path: root/doc
2015-01-30Merge branch 'master' of git://git.denx.de/u-boot-dmTom Rini
2015-01-30add README.distro fileDennis Gilmore
Add documentation on how to setup a system to use the generic distro configs and boot commands. This spells out what is needed to make a system conformant, but does not limit the board to only the defaults. Signed-off-by: Dennis Gilmore <dennis@ausil.us> [swarren, added concept, user config, BOOT_TARGET_DEVICES sections. edited the rest] Signed-off-by: Stephen Warren <swarren@nvidia.com>
2015-01-29dm: i2c: dts: Support an offset-len device tree propertySimon Glass
Since U-Boot can support different offset lengths (0-4 bytes), add a device tree property to specify this. This avoids hard-coding it in the driver. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-29Export redesignMartin Dorwig
this is an atempt to make the export of functions typesafe. I replaced the jumptable void ** by a struct (jt_funcs) with function pointers. The EXPORT_FUNC macro now has 3 fixed parameters and one variadic parameter The first is the name of the exported function, the rest of the parameters are used to format a functionpointer in the jumptable, the EXPORT_FUNC macros are expanded three times, 1. to declare the members of the struct 2. to initialize the structmember pointers 3. to call the functions in stubs.c Signed-off-by: Martin Dorwig <dorwig@tetronik.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> (resending to the list since my tweaks are not quite trivial)
2015-01-29dm: Update documentation for new bus featuresSimon Glass
Now that we have new bus features, update README.txt and the SPI docs to explain these. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-29dm: core: Add a flag to control sequence numberingSimon Glass
At present we try to use the 'reg' property and device tree aliases to give devices a sequence number. The 'reg' property is often actually a memory address, so the sequence numbers thus-obtained are not useful. It would be better if the devices were just sequentially numbered in that case. In fact neither I2C nor SPI use this feature, so drop it. Some devices need us to look up an alias to number them within the uclass. Add a flag to control this, so it is not done unless it is needed. Adjust the tests to test this new behaviour. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-01-29dm: core: Set device tree node for root deviceSimon Glass
The root device corresponds to the root device tree node, so set this up. Also add a few notes to the documentation. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-29dm: tegra: Bring in GPIO device tree bindingSimon Glass
At present the tegra GPIO driver does not fully support the existing device tree binding, but add the binding file to cover the existing partial support. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-29dm: exynos: Bring in GPIO device tree bindingSimon Glass
At present the exynos GPIO driver does not fully support the existing device tree binding, but add the binding file to cover the existing partial support. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-29dm: gpio: Bring in GPIO device tree bindingSimon Glass
Add the binding file that we are about to support. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-29doc: fix misspellingsGuilherme Maciel Ferreira
Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com>
2015-01-29doc: "os" is also mandatory for "ramdisk" FIT image componentsGuilherme Maciel Ferreira
According to fit_image_print(), the "os" property from "image" node is required also when "type=ramdisk". Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com>
2015-01-23powerpc: remove icecube_5200, Lite5200, cpci5200, mecp5200, pf5200Masahiro Yamada
These boards are still non-generic boards. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
2015-01-23powerpc: mpc5xxx: PM520 board supportMasahiro Yamada
This board is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Josef Wagner <Wagner@Microsys.de>
2015-01-23powerpc: mpc5xxx: remove Total5200 board supportMasahiro Yamada
2015-01-23powerpc: ppc4xx: remove PPChameleonEVB, CATcenter boardsMasahiro Yamada
These boards are still non-generic boards. It is a good thing that we can drop board-specific hack code from drivers/mtd/nand/nand_base.c Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Stefan Roese <sr@denx.de> Cc: Andrea "llandre" Marson <andrea.marson@dave-tech.it>
2015-01-23powerpc: mpc85xx: remove P2020DS board supportMasahiro Yamada
2015-01-23powerpc: mpc85xx: remove P2020COME board supportMasahiro Yamada
This board is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Ira W. Snyder <iws@ovro.caltech.edu>
2015-01-23powerpc: mpc85xx: remove P1_P2_RDB boardsMasahiro Yamada
These boards are still non-generic boards: P1011RDB, P1022RDB, P2010RDB, P2020RDB Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Poonam Aggrwal <poonam.aggrwal@freescale.com>
2015-01-23powerpc: mpc83xx: remove MPC8360ERDK, EMPC8360EMDS supportMasahiro Yamada
These boards are still non-generic boards. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Dave Liu <daveliu@freescale.com> Cc: Anton Vorontsov <avorontsov@ru.mvista.com>
2015-01-16net/vsc9953: Add driver for Vitesse VSC9953 L2 Switch IPCodrin Ciubotariu
