path: root/doc
2018-01-31Merge tag 'xilinx-for-v2018.03' of git://git.denx.de/u-boot-microblazeTom Rini
Xilinx changes for v2018.03 - Several Kconfig fixes (also moving configs to defconfigs) - Some DTS updates - ZynqMP psu rework based on Zynq concept - Add low level initialization for zc770 and zcu102 - Add support for Zynq zc770 x16 nand configuration - Add mini nand/emmc ZynqMP targets - Some arasan nand changes
2018-01-30doc: zynq: Describe status of zc770-xm011Michal Simek
zc770-xm011 is also added and supported. Reflect this in README. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-01-28efi_loader: add a README.iscsi describing booting via iSCSIHeinrich Schuchardt
The appended README explains how U-Boot and iPXE can be used to boot a diskless system from an iSCSI SAN. The maintainer for README.efi and README.iscsi is set. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> [agraf: s/Adress/Address/] Signed-off-by: Alexander Graf <agraf@suse.de>
2018-01-26Merge git://git.denx.de/u-boot-spiTom Rini
2018-01-24doc: Update the zynq u-boot statusEzequiel Garcia
NAND and QSPI devices are now supported, so mark them as such. Cc: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Ezequiel Garcia <ezequiel@vanguardiasur.com.ar> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-01-24dts: cadence_spi: Update documentation for DT bindingsJason Rush
Update documentation to reflect adopting the Linux DT bindings. Tested on TI K2G platform: Tested-by: Vignesh R <vigneshr@ti.com> Tested on a socfpga-cyclonev board: Tested-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com> Signed-off-by: Jason Rush <jarush@gmail.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Acked-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com> Acked-by: Marek Vasut <marex@denx.de>
2018-01-22fs: Migrate ext4 to KconfigTuomas Tynkkynen
Migrate the following symbols to Kconfig: CONFIG_FS_EXT4 CONFIG_EXT4_WRITE The definitions in config_fallbacks.h can now be expressed in Kconfig. Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2018-01-19m68k: Drop unreferenced CONFIG_* definesTuomas Tynkkynen
The following config symbols are only defined once and never referenced anywhere else: CONFIG_AMCORE CONFIG_ASTRO5373L CONFIG_M52277EVB CONFIG_M5253DEMO CONFIG_M5253EVBE CONFIG_M5275EVB CONFIG_M54418TWR CONFIG_STMARK2 Most of them are config symbols named after the respective boards which seems to have been a standard practice at some point. Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2018-01-19ARM: Document AArch64 version of qemu-armTuomas Tynkkynen
It's mostly obvious, except that QEMU is annoying and requires an explicit '-cpu cortex-a57' (or some other 64-bit core) to actually run in 64-bit mode. While at it, remove the references to setting the ARCH environment variable; that is not used in U-Boot. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-01-15doc: fix incorrect usage of DT node unit addressAndre Przywara
The DT spec demands a unit-address in a node name to match the "reg" property in that node. Newer dtc versions will throw warnings if this is not the case. Fix all occurences in various documentation files where this was not observed, to not give bad examples to the reader. Signed-off-by: Andre Przywara <andre.przywara@arm.com>
2018-01-15doc: FIT image: fix incorrect examples of DT node unit addressAndre Przywara
The DT spec demands a unit-address of a node name to match the "reg" property in that node. Newer dtc versions will throw warnings if this is not the case. Fix all occurences in the FIT image example files where this was not observed, to not give bad examples to the reader. Signed-off-by: Andre Przywara <andre.przywara@arm.com>
2018-01-15doc: FIT image: fix incorrect description of DT node unit addressAndre Przywara
The DT spec demands a unit-address in a node name to match the "reg" property in that node. Newer dtc versions will throw warnings if this is not the case. Fix all occurences in the FIT image documentation files where this was not observed, to not give bad examples to the reader. Signed-off-by: Andre Przywara <andre.przywara@arm.com>
2018-01-12riscv: doc: Add relative doc to describe RISC-VRick Chen
Add documents to describe NX25 and AE250. Also update other documents for RISC-V. Signed-off-by: Rick Chen <rick@andestech.com> Signed-off-by: Rick Chen <rickchen36@gmail.com> Signed-off-by: Greentime Hu <green.hu@gmail.com>
