The splash image could be loaded from different sources (e.g. sf, mmc)
with different formats (e.g. raw, file-system). These sources are
structured by a board dependent object 'splash_location'. To decide
where is the splash image loaded, following environment variables are
used to select the splash source and file:
- 'splashsource' is used to select the splash source by setting its
value to specified name of splash location.
- 'splashfile' specify the name of splash image file
But, when loads the splash image from FIT, the name of splash image
within FIT is specified by splash location name. Due to the splash
location name is already used for the splash source, its name may
conflicts with the name of splash image.
To solve the conflict, the environment variable 'splashfile' is used
to specify the splash image in FIT, and keeps the splash location
name for the splash source.
Signed-off-by: Leo Ruan <tingquan.ruan@cn.bosch.com>
Signed-off-by: Mark Jonas <mark.jonas@de.bosch.com>
Reviewed-by: Stefano Babic <sbabic@denx.de>
Reviewed-by: Tomas Melin <tomas.melin@vaisala.com>
- A10 FPGA programming support, Gen5 livetree conversion
This patch adds description on properties about file name used for both
peripheral bitstream and core bitstream.
Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com>
This CPU core is old, no boards using the CPU are left in mainline,
it has no prospects of ever being converted to DM, drop it.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Chris Brandt <chris.brandt@renesas.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Cc: Vladimir Zapolskiy <vz@mleia.com>
Cc: Yoshihiro Shimoda <shimoda.yoshihiro.uh@renesas.com>
Improvements and new features:
- split more rockchip pinctrl_core feature into per SoC
- enable TPL for evb-rk3399 board
- enable TPL/SPL for evb-px5 board
- enable TPL and OP-TEE support for evb-rk3229
- update fix in arm common assembly start code for rockchip header file
- update default SPL_FIT_GENERATOR for rockchip
- rk3399 boards update to use '-u-boot.dtsi'
- add new rk3399 boards: Nanopi M4, Nanopc T4
- enable sound for chromebook_minnie
Since rockchip have an individual doc/README.rockchip, it would
be better to update the same instead of maintaining it separately
in board files.
So, add the documentation for rk3399
- procedure to build for Rockchip miniloader and
U-Boot SPL options
- procedure to boot from SD for Rockchip miniloader and
U-Boot SPL options
- procedure to build ATF, PMU M0 firmware for puma boards
- add boot logs of each option, so-that it would help for future
boards porting
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
- Various PHY fixes / enhancements.
- TI K2G fixes
Commit ff7bd212cb8a ("net: phy: micrel: fix divisor value for KSZ9031
phy skew") fixed the skew value divisor for the KSZ9031, but left the
code using the same divisor for the KSZ9021, which is incorrect.
The preceding commit c16e69f702b1 ("net: phy: micrel: add documentation
for Micrel KSZ90x1 binding") added the DTS documentation for the
KSZ90x1, changing it from the equivalent file in the Linux kernel to
correctly state that for this part the skew value is set in 120ps steps,
whereas the Linux documentation and driver continue to this day to use
the incorrect value of 200 that came from the original KSZ9021 datasheet
before it was corrected in revision 1.2 (Feb 2014).
This commit sorts out the resulting confusion in a consistent way by
making the following changes:
- Update the documentation to be clear about what the skew values mean,
in the same was as for the KSZ9031.
- Update the Micrel PHY driver to select the appropriate divisor for
both parts.
- Adjust all the device trees that state skew values for KSZ9021 PHYs to
use values based on 120ps steps instead of 200ps steps. This will result
in the same values being programmed into the skew registers as the
equivalent device trees in the Linux kernel do, where it incorrectly
uses 200ps steps (since that's where all these device trees were copied
from).
Signed-off-by: James Byrne <james.byrne@origamienergy.com>
There are quite a few variables which control where things appear in the
final ROM image. Add a flashmap in the documentation to make this easier
to figure out.
[bmeng: squashed "x86: Update the memory map a little" in]
[bmeng: fixed typo of 'documentation' in the commit title]
There are no more boards using this CPU and there is no prospect
of any boards showing up soon, remove it.
