile at91rm9200 boards in at91 tree instead of at91rm9200 * add header files with c structure defs for AT91 MC, ST and TC * the new cpu files are using at91 c structure soc access * please read README.soc-at91 for details Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
2010-02-12add new CONFIG_AT91_LEGACYJens Scharsig
* add's the new temporary CONFIG_AT91_LEGACY to all board configs This will need for backward compatiblity, while change the SoC access to c structures. If CONFIG_AT91_LEGACY is defined, the deprecated SoC is used. Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
2010-01-25mkimage: Add Freescale imx Boot Image support (imximage)Stefano Babic
This patch adds support for "imximage" (MX Boot Image) to the mkimage utility. The imximage is used on the Freescales's MX.25, MX.35 and MX.51 processors. Further details under doc/README.imximage. This patch was tested on a Freescale mx51evk board. Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-01-23SPEAr : Adding README.spear in docVipin KUMAR
README.spear contains information about SPEAr architecture and build options etc Signed-off-by: Vipin <vipin.kumar@st.com>
2010-01-07mpc83xx: Add NAND boot support for MPC8315E-RDB boardsAnton Vorontsov
The core support for NAND booting is there already, so this patch is pretty straightforward. There is one trick though: top level Makefile expects nand_spl to be in nand_spl/board/$(BOARDDIR), but we can fully reuse the code from mpc8313erdb boards, and so to not duplicate the code we just symlink nand_spl/board/freescale/mpc8315erdb to mpc8313erdb. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> o silence make during ln echo o update documentation o and avoid: $ ./MAKEALL MPC8315ERDB_NAND Configuring for MPC8315ERDB board... sdram.o: In function `fixed_sdram': /home/r1aaha/git/u-boot/nand_spl/board/freescale/mpc8313erdb/sdram.c:72: undefined reference to `udelay' by renaming udelay -> __udelay in the spirit of commit 3eb90bad651fab39cffba750ec4421a9c01d60e7 "Generic udelay() with watchdog support". Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-12-05Merge branch 'master' into nextWolfgang Denk
Conflicts: board/esd/plu405/plu405.c drivers/rtc/ftrtc010.c Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-11-27TI DaVinci: Adding a README for the DaVinci series of SOC'sSandeep Paulraj
Adding an initial README for the DaVinci series of SOC's Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2009-11-24Fix example FIT image source filesIra W. Snyder
The example FIT image source files do not compile with the latest dtc and mkimage. The following error message is produced: DTC: dts->dtb on file "kernel.its" Error: kernel.its 7:0 - 1:0 syntax error FATAL ERROR: Unable to parse input tree ./mkimage: Can't read kernel.itb.tmp: Invalid argument The FIT image source files are missing the "/dts-v1/;" directive at the beginning of the file. Add the directive to the examples. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu>
2009-11-09clarify eth driver halt/recv stepsMike Frysinger
The dev->halt() func can be called at any time, and the dev->recv() func does not need to use NetRxPackets[] when calling NetReceive(). Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-10-28Coding Style cleanup; update CHANGELOG, prepare -rc1v2009.11-rc1Wolfgang Denk
2009-10-13s5pc1xx: add support SMDKC100 boardMinkyu Kang
Adds new board SMDKC100 that uses s5pc100 SoC Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: HeungJun, Kim <riverful.kim@samsung.com>
2009-10-10Rewrite the miiphybb (Bit-banged MII bus driver) in order to support an ↵Luigi 'Comio' Mantellini
arbitrary number of mii buses. This feature is useful when your board uses different mii buses for different phys and all (or a part) of these buses are implemented via bit-banging mode. The driver requires that the following macros should be defined into the board configuration file: CONFIG_BITBANGMII - Enable the miiphybb driver CONFIG_BITBANGMII_MULTI - Enable the multi bus support If the CONFIG_BITBANGMII_MULTI is not defined, the board's config file needs to define at least the following macros: MII_INIT - Generic code to enable the MII bus (optional) MDIO_DECLARE - Declaration needed to access to the MDIO pin (optional) MDIO_ACTIVE - Activate the MDIO pin as out pin MDIO_TRISTATE - Activate the MDIO pin as input/tristate pin MDIO_READ - Read the MDIO pin MDIO(v) - Write v on the MDIO pin MDC_DECLARE - Declaration needed to access to the MDC pin (optional) MDC(v) - Write v on the MDC pin The previous macros make the driver compatible with the previous version (that didn't support the multi-bus). When the CONFIG_BITBANGMII_MULTI is also