path: root/doc
2015-04-29x86: Correct Minnowboard instructions to use the right descriptorSimon Glass
The descriptor provided with the FSP does not seem to work. Update the instructions to use the descriptor from the original Intel firmware. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-22dm: Update the README to reflect the current test outputSimon Glass
There are a lot more tests now. To avoid confusion add the updated test output to the driver model README. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2015-04-20Update MAINTAINERS and git-mailrc for netJoe Hershberger
Update to my corporate email and make the supported filter and aliases more accurate. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2015-04-18dts: sunxi: Bring in Ethernet device tree bindingsSimon Glass
Since we will use these bindings on sunxi, bring them in from Linux 4.0-rc1. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-04-18net: cosmetic: Fix checkpatch.pl failures in net.cJoe Hershberger
Finish eliminating CamelCase from net.c and other failures Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Fix var naming net <-> eth driversJoe Hershberger
Update the naming convention used in the network stack functions and variables that Ethernet drivers use to interact with it. This cleans up the temporary hacks that were added to this interface along with the DM support. This patch has a few remaining checkpatch.pl failures that would be out of the scope of this patch to fix (drivers that are in gross violation of checkpatch.pl). Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Name ethaddr variables consistentlyJoe Hershberger
Use "_ethaddr" at the end of variables and drop CamelCase. Make constant values actually 'const'. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: usb: Add a README for driver modelSimon Glass
Add some documentation describing how USB is implemented with USB. This might make things easier for people to understand. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: i2c: add i2c-gpio driverPrzemyslaw Marczak
This commit adds driver model support to software emulated i2c bus driver. This driver supports kernel-style device tree bindings. Fdt properties in use: - compatible - "i2c-gpio" - gpios - data and clock GPIO pin phandles - delay-us - micro seconds delay between GPIOs toggle operations, which is 1/4 of I2C speed clock period. Added: - Config: CONFIG_DM_I2C_GPIO - File: drivers/i2c/i2c-gpio.c - File: doc/device-tree-bindings/i2c/i2c-gpio.txt Driver base code is taken from: drivers/i2c/soft-i2c.c, changes: - use "i2c-gpio" naming - update comments style - move preprocesor macros into functions - add device tree support - add driver model i2c support - code cleanup, - add Kconfig entry Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Added braces in i2c_gpio_xfer() to fix style nit: Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: eth: Add basic driver model support to Ethernet stackJoe Hershberger
First just add support for MAC drivers. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-04-16dm: pci: Add a uclass for PCISimon Glass
Add a uclass for PCI controllers and a generic one for PCI devices. Adjust the 'pci' command and the existing PCI support to work with this new uclass. Keep most of the compatibility code in a separate file so that it can be removed one day. TODO: Add more header file comments to the new parts of pci.h Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-16x86: video: Allow keyboard presence to be controlled by device treeSimon Glass
At present a VGA console assumes a keyboard unless a CONFIG option is set. This difference can be dealt with by a device tree option, allowing boards that are otherwise the same to use the same configuration. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-14fastboot: check for alias when looking up partition by nameMichael Scott
Implement an alias name check for devices where GPT limitations prevent user-friendly partition names such as "boot", "system" and "cache". Or, where the actual partition name doesn't match a standard partition name used commonly with fastboot. To set an alias, add an environment setting as follows: fastboot_partition_alias_<alias partition name>=<actual partition name> Example: fastboot_partition_alias_boot=LNX Signed-off-by: Michael Scott <michael.scott@linaro.org> Acked-by: Steve Rae <srae@broadcom.com> Cc: Steve Rae <srae@broadcom.com> Cc: Lukasz Majewski <l.majewski@samsung.com>
2015-04-13Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-04-08Fix mxc_hab documenation for DEK blob generationUlises Cardenas
Include/fsl_sec.h defines sec_in and sec_out, according to the platform's endianess. Therefore, CONFIG_SYS_FSL_LE needs to be declared in the configuration file of the target, in order to use enable the DEK blob generation command. This requirement is not explicit in the README.mxc_hab. Signed-off-by: Ulises Cardenas <Ulises.Cardenas@freescale.com>
