path: root/doc
2014-07-09doc: Add zynq fragment to git-mailrc fileMichal Simek
This is a MIME GnuPG-signed message. If you see this text, it means that your E-mail or Usenet software does not support MIME signed messages. The Internet standard for MIME PGP messages, RFC 2015, was published in 1996. To open this message correctly you will need to install E-mail or Usenet software that supports modern Internet standards. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-07-07Merge branch 'tom' of git://git.denx.de/u-boot-x86Tom Rini
2014-07-07git-mailrc: Add sunxi custodians.Ian Campbell
Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Acked-by: Hans de Goede <hdegoede@redhat.com>
2014-07-07mpc8xx: remove spc1920 board supportMasahiro Yamada
This board is old enough and has no maintainer. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-07-07mpc8xx: remove v37 board supportMasahiro Yamada
2014-07-07mpc8xx: remove fads board supportMasahiro Yamada
These boards are old enough and have no maintainers. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-07-07mpc8xx: remove netta, netta2, netphone board supportMasahiro Yamada
2014-07-07mpc8xx: remove rbc823 board supportMasahiro Yamada
2014-07-07mpc8xx: remove RPXlite_dw, quantum board supportMasahiro Yamada
2014-07-07mpc8xx: remove qs850, qs860t board supportMasahiro Yamada
2014-07-07doc/README.falcon: Clarify steps slightly.Tom Rini
Make it clear that we need to load a legacy-formatted (aka uImage) kernel into memory as well as the DT if used before using "spl export". Cc: Yebio Mesfin <ymesfin@ti.com> Signed-off-by: Tom Rini <trini@ti.com>
2014-07-07cosmetic: doc: update README.generic-boardMasahiro Yamada
Now MIPS supports 'generic board' feature. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2014-07-03arm: Add support for semihosting for armv8 fastmodel targets.Darwin Rambo
The armv8 ARM Trusted Firmware (ATF) can be used to load various ATF images and u-boot, and does this for virtual platforms by using semihosting. This commit extends this idea by allowing u-boot to also use semihosting to load the kernel/ramdisk/dtb. This eliminates the need for a bootwrapper and produces a more realistic boot sequence with virtual models. Though the semihosting code is quite generic, support for armv7 in fastmodel is less useful due to the wide range of available silicon and the lack of a free armv7 fastmodel, so this change contains an untested armv7 placeholder for the service trap opcode. Please refer to doc/README.semihosting for a more detailed description of semihosting and how it is used with the armv8 virtual platforms. Signed-off-by: Darwin Rambo <drambo@broadcom.com> Cc: trini@ti.com Cc: fenghua@phytium.com.cn Cc: bhupesh.sharma@freescale.com
2014-06-30Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-06-20dm: Expand and improve the device lifecycle docsSimon Glass
The lifecycle of a device is an important part of driver model. Add to the existing documentation and clarify it. Reported-by: Jon Loeliger <jdl@jdl.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-06-20dm: Rename struct device_id to udevice_idSimon Glass
It is best to avoid having any occurence of 'struct device' in driver model, so rename to achieve this. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-06-19Add documentation for verified boot on Beaglebone BlackSimon Glass
As an example of an end-to-end process for using verified boot in U-Boot, add a detailed description of the steps to be used for a Beaglebone Black. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-06-19Enhance fit_check_sign to check all imagesSimon Glass
At present this tool only checks the configuration signing. Have it also look at each of the images in the configuration and confirm that they verify. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de> (v1)
2014-06-19fdt: Rename the DEV_TREE_BIN Makefile flag to to EXT_DTBSimon Glass
This seems like a better name. This is a patch-up to the earlier commit 63b4b5b, and also removes a redundant Makefile change. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-06-17mx28evk: Add documentation on how to boot from SPI NORFabio Estevam
Explain the necessary steps in order to boot from SPI NOR. Based on a earlier submission from Mårten Wikman. Signed-off-by: Mårten Wikman <marten.wikman@novia.fi> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-06-11docs: driver-model: Fix spellingChris Packham
Signed-off-by: Chris Packham <judge.packham@gmail.com>
2014-06-11fdt: Add DEV_TREE_BIN option to specify a device tree binary fileSimon Glass
In some cases, an externally-built device tree binary is required to be attached to U-Boot. An example is when using image signing, since in that case the .dtb file must include the public keys. Add a DEV_TREE_BIN option to the Makefile, and update the documentation. Usage is something like: make DEV_TREE_BIN=boot/am335x-boneblack-pubkey.dtb Signed-off-by: Simon Glass <sjg@chromium.org>
2014-06-08Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-06-06am335x: update README for BCH16pekon gupta
updates documentation with explanation on how to select ECC schemes. Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-06-06mtd: nand: omap: add CONFIG_SYS_NAND_BUSWIDTH_16BIT to indicate NAND device ↵pekon gupta
bus-width GPMC controller needs to be configured based on bus-width of the NAND device connected to it. Also, dynamic detection of NAND bus-width from on-chip ONFI parameters is not possible in following situations: SPL: SPL NAND drivers does not support ONFI parameter reading. U-boot: GPMC controller iniitalization is done in omap_gpmc.c:board_nand_init() which is called before probing for devices, hence any ONFI parameter information is not available during GPMC initialization. Thus, OMAP NAND driver expected board developers to explicitely write GPMC configurations specific to NAND device attached on board in board files itself. But this was troublesome for board manufacturers as they need to dive into lengthy platform & SoC documents to find details of GPMC registers and appropriate configurations to get NAND device working. This patch instead adds existing CONFIG_SYS_NAND_BUSWIDTH_16BIT to board config hich indicates that connected NAND device has x16 bus-width. And then based on this config GPMC driver itself initializes itself based on NAND bus-width. This keeps board developers free from knowing GPMC controller specific internals. Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-06-05nand_spl: remove simpc8313 supportMasahiro Yamada