defined, the board code needs to fill the bb_miiphy_buses[] array with a record for each required bus and declare the bb_miiphy_buses_num variable with the number of mii buses. The record (struct bb_miiphy_bus) has the following fields/callbacks (see miiphy.h for details): char name[] - The symbolic name that must be equal to the MII bus registered name int (*init)() - Initialization function called at startup time (just before the Ethernet initialization) int (*mdio_active)() - Activate the MDIO pin as output int (*mdio_tristate)() - Activate the MDIO pin as input/tristate pin int (*set_mdio)() - Write the MDIO pin int (*get_mdio)() - Read the MDIO pin int (*set_mdc)() - Write the MDC pin int (*delay)() - Delay function void *priv - Private data used by board specific code The board code will look like: struct bb_miiphy_bus bb_miiphy_buses[] = { { .name = miibus#1, .init = b1_init, .mdio_active = b1_mdio_active, ... }, { .name = miibus#2, .init = b2_init, .mdio_active = b2_mdio_active, ... }, ... int bb_miiphy_buses_num = sizeof(bb_miiphy_buses) / sizeof(bb_miiphy_buses[0]); Signed-off-by: Luigi 'Comio' Mantellini <luigi.mantellini@idf-hit.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-10-05Add information about return values of xxx_eth_register() in documentationBen Warren
As discussed on mailing list, <0 indicates failure, >=0 indicates number of interfaces found. Also added blurb about private data Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-10-04document network driver frameworkMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-09-30Add README.mpc8536dsMingkai Hu
Add boot from NAND/eSDHC/eSPI description Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-30sbc8548: reclaim wasted sector in boot flashPaul Gortmaker
By nature of being based off the MPC8548CDS board, this board inherited an ENV_SIZE setting of 256k. But since it has a smaller flash device (8MB soldered on), it has a native sector size of 128k, and hence the ENV_SIZE was causing 2 sectors to be used for the environment. By removing the unused sector, we can push TEXT_BASE up closer to the end of address space and reclaim that sector for any other application. This also fixes the mismatch between TEXT_BASE and MONITOR_LEN reported by Kumar earlier. Since this board also supports the ability to boot off the 64MB SODIMM flash, this change is forward looking with that in mind; i.e. the settings for MONITOR_LEN and ENV_SIZE will work when the 512k sectors of the SODIMM flash are used for alternate boot in the future. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24sbc8548: replace README with completely new documentPaul Gortmaker
The previous README.sbc8548 was pretty much content-free. Replace it with something that actually gives the end user some relevant hardware details, and also lists the u-boot configuration choices. Also in the cosmetic department, fix the bogus line in the Makefile that was carried over from the SBC8560 Makefile, and the typo in the sbc8548.c copyright. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-22Remove deprecated 'autoscr' command/variablesPeter Tyser
The more standard 'source' command provides identical functionality to the autoscr command. Environment variable names/values on the MVBC_P, MVBML7, kmeter1, mgcoge, and km8xx boards are updated to no longer refernce 'autoscr'. The 'autoscript' and 'autoscript_uname' environment variables are also removed. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Acked-by: Heiko Schocher <hs@denx.de>
2009-09-15tools/netconsole: use ncb automatically if availableMike Frysinger
The standard netcat, while ubiquitous, doesn't handle broadcast udp packets properly. The local ncb util does however. So if ncb can be located in the standard locations, automatically use that instead. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-09-10mkimage: Add Kirkwood Boot Image support (kwbimage)Prafulla Wadaskar
This patch adds support for "kwbimage" (Kirkwood Boot Image) image types to the mkimage code. For details refer to docs/README.kwbimage This patch is tested with Sheevaplug board Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Acked-by: Ron Lee <ron@debian.org> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2009-09-07Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2009-09-05Add support for the DevKit8000 boardFrederik Kriewitz
This patch adds support for the DevKit8000 board. Signed-off-by: Frederik Kriewitz <frederik@kriewitz.eu>
2009-09-02Blackfin: change global data register from P5 to P3Robin Getz
