path: root/doc
2016-12-03image: Add FIT image loadable section custom processingAndrew F. Davis
To help automate the loading of custom image types we add the ability to define custom handlers for the loadable section types. When we find a compatible type while loading a "loadable" image from a FIT image we run its associated handlers to perform any additional steps needed for loading this image. Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-11-29Merge git://git.denx.de/u-boot-mpc85xxTom Rini
2016-11-28serial: pl01x: expose skip_init platdata option in DTFabian Vogt
To be able to represent the skip-init platdata element with OF_CONTROL, it needs to be read from the device tree as well and put into the platform data. Cc: Eric Anholt <eric@anholt.net> Signed-off-by: Fabian Vogt <fvogt@suse.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-11-28serial: bcm283x_mu: add device tree supportFabian Vogt
This patch adds device tree support for the bcm283x mini-uart driver. Signed-off-by: Fabian Vogt <fvogt@suse.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-11-28gpio: bcm2835: add device tree supportFabian Vogt
This patch adds device tree support for the bcm2835 GPIO driver. Signed-off-by: Fabian Vogt <fvogt@suse.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-11-23powerpc: P2010: Drop configuration for P2010York Sun
P2010 is a single-core version of P2020. There is no P2010 target configured. Drop related macros. P2010 SoC is still supported. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P1014: Drop configuration for P1014York Sun
P1014 is a variant of P1010. There is no P1014 target configured. Drop related macros. P1014 SoC is still supported. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P1013: Drop configuration for P1013York Sun
P1013 is a single-core version of P1022. There is no P1022 target configured. Drop related macros. P1022 SoC is still supported. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P1012: Drop configuration for P1012York Sun
P1012 is a single-core version of P1021. There is no P1012 target configured. Drop related macros. P1012 SoC is still supported. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: MPC8560ADS: Remove macro CONFIG_MPC8560ADSYork Sun
This macro is no longer used. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: MPC8540ADS: Remove macro CONFIG_MPC8540ADSYork Sun
2016-11-23powerpc: mpc8540: Remove macro CONFIG_MPC8540York Sun
Replace CONFIG_MPC8540 with ARCH_MPC8540 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-22MAINTAINERS: SUNXI: Update maintainershipJagan Teki
Add Jagan and Maxime as Maintainers for SUNXI Signed-off-by: Jagan Teki <jagan@openedev.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2016-11-18sf: Rename sf_params.c to spi_flash_ids.cJagan Teki
Now the flash params table as renamed to spi_flash_ids structure, so rename the sf_params.c to spi_flash_ids.c and remove the legacy. Cc: Bin Meng <bmeng.cn@gmail.com> Cc: York Sun <york.sun@nxp.com> Cc: Vignesh R <vigneshr@ti.com> Cc: Mugunthan V N <mugunthanvnm@ti.com> Cc: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Jagan Teki <jagan@openedev.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Tested-by: Jagan Teki <jagan@openedev.com> Reviewed-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
2016-11-14x86: Enable EFI loader supportSimon Glass
Enable this so that EFI applications (notably grub) can be run under U-Boot on x86 platforms. At present the 'hello world' EFI application is not supported for the qemu-x86_efi_payload64 board. That board builds a payload consisting of a 64-bit header and a 32-bit U-Boot, which is incompatible with the way the EFI loader builds its EFI application. The following error is obtained: x86_64-linux-ld.bfd: i386 architecture of input file `lib/efi_loader/helloworld.o' is incompatible with i386:x86-64 output This could be corrected with additional Makefile rules. For now, this feature is disabled for that board. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> [agraf: drop hello kconfig bits] Signed-off-by: Alexander Graf <agraf@suse.de>
2016-11-14efi: Add support for a hello world test programSimon Glass
It is useful to have a basic sanity check for EFI loader support. Add a 'bootefi hello' command which loads HelloWord.efi and runs it under U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org> [agraf: Fix documentation, add unfulfilled kconfig dep] Signed-off-by: Alexander Graf <agraf@suse.de>
2016-11-07Merge branch 'master' of git://git.denx.de/u-boot-netTom Rini
2016-11-07dt: net: add DWC EQoS bindingStephen Warren
The Synopsys DWC EQoS is a configurable Ethernet MAC/DMA IP block which supports multiple options for bus type, clocking and reset structure, and feature list. This patch imports the binding from the Linux kernel, including my V3 patch to extend the binding to cover the Tegra186, which is applied for next-20160912. So far, my changes have been acked by Lars Persson, the original author of the binding. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-11-06mkimage: Allow including a ramdisk in FIT auto modeTomeu Vizoso
Adds -i option that allows specifying a ramdisk file to be added to the FIT image when we are using the automatic FIT mode (no ITS file). This makes adding Depthcharge support to LAVA much more convenient, as no additional configuration files need to be kept around in the machine that dispatches jobs to the boards. Signed-off-by: Tomeu Vizoso <tomeu.vizoso@collabora.com> Cc: Simon Glass <sjg@chromium.org> Cc: Matt Hart <matthew.hart@linaro.org> Cc: Neil Williams <codehelp@debian.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-11-05doc: update README.arm64Andre Przywara
This file apparently hasn't seen an update in a while, so just sync it with reality. Signed-off-by: Andre Przywara <andre.przywara@arm.com>
2016-10-30rockchip: doc: add GPT partition layoutJacob Chen
A simple introduction. Signed-off-by: Jacob Chen <jacob2.chen@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-29MAINTAINERS: Update Jagan's emailJagan Teki
2016-10-18ARM: uniphier: update doc/README.uniphierMasahiro Yamada
- Rephrase the toolchains section. Leave only Linaro toolchains since it is the most tested these days. - Add build instruction for ARMv8 SoC boards - Add information about "ddrmphy" command Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-10-18ARM: dts: uniphier: sync DT with latest LinuxMasahiro Yamada
