documentation structure
There is no need to have an extra hab directory under doc/imx/:
- doc/imx/hab/ahab/
- doc/imx/hab/habv4/
Remove extra hab directory for a cleaner documentation structure.
Signed-off-by: Breno Lima <breno.lima@nxp.com>
Reviewed-by: Ye Li <ye.li@nxp.com>
(cherry picked from commit 4568f4a4c853ff9d952cfb5ec7c38c479de697d2)
i.MX8x SPL targets
The current U-Boot implementation includes SPL targets for i.MX8QM and
i.MXQXP MEK boards:
- imx8qxp_mek_spl_defconfig
- imx8qxp_mek_spl_fspi_defconfig
- imx8qm_mek_spl_defconfig
- imx8qm_mek_spl_fspi_defconfig
The U-Boot proper and ATF are included in an additional container being
necessary a different procedure for signing the flash.bin image.
Add a step-by-step guide covering the signing procedure.
Add a CSF example for the 3rd container.
Reviewed-by: Frank Zhang <frank.zhang@nxp.com>
Reviewed-by: Marius Grigoras <marius.grigoras@nxp.com>
Reviewed-by: Utkarsh Gupta <utkarsh.gupta@nxp.com>
(cherry picked from commit 04505024d38eebbb5f39133b502c8e450ca40215)
and 8X families
Add AHAB secure boot step-by-step guide for i.MX8 and i.MX8x families
devices.
Add 3 CSF example files:
- Example to sign flash.bin only using SRK keys.
- Example to sign flash.bin using a subordinate SGK key.
- Example to sign Linux image only using SRK keys.
Signed-off-by: Clement Le Marquis <clement.lemarquis@nxp.com>
(cherry picked from commit 7c46caba3b528b0399242f99612e5b094b1a4703)
The AHAB is currently supported in i.MX8QXP and i.MX8QM devices.
Add an introductory document containing the following topics:
- AHAB Secure Boot Architecture
- System Control Unit (SCU) introduction
- Security Controller (SECO) introduction
- i.MX8/8x secure boot flow
- AHAB PKI tree generation
- SRK Table and SRK Hash generation
(cherry picked from commit 6e9ceb2526bd4a45c6ff669afb086cc3a0627e6b)
The HABv4 secure boot procedure is now documented in different files:
└── habv4
├── csf_examples
│ ├── additional_images
│ │ └── csf_additional_images.txt
│ ├── mx6_mx7
│ │ ├── csf_uboot_fast_authentication.txt
│ │ └── csf_uboot.txt
│ └── mx8m_mx8mm
│ ├── csf_fit.txt
│ └── csf_spl.txt
├── guides
│ ├── mx6_mx7_secure_boot.txt
│ ├── mx8m_mx8mm_secure_boot.pdf
│ └── mx8m_mx8mm_secure_boot.txt
├── introduction_habv4.txt
└── script_examples
└── genIVT.pl
The old documentation secure_boot.txt can be removed.
(cherry picked from commit b0300fcf732ff1e79e771c386bf083e79eacc36a)
i.MX8MM devices
Add HABv4 documentation for i.MX8M and i.MX8MM targets covering the
following topics:
- How to sign an securely boot an flash.bin image.
- How to extend the root of trust for additional boot images.
- Add 2 CSF examples.
(cherry picked from commit cc63be298a3e5f44e417f4098c124715917d09e1)
and i.MX 7 family devices
Add useful documentation for encrypted boot:
- Add 2 CSF examples for encrypt and sign
- How to encrypt and sign a U-Boot binary on closed device
- Why and how increase the PRIBLOB bitfield from CAAM SCFGR
i.MX7 family devices
Add HABv4 documentation for u-boot-dtb.imx targets covering the
following topics:
- How to sign an securely boot an u-boot-dtb.imx image.
- Add 3 CSF examples.
- Add IVT generation script example.
The HABv4 is supported in i.MX 50, i.MX 53, i.MX 6, i.MX 7,
series and i.MX 8M, i.MX8MM devices.
- HABv4 Introduction
- HABv4 Secure Boot
- HABv4 Encrypted Boot
- HAB PKI tree generation
- HAB Fast Authentication PKI tree generation
There is no need to have README in all i.MX documents name.
Remove README from i.MX docs name and add .txt file extension.
The Serial Download Protocol feature is availible in various
i.MX SoCs.
Move README.sdp document to imx/misc directory.
The current High Assurance Boot document README.mxc_hab
include details for the following features in a single file:
- HAB Secure Boot
- HAB Encrypted Boot
Split HAB documentation in a specific directory for a cleaner
documentation structure, subsequent patches will include more
content in HAB documentation.
