path: root/doc
2009-11-09clarify eth driver halt/recv stepsMike Frysinger
The dev->halt() func can be called at any time, and the dev->recv() func does not need to use NetRxPackets[] when calling NetReceive(). Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-10-28Coding Style cleanup; update CHANGELOG, prepare -rc1v2009.11-rc1Wolfgang Denk
2009-10-13s5pc1xx: add support SMDKC100 boardMinkyu Kang
Adds new board SMDKC100 that uses s5pc100 SoC Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: HeungJun, Kim <riverful.kim@samsung.com>
2009-10-10Rewrite the miiphybb (Bit-banged MII bus driver) in order to support an ↵Luigi 'Comio' Mantellini
arbitrary number of mii buses. This feature is useful when your board uses different mii buses for different phys and all (or a part) of these buses are implemented via bit-banging mode. The driver requires that the following macros should be defined into the board configuration file: CONFIG_BITBANGMII - Enable the miiphybb driver CONFIG_BITBANGMII_MULTI - Enable the multi bus support If the CONFIG_BITBANGMII_MULTI is not defined, the board's config file needs to define at least the following macros: MII_INIT - Generic code to enable the MII bus (optional) MDIO_DECLARE - Declaration needed to access to the MDIO pin (optional) MDIO_ACTIVE - Activate the MDIO pin as out pin MDIO_TRISTATE - Activate the MDIO pin as input/tristate pin MDIO_READ - Read the MDIO pin MDIO(v) - Write v on the MDIO pin MDC_DECLARE - Declaration needed to access to the MDC pin (optional) MDC(v) - Write v on the MDC pin The previous macros make the driver compatible with the previous version (that didn't support the multi-bus). When the CONFIG_BITBANGMII_MULTI is also defined, the board code needs to fill the bb_miiphy_buses[] array with a record for each required bus and declare the bb_miiphy_buses_num variable with the number of mii buses. The record (struct bb_miiphy_bus) has the following fields/callbacks (see miiphy.h for details): char name[] - The symbolic name that must be equal to the MII bus registered name int (*init)() - Initialization function called at startup time (just before the Ethernet initialization) int (*mdio_active)() - Activate the MDIO pin as output int (*mdio_tristate)() - Activate the MDIO pin as input/tristate pin int (*set_mdio)() - Write the MDIO pin int (*get_mdio)() - Read the MDIO pin int (*set_mdc)() - Write the MDC pin int (*delay)() - Delay function void *priv - Private data used by board specific code The board code will look like: struct bb_miiphy_bus bb_miiphy_buses[] = { { .name = miibus#1, .init = b1_init, .mdio_active = b1_mdio_active, ... }, { .name = miibus#2, .init = b2_init, .mdio_active = b2_mdio_active, ... }, ... int bb_miiphy_buses_num = sizeof(bb_miiphy_buses) / sizeof(bb_miiphy_buses[0]); Signed-off-by: Luigi 'Comio' Mantellini <luigi.mantellini@idf-hit.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-10-05Add information about return values of xxx_eth_register() in documentationBen Warren
As discussed on mailing list, <0 indicates failure, >=0 indicates number of interfaces found. Also added blurb about private data Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-10-04document network driver frameworkMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-09-30Add README.mpc8536dsMingkai Hu
Add boot from NAND/eSDHC/eSPI description Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-30sbc8548: reclaim wasted sector in boot flashPaul Gortmaker
By nature of being based off the MPC8548CDS board, this board inherited an ENV_SIZE setting of 256k. But since it has a smaller flash device (8MB soldered on), it has a native sector size of 128k, and hence the ENV_SIZE was causing 2 sectors to be used for the environment. By removing the unused sector, we can push TEXT_BASE up closer to the end of address space and reclaim that sector for any other application. This also fixes the mismatch between TEXT_BASE and MONITOR_LEN reported by Kumar earlier. Since this board also supports the ability to boot off the 64MB SODIMM flash, this change is forward looking with that in mind; i.e. the settings for MONITOR_LEN and ENV_SIZE will work when the 512k sectors of the SODIMM flash are used for alternate boot in the future. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24sbc8548: replace README with completely new documentPaul Gortmaker
