The current API is outdated as it requires a devicetree pointer.
Move these functions to use the ofnode API and update this globally. Add
some tests while we are here.
Correct the call in exynos_dsim_config_parse_dt() which is obviously
wrong.
Use the more generic reset-gpios property name.
Signed-off-by: Jorge Ramirez-Ortiz <jorge@foundries.io>
Acked-by: Michal Simek <michal.simek@xilinx.com>
Acked-by: Ilias Apalodimas <ilias.apalodimas@linaro.org>
Version string is available in global variable char version_string[].
Macro U_BOOT_VERSION_STRING is not used by any other file, so remove it
completely from version.h. Other files were already converted to use
variable version_string[].
Signed-off-by: Pali Rohár <pali@kernel.org>
Split this information into subsections and expand it.
Prepare v2021.10-rc4
# gpg: Signature made Tue 14 Sep 2021 06:58:32 PM EDT
# gpg: using RSA key 1A3C7F70E08FAB1707809BBF147C39FF9634B72C
# gpg: Good signature from "Thomas Rini <trini@konsulko.com>" [ultimate]
# Conflicts:
# board/Arcturus/ucp1020/spl.c
# cmd/mvebu/Kconfig
# common/Kconfig.boot
# common/image-fit.c
# configs/UCP1020_defconfig
# configs/sifive_unmatched_defconfig
# drivers/pci/Kconfig
# include/configs/UCP1020.h
# include/configs/sifive-unmatched.h
# lib/Makefile
# scripts/config_whitelist.txt
Support using mmc command for enumerating mmc card in a given mode
Fix device_remove in mmc
Fix switch issue with send_status disabled
Drop 1ms delay in fsl_esdhc command sending
Revert "mmc: sdhci: set to INT_DATA_END when there are data"
https://source.denx.de/u-boot/custodians/u-boot-efi
Pull request for efi-2021-10-rc4-2
Documentation:
* improve documentation of U-Boot for /config DT node
* integrate bloblist documentation
UEFI:
* correct usage of EFI_CALL()
* code tidy up
The current list is missing a few items. Add them.
Reviewed-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
Acked-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
Sort these and add a type so it is clear how to set the value. Add a note
about usage to the top. Correct the 'no-keyboard' binding which is missing
a prefix.
Move this documentation to the new format.
Reviewed-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
Fix the documentation file names: s/apalix/apalis/.
Fixes: e98ea49a0e ("toradex: MAINTAINERS: entries for new reST docs")
Fixes: 3730106cf0 ("doc: board: apalis-imx8x: add documentation")
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@foundries.io>
Reviewed-by: Igor Opaniuk <igor.opaniuk@foundries.io>
Acked-by: Francesco Dolcini <francesco.dolcini@toradex.com>
Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
Add documentation on the usage of "mmc dev" and "mmc rescan" commands to
set user defined speed modes.
Signed-off-by: Aswath Govindraju <a-govindraju@ti.com>
Move TI maintainership to Tom.
Updated with the following commands:
find ./ -name MAINTAINERS | xargs sed -i s/"Lokesh Vutla <lokeshvutla@ti.com>"/"Tom Rini <trini@konsulko.com>"/g
Reviewed-by: Nishanth Menon <nm@ti.com>
Acked-by: Tom Rini <trini@konsulko.com>
Rename this option so that CONFIG_IS_ENABLED can be used with it.
Rename these options so that CONFIG_IS_ENABLED can be used with them.
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
[trini: Fixup some incorrect renames]
Per a request from Andre Przywara and agreed with by Peter Hoyes, the
vexpress aemv8r support wasn't quite ready to be merged, but the
discussion had moved off list. We should keep the first patch in the
series for now, but revert the rest. This reverts the following
commits:
e0bd6f31ce41 doc: Add documentation for the Arm vexpress board configs
30e5a449e8c7 arm: Use armv8_switch_to_el1 env to switch to EL1
b53bbca63bf4 vexpress64: Add BASER_FVP vexpress board variant
2f5b7b74903f armv8: Add ARMv8 MPU configuration logic
37a757e227cc armv8: Ensure EL1&0 VMSA is enabled
This Kconfig symbol was never added to U-Boot but it was mentioned in the
origin commit c35df7c9e43e ("qemu: arm64: Add documentation for capsule
update"). That's why remove it from documentation to be accurate.
Create a new documentation section for Arm Ltd boards with a sub-page
for the vexpress board (FVP-A, FVP-R and Juno).