2018-01-10rockchip:usb: add a simple readme for rockusbEddie Cai
add a simple readme to introduce rockusb and tell people how to use it Signed-off-by: Eddie Cai <eddie.cai.linux@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-01-10doc: bindings: soft-spi: update documentation to match the codeMiquel Raynal
Linux bindings have been introduced in the code (removing the U-Boot specific ones) without documentation update. Compatible string has changed, as well as the four GPIO properties. Reflect this by updating the soft-spi.txt documentation. Fixes: 102412c415 ("dm: spi: soft_spi: switch to use linux compatible string") Signed-off-by: Miquel Raynal <miquel.raynal@free-electrons.com> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2017-12-14Merge git://git.denx.de/u-boot-dmTom Rini
2017-12-12power: extend prefix match to regulator-name propertyFelix Brack
This patch extends pmic_bind_children prefix matching. In addition to the node name the property regulator-name is used while trying to match prefixes. This allows assigning different drivers to regulator nodes named regulator@1 and regulator@10 for example. I have discarded the idea of using other properties then regulator-name as I do not see any benefit in using property compatible or even regulator-compatible. Of course I am open to change this if there are good reasons to do so. Signed-off-by: Felix Brack <fb@ltec.ch> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-12-12SPL: Add FIT data-position property supportPeng Fan
For external data, FIT has a optional property "data-position" which can set the external data to a fixed offset to FIT beginning. Add the support for this property in SPL FIT. Signed-off-by: Ye Li <ye.li@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tomas Melin <tomas.melin@vaisala.com> Cc: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Cc: "Andrew F. Davis" <afd@ti.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: "tomas.melin@vaisala.com" <tomas.melin@vaisala.com> Cc: Kever Yang <kever.yang@rock-chips.com> Cc: Andre Przywara <andre.przywara@arm.com> Cc: York Sun <york.sun@nxp.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Cc: "Cooper Jr., Franklin" <fcooper@ti.com> Cc: George McCollister <george.mccollister@gmail.com> Cc: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi> Cc: Jean-Jacques Hiblot <jjhiblot@ti.com> Cc: Rick Altherr <raltherr@google.com> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-12-11ARC: clk: introduce HSDK CGU clock driverEugeniy Paltsev
Synopsys HSDK clock controller generates and supplies clocks to various controllers and peripherals within the SoC. Each clock has assigned identifier and client device tree nodes can use this identifier to specify the clock which they consume. All available clocks are defined as preprocessor macros in the dt-bindings/clock/snps,hsdk-cgu.h header and can be used in device tree sources. Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com> Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2017-12-07log: Add documentationSimon Glass
Add documentation for the log system. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-11-30rockchip: rk3399-puma: add code to allow forcing a power-on resetPhilipp Tomsich
The reset circuitry in the RK3399 only resets 'almost all logic' when a software reset is performed. To make our software maintenance easier in the future, we want to have the option (controlled by a DTS property) to force all reset causes other than a power-on reset to trigger a power-on reset via a GPIO trigger. This adds the necessary support to the rk3399-puma (i.e. RK3399-Q7) board-support and the documentation for the new property (sysreset-gpio) within the /config-node. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Tested-by: Klaus Goger <klaus.goger@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-11-30dt-bindings: spi: Add andestech atcspi200 spi binding docRick Chen
Add a document to describe Andestech atcspi200 spi and binding information. Signed-off-by: Rick Chen <rick@andestech.com>
2017-11-30dt-bindings: timer: Add andestech atcpit100 timerRick Chen
Add a document to describe Andestech atcpit100 timer and binding information. Signed-off-by: rick <rick@andestech.com> Signed-off-by: Rick Chen <rickchen36@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-11-28Merge git://git.denx.de/u-boot-socfpgaTom Rini
2017-11-26ARM: socfpga: add bindings doc for arria10 fpga managerTien Fong Chee
