Add support for loading splash image from an SD card formatted with
a filesystem. Update boards to maintain original behavior where needed.
Cc: Igor Grinberg <grinberg@compulab.co.il>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
The 10m50 devboard becomes the new golden reference design of
Nios II Linux. So change README.nios2 to use 10m50 as template.
Add Altera Generic Quad SPI Controller support. The controller
converts SPI NOR flash to parallel flash interface. So it is
not like other SPI flash, but rather like CFI flash.
Convert cfi flash to driver model.
After consulting with some of the SPDX team, the conclusion is that
Makefiles are worth adding SPDX-License-Identifier tags too, and most of
ours have one. This adds tags to ones that lack them and converts a few
that had full (or in one case, very partial) license blobs into the
equivalent tag.
Cc: Kate Stewart <kstewart@linuxfoundation.org>
Revert commit 7a2c1b13 which dropped OpenRD boards.
Assume maintainership of OpenRD.
Remove OpenRD from scrapyard.
Switch OpenRD to generic board.
Switch to Thumb build.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
This commit adds:
- new uclass id: UCLASS_ADC
- new uclass driver: drivers/adc/adc-uclass.c
The new uclass's API allows for ADC operation on:
* single-channel with channel selection by a number
* multti-channel with channel selection by bit mask
ADC uclass's functions:
* single-channel:
- adc_start_channel() - start channel conversion
- adc_channel_data() - get conversion data
- adc_channel_single_shot() - start/get conversion data
* multi-channel:
- adc_start_channels() - start selected channels conversion
- adc_channels_data() - get conversion data
- adc_channels_single_shot() - start/get conversion data for channels
selected by bit mask
* general:
- adc_stop() - stop the conversion
- adc_vdd_value() - positive reference Voltage value with polarity [uV]
- adc_vss_value() - negative reference Voltage value with polarity [uV]
- adc_data_mask() - conversion data bit mask
The device tree can provide below constraints/properties:
- vdd-polarity-negative: if true: Vdd = vdd-microvolts * (-1)
- vss-polarity-negative: if true: Vss = vss-microvolts * (-1)
- vdd-supply: phandle to Vdd regulator's node
- vss-supply: phandle to Vss regulator's node
And optional, checked only if the above corresponding, doesn't exist:
- vdd-microvolts: positive reference Voltage [uV]
- vss-microvolts: negative reference Voltage [uV]
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
This driver allows I/O operations on the Samsung S2MPS11 PMIC,
which provides lots of LDO/BUCK outputs.
To enable it, update defconfig with:
- CONFIG_PMIC_S2MPS11
and additional, if were not defined:
- CONFIG_CMD_PMIC
- CONFIG_ERRNO_STR
The binding info: doc/device-tree-bindings/pmic/s2mps11.txt
Tested-by: Anand Moon <linux.amoon@gmail.com>
The CPU name for Exynos was concatenated with cpu id,
but for new Exynos platforms, like Chromebook Peach Pi
based on Exynos5800, the name of SoC variant does not
include the real SoC cpu id (0x5422).
For such case, the CPU name should be defined in device tree.
This commit introduces new device-tree property for Exynos:
- "cpu-model" - with cpu name string
If defined, then the cpu id is not printed.
Signed-off-by: Hou Zhiqiang <B48286@freescale.com>
Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
Signed-off-by: Mingkai Hu <Mingkai.Hu@freescale.com>
Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com>
Reviewed-by: York Sun <yorksun@freescale.com>
For most PPC platforms, they will call the first get_clocks() in
init_sequence_f[] as they define CONFIG_PPC. CONFIG_SYS_FSL_CLK is
then defined to call the second get_clocks(), which should be
redundant for PPC.
This board has not compiled for me for quite some time due to size
constraints, remove.
Cc: Stefan Roese <sr@denx.de>
Cc: John Otken <jotken@softadvances.com>
Added device-tree-binding information for zynq qspi controller
driver.
Signed-off-by: Jagan Teki <jteki@openedev.com>
Cc: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
Acked-by: Michal Simek <michal.simek@xilinx.com>
Tested-by: Jagan Teki <jteki@openedev.com>
Export fdt_blob to the environment variable. So that we may
use it to boot Linux.
The current name is inconsistent with other driver model data access
functions. Rename it and fix up all users.
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
Convert altera_tse to driver model and phylib.
Add README.nios2 about how to add nios2 boards to u-boot.
Convert altera sysid to driver model with misc uclass.
Acked-by: Chin Liang See <clsee@altera.com>
Convert altera timer to driver model.
Convert nios2 cpu to driver model. The cpu parameters are
extracted from device tree and saved to global data structure.
We will use them to replace the custom_fpga.h .
Convert altera_pio to driver model.
Convert altera_spi to driver model
Reviewed-by: Jagan Teki <jteki@openedev.com>
Convert altera_uart to driver model.
Convert altera_jtag_uart to driver model.
Many System on Chip(SoC) solutions are complex with multiple processors
on the same die dedicated to either general purpose of specialized
functions. Many examples do exist in today's SoCs from various vendors.
Typical examples are micro controllers such as an ARM M3/M0 doing a
offload of specific function such as event integration or power
management or controlling camera etc.
Traditionally, the responsibility of loading up such a processor with a
firmware and communication has been with a High Level Operating
System(HLOS) such as Linux. However, there exists classes of products
where Linux would need to expect services from such a processor or the
delay of Linux and operating system being able to load up such a
firmware is unacceptable.
To address these needs, we need some minimal capability to load such a
system and ensure it is started prior to an Operating System(Linux or
any other) is started up.
NOTE: This is NOT meant to be a solve-all solution, instead, it tries to
address certain class of SoCs and products that need such a solution.
A very simple model is introduced here as part of the initial support
that supports microcontrollers with internal memory (no MMU, no
execution from external memory, or specific image format needs). This
basic framework can then (hopefully) be extensible to other complex SoC
processor support as need be.
Signed-off-by: Nishanth Menon <nm@ti.com>
Now that we have added MRC cache for Intel FSP and BayTrail codes,
enable it for all BayTrail boards (Bayley Bay and Minnow Max).
Note it turns out that FSP for Intel Atom E6xx does not produce
the HOB for NV storage, so we don't have such functionality on
Intel Crown Bay board.
Introduce a new fsp command and make the existing hob command a
sub-command to fsp for future extension. Also move cmd_hob.c to
the dedicated fsp sub-directory in arch/x86/lib.
System Management BIOS (SMBIOS) is a specification for how
motherboard and system vendors present management information
about their products in a standard format by extending the BIOS
interface on Intel architecture systems. As of today the latest
spec is 3.0 and can be downloaded from DMTF website. This commit
adds a simple and minimum required implementation.
Current document about how to boot VxWorks is limited.
Add several chapters in README.vxworks to document this.
- Add deletions from August 30 2015.
- A few from Sept 12, one from Oct 2nd.
Add in the commit IDs / dates for boards removed on Sept 2nd.
This reverts commit 8fe11b8901a31d11990488c82bc23612589d57be.
I'll add support to lwmon5 in the next patch and will remove
support for the broken lcd4_lwmon5 as well.
The DDR SDRAM initialization code has not been mainlined yet, but
U-Boot proper should work.
Desktop Management Interface (DMI) is not supported by U-Boot now.
Add it to the TODO list.
Document porting considerations for Intel Quark based board,
including MRC parameters and PCIe initialization.
This board has not been converted to generic board by the deadline.
Remove it.
Remove it.
Remove it.
It's easier to Cc him on ARC-releated patches.