This patch adds a driver for VSC9953 L2 Switch. This Vitesse IP is integrated in Freescale T1040 and T1020 SoCs. The L2 switch has 10 Ethernet ports: 2 internal fixed-links (ports 8 and 9) at 2.5 Gbps and and 8 external ports at 1 Gbps. The external ports may be connected to PHYs over QSGMII and SGMII. Commands have also been added to enable/disable a port and to check a port's link speed, duplexity and status. The commands are: ethsw port <port_nr> enable|disable - enable/disable an l2 switch port ethsw port <port_nr> show - show an l2 switch port's configuration port_nr=0..9; use "all" for all ports For more detailse please see doc/README.t1040-l2switch Signed-off-by: Codrin Ciubotariu <codrin.ciubotariu@freescale.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-01-16Merge branch 'master' of git://git.denx.de/u-boot-tiTom Rini
2015-01-16powerpc: 74xx_7xx: remove 74xx_7xx cpu supportMasahiro Yamada
All the 74xx_7xx boards are still non-generic boards: P3G4, ZUMA, ppmc7xx, ELPPC, mpc7448hpc2 Acked-by: Marek Vasut <marex@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: York Sun <yorksun@freescale.com> Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Nye Liu <nyet@zumanetworks.com> Cc: Roy Zang <tie-fei.zang@freescale.com>
2015-01-14doc: ARM: Use the right function nameMichal Simek
Trivial fix. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-01-14README.scrapyard: fill commit and date fieldsMasahiro Yamada
This commit was generated by the following command: scripts/fill_scrapyard.py The commit-ID of CPCIISER4 removal has been fixed by hand because the board was removed by commit 370572601027 (ppc4xx: remove CPCIISER4 board), but it was added to README.scrapyard by commit 9a4018e09a2f (ppc4xx: remove DP405 board). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-01-14sunxi: video: Add a hpd_delay parameter to configure hpd delayHans de Goede
In some extreme cases it may be necessary to wait 1.5 seconds or more for a hpd signal to show up (and be able to read edid info), but we do not want to penalize all headless boots with an extra second boot delay, so add a hpd_delay parameter which can be set through the video-mode env. variable. While at it raise the default from 300ms to 500ms as 300 may very well be too low in many cases. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sunxi: video: Fallback from HDMI to VGA on boards with VGAHans de Goede
If a board has no LCD, but does have VGA fallback to VGA when no HDMI cable is connected (unless hpd=0). Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sunxi: video: Add lcd output supportHans de Goede
Add lcd output support, see the new Kconfig entries and doc/README.video for how to enable / configure this. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-13Merge git://git.denx.de/u-boot-x86Tom Rini
2015-01-13mtd: OMAP: Enable GPMC prefetch modeDaniel Mack
Enable GPMC's prefetch feature for NAND access. This speeds up NAND read access a lot by pre-fetching contents in the background and reading them through the FIFO address. The current implementation has two limitations: a) it only works in 8-bit mode b) it only supports read access Both is easily fixable by someone who has hardware to implement it. Note that U-Boot code uses non word-aligned buffers to read data into, and request read lengths that are not multiples of 4, so both partial buffers (head and tail) have to be addressed. Tested on AM335x hardware. Tested-by: Guido Martínez <guido@vanguardiasur.com.ar> Reviewed-by: Guido Martínez <guido@vanguardiasur.com.ar> Signed-off-by: Daniel Mack <zonque@gmail.com> [trini: Make apply again, use 'cs' fix pointed out by Guido] Signed-off-by: Tom Rini <trini@ti.com>
2015-01-13x86: Update README.x86 for coreboot supportBin Meng
Update README.x86 to include new build instructions for U-Boot as the coreboot payload and testing considerations with coreboot. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: Add an 'mtrr' command to list and adjust MTRRsSimon Glass
It is useful to be able to see the MTRR setup in U-Boot. Add a command to list the state of the variable MTRR registers and allow them to be changed. Update the documentation to list some of the available commands. This does not support fixed MTRRs as yet. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2015-01-13ppc4xx: remove some CPCI405 variantsMatthias Fuchs
only keep CPCI4052 Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2015-01-13ppc4xx: remove G2000 boardMatthias Fuchs
2015-01-13ppc4xx: remove WUH405 boardMatthias Fuchs
2015-01-13ppc4xx: remove VOH405 boardMatthias Fuchs
2015-01-13ppc4xx: remove PMC405 boardMatthias Fuchs
2015-01-13ppc4xx: remove PCI405 boardMatthias Fuchs
2015-01-13ppc4xx: remove OCRTC boardMatthias Fuchs
2015-01-13ppc4xx: remove HUB405 boardMatthias Fuchs
2015-01-13ppc4xx: remove HH405 boardMatthias Fuchs
2015-01-13ppc4xx: remove DU440 boardMatthias Fuchs
2015-01-13ppc4xx: remove DU405 boardMatthias Fuchs
2015-01-13ppc4xx: remove DP405 boardMatthias Fuchs
2015-01-13ppc4xx: remove CMS700 boardMatthias Fuchs
2015-01-13ppc4xx: remove ASH405 boardMatthias Fuchs
2015-01-13ppc4xx: remove AR405 boardMatthias Fuchs
2015-01-13ppx4xx: remove APC405 boardMatthias Fuchs
2015-01-13m68k: remove TASREG boardMatthias Fuchs
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Acked-by: Stefan Roese <sr@denx.de>
2015-01-08MAINTAINERS: add me as a co-maintainer of KIRKWOODLuka Perkov
Signed-off-by: Luka Perkov <luka.perkov@sartura.hr> CC: Prafulla Wadaskar <prafulla@marvell.com> CC: Wolfgang Denk <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