The previous README.sbc8548 was pretty much content-free. Replace it with something that actually gives the end user some relevant hardware details, and also lists the u-boot configuration choices. Also in the cosmetic department, fix the bogus line in the Makefile that was carried over from the SBC8560 Makefile, and the typo in the sbc8548.c copyright. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-22Remove deprecated 'autoscr' command/variablesPeter Tyser
The more standard 'source' command provides identical functionality to the autoscr command. Environment variable names/values on the MVBC_P, MVBML7, kmeter1, mgcoge, and km8xx boards are updated to no longer refernce 'autoscr'. The 'autoscript' and 'autoscript_uname' environment variables are also removed. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Acked-by: Heiko Schocher <hs@denx.de>
2009-09-15tools/netconsole: use ncb automatically if availableMike Frysinger
The standard netcat, while ubiquitous, doesn't handle broadcast udp packets properly. The local ncb util does however. So if ncb can be located in the standard locations, automatically use that instead. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-09-10mkimage: Add Kirkwood Boot Image support (kwbimage)Prafulla Wadaskar
This patch adds support for "kwbimage" (Kirkwood Boot Image) image types to the mkimage code. For details refer to docs/README.kwbimage This patch is tested with Sheevaplug board Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Acked-by: Ron Lee <ron@debian.org> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2009-09-07Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2009-09-05Add support for the DevKit8000 boardFrederik Kriewitz
This patch adds support for the DevKit8000 board. Signed-off-by: Frederik Kriewitz <frederik@kriewitz.eu>
2009-09-02Blackfin: change global data register from P5 to P3Robin Getz
Since the Blackfin ABI favors higher scratch registers by default, use the last scratch register (P3) for global data rather than the first (P5). This allows the compiler's register allocator to use higher number scratch P registers, which in turn better matches the Blackfin instruction set, which reduces the size of U-Boot by more than 1024 bytes... Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-08-2885xx: Add support for P2020RDB boardPoonam Aggrwal
The code base adds P1 & P2 RDB platforms support. The folder and file names can cater to future SOCs of P1/P2 family. P1 & P2 processors are 85xx platforms, part of Freescale QorIQ series. Tested following on P2020RDB: 1. eTSECs 2. DDR, NAND, NOR, I2C. Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-21mpc83xx: sbc8349 - make enabling PCI more user friendlyPaul Gortmaker
Prior to this commit, to enable PCI, you had to go manually edit the board config header, which isn't really user friendly. This adds the typical PCI make targets to the toplevel Makefile in accordance with what is being done with other boards. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-07-27sbc8349: combine HRCW flash and u-boot image flashPaul Gortmaker
Up to this point in time, the sbc8349 board was storing the u-boot image in flash 2x. One for the HRCW value at the beginning of flash (0xff80_0000), and once close to the end of flash (0xfff8_0000) for the actual image that got executed. This moves the TEXT_BASE to be the beginning of flash, which makes the second copy of the image redundant, and frees up the flash from the end of the environment storage to the end of the flash device itself. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-07-27Prepare 2009.08-rc1Wolfgang Denk
Update CHANGELOG, minor coding style fix. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-26new video driver for bus vcxk framebuffersJens Scharsig
This patch adds a new video driver * adds common bus_vcxk framebuffer driver Signed-off-by: Jens Scharsig <esw@bus-elektronik.de> [agust@denx.de: fixed lots of style issues before applying] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2009-07-23Coding Style cleanup; update CHANGELOG.Wolfgang Denk
2009-07-22Add DNS supportRobin Getz
