One limitation of FIT is that all the data is 'inline' within it, using a
'data' property in each image node. This means that to find out what is in
the FIT it is necessary to scan the entire file. Once loaded it can be
scanned and then the images can be copied to the correct place in memory.
In SPL it can take a significant amount of time to copy images around in
memory. Also loading data that does not end up being used is wasteful. It
would be useful if the FIT were small, acting as a directory, with the
actual data stored elsewhere.
This allows SPL to load the entire FIT, without the images, then load the
images it wants later.
Add a -E option to mkimage to request that it output an 'external' FIT.
To make the auto-FIT feature useful we need to be able to provide a list of
device tree files on the command line for mkimage to add into the FIT. Add
support for this feature.
So far there is no support for hashing or verified boot using this method.
For those cases, a .its file must still be provided.
At present, when generating a FIT, mkimage requires a .its file containing
the structure of the FIT and referring to the images to be included.
Creating the .its file is a separate step that makes it harder to use FIT.
This is not required for creating legacy images.
Often the FIT is pretty standard, consisting of an OS image, some device
tree files and a single configuration. We can handle this case automatically
and avoid needing a .its file at all.
To start with, support automatically generate the FIT using a new '-f auto'
option. Initially this only supports adding a single image (e.g. a linux
kernel) and a single configuration.
This will be used in mkimage when working out the required size of the FIT
based on the files to be placed into it.
I didn't have a common board to enable LVDS.
So add this dcocument to help others who want to enable LVDS in their board.
Signed-off-by: Jacob Chen <jacob-chen@iotwrt.com>
PH1-Pro5 support and ProXstream2/PH1-LD6b support can coexist in one
image and there is bit more room in SPL to accommodate all of them.
Merge uniphier_pro5_defconfig into uniphier_pxs2_defconfig.
The Boot ROM expects the boot image (SPL) in the Boot Partition 1.
So, updating images involves the hardware partition switch. It might
be a bit advanced for some users.
To be user-friendly, this commit adds a useful command to update the
images; just put SPL and U-Boot proper into the public directory of
the TFTP server and execute "run emmcupdate" from the command line.
Add a driver for the on-chip SD/eMMC host controller used by
UniPhier SoC family.
This GPIO controller device is used on UniPhier SoCs.
Remove ARM Debug communication channel driver from the list
of not converted drivers to DM.
Update existing documentation to mention Intel Bayley Bay board
instructions, an additional Bay Trail based board to MinnowMax.
This also adds a minor change to QEMU section to indicate clearly
the instructions are for bare mode.
This adds basic support to Intel Cougar Canyon 2 board, a board
based on Chief River platform with an Ivy Bridge processor and
a Panther Point chipset.
Fixes typo of pxe_addr_r with pxefile_addr_r.
Signed-off-by: Vagrant Cascadian <vagrant@debian.org>
Reviewed-by: Stephen Warren <swarren@wwwdotorg.org>
Since commit ad1ecd2063da ("fdt: Build a U-Boot binary without device
tree") and commit 03c25bcd263a ("fdt: Build an SPL binary without
device tree"), we can use shorter file names for the output images.
The default configuration for UniPhier SoCs enables CONFIG_OF_SEPARATE
and CONFIG_SPL_OF_CONTROL. In this case, spl/u-boot-spl.bin is the
same as spl/u-boot-spl-dtb.bin. Likewise, u-boot.img is the same as
as u-boot-dtb.img. So, this change of the flow has no impact.
CONFIG_HWFLOW and friends from the documentation.
Signed-off-by: David Müller <d.mueller@elsoft.ch>
Update the README to reflect the current status.
Correct spelling of "U-Boot" shall be used in all written text
(documentation, comments in source files etc.).
Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
The i.MX6SX and i.MX6UL has two ENET controllers, add support for reading
MAC address from fuse for ENET2.
Signed-off-by: Ye Li <ye.li@nxp.com>
This adds PIC32 UART controller support based on driver model.
Signed-off-by: Paul Thacker <paul.thacker@microchip.com>
Signed-off-by: Purna Chandra Mandal <purna.mandal@microchip.com>
Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
PIC32 clock module consists of multiple oscillators, PLLs, mutiplexers
and dividers capable of supplying clock to various controllers
on or off-chip.
The PCI bus must be enumerated before PCI devices, such as Ethernet
devices, are known to U-Boot. Enhance the distro boot commands to perform
PCI enumeration when needed.
Currently, the distro boot commands always enumerate USB devices before
performing network operations. However, depending on the board and end-
user configuration, network devices may not be attached to USB, and so
enumerating USB may not be necessary. Enhance the scripts to make this
step optional, so that the user can decrease boot time if they don't
need USB.
This change is performed by moving the "usb start" invocation into a
standalone variable. If the user desires, they can replace that
variable's value with some no-op command such as "true" instead.
Booting from a USB storage device always needs to enumerate USB devices,
so this action is still hard-coded.
Add the DTS documentation for the Micrel KSZ90x1 binding.
The original document was from:
[commit 4b405efbe12de28b26289282b431323d73992381 from the Linux kernel]
This takes the original document and adds a clarification on how the skew
values are represented in the code.
