path: root/doc
2016-09-07pxe: Modify README to add the description about FIT imageWenbin Song
Use environment variable "kernel_addr_r" to indicate the location in RAM where FIT image will be stored. Use label command "kernel" to indicate which <path> the FIT image at. Signed-off-by: Wenbin Song <wenbin.song@nxp.com>
2016-09-06regulator: fixed: obey startup delayJohn Keeping
When enabling a fixed regulator, it may take some time to rise to the correct voltage. If we do not delay here then subsequent operations will fail. Signed-off-by: John Keeping <john@metanate.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-08-26treewide: fix "followings" to "following"Masahiro Yamada
Most of them are my mistakes. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-08-16x86: Mention running U-Boot in 64-bit mode in the READMESimon Glass
This feature is not supported. Document this, and add some details on how it might be implemented. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-08-16x86: Add a reference to README.efiSimon Glass
UEFI is commonly used on x86. Add a reference to U-Boot's support for this in the x86 README. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-08-16x86: Mention how to boot a 64-bit kernel from U-BootSimon Glass
The README indicates that this is not supported, but this is no-longer true. Update the text to indicate this and describe the FIT changes required. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-08-16x86: doc: Add note about the debug FSP usage on BayTrailStefan Roese
The debug FSP image is bigger in size than the normal FSP image. This patch adds a small description on how to use this FSP debug version by changing CONFIG_FSP_ADDR. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-08-15xtensa: add support for the xtensa processor architecture [1/2]Chris Zankel
The Xtensa processor architecture is a configurable, extensible, and synthesizable 32-bit RISC processor core provided by Cadence. This is the first part of the basic architecture port with changes to common files. The 'arch/xtensa' directory, and boards and additional drivers will be in separate commits. Signed-off-by: Chris Zankel <chris@zankel.net> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-08-15atmel: Bring in at91 pio4 device tree file and bindingsWenyou Yang
Bring in required device tree file and bindings from Linux. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Andreas Bießmann <andreas@biessmann.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-08-15i2c: atmel: DT binding for i2c driverSongjun Wu
DT binding documentation for atmel i2c driver. Signed-off-by: Songjun Wu <songjun.wu@atmel.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2016-08-08gpio: Add driver for TI PCF8575 I2C GPIO expanderVignesh R
TI's PCF8575 is a 16-bit I2C GPIO expander.The device features a 16-bit quasi-bidirectional I/O ports. Each quasi-bidirectional I/O can be used as an input or output without the use of a data-direction control signal. The I/Os should be high before being used as inputs. Read the device documentation for more details[1]. This driver is based on pcf857x driver available in Linux v4.7 kernel. It supports basic reading and writing of gpio pins. [1] http://www.ti.com/lit/ds/symlink/pcf8575.pdf Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Mugunthan V N <mugunthanvnm@ti.com>
2016-08-06Merge git://git.denx.de/u-boot-rockchipTom Rini
2016-08-05rockchip: add support for rk3288 miniarm boardXu Ziyuan
Miniarm is a rockchip rk3288 based development board, which has lots of interface such as HDMI, USB, micro-SD card, Audio etc. Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-08-04dt-bindings: add Tegra186 BPMP I2C bindingStephen Warren
In Tegra186, the BPMP (Boot and Power Management Processor) owns certain HW devices, such as the I2C controller for the power management I2C bus. Software running on other CPUs must perform IPC to the BPMP in order to execute transactions on that I2C bus. This binding describes an I2C bus that is accessed in such a fashion. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-08-04dt-bindings: allow child nodes inside the Tegra BPMPStephen Warren
The BPMP implements some services which must be represented by separate nodes. For example, it can provide access to certain I2C controllers, and the I2C bindings represent each I2C controller as a device tree node. Update the binding to describe how the BPMP supports this. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-08-04ARM: tegra: add BPMP DT bindingsStephen Warren