2016-10-12x86: coreboot: Convert to use DM coreboot video driverBin Meng
This converts coreboot to use DM framebuffer driver. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-12x86: doc: Correct qfw command exampleBin Meng
The kernel load address for zboot should be 0x1000000. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-12x86: doc: Document coreboot framebuffer driver issue on QEMUBin Meng
For some unknown reason, coreboot framebuffer driver never works on QEMU since day 1. It seems the driver only works on real hardware. Document this issue. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-08Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2016-10-07power: pmic: add Ricoh RN5T567 PMIC supportStefan Agner
Add device model enabled PMIC driver for Ricoh RN5T567 PMIC used on Colibri iMX7. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-07dm: imx: serial: support device treeStefan Agner
Support instatiation through device tree. Also parse the fsl,dte-mode property to determine whether DTE mode shall be used. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-06doc: typo fix addess -> addressJelle van der Waa
Signed-off-by: Jelle van der Waa <jelle@vdwaa.nl>
2016-10-06README: Fix CONFIG_SYS_NAND_MAX_DEVICE typoSimon Glass
This should be CONFIG_SYS_MAX_NAND_DEVICE. Fix it. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Scott Wood <oss@buserror.net> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-10-06README: Drop CONFIG_MPC8349ADSSimon Glass
This option is not used now. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-10-06README: Drop README.imx31Simon Glass
The only content of this file is CONFIG options which are no-longer present in U-Boot. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-10-06atmel: Drop README.at91-socSimon Glass
This issue covered by this doc appears to be fixed, so let's remove the README. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com> Acked-by: Andreas Bießmann <andreas@biessmann.org>
2016-10-06README: Drop unused JFFS2 optionsSimon Glass
There appear to be neither implemented nor used. Drop them. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-10-04README.imx6: Fix Boundary Devices nameFabio Estevam
Correct name is "Boundary Devices". Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-10-02doc: Update info on using AM33xx secure devices from TIAndrew F. Davis
Add a section describing the additional boot types used on AM33xx secure devices. Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com>
2016-10-01disk: part: refactor generic name creation for DOS and ISOPetr Kulhavy
In both DOS and ISO partition tables the same code to create partition name like "hda1" was repeated. Code moved to into a new function part_set_generic_name() in part.c and optimized. Added recognition of MMC and SD types, name is like "mmcsda1". Signed-off-by: Petr Kulhavy <brain@jikos.cz> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Steve Rae <steve.rae@raedomain.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-01fastboot: add support for writing MBRPetr Kulhavy
Add special target "mbr" (otherwise configurable via CONFIG_FASTBOOT_MBR_NAME) to write MBR partition table. Partitions are now searched using the generic function which finds any partiiton by name. For MBR the partition names hda1, sda1, etc. are used. Signed-off-by: Petr Kulhavy <brain@jikos.cz> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Steve Rae <steve.rae@raedomain.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-21boston: Introduce support for the MIPS Boston development boardPaul Burton
This patch introduces support for building U-Boot to run on the MIPS Boston development board. This is a board built around an FPGA & an Intel EG20T Platform Controller Hub, used largely as part of the development of new CPUs and their software support. It is essentially the successor to the older MIPS Malta board. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2016-09-07pxe: Modify README to add the description about FIT imageWenbin Song
Use environment variable "kernel_addr_r" to indicate the location in RAM where FIT image will be stored. Use label command "kernel" to indicate which <path> the FIT image at. Signed-off-by: Wenbin Song <wenbin.song@nxp.com>
2016-09-06regulator: fixed: obey startup delayJohn Keeping
When enabling a fixed regulator, it may take some time to rise to the correct voltage. If we do not delay here then subsequent operations will fail. Signed-off-by: John Keeping <john@metanate.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-08-26treewide: fix "followings" to "following"Masahiro Yamada
Most of them are my mistakes. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-08-16x86: Mention running U-Boot in 64-bit mode in the READMESimon Glass
This feature is not supported. Document this, and add some details on how it might be implemented. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-08-16x86: Add a reference to README.efiSimon Glass
UEFI is commonly used on x86. Add a reference to U-Boot's support for this in the x86 README. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-08-16x86: Mention how to boot a 64-bit kernel from U-BootSimon Glass
The README indicates that this is not supported, but this is no-longer true. Update the text to indicate this and describe the FIT changes required. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-08-16x86: doc: Add note about the debug FSP usage on BayTrailStefan Roese
The debug FSP image is bigger in size than the normal FSP image. This patch adds a small description on how to use this FSP debug version by changing CONFIG_FSP_ADDR. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-08-15xtensa: add support for the xtensa processor architecture [1/2]Chris Zankel
The Xtensa processor architecture is a configurable, extensible, and synthesizable 32-bit RISC processor core provided by Cadence. This is the first part of the basic architecture port with changes to common files. The 'arch/xtensa' directory, and boards and additional drivers will be in separate commits. Signed-off-by: Chris Zankel <chris@zankel.net> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-08-15atmel: Bring in at91 pio4 device tree file and bindingsWenyou Yang
Bring in required device tree file and bindings from Linux. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Andreas Bießmann <andreas@biessmann.org> Reviewed-by: Simon Glass <sjg@chromium.org>