References:
Micrel ksz9021rl/rn Data Sheet, Revision 1.2. Dated 2/13/2014.
http://www.micrel.com/_PDF/Ethernet/datasheets/ksz9021rl-rn_ds.pdf
Micrel ksz9031rnx Data Sheet, Revision 2.1. Dated 11/20/2014.
http://www.micrel.com/_PDF/Ethernet/datasheets/KSZ9031RNX.pdf
Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
Add a new member 'tbiaddr' to tsec_private struct. For non-DM driver,
it is initialized as CONFIG_SYS_TBIPA_VALUE, but for DM driver, we
can get this from device tree. Update the bindings doc as well.
Adapted from the same file name in the kernel device tree bindings
documentation, to use with U-Boot.
You can now configure LAG on VSC9953's ports using the command:
ethsw [port <port_no>] aggr {[help] | show | <lag_group_no>}
A port must belong to a single LAG. By default, a port
belongs to a LAG equal to the port's number.
For each frame, a hash will be calculated based on
Source/Destination MAC addresses, Source/Destination IP(v4/v6)
addresses, Source/Destination ports. This hash will be used to
select a single egress port from LAG. This also assures
that frames from the same flow will always have the
same egress port.
Signed-off-by: Codrin Ciubotariu <codrin.ciubotariu@freescale.com>
The driver for VSC9953 L2 switch IP supports many features and
the documentation needs to be updated.
This patch adds a parameter to the function setup_early_uart() to either
enable or disable the internal BayTrail legacy UART. Since the name
setup_early_uart() does not match its functionality any more, lets
rename it to setup_internal_uart() as well in this patch.
This patch adds the documentation for the memory-down parameters
of the Intel FSP. To configure a board without SPD DDR DIMM but
with onboard DDR chips. The values are taken from the coreboot
header:
src/soc/intel/fsp_baytrail/chip.h
(git ID da1a70ea from 2016-01-16 as reference).
Cc: Andrew Bradford <andrew.bradford@kodakalaris.com>
Cc: Bin Meng <bmeng.cn@gmail.com>
Enable SPL DM too.
Reviewed-by: Thomas Chou <thomas@wytron.com.tw>
Replace ns16550.txt with binding files from Linux kernel. As suggested
by Stephen Warren, we should keep the directory structure, filenames,
and file content identical to the bindings in the Linux kernel.
GPIO, I2C, LCD and HDMI are now implemented. We have more than one PMIC.
There is an implementation to run the CPU at full speed although it does
not seem to make much difference.
Update the README to cover recent developments.
This board includes an RK3288 SoC on a SOM. It can be mounted on a
base-board which provides a wide range of peripherals.
So far this is verified to boot to a prompt from a microSD card. The serial
console works as well as HDMI.
Thanks to Tom Cubie for sending me a board.
This script has proved useful for parsing datasheets and creating register
shift/mask values for use in header files. Include it in case it is useful
for others.
Add this binding file since we now use it in U-Boot.
This adds driver model support to lpuart serial driver.
Acked-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Tested-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Adding timer init function in timer-uclass driver to create and
initialize the timer device on platforms where u-boot,dm-pre-reloc
is not used. Since there will be multiple timer devices in the
system, adding a tick-timer node in chosen node to know which
timer device to be used as tick timer in u-boot.
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
This patch adds code which sets up 2-level page tables on ARM64 thus
extending available VA space. CPUs implementing 64k translation
granule are able to use direct PA-VA mapping of the whole 48 bit
address space.
It also adds the ability to reset the SCTRL register at the very beginning
of execution to avoid interference from stale mappings set up by early
firmware/loaders/etc.
Signed-off-by: Sergey Temerkhanov <s.temerkhanov@gmail.com>
Signed-off-by: Radha Mohan Chintakuntla <rchintakuntla@cavium.com>
Document the usage of 'qfw' command
Signed-off-by: Miao Yan <yanmiaobest@gmail.com>
The mem_is_flash() in arch/arm/mach-uniphier/micro-support_card.c
writes/reads the tail of each NOR flash bank to check if the device
really resides there.
If CS1_SPLIT were enabled, the support card would always require two
NOR flash devices to be inserted for the correct NOR detection.
This is not probably what we want.
Various updates did not make it through to this board. Also the instructions
for building a SPI image are no-longer correct. Fix these so that Jerry can
boot to a prompt again.
Check for bmode before reading the boot device
to check if a serial downloader is started,
and returns UART if the serial downloader is set,
letting SPL to wait for an image if
CONFIG_SPL_YMODEM_SUPPORT is set.
This allows to load again a SPL based board
with imx_usb_loader together with a tool
such as kermit.
CC: Tim Harvey <tharvey@gateworks.com>
CC: Fabio Estevam <Fabio.Estevam@freescale.com>
CC: Eric Nelson <eric.nelson@boundarydevices.com>
Reviewed-by: Eric Nelson <eric@nelint.com>
Tested-by: Eric Nelson <eric@nelint.com>
Rename rest of defconfig files of UniPhier SoC family to have the
prefix uniphier_.
These boards are similar enough to be supported in a single defconfig
file. Distinguish one from another by "DEVICE_TREE" from the command
line. The how-to-build in doc/README.uniphier should be also updated.
