path: root/doc
2017-05-29doc: document u-boot, mmc-env-offset and u-boot, mmc-env-offset-redundPhilipp Tomsich
Adding documentation on the new config properties: 'u-boot,mmc-env-offset' - overrides CONFIG_ENV_OFFSET 'u-boot,mmc-env-offset-redundant' - overrides CONFIG_ENV_OFFSET_REDUND Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2017-05-22Merge git://git.denx.de/u-boot-sunxiTom Rini
trini: Make Kconfig SPL_xxx entires only show if SPL, so that we don't get Kconfig errors on platforms without SPL, ie sandbox (without SPL). Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22fs: Kconfig: Add a separate option for FS_JFFS2Simon Glass
Rather than using CMD_JFFS2 for both the filesystem and its command, we should have a separate option for each. This allows us to enable JFFS2 support without the command, if desired, which reduces U-Boot's size slightly. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-17SPL: FIT: allow loading multiple imagesAndre Przywara
So far we were not using the FIT image format to its full potential: The SPL FIT loader was just loading the first image from the /images node plus one of the listed DTBs. Now with the refactored loader code it's easy to load an arbitrary number of images in addition to the two mentioned above. As described in the FIT image source file format description, iterate over all images listed at the "loadables" property in the configuration node and load every image at its desired location. This allows to load any kind of images: - firmware images to execute before U-Boot proper (for instance ARM Trusted Firmware (ATF)) - firmware images for management processors (SCP, arisc, ...) - firmware images for devices like WiFi controllers - bit files for FPGAs - additional configuration data - kernels and/or ramdisks The actual usage of this feature would be platform and/or board specific. Also update the FIT documentation to mention the new SPL feature and provide an example .its file to demonstrate its features. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Lokesh Vutla <lokeshvuta@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Heiko Stuebner <heiko@sntech.de> Reviewed-by: Kever Yang <kever.yang@rock-chips.com> Tested-by: Kever Yang <kever.yang@rock-chips.com> Tested-by: Jagan Teki <jagan@openedev.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-05-17x86: Document ACPI S3 supportBin Meng
Now that we have ACPI S3 support on Intel MinnowMax board, document some generic information of S3 and how to test it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Stefan Roese <sr@denx.de>
2017-05-15omap5: Migrate CONFIG_OMAP_PLATFORM_RESET_TIME_MAX_USEC to KconfigTom Rini
While in theory this value could be used in places outside of "omap5" (such as OMAP4), we only make use of it today in OMAP5, so place the Kconfig entry there. Given that Kconfig lets us provide a default, we drop CONFIG_DEFAULT_OMAP_RESET_TIME_MAX_USEC entirely. The contents of doc/README.omap-reset-time make a good help entry, so adjust them slightly and delete the file. Move the comment about range to where we use the value now, and have Kconfig enforce the upper bound. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-11doc: document /config/u-boot, spl-payload-offset propertyPhilipp Tomsich
This adds documentation on the u-boot,spl-payload-offset property (which overrides CONFIG_SYS_SPI_U_BOOT_OFFS during the SPI loading in the SPL stage, if present). Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-05-10Merge git://git.denx.de/u-boot-rockchipTom Rini
This adds a new firefly-rk3399 board, MIPI support for rk3399 and rk3288, rk818 pmic support, mkimage improvements for rockchip and a few other things.