Document how the armv8_switch_to_el1 environment variable can be used
to switch between booting from S-EL2/S-EL1 at runtime on the BASER_FVP.
Signed-off-by: Peter Hoyes <Peter.Hoyes@arm.com>
The BASER_FVP board variant is implemented on top of the BASE_FVP board
config (which, in turn, is based on the Juno Versatile Express board
config). They all share a similar memory map - for BASER_FVP the map is
inverted from the BASE_FVP
(https://developer.arm.com/documentation/100964/1114/Base-Platform/Base---memory/BaseR-Platform-memory-map)
* Create new TARGET_VEXPRESS64_BASER_FVP target, which uses the same
board config as BASE_FVP and JUNO
* Adapt vexpress_aemv8a.h header file to support BASER_FVP (and rename
to vexpress_aemv8.h)
* Enable config to switch to EL1 for the BASER_FVP
* Create vexpress_aemv8r defconfig
* Provide an MPU memory map for the BASER_FVP
For now, only single core boot is supported.
[trini: Add MAINTAINERS, move BOOTCOMMAND to defconfig]
Over the time, the "stemmy" U-Boot board was tested on several other
Samsung smartphones based on ST-Ericsson NovaThor Ux500. Convert the
documentation to reStructuredText at doc/board/ste/stemmy.rst and
make the device list complete. Also note that the board now boots
into USB Fastboot instead of just ending up at the U-Boot prompt.
The device table is mostly taken from the postmarketOS wiki article
(https://wiki.postmarketos.org/wiki/ST-Ericsson_NovaThor_U8500).
All the newly added devices were tested by Linus Walleij.
Signed-off-by: Stephan Gerhold <stephan@gerhold.net>
This resyncs us with the version found in v5.13 of the Linux kernel with
the following exceptions:
- Keep our u-boot specific tests / code area.
- Change the location of checkpatch.rst (which we now import)
- Drop the "use strscpy" test as we don't have that, but do have strlcpy
and want that used now.
- Keep debug/printf in the list for $logFunctions
And note that we now also include the spdxcheck.py tool that
checkpatch.pl supports calling out to, and include upstream's
checkpatch.rst in our develop section of the documentation.
https://gitlab.denx.de/u-boot/custodians/u-boot-marvell into next
- Handling all DM watchdogs in watchdog_reset() (Rasmus)
CONFIG_SKIP_LOWLEVEL_INIT
CONFIG_SKIP_LOWLEVEL_INIT_ONLY
In order to do this, we need to introduce SPL and TPL variants of these
options so that we can clearly disable these options only in SPL in some
cases, and both instances in other cases.
All platforms define CONFIG_SYS_LOAD_ADDR, but only some define
CONFIG_LOADADDR. Very very rarely are these not the same address, and
qemu-ppce500 is one such case. However, based on reading the history of
the code, this mismatched value was simply a copy-paste from other
PowerPC platforms where it is this unused currently. Switch the code to
use CONFIG_SYS_LOAD_ADDR and update the documentation.
Cc: Bin Meng <bmeng.cn@gmail.com>
A rather common kind of external watchdog circuit is one that is kept
alive by toggling a gpio. Add a driver for handling such a watchdog.
The corresponding linux driver apparently has support for some
watchdog circuits which can be disabled by tri-stating the gpio, but I
have never actually encountered such a chip in the wild; the whole
point of adding an external watchdog is usually that it is not in any
way under software control. For forward-compatibility, and to make DT
describe the hardware, the current driver only supports devices that
have the always-running property. I went a little back and forth on
whether I should fail ->probe or only ->start, and ended up deciding
->start was the right place.
The compatible string is probably a little odd as it has nothing to do
with linux per se - however, I chose that to make .dts snippets
reusable between device trees used with U-Boot and linux, and this is
the (only) compatible string that linux' corresponding driver and DT
binding accepts. I have asked whether one should/could add "wdt-gpio"
to that binding, but the answer was no:
https://lore.kernel.org/lkml/CAL_JsqKEGaFpiFV_oAtE+S_bnHkg4qry+bhx2EDs=NSbVf_giA@mail.gmail.com/
If someone feels strongly about this, I can certainly remove the
"linux," part from the string - it probably wouldn't the only place where
one can't reuse a DT snippet as-is between linux and U-Boot.