The Tegra BPMP (Boot and Power Management Processor) is a separate auxiliary CPU embedded into Tegra to perform power management work, and controls related features such as clocks, resets, power domains, PMIC I2C bus, etc. These bindings dictate how to represent the BPMP in device tree. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-08-04ARM: tegra: adapt to latest HSP DT bindingStephen Warren
The DT binding for the Tegra186 HSP module apparently wasn't quite final when I posted initial U-Boot support for it. Add the final DT binding doc and adapt all code and DT files to match it. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-08-02MAINTAINERS, git-mailrc: Update the mmc maintainerJaehoon Chung
Update the mmc maintainer from Pantelis to me. Acked-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-07-31Drop references to MAKEALL in the documentationSimon Glass
It is confusing to mention MAKEALL when it is not the normal way of building U-Boot anymore. Update the documentation to suit. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-07-31rockchip: add support for rk3288 PopMetal boardjk.kernel@gmail.com
PopMetal is a rockchip rk3288 based board made by ChipSpark, which has many interface such as HDMI, VGA, USB, micro-SD card, WiFi, Audio and Gigabit Ethernet. Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-07-31rockchip: add basic support for fennec-rk3288 boardjk.kernel@gmail.com
Fennec is a RK3288-based development board with 2 USB ports, HDMI, micro-SD card, audio and WiFi and Gigabit Ethernet. It also includes on-board 8GB eMMC and 2GB of SDRAM. Expansion connectors provides access to display pins, I2C, SPI, UART and GPIOs. Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-07-28Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2016-07-25rockchip: update fastboot usageXu Ziyuan
Introduce how to use fastboot feature on rk3288. Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-07-25rockchip: add basic support for evb-rk3288 boardXu Ziyuan
evb-3288 board RK3288-based development board with 2 USB ports, HDMI, VGA, micro-SD card, audio, WiFi and Gigabit Ethernet. It also includes on-board 8G eMMC and 2GB of SDRAM. Expansion connector provide access to display pins, I2C, SPI, UART and GPIOs. This add some basic files required to allow the board to output serial messaged and can run command(mmc info etc). evb-rk3288 also supports booting from eMMC or SD card, the default is eMMC. Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-07-25rockchip: add option to change method of loading u-bootXu Ziyuan
If we would like to boot from SD card, we have to implement mmc driver in SPL stage, and get a slightly large SPL binary. Rockchip SoC's bootrom code has the ability to load spl and u-boot, then boot. If CONFIG_ROCKCHIP_SPL_BACK_TO_BROM is enabled, the spl will return to bootrom in board_init_f(), then bootrom loads u-boot binary. Loading sequence after rework: bootrom ==> spl ==> bootrom ==> u-boot Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org> Fixed up spelling of U-Boot, boorom, opinion->option, Rochchip: Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-22spl: Lightweight UBI and UBI fastmap supportThomas Gleixner
Booting a payload out of NAND FLASH from the SPL is a crux today, as it requires hard partioned FLASH. Not a brilliant idea with the reliability of todays NAND FLASH chips. The upstream UBI + UBI fastmap implementation which is about to brought to u-boot is too heavy weight for SPLs as it provides way more functionality than needed for a SPL and does not even fit into the restricted SPL areas which are loaded from the SoC boot ROM. So this provides a fast and lightweight implementation of UBI scanning and UBI fastmap attach. The scan and logical to physical block mapping code is developed from scratch, while the fastmap implementation is lifted from the linux kernel source and stripped down to fit the SPL needs. The text foot print on the board which I used for development is: 6854 0 0 6854 1abd drivers/mtd/ubispl/built-in.o Attaching a NAND chip with 4096 physical eraseblocks (4 blocks are reserved for the SPL) takes: In full scan mode: 1172ms In fastmap mode: 95ms The code requires quite some storage. The largest and unknown part of it is the number of fastmap blocks to read. Therefor the data structure is not put into the BSS. The code requires a pointer to free memory handed in which is initialized by the UBI attach code itself. See doc/README.ubispl for further information on how to use it. This shares the ubi-media.h and crc32 implementation of drivers/mtd/ubi There is no way to share the fastmap code, as UBISPL only utilizes the slightly modified functions ubi_attach_fastmap() and ubi_scan_fastmap() from the original kernel ubi fastmap implementation. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Acked-by: Heiko Schocher <hs@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-07-21Merge git://git.denx.de/u-boot-mpc85xxTom Rini