2017-05-10Merge branch 'master' of git://git.denx.de/u-boot-mipsTom Rini
2017-05-10doc: dtbinding: add pwm binding fileKever Yang
This is a copy from kernel. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-05-10dm: led: add BCM6358 led driverÁlvaro Fernández Rojas
This driver is a simplified version of linux/drivers/leds/leds-bcm6358.c Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-10dm: led: add BCM6328 led driverÁlvaro Fernández Rojas
This driver is a simplified version of linux/drivers/leds/leds-bcm6328.c, simplified to remove HW leds and blink fallbacks. Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-09Allow boards to initialize the DT at runtime.Alex Deymo
In some boards like the Raspberry Pi the initial bootloader will pass a DT to the kernel. When using U-Boot as such kernel, the board code in U-Boot should be able to provide U-Boot with this, already assembled device tree blob. This patch introduces a new config option CONFIG_OF_BOARD to use instead of CONFIG_OF_EMBED or CONFIG_OF_SEPARATE which will initialize the DT from a board-specific funtion instead of bundling one with U-Boot or as a separated file. This allows boards like the Raspberry Pi to reuse the device tree passed from the bootcode.bin and start.elf firmware files, including the run-time selected device tree overlays. Signed-off-by: Alex Deymo <deymo@google.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-08ARM: DT: stm32f7: add sdram pin contol nodeVikas Manocha
Also added DT binding doc for stm32 fmc(flexible memory controller). Signed-off-by: Vikas Manocha <vikas.manocha@st.com> cc: Christophe KERELLO <christophe.kerello@st.com>
2017-04-14Merge branch 'master' of git://git.denx.de/u-boot-videoTom Rini
2017-04-14at91: video: DT binding for HLCDC driverSongjun Wu
DT binding documentation for atmel HLCDC driver. Signed-off-by: Songjun Wu <songjun.wu@microchip.com>
2017-04-14Merge branch 'master' of git://git.denx.de/u-boot-socfpgaTom Rini
2017-04-14ARM: socfpga: add fpga build and bsp handoff instructions to readmeStephen Arnold
This patch adds the steps to manually (re)build a Quartus FPGA project, generate the required BSP glue, and update u-boot handoff files for mainline SPL support. Requires Quartus toolchain and current U-Boot. Signed-off-by: Steve Arnold <stephen.arnold42@gmail.com> Cc: Dinh Nguyen <dinguyen@kernel.org> Cc: Stefan Roese <sr@denx.de> Cc: Marek Vasut <marex@denx.de>
2017-04-13Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
Drop CONFIG_STACKSIZE from include/configs/imx6_logic.h Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-13board_f: Rename initdram() to dram_init()Simon Glass
This allows us to use the same DRAM init function on all archs. Add a dummy function for arc, which does not use DRAM init here. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Dummy function on nios2] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-08doc: Updates info on using Keystone2 secure devicesMadan Srinivas
Add a section describing the secure boot image used on Keystone2 secure devices. Signed-off-by: Madan Srinivas <madans@ti.com> Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-04-05ARM: mxs: Rename M28EVKMarek Vasut
The board is now manufactured by Aries Embedded GmbH , rename it. Signed-off-by: Marek Vasut <marex@denx.de>
2017-04-04rockchip: Add support for MiQi rk3288 boardJernej Skrabec
MiQi is rk3288 based development board with 1 or 2 GB SDRAM, 16 GB eMMC, micro SD card interface, 4 USB 2.0 ports, HDMI, gigabit Ethernet and expansion ports. Signed-off-by: Jernej Skrabec <jernej.skrabec@siol.net> Reviewed-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Eddie Cai <eddie.cai.linux@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-04-04rockchip: cosmetic: Sort RK3288 boardsJernej Skrabec
Sort rk3288 boards in alphabetical order. Signed-off-by: Jernej Skrabec <jernej.skrabec@siol.net> Reviewed-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Eddie Cai <eddie.cai.linux@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-04-04rockchip: rk3399: spl: make SPL boot-order configurable via /chosenPhilipp Tomsich
The RK3399 does not have any boot selection pins and the BootROM probes the boot interfaces using the following boot-order: 1. SPI 2. eMMC (sdhci in DTS) 3. SD card (sdmmc in DTS) 4. USB loader For ease of deployment, the SPL stage should mirror the boot order of the ROM and use the same probing order (assuming that valid images can be detected by SPL) unless instructed otherwise. The boot-order can then be configured via the 'u-boot,spl-boot-order' property in the chosen-node of the DTS. While this approach is easily extensible to other boards, it is only implemented for the RK3399 for now, as the large SRAM on the RK3399 makes this easy to fit the needed infrastructure into SPL and our production setup already runs with DM, OF_CONTROL and BLK in SPL. The new boot-order property is expected to be used in conjunction with FIT images (and all legacy image formats disabled via Kconfig). A boot-sequence with probing and fallthroughs from SPI via eMMC to SD card (i.e. &spiflash, &sdhci, &sdmmc) has been validated on the RK3399-Q7. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Tested-by: Klaus Goger <klaus.goger@theobroma-systems.com> Tested-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-04-04rockchip: rk3188: add README.rockchip paragraph describing sd bootHeiko Stübner
Building sd images for rk3188 requires more steps due to the needed split into TPL and SPL as loaders. Describe how to build an image for it in a separate paragraph in the READER.rockchip file. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2017-03-26drivers/net/phy: add fixed-phy / fixed-link supportHannes Schmelzer
This patch adds support for having a "fixed-link" to some other MAC (like some embedded switch-device). For this purpose we introduce a new phy-driver, called "Fixed PHY". Fixed PHY works only with CONFIG_DM_ETH enabled, since the fixed-link is described with a subnode below ethernet interface. Most ethernet drivers (unfortunately not all are following same scheme for searching/attaching phys) are calling "phy_connect(...)" for getting a phy-device. At this point we link in, we search here for a subnode called "fixed- link", once found we start phy_device_create(...) with the special phy- id PHY_FIXED_ID (0xa5a55a5a). During init the "Fixed PHY" driver has registered with this id and now gets probed, during probe we get all the details about fixed-link out of dts, later on the phy reports this values. Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2017-03-24Merge git://git.denx.de/u-boot-arcTom Rini
This replaces legacy arch/arc/lib/timer.c implementation and allows us to describe ARC Timers in Device Tree. Among other things that way we may properly inherit Timer's clock from CPU's clock s they really run synchronously.
