simple-framebuffer is a new device tree binding that describes a pre-
configured frame-buffer memory region and its format. The Linux kernel
contains a driver that supports this binding. Implement functions to
create a DT node (or fill in an existing node) with parameters that
describe the framebuffer format that U-Boot is using.
This will be immediately used by the Raspberry Pi board in U-Boot, and
likely will be used by the Samsung ARM ChromeBook support soon too. It
could well be used by many other boards (e.g. Tegra boards with built-in
LCD panels, which aren't yet supported by the Linux kernel).
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
common/cmd_fpga.c
drivers/usb/host/ohci-at91.c
Debug trace buffers are memory mapped in DCSR space beyond 4M.
Signed-off-by: Stephen George <stephen.george@freescale.com>
Signed-off-by: Andy Fleming <afleming@freescale.com>
Allow VDD voltage overriding with a command. This is an add-on feasture of
VID. To override VDD, use command vdd_override with the value of voltage
in mV, for example
vdd_override <voltage in mV, eg. 1050>
The above example will set the VDD to 1.050 volt. Any wrong value out of
range of 0.8188 to 1.2125 volt or invalid string is ignored.
In addition to the command, if overriding VDD is needed earlier in booting
process, save an variable and reboot:
setenv t4240qds_vdd_mv <voltage in mV>
saveenv
Signed-off-by: York Sun <yorksun@freescale.com>
Add NAND partition table, EK board support boot up NAND flash using
the same NAND partition table
Add Index in this file
Signed-off-by: Bo Shen <voice.shen@atmel.com>
This patch add following EK information
- at91sam9n12ek, at91sam9x5ek
- sama5d3xek
This patch implement following things
- The link no longer accessable
- Remove the error configuration command
- Update soldered data flash memory map
- Update at91sam9m10g45ek memory size to 128MiB
The Freescale MPC8220 Power Architecture processors have long reached
EOL; Freescale does not even list these any more on their web site.
Remove the code to avoid wasting maitaining efforts on dead stuff.
Cc: Andy Fleming <afleming@gmail.com>
Signed-off-by: "Paul B. Henson" <henson@acm.org>
A few things have changed since this doc was written, so update it to
match the current state of things.
- Enable hw_watchdog_init() in watchdog.h if CONFIG_HW_WATCHDOG is defined.
- Move blackfin hw watchdog driver to the generic driver folder.
- Call hw_watchdog_init() from blackfin board init code.
- Reuse macro CONFIG_WATCHDOG_TIMEOUT_MSECS
- Update README.watchdog accordingly
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
drivers/mtd/nand/mxc_nand_spl.c
include/configs/m28evk.h
Warm reset on OMAP5 freezes when USB cable is connected.
Fix requires PRM_RSTTIME.RSTTIME1 to be programmed
with the time for which reset should be held low for the
voltages and the oscillator to reach stable state.
There are 3 parameters to be considered for calculating
the time, which are mostly board and PMIC dependent.
-1- Time taken by the Oscillator to shut + restart
-2- PMIC OTP times
-3- Voltage rail ramp times, which inturn depends on the
PMIC slew rate and value of the voltage ramp needed.
In order to keep the code in u-boot simple, have a way
for boards to specify a pre computed time directly using
the 'CONFIG_OMAP_PLATFORM_RESET_TIME_MAX_USEC'
option. If boards fail to specify the time, use a default
as specified by 'CONFIG_DEFAULT_OMAP_RESET_TIME_MAX_USEC' instead.
Using the default value translates into some ~22ms and should work in
all cases.
However in order to avoid this large delay hiding other bugs,
its recommended that all boards look at their respective data
sheets and specify a pre computed and optimal value using
In order to help future board additions to compute this
config option value, add a README at doc/README.omap-reset-time
which explains how to compute the value. Also update the toplevel
README with the additional option and pointers to
doc/README.omap-reset-time.
[rnayak@ti.com: Updated changelog and added the README]
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
Many boot image configuration files refer to the
appropriate documentation file, but these references
contain typos in the directory and file name. Fix
them. Also fix reference to doc/README.SPL file.
Cc: Prafulla Wadaskar <prafulla@marvell.com>
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
There could be scenarios where the user would like to manually(via JTAG)
configure the DDR/L2SRAM and load the bootloader binary onto DDR/L2SRAM.
This document explains thse usecases and the detailed explanation of what needs
to be done to use it.
Most of the code from CONFIG_SYS_RAMBOOT will be used except for small changes
of CCSRBAR etc.
The changes are not very large, but it is good to document them so that user
can get it working at once.
Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com>
With sandbox it is tricky to add an FDT to the image at build time (or
later) since we build an ELF file, not a plain binary, and the address
space of the whole U-Boot is not accessible in the emulated memory map
of sandbox.
Sandbox can read files directly from the host, though, so add an option
to read an FDT from a host file on start-up.
Watchdog can be used on Microblaze, PPC and Zynq hw designs.
Reviewed-by: Tom Rini <trini@ti.com>
This is a MIME GnuPG-signed message. If you see this text, it means that
your E-mail or Usenet software does not support MIME signed messages.
The Internet standard for MIME PGP messages, RFC 2015, was published in 1996.
To open this message correctly you will need to install E-mail or Usenet
software that supports modern Internet standards.