2015-04-06video: exynos_fb: configure backlight GPIOs if specified in DTAjay Kumar
Add support to configure PWM_OUT(PWM output) GPIO and BL_EN(backlight enable) GPIO, if provided in FIMD DT node. Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-03-30nand: Remove unused CONFIG_MTD_NAND_ECC_JFFS2 optionPeter Tyser
This option was removed along with legacy NAND support in be33b046b549ad88c204c209508cd7657232ffbd. Clean up some remnants. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2015-03-28armv8: semihosting: add a command to load semihosted imagesLinus Walleij
Instead of sprinkling custom code and calls over the Vexpress64 boardfile, create a command that loads images using semihosting just like we would load from flash memory of over the network, using a special command: smhload <image> <address> This will make it possible to remove some custom calls and code and make the boot easier. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-03-28Document config_distro_bootcmd environment variables for interactive booting.Karsten Merker
config_distro_bootcmd.h defines a common boot environment for multiple platforms, including several environment variables that are intended for interactive use by an end-user. Document which variables are considered public interfaces that must remain compatible in future u-boot versions. Signed-off-by: Karsten Merker <merker@debian.org> Acked-by: Stephen Warren <swarren@nvidia.com>
2015-03-28generic-board: move __HAVE_ARCH_GENERIC_BOARD to KconfigMasahiro Yamada
Move the option to Kconfig renaming it to CONFIG_HAVE_GENERIC_BOARD. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Alexey Brodkin <abrodkin@synopsys.com>
2015-03-24net: Update README.drivers.eth to mention latest APIsBin Meng
README.drivers.eth still refers to the deprecated miiphy_register(). Update the doc to mention new APIs mdio_alloc() and mdio_register(). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-03-24x86: Add queensbay fsp patch information in README.x86Bin Meng
The FSP release version 001 for Intel Queensbay has a bug which could cause random endless loop during the FspInit call. This bug was published by Intel although Intel did not describe any details. Describe this information in the x86 doc so that U-Boot Queensbay support is invulnerable. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-03-17powerpc: ppc4xx: remove korat board supportMasahiro Yamada
This has not been converted to Generic Board, so should be removed. (See doc/README.generic-board for details.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Larry Johnson <lrj@acm.org>
2015-03-17powerpc: mpc5xxx: remove galaxy5200 board supportMasahiro Yamada
This has not been converted to Generic Board, so should be removed. (See doc/README.generic-board for details.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Eric Millbrandt <emillbrandt@dekaresearch.com>
2015-03-17powerpc: ppc4xx: remove W7OLMC/W7OLMG board supportMasahiro Yamada
They have not been converted to Generic Board, so should be removed. (See doc/README.generic-board for details.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Erik Theisen <etheisen@mindspring.com>
2015-03-17powerpc: mpc5xxx: remove aev, TB5200 board supportMasahiro Yamada
2015-03-17powerpc: ppc4xx: remove JSE board supportMasahiro Yamada
This has not been converted to Generic Board, so should be removed. (See doc/README.generic-board for details.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Stephen Williams <steve@icarus.com>
2015-03-17powerpc: mpc5xxx: remove BC3450 board supportMasahiro Yamada
2015-03-15git-mailrc: update Masahiro's email addressMasahiro Yamada
I have transferred to Socionext Inc. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-03-05Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
2015-03-05SECURE BOOT: Add command for validation of imagesgaurav rana
1. esbc_validate command is meant for validating header and signature of images (Boot Script and ESBC uboot client). SHA-256 and RSA operations are performed using SEC block in HW. This command works on both PBL based and Non PBL based Freescale platforms. Command usage: esbc_validate img_hdr_addr [pub_key_hash] 2. ESBC uboot client can be linux. Additionally, rootfs and device tree blob can also be signed. 3. In the event of header or signature failure in validation, ITS and ITF bits determine further course of action. 4. In case of soft failure, appropriate error is dumped on console. 5. In case of hard failure, SoC is issued RESET REQUEST after dumping error on the console. 6. KEY REVOCATION Feature: QorIQ platforms like B4/T4 have support of srk key table and key revocation in ISBC code in Silicon. The srk key table allows the user to have a key table with multiple keys and revoke any key in case of particular key gets compromised. In case the ISBC code uses the key revocation and srk key table to verify the u-boot code, the subsequent chain of trust should also use the same. 6. ISBC KEY EXTENSION Feature: This feature allows large number of keys to be used for esbc validation of images. A set of public keys is being signed and validated by ISBC which can be further used for esbc validation of images. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> Signed-off-by: Gaurav Rana <gaurav.rana@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-03-05gpt: support random UUIDs without setting environment variablesRob Herring