2016-07-21doc: SPL: Add README for secure boot supportSumit Garg
Adds information regarding SPL handling validation process of main u-boot image on power/mpc85xx and arm/layerscape platforms. Signed-off-by: Sumit Garg <sumit.garg@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: York Sun <york.sun@nxp.com>
2016-07-21Merge branch 'master' of git://git.denx.de/u-boot-shTom Rini
2016-07-16Various, unrelated tree-wide typo fixes.Robert P. J. Day
Fix a number of typos, including: * "compatble" -> "compatible" * "eanbeld" -> "enabled" * "envrionment" -> "environment" * "FTD" -> "FDT" (for "flattened device tree") * "ommitted" -> "omitted" * "overriden" -> "overridden" * "partiton" -> "partition" * "propogate" -> "propagate" * "resourse" -> "resource" * "rest in piece" -> "rest in peace" * "suport" -> "support" * "varible" -> "variable" Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2016-07-15Merge git://git.denx.de/u-boot-dmTom Rini
2016-07-14dm: Update the of-platdata README for the new featuresSimon Glass
Revise the content based on the v2 additions. This is kept as a separate patch to avoid confusing those who have already reviewed the v1 series. Signed-off-by: Simon Glass <sjg@chromium.org> Suggested-by: Tom Rini <trini@konsulko.com>
2016-07-14dm: Add a README for of-platdataSimon Glass
Add documentation on how this works, including the benefits and drawbacks. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-14doc: Update info on using secure devices from TIAndreas Dannenberg
Adds information regarding SPL handling the loading and processing of secured u-boot images as part of the second stage boot the SPL does. Introduces the description of a new interface script in the TI SECDEV Package which handles the creation and prep of secured binary images. Signed-off-by: Daniel Allred <d-allred@ti.com> Signed-off-by: Andreas Dannenberg <dannenberg@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-07-12driver/net/fec: support fixed speed connectionHannes Schmelzer
If MAC is directly connected to another MAC (like a switch for example) we don't need to probe for a phy, autoneogation and so on. We simply have to setup speed. Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-07-12x86: acpi: Pack global NVS into ACPI tableBin Meng
Now that platform-specific ACPI global NVS is added, pack it into ACPI table and get its address fixed up. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: George McCollister <george.mccollister@gmail.com> Tested-by: George McCollister <george.mccollister@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-07-11git-mailrc: add rockchip aliasjk.kernel@gmail.com
It's easier to Cc rockchip maintainers on rockchip-releated patches. Signed-off-by: jk <jk.kernel@gmail.com>
2016-07-09serial_sh: Add standrad SCI (w/o FIFO) supportYoshinori Sato
Add support for standard type SCI (without FIFO) port. Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-07-09serial_sh: Device Tree supportYoshinori Sato
Add Device Tree bindings. Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-07-01autoboot: remove CONFIG_ZERO_BOOTDELAY_CHECKMasahiro Yamada
As the help message of CONFIG_BOOTDELAY says, CONFIG_BOOTDELAY=-2 means the autoboot with no delay, with no abort check even if CONFIG_ZERO_BOOTDELAY_CHECK is defined. To sum up, the autoboot behaves as follows: [1] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=y autoboot with no delay, but you can abort it by key input [2] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=n autoboot with no delay, with no check for abort [3] CONFIG_BOOTDELAY=-1 disable autoboot [4] CONFIG_BOOTDELAY=-2 autoboot with no delay, with no check for abort As you notice, [2] and [4] come to the same result, which means we do not need CONFIG_ZERO_BOOTDELAY_CHECK. We can control all the cases only by CONFIG_BOOTDELAY, like this: [1] CONFIG_BOOTDELAY=0 autoboot with no delay, but you can abort it by key input [2] CONFIG_BOOTDELAY=-1 disable autoboot [3] CONFIG_BOOTDELAY=-2 autoboot with no delay, with no check for abort This commit converts the logic as follow: CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=n --> CONFIG_BOOTDELAY=-2 Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Stefan Roese <sr@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Christian Riesch <christian.riesch@omicronenergy.com> Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