The following documents describe device details according to the
i.MX family:
- README.imx25
- README.imx27
- README.imx5
- README.imx6
- README.mxs
Move all device common related document to doc/imx/common for a better
directory structure.
The following documents describe the image type used by the mkimage
tool to generate U-Boot images for i.MX devices.
- README.imximage
- README.mxsimage
Move all mkimage related document to doc/imx/mkimage for a better
Currently the Serial Download Protocol tools and procedure are
documented in two places:
- doc/imx/README.sdp
- doc/imx/README.imx6
It is better to consolidate all SDP related information into
README.sdp file, so move the content from README.imx6 to
README.sdp.
Currently the U-Boot doc/ directory contains the following files
that are only relevant for i.MX devices:
- doc/README.imx25
- doc/README.imx27
- doc/README.imx5
- doc/README.imx6
- doc/README.imximage
- doc/README.mxc_hab
- doc/README.mxs
- doc/README.mxsimage
- doc/README.sdp
Move all content to a common i.MX folder for a better documentation
structure.
doc/device-tree-bindings
Currently the U-Boot project contains 2 documentation directories:
- doc/
- Documentation/
The Documentation directory only contains device tree bindings related
content, so move the 2 files to doc/device-tree-bindings/.
This commit is based in a previous submission in U-Boot upstream:
http://git.denx.de/?p=u-boot.git;a=commit;h=ad7061ed742e1312289644268859a0f4b512aaee
The README.mxc_hab is outdated and need improvements, add the following
modifications:
- Reorganize document and remove duplicate content
- Add CST download link
- Update CST package name
- Align command lines with CST v2.3.3
- Update U-Boot binary name
- Remove CSF padding since is not documented in AN4581
Currently the High Assurance Boot procedure is documented in two
places:
- doc/README.imx6
It is better to consolidate all HAB related information into
README.mxc_hab file, so move the content from README.imx6 to
README.mxc_hab.
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
With the contents of config_distro_defaults.h migrated to Kconfig,
we can remove this header file completely
README.efi describes two different concepts:
* U-Boot exposing the UEFI API
* U-Boot running on top of UEFI.
This patch splits the document in two.
Religious references are removed.
The separation of the concepts makes sense before detailing the internals
of U-Boot exposing the UEFI API in a future patch.
This commit cleans up the README.watchdog by removing the reminescent of
ADI's Blackfin architecture removed some time ago.
Signed-off-by: Lukasz Majewski <lukma@denx.de>
The original text is from the time that the config options were not
converted to Kconfig.
After the conversion to Kconfig only CONFIG_SECURE_BOOT and
CONFIG_CMD_DEKBLOB need to be selected by the user.
The other config options are automatically selected by the Kconfig
logic.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Reviewed-by: Breno Lima <breno.lima@nxp.com>
The EFI implementation does not fit into any of the existing categories.
Provide LOGC_EFI so that EFI related message can be filtered.
When functions return an error it propagates up the stack to the point
where it is reported. Often the error code provides enough information
about the root cause of the error that this is obvious what went wrong.
However in some cases the error may be hard to trace. For example if a
driver uses several devices to perform an operation, it may not be
obvious which one failed.
Add a log_ret() macro to help with this. This can be used to wrap any
error-return value. The logging system will then output a log record when
the original error is generated, making it easy to trace the call stack
of the error.
This macro can significantly impact code size, so its use is controlled
by a Kconfig option, which is enabled for sandbox.
Add some notes about recent new features.
Xilinx changes for v2018.03
- Several Kconfig fixes (also moving configs to defconfigs)
- Some DTS updates
- ZynqMP psu rework based on Zynq concept
- Add low level initialization for zc770 and zcu102
- Add support for Zynq zc770 x16 nand configuration
- Add mini nand/emmc ZynqMP targets
- Some arasan nand changes
zc770-xm011 is also added and supported. Reflect this in README.
The appended README explains how U-Boot and iPXE can be used
to boot a diskless system from an iSCSI SAN.
The maintainer for README.efi and README.iscsi is set.
[agraf: s/Adress/Address/]
NAND and QSPI devices are now supported, so mark
them as such.
Cc: Michal Simek <michal.simek@xilinx.com>
Signed-off-by: Ezequiel Garcia <ezequiel@vanguardiasur.com.ar>
Update documentation to reflect adopting the Linux DT bindings.