Currently, an environment variable must be used to store the randomly generated UUID for each partition. This is not necessary, so make storing the UUID optional. Now passing uuid_disk and uuid are optional when random UUIDs are enabled. Signed-off-by: Rob Herring <robh@kernel.org> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
2015-03-05Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-03-04powerpc/mpc85xx: Add DSP side awareness for Freescale Heterogeneous SoCsShaveta Leekha
The code provides framework for heterogeneous multicore chips based on StarCore and Power Architecture which are chasis-2 compliant, like B4860 and B4420 It will make u-boot recognize all non-ppc cores and peripherals like SC3900/DSP CPUs, MAPLE, CPRI and print their configuration in u-boot logs. Example boot logs of B4860QDS: U-Boot 2015.01-00232-geef6e36-dirty (Jan 19 2015 - 11:58:45) CPU0: B4860E, Version: 2.2, (0x86880022) Core: e6500, Version: 2.0, (0x80400120) Clock Configuration: CPU0:1600 MHz, CPU1:1600 MHz, CPU2:1600 MHz, CPU3:1600 MHz, DSP CPU0:1200 MHz, DSP CPU1:1200 MHz, DSP CPU2:1200 MHz, DSP CPU3:1200 MHz, DSP CPU4:1200 MHz, DSP CPU5:1200 MHz, CCB:666.667 MHz, DDR:933.333 MHz (1866.667 MT/s data rate) (Asynchronous), IFC:166.667 MHz CPRI:600 MHz MAPLE:600 MHz, MAPLE-ULB:800 MHz, MAPLE-eTVPE:1000 MHz FMAN1: 666.667 MHz QMAN: 333.333 MHz Top level changes include: (1) Top level CONFIG to identify HETEROGENUOUS clusters (2) CONFIGS for SC3900/DSP components (3) Global structures like "cpu_type" and "MPC85xx_SYS_INFO" updated for dsp cores and other components (3) APIs to get DSP num cores and their Mask like: cpu_dsp_mask, cpu_num_dspcores etc same as that of PowerPC (5) Code to fetch and print SC cores and other heterogenous device's frequencies (6) README added for the same Signed-off-by: Shaveta Leekha <shaveta@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-03-02MAINTAINERS, git-mailrc: Update my email addressTom Rini
2015-03-02Merge git://git.denx.de/u-boot-usbTom Rini
2015-03-02imx6: Added DEK blob generator commandRaul Cardenas
Freescale's SEC block has built-in Data Encryption Key(DEK) Blob Protocol which provides a method for protecting a DEK for non-secure memory storage. SEC block protects data in a data structure called a Secret Key Blob, which provides both confidentiality and integrity protection. Every time the blob encapsulation is executed, a AES-256 key is randomly generated to encrypt the DEK. This key is encrypted with the OTP Secret key from SoC. The resulting blob consists of the encrypted AES-256 key, the encrypted DEK, and a 16-bit MAC. During decapsulation, the reverse process is performed to get back the original DEK. A caveat to the blob decapsulation process, is that the DEK is decrypted in secure-memory and can only be read by FSL SEC HW. The DEK is used to decrypt data during encrypted boot. Commands added -------------- dek_blob - encapsulating DEK as a cryptgraphic blob Commands Syntax --------------- dek_blob src dst len Encapsulate and create blob of a len-bits DEK at address src and store the result at address dst. Signed-off-by: Raul Cardenas <Ulises.Cardenas@freescale.com> Signed-off-by: Nitin Garg <nitin.garg@freescale.com> Signed-off-by: Ulises Cardenas <ulises.cardenas@freescale.com> Signed-off-by: Ulises Cardenas-B45798 <Ulises.Cardenas@freescale.com>
2015-03-02Merge branch 'master' of git://git.denx.de/u-bootStefano Babic
2015-03-01usb: UniPhier: add UniPhier on-chip xHCI host driver supportMasahiro Yamada
Support xHCI host driver used on Panasonic UniPhier platform. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Marek Vasut <marex@denx.de>
2015-02-25Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
2015-02-25usb: gadget: fastboot: Add fastboot eraseDileep Katta
Adds the fastboot erase functionality, to erase a partition specified by name. The erase is performed based on erase group size, to avoid erasing other partitions. The start address and the size is aligned to the erase group size for this. Currently only supports erasing from eMMC. Signed-off-by: Dileep Katta <dileep.katta@linaro.org> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2015-02-24ARM: davinci: remove hawkboard supportMasahiro Yamada