On 04 Oct 2008 Pieter posted a dns implementation for U-Boot. http://www.mail-archive.com/u-boot-users@lists.sourceforge.net/msg10216.html > > DNS can be enabled by setting CFG_CMD_DNS. After performing a query, > the serverip environment var is updated. > > Probably there are some cosmetic issues with the patch. Unfortunatly I > do not have the time to correct these. So if anybody else likes DNS > support in U-Boot and has the time, feel free to patch it in the main tree. Here it is again - slightly modified & smaller: - update to 2009-06 (Pieter's patch was for U-Boot 1.2.0) - README.dns is added - syntax is changed (now takes a third option, the env var to store the result in) - add a random port() function in net.c - sort Makefile in ./net/Makefile - dns just returns unless a env var is given - run through checkpatch, and clean up style issues - remove packet from stack - cleaned up some comments - failure returns much faster (if server responds, don't wait for timeout) - use built in functions (memcpy) rather than byte copy. Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org> Signed-off-by: Pieter Voorthuijsen <pieter.voorthuijsen@prodrive.nl> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-07-16Remove legacy NAND and disk on chip code.Scott Wood
Legacy NAND had been scheduled for removal. Any boards that use this were already not building in the previous release due to an #error. The disk on chip code in common/cmd_doc.c relies on legacy NAND, and it has also been removed. There is newer disk on chip code in drivers/mtd/nand; someone with access to hardware and sufficient time and motivation can try to get that working, but for now disk on chip is not supported. Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-07-14Merge branch 'master' of /home/wd/git/u-boot/masterWolfgang Denk
2009-07-13Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2009-07-12at91: Introduction of at91sam9g10 SOC.Sedji Gaouaou
AT91sam9g10 is an ARM 926ej-s SOC. It is an evolution of the at91sam9261 with a faster clock speed: 266/133MHz. Signed-off-by: Sedji Gaouaou <sedji.gaouaou@atmel.com>
2009-07-12at91: Introduction of at91sam9g45 SOC.Sedji Gaouaou
AT91sam9g45 series is an ARM 926ej-s SOC family clocked at 400/133MHz. It embeds USB high speed host and device, LCD, DDR2 RAM, and a full set of peripherals. The first board that embeds at91sam9g45 chip is the AT91SAM9G45-EKES. On the board you can find 2 USART, USB high speed, a 480*272 LG lcd, ethernet, gpio/joystick/buttons. Signed-off-by: Sedji Gaouaou <sedji.gaouaou@atmel.com>
2009-07-10board support patch for phyCORE-MPC5200B-tinyJon Smirl
Add support for the Phytec phyCORE-MPC5200B-tiny. Code originally from Pengutronix.de. Created CONFIG_SYS_ATA_CS_ON_TIMER01 define for when IDE CS is on Timer 0/1 Signed-off-by: Jon Smirl <jonsmirl@gmail.com> Acked-by: Grant Likely <grant.likely@secretlab.ca>
2009-07-07davinci_nand: cleanup II (CONFIG_SYS_DAVINCI_BROKEN_ECC)David Brownell
Remove CONFIG_SYS_DAVINCI_BROKEN_ECC option. It's not just nasty; it's also unused by any current boards, and doesn't even match the main U-Boot distributions from TI (which use soft ECC, or 4-bit ECC on newer chips that support it). DaVinci GIT kernels since 2.6.24, and mainline Linux since 2.6.30, match non-BROKEN code paths for 1-bit HW ECC. The BROKEN code paths do seem to partially match what MontaVista/TI kernels (4.0/2.6.10, and 5.0/2.6.18) do ... but only for small pages. Large page support is really broken (and it's unclear just what software it was trying to match!), and the ECC layout was making three more bytes available for use by filesystem (or whatever) code. Since this option itself seems broken, remove it. Add a comment about the MV/TI compat issue, and the most straightforward way to address it (should someone really need to solve it). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-07-07Coding style cleanup; update CHANGELOGWolfgang Denk
2009-07-06arm nomadik: allow Nand and OneNand to coexistsAlessandro Rubini
The evaluation kit has both Nand and OneNand, both drivers are there and the two configurations only select a different default for the jffs partition. This adds the OneNand driver and cleans up storage. Signed-off-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Andrea Gallo <andrea.gallo@stericsson.com>
2009-07-06arm nomadik: rename board to nhk8815Alessandro Rubini
This is an error in my side in the initial submission: nobody calls it ""nmdk8815", it's "nomadik hardware kit", nhk8815, instead. Signed-off-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Andrea Gallo <andrea.gallo@stericsson.com>
2009-06-21at91sam9263ek: add nor flash supportJean-Christophe PLAGNIOL-VILLARD