Signed-off-by: Rasmus Villemoes <rasmus.villemoes@prevas.dk>
Pull request for efi-2021-10-rc3
Documentation:
* Rename Freescale to NXP
* Document structures used for the UEFI TCG2 protocol
UEFI:
* Device paths must use EfiBootServicesData
The driver will use a syscon regmap as backend and supports both
16 and 32 size value. The value will be stored in the CPU's endianness.
Signed-off-by: Nandor Han <nandor.han@vaisala.com>
'make htmldocs' does not use file doc/board/st/st.rst because the name
matches the directory name. Let's rename it to st-dt.rst.
Freescale Semiconductor, Inc. was merged into NXP Semiconductors in 2015.
Having "i.MX7D/i.MX8MM SRC_GPR10 PERSIST_SECONDARY_BOOT for bootloader A/B
switching" at the top level of the documentation tree does not make sense.
Move it to board specific information.
Fixes: 59e3d1bd4992 ("doc: imx: psb: Document usage of SRC_GPR10 PERSIST_SECONDARY_BOOT for A/B switching")
TF-A for STM32MP15 now supports the FIP: it is a packaging format which
includes the secure monitor, u-boot-nodtb.bin and u-boot.dtb
This FIP file is loaded by FSBL = TF-A BL2.
This patch updates the board documentation to use this FIP file and no
more u-boot.stm32 (with STM32 image header) which is no more generated.
Signed-off-by: Patrick Delaunay <patrick.delaunay@foss.st.com>
Reviewed-by: Patrice Chotard <patrice.chotard@foss.st.com>
With device tree binding migration to yaml it is difficult to synchronize
the binding from Linux kernel to U-Boot.
Instead of maintaining the same dt bindings, this patch adds in the U-Boot
documentation the path to the device tree bindings in Linux kernel for
STMicroelectronics devices, when they are used without modification.
Signed-off-by: Patrice Chotard <patrice.chotard@foss.st.com>
Add links for referenced text files.
This question comes up every now and then with people coming from Linux.
Add some notes about it so we can point to it in the mailing list.
This file is about 10 years old and the updates have not covered
everything that has changed, particularly in the last few years. Update
the information and add mention of the u-boot.dtsi files.
Fix typos.
Move this to rST format, largely unchanged to start with. Add an index
for this topic, as well as an empty intro.
Note this patch does not include updates! Is it just a conversion to the
new format. See the next patch.
Reviewed-by: Heinrich Schuchart <xypron.glpk@gmx.de>
Adjust the Latex formatting to match Linux v5.13.1:
* add Latex margins
* reformat the code in doc/conf.py to match Linux
Require Sphinx 2.44 to build the documentation.
Remove all code related to earlier versions.
tools/Makefile uses pkg-config.
Update SeaBIOS build instructions using exact command that involves
"make olddefconfig", and mention SeaBIOS release 1.14.0 has been
used for testing.
https://source.denx.de/u-boot/custodians/u-boot-imx
u-boot-imx-20210809
- new SOC: add support for imx8ulp
- Toradex fixes for colibri (vf / imx6 / imx7 / imx8x)
- convert to DM for mx28evk
- Fixes for Gateworks ventana boards
CI: https://source.denx.de/u-boot/custodians/u-boot-imx/-/pipelines/8639
Update the documentation on how to build the u-boot image for
Colibri iMX8QXP, adding support of V1.0D revision of the module.
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Migration is complete. Drop the message.
These boards have been removed. Drop the config file and other references.
Start out by documenting general expectations on when CI is run, how
anyone can run Azure pipelines, and how GitLab CI pipelines can be run.
- Fixed broken ICH SPI driver in software sequencer mode
- Added "m25p,fast-read" to SPI flash node for x86 boards
- Drop ROM_NEEDS_BLOBS and BUILD_ROM for x86 ROM builds
- Define a default TSC timer frequency for all x86 boards
- x86 MTRR MSR programming codes bug fixes
- x86 "hob" command bug fixes
- Don't program MTRR for DRAM for FSP1
- Move INIT_PHASE_END_FIRMWARE to FSP2
- Use external graphics card by default on Intel Crown Bay
- tangier: Fix DMA controller IRQ polarity in CSRT
U-Boot mostly uses hex for value input, largely because addresses are much
easier to understand in hex.
But in some cases a decimal value is requested, such as where the value is
small or hex does not make sense in the context. In these cases it is
sometimes useful to be able to provide a hex value in any case, if only to
resolve any ambiguity.
Add this functionality, for increased flexibility.
Mention the default base of U-Boot in the command-line section. Add
examples for decimal and octal.
Take this part of the README and put it into rST format.