Since the Blackfin ABI favors higher scratch registers by default, use the last scratch register (P3) for global data rather than the first (P5). This allows the compiler's register allocator to use higher number scratch P registers, which in turn better matches the Blackfin instruction set, which reduces the size of U-Boot by more than 1024 bytes... Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-08-2885xx: Add support for P2020RDB boardPoonam Aggrwal
The code base adds P1 & P2 RDB platforms support. The folder and file names can cater to future SOCs of P1/P2 family. P1 & P2 processors are 85xx platforms, part of Freescale QorIQ series. Tested following on P2020RDB: 1. eTSECs 2. DDR, NAND, NOR, I2C. Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-21mpc83xx: sbc8349 - make enabling PCI more user friendlyPaul Gortmaker
Prior to this commit, to enable PCI, you had to go manually edit the board config header, which isn't really user friendly. This adds the typical PCI make targets to the toplevel Makefile in accordance with what is being done with other boards. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-07-27sbc8349: combine HRCW flash and u-boot image flashPaul Gortmaker
Up to this point in time, the sbc8349 board was storing the u-boot image in flash 2x. One for the HRCW value at the beginning of flash (0xff80_0000), and once close to the end of flash (0xfff8_0000) for the actual image that got executed. This moves the TEXT_BASE to be the beginning of flash, which makes the second copy of the image redundant, and frees up the flash from the end of the environment storage to the end of the flash device itself. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-07-27Prepare 2009.08-rc1Wolfgang Denk
Update CHANGELOG, minor coding style fix. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-26new video driver for bus vcxk framebuffersJens Scharsig
This patch adds a new video driver * adds common bus_vcxk framebuffer driver Signed-off-by: Jens Scharsig <esw@bus-elektronik.de> [agust@denx.de: fixed lots of style issues before applying] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2009-07-23Coding Style cleanup; update CHANGELOG.Wolfgang Denk
2009-07-22Add DNS supportRobin Getz
On 04 Oct 2008 Pieter posted a dns implementation for U-Boot. http://www.mail-archive.com/u-boot-users@lists.sourceforge.net/msg10216.html > > DNS can be enabled by setting CFG_CMD_DNS. After performing a query, > the serverip environment var is updated. > > Probably there are some cosmetic issues with the patch. Unfortunatly I > do not have the time to correct these. So if anybody else likes DNS > support in U-Boot and has the time, feel free to patch it in the main tree. Here it is again - slightly modified & smaller: - update to 2009-06 (Pieter's patch was for U-Boot 1.2.0) - README.dns is added - syntax is changed (now takes a third option, the env var to store the result in) - add a random port() function in net.c - sort Makefile in ./net/Makefile - dns just returns unless a env var is given - run through checkpatch, and clean up style issues - remove packet from stack - cleaned up some comments - failure returns much faster (if server responds, don't wait for timeout) - use built in functions (memcpy) rather than byte copy. Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org> Signed-off-by: Pieter Voorthuijsen <pieter.voorthuijsen@prodrive.nl> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-07-16Remove legacy NAND and disk on chip code.Scott Wood
Legacy NAND had been scheduled for removal. Any boards that use this were already not building in the previous release due to an #error. The disk on chip code in common/cmd_doc.c relies on legacy NAND, and it has also been removed. There is newer disk on chip code in drivers/mtd/nand; someone with access to hardware and sufficient time and motivation can try to get that working, but for now disk on chip is not supported. Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-07-14Merge branch 'master' of /home/wd/git/u-boot/masterWolfgang Denk
2009-07-13Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2009-07-12at91: Introduction of at91sam9g10 SOC.Sedji Gaouaou
AT91sam9g10 is an ARM 926ej-s SOC. It is an evolution of the at91sam9261 with a faster clock speed: 266/133MHz. Signed-off-by: Sedji Gaouaou <sedji.gaouaou@atmel.com>
2009-07-12at91: Introduction of at91sam9g45 SOC.Sedji Gaouaou
AT91sam9g45 series is an ARM 926ej-s SOC family clocked at 400/133MHz. It embeds USB high speed host and device, LCD, DDR2 RAM, and a full set of peripherals. The first board that embeds at91sam9g45 chip is the AT91SAM9G45-EKES. On the board you can find 2 USART, USB high speed, a 480*272 LG lcd, ethernet, gpio/joystick/buttons. Signed-off-by: Sedji Gaouaou <sedji.gaouaou@atmel.com>
