As suggested by Eugene O'Brien <Eugene.O'Brien@advantechamt.com>,
here an updated Bamboo README.
- now the Flash ST M29W040B is supported (not tested)
- fix the "led" command
- fix compile error, if BUILD_DIR is used
This patch removes the CFG_PCI_PRE_INIT option completely, since
it's not needed anymore with the patch from Matthias Fuchs with
the "weak" pci_pre_init() implementation.
e600 does not have a bootpg restriction.
Move the version string to beginning of image at fff00000.
Resetvec.S is not needed.
Update flash copy instructions.
Add tftpflash env variable
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
Signed-off-by: Domen Puncer <domen.puncer@telargo.com>
Move the 8641HPCN's PIXIS code to the new directory
board/freescale/common/ as it will be shared by
future boards not in the same processor family.
Write a "pixis_reset" command that utilizes the FPGA
reset sequencer to support alternate soft-reset options
such as using the "alternate" flash bank, enabling
the watch dog, or choosing different CPU frequencies.
Add documentation for the pixis_reset to README.mpc8641hpcn.
Signed-off-by: Haiying Wang <haiying.wang@freescale.com>
Added information about usage of NetConsole on systems where the -l and -p
switches are mutually exclusive.
Signed-off-by: Igor Marnat <marny@rambler.ru>
Signed-off-by: Ben Warren <bwarren@qstreams.com>
Add support for the MPC8349E-mITX-GP, a stripped-down version of the
MPC8349E-mITX. Bonus features include support for low-boot (BMS bit in
HRCW is 0) for the ITX and a README for the ITX and the ITX-GP.
I've redone the SBC8349 support to match git-current, which
incorporates all the MPC834x updates from Freescale since the 1.1.6
release, including the DDR changes.
I've kept all the SBC8349 files as parallel as possible to the
MPC8349EMDS ones for ease of maintenance and to allow for easy
inspection of what was changed to support this board. Hence the SBC8349
U-Boot has FDT support and everything else that the MPC8349EMDS has.
Fortunately the Freescale updates added support for boards using CS0,
but I had to change spd_sdram.c to allow for board specific settings for
the sdram_clk_cntl (it is/was hard coded to zero, and that remains the
default if the board doesn't specify a value.)
Hopefully this should be mergeable as-is and require no whitespace
cleanups or similar, but if something doesn't measure up then let me
know and I'll fix it.
Thanks,
Paul.
Add the MPC832XEMDS board readme
Signed-off-by: Dave Liu <daveliu@freescale.com>
The conflicts due to a new mpc7448 p3m7448 board is in the main tree.
Merge branch 'master' into hpc2
MAKEALL
cpu/74xx_7xx/cpu.c
cpu/74xx_7xx/cpu_init.c
cpu/74xx_7xx/speed.c
(1) remove some C++ comments.
(2) remove trailing white space.
(3) remove trailing empty line.
(4) Indentation by table.
(5) remove {} in one line condition.
(6) add space before '(' in function call.
Remove some weird printf () output.
Add necessary comments.
Modified Makefile to support building in a separate directory.
add doc/README.mpc8360emds to accompany the new board support
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
chpart, nboot and NAND subsystem related commands now accept also partition
name to specify offset.
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
Patch by Haavard Skinnemoen, 6 Sep 2006 16:23:02 +0200
This patch adds common infrastructure code for the Atmel AVR32
architecture. See doc/README.AVR32 for details.
Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
- JFFS2 related commands implemented in mtd-utils style
- Support for bad blocks
- Bad block testing commands
- NAND lock commands
Please take a look at doc/README.nand for more details
Patch by Guido Classen, 10 Oct 2006
board/stxxtc/Makefile
Patch by Stefan Roese, 12 Sep 2006
- Add support for PPC440EPx & PPC440GRx
- Add support for PPC440EP(x)/GR(x) NAND controller
in cpu/ppc4xx directory
- Add NAND boot functionality for Sequoia board,
please see doc/README.nand-boot-ppc440 for details
- This Sequoia NAND image doesn't support environment
in NAND for now. This will be added in a short while.
Patch by Stefan Roese, 07 Sep 2006
include/ft_build.h
include/pci.h
Resolved, though.
* Added comments and a printf to warn that PCI-X won't
work at 33MHz
Patch by Andy Fleming 17-Mar-2006
Signed-off-by: Andy Fleming <afleming@freescale.com>
AMCC suggested to set the PMU bit to 0 for best performace on
the PPC440 DDR controller.
Please see doc/README.440-DDR-performance for details.
Patch by Stefan Roese, 28 Jul 2006
Please see doc/README.bamboo for details.
Patch by Stefan Roese, 27 Jul 2006
Patch by Martin Krause, 8 Jun 2006
This patch supports two serial consoles on boards with
a MPC5xxx CPU. The console can be switched at runtime
by setting stdin, stdout and stderr to the desired serial
interface (serial0 or serial1). The PSCs to be used as
console port are definded by CONFIG_PSC_CONSOLE
and CONFIG_PSC_CONSOLE2.
See README.serial_multi for details.
Signed-off-by: Jon Loeliger <jdl@jdl.com>
relocate ichache_State to ram
u-boot can run from internal flash
Add EB+MCF-EV123 board support.
Add m68k Boards to MAKEALL
Patch from Jens Scharsig, 08 Aug 2005
multiple-bit errors.