Cc: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com>
- Various btrfs fixes
- Various TI platform fixes
- Other fixes (cross build, taurus update, Kconfig help text)
The DM* family of SOCs is no longer supported. We now support the
omap-l138 lcdk board and Lego EV3 platform. Reflect those changes
in the README.
Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
Reviewed-by: Sekhar Nori <nsekhar@ti.com>
Update the mmc maintainer from Jaehoon to me.
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Signed-off-by: Peng Fan <peng.fan@nxp.com>
This updates MAINTAINERS and git-mailrc to add me as a
co-custodian for rockchip
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
Acked-by: Tom Rini <trini@konsulko.com>
As far back as 2011, "_armboot_start" was being described as "no
longer defined":
commit 297f18ac0fbeef30ba1c17fe131ca75f09a6e7cf
Author: Greg Ungerer <greg.ungerer@opengear.com>
Date: Fri Sep 9 22:23:34 2011 +1000
CM4000: fix broken flash base for OpenGear boards
Use _bss_start_ofs as the size of the boot loader code+data that we want
to protect in the flash. This replaces use of the no longer defined
_armboot_start.
Signed-off-by: Andrew F. Davis <afd@ti.com>
Reviewed-by: Andreas Dannenberg <dannenberg@ti.com>
co-custodian for socfpga.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
The driver add the support of the led IP on bcm6858.
This led IP can drive up to 32 leds, and can handle
blinking.
Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
In previously label which will be expanded to the node's full path was
used, and now replacing label with most commonly used DT phandle. The
codes were changed accordingly to the use of DT phandle and supporting
multiple instances.
The DK1 and DK2 boards use the USB Type-C controller STUSB1600.
This patch updates:
- the device tree to add the I2C node in the DT
- the board stm32mp1 to probe this I2C device and use this controller
to check cable detection.
- the DWC2 driver to support a new dt property
"u-boot,force-b-session-valid" which forces B session and
device mode; it is a workaround because the VBUS sensing and
ID detection isn't available with stusb1600.
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Add compatible "st,stm32mp1-hsotg" and associated driver data to manage
the usb33d-supply and the ST specific register for VBus sensing.
# Conflicts:
# drivers/usb/gadget/dwc2_udc_otg.c
Minimal conversion to driver model by using the uclass
UCLASS_USB_GADGET_GENERIC based on:
- reset uclass
- clock uclass
- generic uclass.
Move supply vdda1v1 and vdda1v8 in usbphyc node and
no more in port
In this small series we migrate ARC boards to DM_MMC
so we're hopefully are good now and our boards will be kept
in U-Boot for some more time :)
Add the DM_MMC-compatible DesignWare MMC driver support for Synopsys
ARC devboards. It is created to switch ARC devboards to use DM_MMC.
It required information such as clocks (Bus Interface Unit clock,
Card Interface Unit clock) and SDIO bus width.
Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com>
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
- drop non-DM code from ti_qspi
- support spi-mem for ti_qspi
Now that all boards using TI QSPI have moved to DM and DT, drop non DM
code completely.
Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com>
[jagan: update MIGRATION.txt, rebase config_whitelist.txt]
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
Pull request for UEFI sub-system for v2019.07-rc1 (2)
In the aarch64 crash dump information about the loaded EFI images is added.
In README.uefi the development target is for the UEFI subsystem is
described as "Embedded Base Boot Requirements (EBBR) Specification"
compliance.
Several bug fixes are supplied.
arch/arm/dts/armada-385-amc.dts
arch/arm/dts/armada-xp-theadorable.dts
arch/arm/dts/stm32mp157c-ev1-u-boot.dtsi
fdtdec tests and improvements for carve-outs
pinctrl race-condition fix
various other fixes in sandbox, sound, mkimage, etc.
Two subsets of the UEFI specifications have been defined. The one for
servers is "Server Base Boot Requirements System Software on ARM
Platforms" (SBBR), the one for embedded systems is the "Embedded Base Boot
Requirements (EBBR) Specification". Reaching compliance with thei EBBR is a
more realistic development target than reaching complicance with the SBBR.