This DT binding doc is porting from Linux DT binding doc. commit 1adcbea4201a6852362aa5ece573f1f169b28113 Add a device tree bindings document for the SoCFPGA Arria10 FPGA Manager driver. Signed-off-by: Alan Tull <atull@opensource.altera.com> Acked-by: Rob Herring <robh@kernel.org> Acked-By: Moritz Fischer <moritz.fischer@ettus.com> Signed-off-by: Rob Herring <robh@kernel.org> Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com>
2017-11-26MAINTAINERS: Update maintainer for USB xHCIBin Meng
As discussed with Marek, this adds myself as the maintainer to offload the USB xHCI part. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-11-21rockchip: rk3188: use boot0 hook to load up SPL in 2 stepsPhilipp Tomsich
For the RK3188, the BROM will attempt to load up the first stage image (SPL for the RK3188) in two steps: first 1KB to offset 0x800 in the SRAM and then the remainder to offset 0xc00 in the SRAM. It always enters at 0x804, though. With this changeset, the RK3188 boot removes the TPL (stub) stage and builds a single SPL binary that utilizes the early back-to-bootrom via the boot0-hook. Consequently, the passing of the saved boot params via pmu->os_reg[2] is also removed. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-11-21thermal: ti-bandgap: Add support for temperature sensorFaiz Abbas
The dra7xx series of SOCs contain a temperature sensor and an associated analog-to-digital converter (ADC) which produces an output which is proportional to the SOC temperature. Add support for this temperature sensor. Signed-off-by: Faiz Abbas <faiz_abbas@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-11-20Makefile: add coccicheck targetHeinrich Schuchardt
Coccinelle is a program for static code analysis. For details on Coccinelle see http://coccinelle.lip6.fr/ Add scripts/coccicheck copied from Linux kernel v4.14. The coccicheck script executes the tests *.cocci in directory scripts/coccinelle by calling spatch. In Makefile add a coccicheck target. You can use it with make coccicheck MODE=<mode> where mode in patch, report, context, org. Add a copy of Linux v4.14 file Documentation/dev-tools/coccinelle.rst as doc/README.coccinelle. Cc: Simon Glass <sjg@chromium.org> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2017-11-17env: Save environment at the end of an MMC partitionJorge Ramirez-Ortiz
Allow the platform to define a partition by name at the end of which the environment data will be located. Signed-off-by: Jorge Ramirez-Ortiz <jorge.ramirez-ortiz@linaro.org>
2017-11-10rockchip: doc: Fix U-Boot proper location for falconJagan Teki
This patch fixed U-Boot proper location has been missed to update in bewlo commit "rockchip: doc: update U-Boot location info" (sha1: 73e6dbe855f357a8330cfd53ff3033303611c1ad) Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-11-10rockchip: doc: update U-Boot location infoGoldschmidt Simon
The U-Boot location has been moved to block 16384. This is 8MB, not 4MB. Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-11-07rockchip: doc: update U-Boot location infoKever Yang
Update rockchip U-Boot location to 0x4000/16384. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-11-06m68k: doc: update outdated documentationAngelo Dureghello
Update m68k documentation to reflect the current ColdFire architecture support status. Signed-off-by: Angelo Dureghello <angelo@sysam.it>
2017-10-23doc: verified-boot: fix crypto algorithm examplesMasahiro Yamada
As you see in crypto_algos in common/image-sig.c, the algorithm should be either "rsa2048" or "rsa4096". "rs2048" is a typo. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-23doc: uniphier: add simple guide to Verified BootMasahiro Yamada
Add a simple documentation about how to use the Verified Boot on UniPhier boards. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-10-19x86: provide CONFIG_BUILD_ROMHeinrich Schuchardt
Up to now we depended on an exported variable to build u-boot.rom. We should be able to specify it in the configuration file, too. With this patch this becomes possible using the new Kconfig option CONFIG_BUILD_ROM. This option depends on CONFIG_X86 and is selected in qemu-x86_defconfig and qemu-x86_64_defconfig. Cc: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-10-19x86: minnowmax: Adjust VGA rom addressBin Meng
Adjust VGA rom address to 0xfffb0000 so that u-boot.rom image can be built again. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de>
