Add some documentation describing how USB is implemented with USB. This
might make things easier for people to understand.
This commit adds driver model support to software emulated i2c bus driver.
This driver supports kernel-style device tree bindings. Fdt properties in use:
- compatible - "i2c-gpio"
- gpios - data and clock GPIO pin phandles
- delay-us - micro seconds delay between GPIOs toggle operations,
which is 1/4 of I2C speed clock period.
Added:
- Config: CONFIG_DM_I2C_GPIO
- File: drivers/i2c/i2c-gpio.c
- File: doc/device-tree-bindings/i2c/i2c-gpio.txt
Driver base code is taken from: drivers/i2c/soft-i2c.c, changes:
- use "i2c-gpio" naming
- update comments style
- move preprocesor macros into functions
- add device tree support
- add driver model i2c support
- code cleanup,
- add Kconfig entry
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
Added braces in i2c_gpio_xfer() to fix style nit:
First just add support for MAC drivers.
Add a uclass for PCI controllers and a generic one for PCI devices. Adjust
the 'pci' command and the existing PCI support to work with this new uclass.
Keep most of the compatibility code in a separate file so that it can be
removed one day.
TODO: Add more header file comments to the new parts of pci.h
At present a VGA console assumes a keyboard unless a CONFIG option is set.
This difference can be dealt with by a device tree option, allowing boards
that are otherwise the same to use the same configuration.
Implement an alias name check for devices where GPT limitations prevent
user-friendly partition names such as "boot", "system" and "cache". Or,
where the actual partition name doesn't match a standard partition name
used commonly with fastboot.
To set an alias, add an environment setting as follows:
fastboot_partition_alias_<alias partition name>=<actual partition name>
Example: fastboot_partition_alias_boot=LNX
Signed-off-by: Michael Scott <michael.scott@linaro.org>
Acked-by: Steve Rae <srae@broadcom.com>
Cc: Steve Rae <srae@broadcom.com>
Cc: Lukasz Majewski <l.majewski@samsung.com>
Include/fsl_sec.h defines sec_in and sec_out, according to the
platform's endianess. Therefore, CONFIG_SYS_FSL_LE needs to be
declared in the configuration file of the target, in order to use
enable the DEK blob generation command. This requirement is not
explicit in the README.mxc_hab.
Signed-off-by: Ulises Cardenas <Ulises.Cardenas@freescale.com>
Add support to configure PWM_OUT(PWM output) GPIO and
BL_EN(backlight enable) GPIO, if provided in FIMD DT node.
Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com>
This option was removed along with legacy NAND support in
be33b046b549ad88c204c209508cd7657232ffbd. Clean up some remnants.
Instead of sprinkling custom code and calls over the Vexpress64
boardfile, create a command that loads images using semihosting
just like we would load from flash memory of over the network,
using a special command:
smhload <image> <address>
This will make it possible to remove some custom calls and
code and make the boot easier.
config_distro_bootcmd.h defines a common boot environment for multiple
platforms, including several environment variables that are intended for
interactive use by an end-user. Document which variables are considered
public interfaces that must remain compatible in future u-boot versions.
Signed-off-by: Karsten Merker <merker@debian.org>
Move the option to Kconfig renaming it to CONFIG_HAVE_GENERIC_BOARD.
Reviewed-by: Alexey Brodkin <abrodkin@synopsys.com>
README.drivers.eth still refers to the deprecated miiphy_register().
Update the doc to mention new APIs mdio_alloc() and mdio_register().
The FSP release version 001 for Intel Queensbay has a bug which
could cause random endless loop during the FspInit call. This bug
was published by Intel although Intel did not describe any details.
Describe this information in the x86 doc so that U-Boot Queensbay
support is invulnerable.
This has not been converted to Generic Board, so should be removed.
(See doc/README.generic-board for details.)
Cc: Larry Johnson <lrj@acm.org>
Cc: Eric Millbrandt <emillbrandt@dekaresearch.com>
They have not been converted to Generic Board, so should be removed.
Cc: Erik Theisen <etheisen@mindspring.com>
Cc: Stephen Williams <steve@icarus.com>
I have transferred to Socionext Inc.
1. esbc_validate command is meant for validating header and
signature of images (Boot Script and ESBC uboot client).
SHA-256 and RSA operations are performed using SEC block in HW.
This command works on both PBL based and Non PBL based Freescale
platforms.
Command usage:
esbc_validate img_hdr_addr [pub_key_hash]
2. ESBC uboot client can be linux. Additionally, rootfs and device
tree blob can also be signed.