2017-03-24drivers: timer: Introduce ARC timer driverVlad Zakharov
This commit introduces timer driver for ARC. ARC timers are configured via ARC AUX registers so we use special functions to access timer control registers. This driver allows utilization of either timer0 or timer1 depending on which one is available in real hardware. Essentially only existing timers should be mentioned in board's Device Tree description. Signed-off-by: Vlad Zakharov <vzakhar@synopsys.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-03-23dm: Add callback to modify the device treemario.six@gdsys.cc
Certain boards come in different variations by way of utilizing daughter boards, for example. These boards might contain additional chips, which are added to the main board's busses, e.g. I2C. The device tree support for such boards would either, quite naturally, employ the overlay mechanism to add such chips to the tree, or would use one large default device tree, and delete the devices that are actually not present. Regardless of approach, even on the U-Boot level, a modification of the device tree is a prerequisite to have such modular families of boards supported properly. Therefore, we add an option to make the U-Boot device tree (the actual copy later used by the driver model) writeable, and add a callback method that allows boards to modify the device tree at an early stage, at which, hopefully, also the application of device tree overlays will be possible. Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Stefan Roese <sr@denx.de>
2017-03-23mvebu: usb: xhci: Add VBUS regulator supply to the host driverKonstantin Porotchkin
The USB device should linked to VBUS regulator through "vbus-supply" DTS property. This patch adds handling for "vbus-supply" property inside the USB device entry for turning on the VBUS regulator upon the host adapter probe. Signed-off-by: Konstantin Porotchkin <kostap@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Neta Zur Hershkovits <neta@marvell.com> Cc: Igal Liberman <igall@marvell.com> Cc: Haim Boot <hayim@marvell.com> Acked-by: Marek Vasut <marex@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2017-03-23mvebu: pcie: Add support for GPIO reset for PCIe deviceKonstantin Porotchkin
Add support for "marvell,reset-gpio" property to mvebu DW PCIe driver. This option is valid when CONFIG_DM_GPIO=y Change-Id: Ic17c500449050c2fbb700731f1a9ca8b83298986 Signed-off-by: Konstantin Porotchkin <kostap@marvell.com> Signed-off-by: Rabeeh Khoury <rabeeh@solid-run.com> Cc: Stefan Roese <sr@denx.de> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Neta Zur Hershkovits <neta@marvell.com> Cc: Igal Liberman <igall@marvell.com> Cc: Haim Boot <hayim@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de>
2017-03-20part_efi: document device-tree binding for part_efi configurationPhilipp Tomsich
This adds documentation on the u-boot,efi-partition-entries-offset property (which overrides CONFIG_EFI_PARTITION_ENTRIES_OFF, if present). Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-03-20doc: move documentation for /config node into a separate filePhilipp Tomsich
This moves the description of the /config node from README.fdt-control into a separate file doc/device-tree-bindings/config.txt. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-03-17Merge git://git.denx.de/u-boot-rockchipTom Rini
This includes support for rk3188 from Heiko Stübner and and rk3328 from Kever Yang. Also included is SPL support for rk3399 and a fix for rk3288 to get it booting again (spl_early_init()).