This is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Sughosh Ganu <urwithsughosh@gmail.com> Cc: Syed Mohammed Khasim <sm.khasim@gmail.com> Acked-by: Marek Vasut <marex@denx.de>
2015-02-24ARM: remove tnetv107x board supportMasahiro Yamada
This is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Chan-Taek Park <c-park@ti.com> Acked-by: Marek Vasut <marex@denx.de>
2015-02-24ARM: remove a320evb board supportMasahiro Yamada
This is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Po-Yu Chuang <ratbert@faraday-tech.com> Acked-by: Marek Vasut <marex@denx.de>
2015-02-24ARM: remove cm4008 and cm41xx board supportMasahiro Yamada
These are still non-generic boards. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Greg Ungerer <greg.ungerer@opengear.com> Acked-by: Marek Vasut <marex@denx.de>
2015-02-24ARM: remove dkb board supportMasahiro Yamada
This is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Lei Wen <leiwen@marvell.com> Acked-by: Marek Vasut <marex@denx.de>
2015-02-24ARM: remove jadecpu board supportMasahiro Yamada
This is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Matthias Weisser <weisserm@arcor.de> Acked-by: Marek Vasut <marex@denx.de>
2015-02-24kconfig: switch to single .config configurationMasahiro Yamada
When Kconfig for U-boot was examined, one of the biggest issues was how to support multiple images (Normal, SPL, TPL). There were actually two options, "single .config" and "multiple .config". After some discussions and thought experiments, I chose the latter, i.e. to create ".config", "spl/.config", "tpl/.config" for Normal, SPL, TPL, respectively. It is true that the "multiple .config" strategy provided us the maximum flexibility and helped to avoid duplicating CONFIGs among Normal, SPL, TPL, but I have noticed some fatal problems: [1] It is impossible to share CONFIG options across the images. If you change the configuration of Main image, you often have to adjust some SPL configurations correspondingly. Currently, we cannot handle the dependencies between them. It means one of the biggest advantages of Kconfig is lost. [2] It is too painful to change both ".config" and "spl/.config". Sunxi guys started to work around this problem by creating a new configuration target. Commit cbdd9a9737cc (sunxi: kconfig: Add %_felconfig rule to enable FEL build of sunxi platforms.) added "make *_felconfig" to enable CONFIG_SPL_FEL on both images. Changing the configuration of multiple images in one command is a generic demand. The current implementation cannot propose any good solution about this. [3] Kconfig files are getting ugly and difficult to understand. Commit b724bd7d6349 (dm: Kconfig: Move CONFIG_SYS_MALLOC_F_LEN to Kconfig) has sprinkled "if !SPL_BUILD" over the Kconfig files. [4] The build system got more complicated than it should be. To adjust Linux-originated Kconfig to U-Boot, the helper script "scripts/multiconfig.sh" was introduced. Writing a complicated text processor is a shell script sometimes caused problems. Now I believe the "single .config" will serve us better. With it, all the problems above would go away. Instead, we will have to add some CONFIG_SPL_* (and CONFIG_TPL_*) options such as CONFIG_SPL_DM, but we will not have much. Anyway, this is what we do now in scripts/Makefile.spl. I admit my mistake with my apology and this commit switches to the single .config configuration. It is not so difficult to do that: - Remove unnecessary processings from scripts/multiconfig.sh This file will remain for a while to support the current defconfig format. It will be removed after more cleanups are done. - Adjust some makefiles and Kconfigs - Add some entries to include/config_uncmd_spl.h and the new file scripts/Makefile.uncmd_spl. Some CONFIG options that are not supported on SPL must be disabled because one .config is shared between SPL and U-Boot proper going forward. I know this is not a beautiful solution and I think we can do better, but let's see how much we will have to describe them. - update doc/README.kconfig More cleaning up patches will follow this. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-02-24fsl-ch3/lowlevel: TZPC and TZASC programming to configure non-secure accessesBhupesh Sharma
This patch ensures that the TZPC (BP147) and TZASC-400 programming happens for LS2085A SoC only when the desired config flags are enabled and ensures that the TZPC programming is done to allow Non-secure (NS) + secure (S) transactions only for DCGF registers. The TZASC component is not present on LS2085A-Rev1, so the TZASC-400 config flag is turned OFF for now. Signed-off-by: Bhupesh Sharma <bhupesh.sharma@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-02-23mmc: fsl_esdhc: Add support to force VSELECT setOtavio Salvador
Some boards cannot do voltage negotiation but need to set the VSELECT bit forcely to ensure it to work at 1.8V. This commit adds CONFIG_SYS_FSL_ESDHC_FORCE_VSELECT flag for this use. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