3. In the event of header or signature failure in validation,
ITS and ITF bits determine further course of action.
4. In case of soft failure, appropriate error is dumped on console.
5. In case of hard failure, SoC is issued RESET REQUEST after
dumping error on the console.
6. KEY REVOCATION Feature:
QorIQ platforms like B4/T4 have support of srk key table and key
revocation in ISBC code in Silicon.
The srk key table allows the user to have a key table with multiple
keys and revoke any key in case of particular key gets compromised.
In case the ISBC code uses the key revocation and srk key table to
verify the u-boot code, the subsequent chain of trust should also
use the same.
6. ISBC KEY EXTENSION Feature:
This feature allows large number of keys to be used for esbc validation
of images. A set of public keys is being signed and validated by ISBC
which can be further used for esbc validation of images.
Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com>
Signed-off-by: Gaurav Rana <gaurav.rana@freescale.com>
Reviewed-by: York Sun <yorksun@freescale.com>
Currently, an environment variable must be used to store the randomly
generated UUID for each partition. This is not necessary, so make storing
the UUID optional. Now passing uuid_disk and uuid are optional when random
UUIDs are enabled.
Signed-off-by: Rob Herring <robh@kernel.org>
Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
The code provides framework for heterogeneous multicore chips based on StarCore
and Power Architecture which are chasis-2 compliant, like B4860 and B4420
It will make u-boot recognize all non-ppc cores and peripherals like
SC3900/DSP CPUs, MAPLE, CPRI and print their configuration in u-boot logs.
Example boot logs of B4860QDS:
U-Boot 2015.01-00232-geef6e36-dirty (Jan 19 2015 - 11:58:45)
CPU0: B4860E, Version: 2.2, (0x86880022)
Core: e6500, Version: 2.0, (0x80400120)
Clock Configuration:
CPU0:1600 MHz, CPU1:1600 MHz, CPU2:1600 MHz, CPU3:1600 MHz,
DSP CPU0:1200 MHz, DSP CPU1:1200 MHz, DSP CPU2:1200 MHz, DSP CPU3:1200 MHz,
DSP CPU4:1200 MHz, DSP CPU5:1200 MHz,
CCB:666.667 MHz,
DDR:933.333 MHz (1866.667 MT/s data rate) (Asynchronous), IFC:166.667 MHz
CPRI:600 MHz
MAPLE:600 MHz, MAPLE-ULB:800 MHz, MAPLE-eTVPE:1000 MHz
FMAN1: 666.667 MHz
QMAN: 333.333 MHz
Top level changes include:
(1) Top level CONFIG to identify HETEROGENUOUS clusters
(2) CONFIGS for SC3900/DSP components
(3) Global structures like "cpu_type" and "MPC85xx_SYS_INFO"
updated for dsp cores and other components
(3) APIs to get DSP num cores and their Mask like:
cpu_dsp_mask, cpu_num_dspcores etc same as that of PowerPC
(5) Code to fetch and print SC cores and other heterogenous
device's frequencies
(6) README added for the same
Signed-off-by: Shaveta Leekha <shaveta@freescale.com>
Freescale's SEC block has built-in Data Encryption
Key(DEK) Blob Protocol which provides a method for
protecting a DEK for non-secure memory storage.
SEC block protects data in a data structure called
a Secret Key Blob, which provides both confidentiality
and integrity protection.
Every time the blob encapsulation is executed,
a AES-256 key is randomly generated to encrypt the DEK.
This key is encrypted with the OTP Secret key
from SoC. The resulting blob consists of the encrypted
AES-256 key, the encrypted DEK, and a 16-bit MAC.
During decapsulation, the reverse process is performed
to get back the original DEK. A caveat to the blob
decapsulation process, is that the DEK is decrypted
in secure-memory and can only be read by FSL SEC HW.
The DEK is used to decrypt data during encrypted boot.
Commands added
dek_blob - encapsulating DEK as a cryptgraphic blob
Commands Syntax
dek_blob src dst len
Encapsulate and create blob of a len-bits DEK at
address src and store the result at address dst.
Signed-off-by: Raul Cardenas <Ulises.Cardenas@freescale.com>
Signed-off-by: Nitin Garg <nitin.garg@freescale.com>
Signed-off-by: Ulises Cardenas <ulises.cardenas@freescale.com>
Signed-off-by: Ulises Cardenas-B45798 <Ulises.Cardenas@freescale.com>
Support xHCI host driver used on Panasonic UniPhier platform.