Commit 3d5a335c announced that all the nand_spl boards would be removed before v2014.07 release. Also update README.scrapyard. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-06-05bootm: make use of legacy image format configurableHeiko Schocher
make the use of legacy image format configurable through the config define CONFIG_IMAGE_FORMAT_LEGACY. When relying on signed FIT images with required signature check the legacy image format should be disabled. Therefore introduce this new define and enable legacy image format if CONFIG_FIT_SIGNATURE is not set. If CONFIG_FIT_SIGNATURE is set disable per default the legacy image format. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Lars Steubesand <lars.steubesand@philips.com> Cc: Mike Pearce <mike@kaew.be> Cc: Wolfgang Denk <wd@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Michal Simek <monstr@monstr.eu> Acked-by: Simon Glass <sjg@chromium.org>
2014-06-05FDT: Fix DTC repository referencesJon Loeliger
The Device Tree Compiler (DTC) used to have its master repository located on jdl.com. While it is still there, its official, new, shiny location is on kernel.org here: git://git.kernel.org/pub/scm/utils/dtc/dtc.git Update a few references to point there instead. Signed-off-by: Jon Loeliger <jdl@jdl.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-06-02Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-05-30powerpc: hiddendragon: remove orphan boardMasahiro Yamada
This board has been orphan for a while. (Emails to its maintainer have been bouncing.) Because MPC82xx family is old enough, nobody would pick up the maintainership on it. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denx <wd@denx.de>
2014-05-30powerpc: debris: remove orphan boardMasahiro Yamada
2014-05-30powerpc: kvme080: remove orphan boardMasahiro Yamada
2014-05-30powerpc: ep8248: remove orphan boardMasahiro Yamada
2014-05-30powerpc: ispan: remove orphan boardMasahiro Yamada
2014-05-30powerpc: rattler: remove orphan boardMasahiro Yamada
2014-05-30powerpc: zpc1900: remove orphan boardMasahiro Yamada
2014-05-30powerpc: mpc8260ads: remove orphan boardMasahiro Yamada
2014-05-30powerpc: adder: remove orphan boardMasahiro Yamada
This board has been orphan for a while. (Emails to its maintainer have been bouncing.) Because MPC8xx family is old enough, nobody would pick up the maintainership on it. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denx <wd@denx.de>
2014-05-30PPC4xx: Remove quad100hd boardWolfgang Denk
The quad100hd has been unmaintained and dead ever since it's been added some 6 years ago. Remove it. Also update README.scrapyard and insert some commit IDs for removed boards. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Gary Jennejohn <gljennjohn@googlemail.com>
2014-05-30Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-05-28power: Add support for TPS65090 PMU chip.Tom Wai-Hong Tam
This adds driver support for the TPS65090 PMU. Support includes hooking into the pmic infrastructure so that the pmic commands can be used on the console. The TPS65090 supports the following functionality: - fet enable/disable/querying - getting and setting of charge state Even though it is connected to the pmic infrastructure it does not hook into the pmic charging charging infrastructure. The device tree binding is from Linux, but only a small subset of functionality is supported. Signed-off-by: Tom Wai-Hong Tam <waihong@chromium.org> Signed-off-by: Hatim Ali <hatim.rv@samsung.com> Signed-off-by: Katie Roberts-Hoffman <katierh@chromium.org> Signed-off-by: Rong Chang <rongchang@chromium.org> Signed-off-by: Sean Paul <seanpaul@chromium.org> Signed-off-by: Vincent Palatin <vpalatin@chromium.org> Signed-off-by: Aaron Durbin <adurbin@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-05-27dm: rename device struct to udeviceHeiko Schocher
using UBI and DM together leads in compiler error, as both define a "struct device", so rename "struct device" in include/dm/device.h to "struct udevice", as we use linux code (MTD/UBI/UBIFS some USB code,...) and cannot change the linux "struct device" Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Marek Vasut <marex@denx.de>
2014-05-27arm:at91: enable ROM loadable atmel imageAndreas Bießmann
For sama5d3xek we need to modify the SPL image for correct detection by ROM code. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Tested-by: Bo Shen <voice.shen@atmel.com>
2014-05-23doc:git-mailrc: Add entry for dfu subsystemŁukasz Majewski
Entry for dfu subsystem have been added to doc/git-mailrc file Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
2014-05-22Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
2014-05-16Revert "sandbox: move source files from board/ to arch/sandbox/"Masahiro Yamada
This reverts commit 258060905e04fe2eb509756ef3b37e23e220a2d6. Conflicts: boards.cfg Wrong patch 25806090 was applied by accident. Revert it. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2014-05-16ARM: dts: exynos: rename from EXYNOS5_DWMMC to EXYNOS_DWMMCJaehoon Chung
Exynos serise can be supported the dw-mmc controller. So, it's good that used the general prefix as "_EXYNOS_DWMMC". Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-05-12disk: part_efi: add support for the Backup GPTSteve Rae
Check the Backup GPT table if the Primary GPT table is invalid. Renamed "Secondary GPT" to "Backup GPT" as per: UEFI Specification (Version 2.3.1, Errata A) Signed-off-by: Steve Rae <srae@broadcom.com>
2014-05-12doc: README.generic-board: Fix typoFabio Estevam
Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-05-09Merge branch 'tom' of git://git.denx.de/u-boot-x86Tom Rini