Suggested-by: Alexander Graf <agraf@csgraf.de>
stm32 patches for v2019.07-rc1
- Add trusted boot with TF-A for stm32mp1
- stm32mp1 dts files sync'ed with Linux version
- add STM32MP1 Discovery boards (DK1 and DK2)
- add STMFX gpio expander driver
- misc improvement for stm3mp1 supports
- rename stpmu1 to stpmic1 (official name)
- stm32_qspi: move to exec_op (spi nor driver for stm32 mpu and mcu)
- add STM32 FMC2 NAND flash controller driver
This patch adds the documentation of the device tree bindings for the STM32
FMC2 NAND controller.
Signed-off-by: Christophe Kerello <christophe.kerello@st.com>
Reviewed-by: Patrick DELAUNAY <patrick.delaunay@st.com>
Missed few mails from openedev, since most of the day I look at
amarulasolutions mail so update the same.
Since all DTS files has been switched to "jedec,spi-nor", remove
the "spi-flash" compatible from the bindings examples.
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
Reviewed-by: Rick Chen <rick@andestech.com>
Reviewed-by: Patrick Delaunay <Patrick.delaunay@st.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
Update the kirkwood entry to match MAINTAINERS following commit
1579faf52b9f4 ("MAINTAINERS: Update u-boot-marvell entry").
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
The current documentation only covers how to chain-load U-Boot on a
Chromebook. Add more information about the other ways to use U-Boot on
Chromebooks.
In particular it is again possible to build it with Chromium OS
verified boot.
The 'u-boot,i2c-transaction-bytes' device tree property provides
information regarding number of bytes transferred by a device in a
single transaction.
This change is necessary to avoid hanging devices after soft reset.
One notable example is communication with MC34708 device:
1. Reset when communicating with MC34708 via I2C.
2. The u-boot (after reboot -f) tries to setup the I2C and then calls
force_idle_bus. In the same time MC34708 still has some data to be sent
(as it transfers data in 24 bits chunks).
3. The force_idle_bus() is not able to make the bus idle as 8 SCL
clocks may be not enough to have the full transmission.
4. We end up with I2C inconsistency with MC34708.
This PMIC device requires 24+ SCL cycles to make finish any pending I2C
transmission.
Signed-off-by: Lukasz Majewski <lukma@denx.de>
Add defconfig and board specific adjustments for the R8A77965 M3N ULCB.
The ohci driver calls board_usb_init(), not usb_board_init().
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
- Bugfixes:
- mmc: correct the HS400 initialization process
- configs: ti: Move FIT image load address to avoid overwrite
- lib: time: update module enable MACRO
- Add mbrugger as RPi board maintainer, correct agraf's email address.
Correct Alex's email address.
Reviewed-by: Alexander Graf <agraf@csgraf.de>
Describe the target scope of the UEFI implementation in U-Boot.
The following TODOs are closed:
- GetNextVariableName is not implemented
- event groups
- manage events in a linked list
We currently only support EFI_FILE_PROTOCOL_REVISION while
UEFI specs 2.4 - 2.7 prescribe EFI_FILE_PROTOCOL_REVISION2.
Add a todo.
Add missing constants for the EFI file protocol revision.
Changing voltage and enabling regulator might require delays so the
regulator stabilizes at expected level.
Add support for "regulator-ramp-delay" binding which can introduce
required time to both enabling the regulator and to changing the
voltage.
Tested-by: Anand Moon <linux.amoon@gmail.com>
Alignment with kernel directory name as it have already bindings for
DDR controllers in the directory:
Documentation/devicetree/bindings/memory-controller
PS: the drivers using RAM u-class should be associated with
this binding directory
The readme guide describes the procedure to build, flash and boot Linux
using U-Boot on HiFive Unleashed. It also explains the current state of
U-boot support and future action items.
Signed-off-by: Atish Patra <atish.patra@wdc.com>
Signed-off-by: Anup Patel <anup.patel@wdc.com>
Reviewed-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de>
This patch adds fixed-factor clock driver which derives clock
rate by dividing (div) and multiplying (mult) fixed factors
to a parent clock.