2017-03-17PINCTRL: stm32f7: add pin control driverVikas Manocha
This driver uses the same pin control binding as that of linux, binding document of this patch is copied from linux. One addition done is for GPIO input and output mode configuration which was missing. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-03-17clk: stm32f7: add clock driver for stm32f7 familyVikas Manocha
add basic clock driver support for stm32f7 to enable clocks required by the peripherals. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-03-16rockchip: arm64: rk3399: add ddr controller driverKever Yang
RK3399 support DDR3, LPDDR3, DDR4 sdram, this patch is porting from coreboot, support 4GB lpddr3 in this version. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Added rockchip: tag: Signed-off-by: Simon Glass <sjg@chromium.org>
2017-03-16dm: allow limiting pre-reloc markings to spl or tplHeiko Stübner
Right now the u-boot,dm-pre-reloc flag will make each marked node always appear in both spl and tpl. But systems needing an additional tpl might have special constraints for each, like the spl needing to be very tiny. So introduce two additional flags to mark nodes for only spl or tpl environments and introduce a function dm_fdt_pre_reloc to automate the necessary checks in code instances checking for pre-relocation flags. The behaviour of the original flag stays untouched and still marks a node for both spl and tpl. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Kever Yang <kever.yang@rock-chips.com>
2017-02-23ARM: uniphier: update README.uniphier for latest build instructionMasahiro Yamada
Since commit c0efc3140e75 ("ARM: uniphier: change CONFIG_SPL_PAD_TO to 128KB"), the u-boot.bin should be burned at the offset 0x20000. I missed to update README.uniphier in that commit. Now updating. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-02-09rockchip: rename miniarm to tinker boardEddie Cai
Miniarm is the internal project code. Now it is officially named Tinker board. So rename it. Signed-off-by: Eddie Cai <eddie.cai@rock-chips.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-02-08dm: core: Replace of_offset with accessorSimon Glass
At present devices use a simple integer offset to record the device tree node associated with the device. In preparation for supporting a live device tree, which uses a node pointer instead, refactor existing code to access this field through an inline function. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-02-01Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2017-02-01Merge git://www.denx.de/git/u-boot-marvellTom Rini
2017-02-01arm: mvebu: Implement secure bootMario Six
The patch implements secure booting for the mvebu architecture. This includes: - The addition of secure headers and all needed signatures and keys in mkimage - Commands capable of writing the board's efuses to both write the needed cryptographic data and enable the secure booting mechanism - The creation of convenience text files containing the necessary commands to write the efuses The KAK and CSK keys are expected to reside in the files kwb_kak.key and kwb_csk.key (OpenSSL 2048 bit private keys) in the top-level directory. Signed-off-by: Reinhard Pfau <reinhard.pfau@gdsys.cc> Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Stefan Roese <sr@denx.de>
2017-01-31mmc: move CONFIG_GENERIC_MMC to KconfigMasahiro Yamada
Now, CONFIG_GENERIC_MMC seems equivalent to CONFIG_MMC. Let's create an entry for "config GENERIC_MMC" with "default MMC", then convert all macro defines in headers to Kconfig. Almost all of the defines will go away. I see only two exceptions: configs/blanche_defconfig configs/sandbox_noblk_defconfig They define CONFIG_GENERIC_MMC, but not CONFIG_MMC. Something might be wrong with these two boards, so should be checked later. Anyway, this is the output of the moveconfig tool. This commit was created as follows: [1] create a config entry in drivers/mmc/Kconfig [2] tools/moveconfig.py -r HEAD GENERIC_MMC [3] manual clean-up of garbage comments in doc/README.* and include/configs/*.h Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-28ARM: DTS: stm32: add stm32f746-disco device tree filesMichael Kurz
This patch adds the DTS source files needed for stm32f746-disco board The files are based on the stm32f429/469 files from current linux kernel. Source for "arch/arm/dts/armv7-m.dtsi": Linux: "arch/arm/boot/dts/armv7-m.dtsi" Signed-off-by: Michael Kurz <michi.kurz@gmail.com> Acked-by: Vikas MANOCHA <vikas.manocha@st.com>
2017-01-27README: mxc_hab: Adapt the CONFIG_SECURE_BOOT text to KconfigFabio Estevam
Commit 6e1f4d2652e79 ("arm: imx-common: add SECURE_BOOT option to Kconfig") moved the CONFIG_SECURE_BOOT option to Kconfig, so update the mxc_hab README file to reflect that. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Gary Bisson <gary.bisson@boundarydevices.com>
2017-01-22ARM: uniphier: add PXs3 SoC supportMasahiro Yamada
Initial support for PXs3 SoC. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-01-21status_led: Kconfig migration - introductionUri Mashiach
Move all of the status LED feature to drivers/led/Kconfig. doc/README.LED updated to reflect the Kconfig implementation. Tested boards: CL-SOM-AM57x, CM-T335 Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il>