Easier for using with patman.
Implement BOOT_OFFSET command for imximage. This command is parallel
to current BOOT_FROM command, but allows more flexibility in configuring
arbitrary image header offset. Also add an imximage.cfg with default
offset values into arm/arch/imx-common/ so the board-specific imximage.cfg
can include this file to avoid magic constants.
The syntax of BOOT_OFFSET command is "BOOT_OFFSET <u32 offset>".
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Cc: Scott Wood <scottwood@freescale.com>
Cc: Tom Rini <trini@ti.com>
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Add an mxc_ocotp driver for i.MX6.
Add a fsl_iim driver common to i.MX and MPC.
This can be useful for fuse-like hardware, OTP SoC options, etc.
With 'mtest' no longer a default command, we will have unused defines
which should be removed for the v2013.10 release.
As per doc/feature-removal-schedule.txt, remove CONFIG_CMD_MEMTEST from
default list of commands.
drivers/video/exynos_fb.c
Following the removal of the smdk6400 board, the s3c64xx SoC becomes unused, so
remove associated code. It will still be possible to restore it later from the
Git history if necessary.
This reverts commit 1285a2808a254f3d1a809c1a541f0c0f746e03d7 since the migration
of boards from Makefile to boards.cfg is now complete.
The migration of boards from Makefile to boards.cfg was due for v2012.03, but
smdk6400 did not follow, and it does not build, so move it to scrapyard. It will
still be possible to restore it from the Git history before fixing it.
This also fixes support for mx31pdk and tx25, which had been broken by commit
e05e5de7fae5bec79617e113916dac6631251156.
Acked-by: Scott Wood <scottwood@freescale.com>
Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
We shall remove these OMAP4/5-specific options in v2013.07, barring
insufficient progress on the kernel side.
Cc: Sricharan R <r.sricharan@ti.com>
The kernel states:
---8<---
The OMAP3 GPMC hardware BCH engine computes remainder polynomials, it does not
provide automatic error location and correction: this step is implemented using
the BCH library.
--->8---
And we do so in u-boot.
This implementation uses the same layout for BCH8 but it is fix. The current
provided layout does only work with 64 Byte OOB.
Cc: Ilya Yanok <ilya.yanok@cogentembedded.com>
Cc: Mansoor Ahamed <mansoor.ahamed@ti.com>
Cc: Thomas Weber <thomas.weber.linux@googlemail.com>
Introduce 'mx28evk_nand' target for saving environment variables into NAND.
The mx28evk board does not come with a NAND flash populated from the
factory. It comes with an empty slot (U23), which allows the insertion of a
48-pin TSOP flash device.
Tested with a K9LBG08U0D.
Reviewed-by: Otavio Salvador <otavio@ossystems.com.br>
This patch provides a support to build the user specified dts.
Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
The "bootmenu" command uses U-Boot menu interfaces and provides
a simple mechanism for creating menus with several boot items.
When running this command the menu will be assembled as defined
by a set of environment variables which contain a title and
command key-value pairs. The "Up" and "Down" keys are used for
navigation through the items. Current active menu item is
highlighted and can be selected using the "Enter" key.
The command interprets and generates various ANSI escape
sequencies, so for proper menu rendering and item selection
the used terminal should support them.
Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
[agust: various fixes and documentation updates]
Checking the default menu item and obtaining its data can
be useful in custom menu code. Export menu_default_choice()
function which serves this purpose.
Selecting menu items is currently done in menu_interactive_choice()
by reading the user input strings from standard input.
Extend menu_interactive_choice() to support user defined function
for selecting menu items. This function and its argument can be
specified when creating the menu.
Add DT node and bindings documentaion for DP.
Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com>
Add DT node and bindings documentation for FIMD.
Albert's rework of the linker scripts conflicted with Simon's making
everyone use __bss_end. We also had a minor conflict over
README.scrapyard being added to in mainline and enhanced in
u-boot-arm/master with proper formatting.
arch/arm/cpu/ixp/u-boot.lds
arch/arm/cpu/u-boot.lds
arch/arm/lib/Makefile
board/actux1/u-boot.lds
board/actux2/u-boot.lds
board/actux3/u-boot.lds
board/dvlhost/u-boot.lds
board/freescale/mx31ads/u-boot.lds
doc/README.scrapyard
include/configs/tegra-common.h
Build tested for all of ARM and run-time tested on am335x_evm.
Refactor linker-generated array code so that symbols
which were previously linker-generated are now compiler-
generated. This causes relocation records of type
R_ARM_ABS32 to become R_ARM_RELATIVE, which makes
code which uses LGA able to run before relocation as
well as after.
Note: this affects more than ARM targets, as linker-
lists span possibly all target architectures, notably
PowerPC.
arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds
arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds
arch/arm/cpu/armv7/omap-common/u-boot-spl.lds
board/ait/cam_enc_4xx/u-boot-spl.lds
board/davinci/da8xxevm/u-boot-spl-da850evm.lds
board/davinci/da8xxevm/u-boot-spl-hawk.lds
board/vpac270/u-boot-spl.lds
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
This adds a member to TMU FDT node for providing hardware
tripping temperature threshold.
Signed-off-by: Akshay Saraswat <akshay.s@samsung.com>