this will allow you to store use it for the env and to boot directly U-Boot from Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-06-14Merge branch 'next' of ../masterWolfgang Denk
2009-06-14Prepare v2009.06v2009.06Wolfgang Denk
Update CHANGELOG, fix minor coding stylke issue. Update Makefile. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-1283xx: Replace CONFIG_MPC83[0-9]X with MPC83[0-9]xPeter Tyser
Use the standard lowercase "x" capitalization that other Freescale architectures use for CPU defines to prevent confusion and errors Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-06-1283xx: Replace CONFIG_MPC83XX with CONFIG_MPC83xxPeter Tyser
Use the standard lowercase "xx" capitalization that other Freescale architectures use for CPU defines to prevent confusion and errors Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-06-12Fix a typo in the instructions on using omap3's gpio interface.Tom Rix
Using the example for reading a gpio, shows the problem. NULL should be the gpio number. Signed-off-by: Tom Rix <Tom.Rix@windriver.com> Acked-by: Dirk Behme <dirk.behme@googlemail.com>
2009-06-12OMAP3 Port kernel omap gpio interface.Tom Rix
Port version 2.6.27 of the linux kernel's omap gpio interface to u-boot. The orignal source is in linux/arch/arm/plat-omap/gpio.c See doc/README.omap3 for instructions on use. Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-06-12ZOOM2 Add initial support for Zoom2Tom Rix
Zoom2 is a new board from Texas Instruments and LogicPD The logicpd web site is a good source for general information on this board. Please start looking here if the below links are broken. http://www.logicpd.com This is a pdf of the product http://www.logicpd.com/sites/default/files/1012659A_Zoom_OMAP34x-II_MDP_Brief.pdf This is the product description web page http://www.logicpd.com/products/development-kits/texas-instruments-zoom%E2%84%A2-omap34x-ii-mdp This patch provides a zoom2 base target by copying zoom1 and by making some obvious changes. To configure, run make omap3_zoom2_config Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-06-12LED Add documentation describing the status_led and colour led API.Tom Rix
This document describes the u-boot status LED API. This allows common u-boot commands to use a board's leds to provide status for activities like booting and downloading files. Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-06-12i2c: Update references to individual i2c commandsPeter Tyser
The individual i2c commands imd, imm, inm, imw, icrc32, iprobe, iloop, and isdram are no longer available so all references to them have been updated to the new form of "i2c <cmd>". Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-06-12i2c: Remove deprecated individual i2c commandsPeter Tyser
The following individual I2C commands have been removed: imd, imm, inm, imw, icrc32, iprobe, iloop, isdram. The functionality of the individual commands is still available via the 'i2c' command. This change only has an impact on those boards which did not have CONFIG_I2C_CMD_TREE defined. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-06-1285xx: Add README for MPC8569MDSHaiying Wang
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-05-15Schedule removal of non-CONFIG_NET_MULTI net driver APIBen Warren
This will make CONFIG_NET_MULTI the only net driver configuration and we'll be able to remove this option. Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-04-05Update CHANGELOG, coding style cleanup.Wolfgang Denk
2009-04-04at91sam9: add watchdog supportJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-04-04tools/Makefile: Compile ncb when CONFIG_NETCONSOLEPeter Tyser
Also conditionally add ncb.o to OBJ_FILES list Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-04-03mflash: Initial mflash supportunsik Kim
Mflash is fusion memory device mainly targeted consumer eletronic and mobile phone. Internally, it have nand flash and other hardware logics and supports some different operation (ATA, IO, XIP) modes. IO mode is custom mode for the host that doesn't have IDE interface. (Many mobile targeted SoC doesn't have IDE bus) This driver support mflash IO mode. Followings are brief descriptions about IO mode. 1. IO mode based on ATA protocol and uses some custom command. (read confirm, write confirm) 2. IO mode uses SRAM bus interface. Signed-off-by: unsik Kim <donari75@gmail.com>
2009-04-03Merge branch 'master' of git://git.denx.de/u-boot-nand-flashWolfgang Denk