2017-10-16ARM: Add documentation for the qemu-arm boardTuomas Tynkkynen
Add brief documentation for the recently merged qemu-arm board. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-10-12doc: update imx_usb_loader URLStefan Agner
The changes required to use U-Boot's Serial Download Protocol implementation are now available in upstream imx_usb_loader repository. Update the URL accordingly. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-10-12README.imx6: Prefer loading SPL via the new SDP mechanismFabio Estevam
Now that it is possible to load SPL and u-boot.img via imx_usb_loader tool, mention this method instead of the old one that relied on ymodem. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-10-10Merge branch 'rmobile' of git://git.denx.de/u-boot-shTom Rini
2017-10-06doc: Fix statements on case sensitivity for regulator prefixFelix Brack
The regulator bindings state that regulator prefixes are allowd to be in upper or lower case. However pmic_bind_children from pmic_uclass uses strncmp to compare DT node name against prefix. This comparison is case sensitive hence the regulator driver prefix case matters. Signed-off-by: Felix Brack <fb@ltec.ch>
2017-10-06spl: dm: Make it possible for the SPL to pick its own DTB from a FITJean-Jacques Hiblot
u-boot can be embedded within a FIT image with multiple DTBs. It then selects at run-time which one is best suited for the platform. Use the same principle here for the SPL: put the DTBs in a FIT image, compress it (LZO, GZIP, or no compression) and append it at the end of the SPL. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> [trini: Move default y of SPL_MULTI_DTB_FIT_DYN_ALLOC to it being the default choice if SYS_MALLOC_F, drop spl.h include from lib/fdtdec.c it's unused.] Signed-off-by Tom Rini <trini@konsulko.com>
2017-10-05dts: renamed FIT_EMBED to MULTI_DTB_FIT and moved it to the dts KconfigJean-Jacques Hiblot
CONFIG_FIT_EMBED might be confused with CONFIG_OF_EMBED, rename it MULTI_DTB_FIT as it is able to get a DTB from a FIT image containing multiple DTBs. Also move the option to the Kconfig dedicated to the DTS options and create a README for this feature. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-04doc: rmobile: Update READMEMarek Vasut
Update the README with build instructions for R8A7795/R8A7796 boards. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-10-03usb: gadget: Make g_dnl USB settings commonMaxime Ripard
The g_dnl USB settings for the vendor ID, product ID and manufacturer are actually common settings that can and should be shared by all the gadgets. Make them common by renaming them, and convert all the users. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-10-01rockchip: spl: support a 'same-as-spl'-specifier in the spl-boot-orderPhilipp Tomsich
It is often desirable to configure the spl-boot-order (i.e. the order that SPL probes devices to find the FIT image containing a full U-Boot) such that it contains 'the same device the SPL stage was booted from' early on. To support this, we introduce the 'same-as-spl' specifier for the spl-boot-order property. This commit adds: - documentation for the new board_spl_was_booted_from() function that individual SoCs/boards should provide, if they can determine where the SPL was booted from - implements the new board_spl_was_booted_from() stub function - adds support for handling the 'same-as-spl' specifier and calling into the per-SoC/per-board support code. This also updates the documentation for the 'u-boot,spl-boot-order' property. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-01rk3288: vyasa: Add TPL supportJagan Teki
Since the size of SPL can't be exceeded 0x8000 bytes in RK3288, it is not possible add new SPL features like Falcon mode or etc. So add TPL stage so-that adding new features to SPL is possible. - TPL: DRAM init, clocks - SPL: MMC, falcon, etc Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-09-22dm: reset: add stm32 reset driverPatrice Chotard
This driver is adapted from linux drivers/reset/reset-stm32.c It's compatible with STM32 F4/F7/H7 SoCs. This driver doesn't implement .of_match as it's binded by MFD RCC driver. To add support for each SoC family, a SoC's specific include/dt-binfings/mfd/stm32xx-rcc.h file must be added. This patch only includes stm32h7-rcc.h dedicated for STM32H7 SoCs. Other SoCs support will be added in the future. Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