Adds the fastboot erase functionality, to erase a partition
specified by name. The erase is performed based on erase group size,
to avoid erasing other partitions. The start address and the size
is aligned to the erase group size for this.
Currently only supports erasing from eMMC.
Signed-off-by: Dileep Katta <dileep.katta@linaro.org>
Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
This is still a non-generic board.
Acked-by: Sughosh Ganu <urwithsughosh@gmail.com>
Cc: Syed Mohammed Khasim <sm.khasim@gmail.com>
Cc: Chan-Taek Park <c-park@ti.com>
Cc: Po-Yu Chuang <ratbert@faraday-tech.com>
These are still non-generic boards.
Cc: Greg Ungerer <greg.ungerer@opengear.com>
Cc: Lei Wen <leiwen@marvell.com>
Cc: Matthias Weisser <weisserm@arcor.de>
When Kconfig for U-boot was examined, one of the biggest issues was
how to support multiple images (Normal, SPL, TPL). There were
actually two options, "single .config" and "multiple .config".
After some discussions and thought experiments, I chose the latter,
i.e. to create ".config", "spl/.config", "tpl/.config" for Normal,
SPL, TPL, respectively.
It is true that the "multiple .config" strategy provided us the
maximum flexibility and helped to avoid duplicating CONFIGs among
Normal, SPL, TPL, but I have noticed some fatal problems:
[1] It is impossible to share CONFIG options across the images.
If you change the configuration of Main image, you often have to
adjust some SPL configurations correspondingly. Currently, we
cannot handle the dependencies between them. It means one of the
biggest advantages of Kconfig is lost.
[2] It is too painful to change both ".config" and "spl/.config".
Sunxi guys started to work around this problem by creating a new
configuration target. Commit cbdd9a9737cc (sunxi: kconfig: Add
%_felconfig rule to enable FEL build of sunxi platforms.) added
"make *_felconfig" to enable CONFIG_SPL_FEL on both images.
Changing the configuration of multiple images in one command is a
generic demand. The current implementation cannot propose any
good solution about this.
[3] Kconfig files are getting ugly and difficult to understand.
Commit b724bd7d6349 (dm: Kconfig: Move CONFIG_SYS_MALLOC_F_LEN to
Kconfig) has sprinkled "if !SPL_BUILD" over the Kconfig files.
[4] The build system got more complicated than it should be.
To adjust Linux-originated Kconfig to U-Boot, the helper script
"scripts/multiconfig.sh" was introduced. Writing a complicated
text processor is a shell script sometimes caused problems.
Now I believe the "single .config" will serve us better. With it,
all the problems above would go away. Instead, we will have to add
some CONFIG_SPL_* (and CONFIG_TPL_*) options such as CONFIG_SPL_DM,
but we will not have much. Anyway, this is what we do now in
scripts/Makefile.spl.
I admit my mistake with my apology and this commit switches to the
single .config configuration.
It is not so difficult to do that:
- Remove unnecessary processings from scripts/multiconfig.sh
This file will remain for a while to support the current defconfig
format. It will be removed after more cleanups are done.
- Adjust some makefiles and Kconfigs
- Add some entries to include/config_uncmd_spl.h and the new file
scripts/Makefile.uncmd_spl. Some CONFIG options that are not
supported on SPL must be disabled because one .config is shared
between SPL and U-Boot proper going forward. I know this is not
a beautiful solution and I think we can do better, but let's see
how much we will have to describe them.
- update doc/README.kconfig
More cleaning up patches will follow this.
This patch ensures that the TZPC (BP147) and TZASC-400 programming
happens for LS2085A SoC only when the desired config flags are
enabled and ensures that the TZPC programming is done to allow Non-secure
(NS) + secure (S) transactions only for DCGF registers.
The TZASC component is not present on LS2085A-Rev1, so the TZASC-400
config flag is turned OFF for now.
Signed-off-by: Bhupesh Sharma <bhupesh.sharma@freescale.com>
Some boards cannot do voltage negotiation but need to set the VSELECT
bit forcely to ensure it to work at 1.8V.
This commit adds CONFIG_SYS_FSL_ESDHC_FORCE_VSELECT flag for this use.
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
[ imported from Linux Kernel, commit 74981fb81d83 ]
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Some exynos boards require special handling of nRESET_OUT line for eMMC
memory to perform complete reboot e.g. Odroid X2/U3/XU3 boards.
This will support eMMC reset using DT from reset_misc of samsung common
board file.
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Expand the help messages for each driver. Add missing Kconfig for I2C,
SPI flash and thermal.
Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
Add some instructions about building U-Boot for Intel Galileo board.