Tested on TI K2G platform:
Tested-by: Vignesh R <vigneshr@ti.com>
Tested on a socfpga-cyclonev board:
Tested-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com>
Signed-off-by: Jason Rush <jarush@gmail.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
Acked-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com>
Migrate the following symbols to Kconfig:
CONFIG_FS_EXT4
CONFIG_EXT4_WRITE
The definitions in config_fallbacks.h can now be expressed in Kconfig.
The following config symbols are only defined once and never referenced
anywhere else:
CONFIG_AMCORE
CONFIG_ASTRO5373L
CONFIG_M52277EVB
CONFIG_M5253DEMO
CONFIG_M5253EVBE
CONFIG_M5275EVB
CONFIG_M54418TWR
CONFIG_STMARK2
Most of them are config symbols named after the respective boards which
seems to have been a standard practice at some point.
It's mostly obvious, except that QEMU is annoying and requires an
explicit '-cpu cortex-a57' (or some other 64-bit core) to actually run
in 64-bit mode.
While at it, remove the references to setting the ARCH environment
variable; that is not used in U-Boot.
The DT spec demands a unit-address in a node name to match the "reg"
property in that node. Newer dtc versions will throw warnings if this is
not the case.
Fix all occurences in various documentation files where this was not
observed, to not give bad examples to the reader.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
The DT spec demands a unit-address of a node name to match the "reg"
not the case.
Fix all occurences in the FIT image example files where this was not
not the case.
Fix all occurences in the FIT image documentation files where this was not
Add documents to describe NX25 and AE250.
Also update other documents for RISC-V.
Signed-off-by: Rick Chen <rick@andestech.com>
Signed-off-by: Rick Chen <rickchen36@gmail.com>
Signed-off-by: Greentime Hu <green.hu@gmail.com>
add a simple readme to introduce rockusb and tell people how to use it
Signed-off-by: Eddie Cai <eddie.cai.linux@gmail.com>
Linux bindings have been introduced in the code (removing the U-Boot
specific ones) without documentation update. Compatible string has
changed, as well as the four GPIO properties. Reflect this by updating
the soft-spi.txt documentation.
Fixes: 102412c415 ("dm: spi: soft_spi: switch to use linux compatible string")
Signed-off-by: Miquel Raynal <miquel.raynal@free-electrons.com>
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
This patch extends pmic_bind_children prefix matching. In addition to
the node name the property regulator-name is used while trying to match
prefixes. This allows assigning different drivers to regulator nodes
named regulator@1 and regulator@10 for example.
I have discarded the idea of using other properties then regulator-name
as I do not see any benefit in using property compatible or even
regulator-compatible. Of course I am open to change this if there are
good reasons to do so.
Signed-off-by: Felix Brack <fb@ltec.ch>
For external data, FIT has a optional property "data-position" which
can set the external data to a fixed offset to FIT beginning.
Add the support for this property in SPL FIT.
Signed-off-by: Ye Li <ye.li@nxp.com>
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Reviewed-by: Tomas Melin <tomas.melin@vaisala.com>
Cc: Pantelis Antoniou <pantelis.antoniou@konsulko.com>
Cc: "Andrew F. Davis" <afd@ti.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Cc: "tomas.melin@vaisala.com" <tomas.melin@vaisala.com>
Cc: Kever Yang <kever.yang@rock-chips.com>
Cc: Andre Przywara <andre.przywara@arm.com>
Cc: York Sun <york.sun@nxp.com>
Cc: Lokesh Vutla <lokeshvutla@ti.com>
Cc: "Cooper Jr., Franklin" <fcooper@ti.com>
Cc: George McCollister <george.mccollister@gmail.com>
Cc: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
Cc: Jean-Jacques Hiblot <jjhiblot@ti.com>
Cc: Rick Altherr <raltherr@google.com>
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
Reviewed-by: York Sun <york.sun@nxp.com>
Synopsys HSDK clock controller generates and supplies clocks to various
controllers and peripherals within the SoC.
Each clock has assigned identifier and client device tree nodes can use
this identifier to specify the clock which they consume. All available
clocks are defined as preprocessor macros in the
dt-bindings/clock/snps,hsdk-cgu.h header and can be used in device
tree sources.
Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com>
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Add documentation for the log system.
The reset circuitry in the RK3399 only resets 'almost all logic' when
a software reset is performed. To make our software maintenance
easier in the future, we want to have the option (controlled by a DTS
property) to force all reset causes other than a power-on reset to
trigger a power-on reset via a GPIO trigger.
This adds the necessary support to the rk3399-puma (i.e. RK3399-Q7)
board-support and the documentation for the new property
(sysreset-gpio) within the /config-node.
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Tested-by: Klaus Goger <klaus.goger@theobroma-systems.com>
Add a document to describe Andestech atcspi200 spi and
binding information.