2016-06-24mkimage: fit: spl: Add an optional static offset for external dataTeddy Reed
When building a FIT with external data (-E), U-Boot proper may require absolute positioning for executing the external firmware. To acheive this use the (-p) switch, which will replace the amended 'data-offset' with 'data-position' indicating the absolute position of external data. It is considered an error if the requested absolute position overlaps with the initial data required for the compact FIT. Signed-off-by: Teddy Reed <teddy.reed@gmail.com>
2016-06-20Kconfig: Add a new DISTRO_DEFAULTS Kconfig optionHans de Goede
DISTRO_DEFAULTS is intended to mirror / replace include/config_distro_defaults.h. The intend is for boards which include this file to select this from their Kconfig files and when moving setting to Kconfig which are #define-ed in config_distro_defaults.h to select this from DISTRO_DEFAULTS so that boards which have selected DISTRO_DEFAULTS will keep the same configuration as before without needing any defconfig file changes. The initial list of selected things matches all settings recently removed from config_distro_defaults.h because they have been converted to Kconfig, with the exception of CMD_ELF and CMD_NET, which have a default of y, if the default of these ever changes they should be selected by DISTRO_DEFAULTS too. For testing and example purposes this commit also converts ARCH_SUNXI to use DISTRO_DEFAULT instead of selecting everything it needs itself. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-06-20Merge git://git.denx.de/u-boot-nand-flashTom Rini
2016-06-19mtd: nand: Patch remaining places where nand_to_mtd() should be usedBoris Brezillon
Some drivers are still directly accessing the chip->mtd field. Patch them to use nand_to_mtd() instead. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
2016-06-19nand: doc: fix example ecc scheme calculationFabian Mewes
Signed-off-by: Fabian Mewes <architekt@coding4coffee.org>
2016-06-19nand: extend nand tortureMax Krummenacher
nand torture currently works on exactly one nand block which is specified by giving the byteoffset to the beginning of the block. Extend this by allowing for a second parameter specifying the byte size to be tested. e.g. ==> nand torture 1000000 NAND torture: device 0 offset 0x1000000 size 0x20000 (block size 0x20000) Passed: 1, failed: 0 ==> nand torture 1000000 40000 NAND torture: device 0 offset 0x1000000 size 0x40000 (block size 0x20000) Passed: 2, failed: 0 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau.dev@gmail.com> [scottwood: fix usage to show size as optional, and add misssing braces] Signed-off-by: Scott Wood <oss@buserror.net>
2016-06-19Add a reset driver framework/uclassStephen Warren
A reset controller is a hardware module that controls reset signals that affect other hardware modules or chips. This patch defines a standard API that connects reset clients (i.e. the drivers for devices affected by reset signals) to drivers for reset controllers/providers. Initially, DT is the only supported method for connecting the two. The DT binding specification (reset.txt) was taken from Linux kernel v4.5's Documentation/devicetree/bindings/reset/reset.txt. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-06-12x86: Update x86-pinctrl driver device-tree-bindings docBin Meng
This updates the device-tree-bindings doc for x86-pinctrl driver: - clarify "gpio-offset" is required only when "mode-gpio" is set - correct property name "pull-strength" - use tab instead of space at several places Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-06-09doc, spl, am335x: update am335x-networkHeiko Schocher
on the shc board we see when booting in net boot mode, that the ROM bootloader sends "AM335x ROM" as vendor-class-identifier. U-Boots doc says "DM814x ROM". So, add the info to the doc, that there is also "AM335x ROM" possible. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-06-04Merge git://git.denx.de/u-boot-nand-flashTom Rini
