path: root/doc
2015-10-23net: convert altera_tse to driver model and phylibThomas Chou
Convert altera_tse to driver model and phylib. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Marek Vasut <marex@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-10-23nios2: add README.nios2Thomas Chou
Add README.nios2 about how to add nios2 boards to u-boot. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Marek Vasut <marex@denx.de>
2015-10-23nios2: convert altera sysid to driver modelThomas Chou
Convert altera sysid to driver model with misc uclass. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Chin Liang See <clsee@altera.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-10-23nios2: convert altera timer to driver modelThomas Chou
Convert altera timer to driver model. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Chin Liang See <clsee@altera.com>
2015-10-23nios2: convert nios2 cpu to driver modelThomas Chou
Convert nios2 cpu to driver model. The cpu parameters are extracted from device tree and saved to global data structure. We will use them to replace the custom_fpga.h . Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-10-23nios2 : convert altera_pio to driver modelThomas Chou
Convert altera_pio to driver model. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Chin Liang See <clsee@altera.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-10-23spi : convert altera_spi to driver modelThomas Chou
Convert altera_spi to driver model Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-10-23nios2: convert altera_uart to driver modelThomas Chou
Convert altera_uart to driver model. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de>
2015-10-23nios2: convert altera_jtag_uart to driver modelThomas Chou
Convert altera_jtag_uart to driver model. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Marek Vasut <marex@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-10-22drivers: Introduce a simplified remoteproc frameworkNishanth Menon
Many System on Chip(SoC) solutions are complex with multiple processors on the same die dedicated to either general purpose of specialized functions. Many examples do exist in today's SoCs from various vendors. Typical examples are micro controllers such as an ARM M3/M0 doing a offload of specific function such as event integration or power management or controlling camera etc. Traditionally, the responsibility of loading up such a processor with a firmware and communication has been with a High Level Operating System(HLOS) such as Linux. However, there exists classes of products where Linux would need to expect services from such a processor or the delay of Linux and operating system being able to load up such a firmware is unacceptable. To address these needs, we need some minimal capability to load such a system and ensure it is started prior to an Operating System(Linux or any other) is started up. NOTE: This is NOT meant to be a solve-all solution, instead, it tries to address certain class of SoCs and products that need such a solution. A very simple model is introduced here as part of the initial support that supports microcontrollers with internal memory (no MMU, no execution from external memory, or specific image format needs). This basic framework can then (hopefully) be extensible to other complex SoC processor support as need be. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Nishanth Menon <nm@ti.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-10-21x86: Enable mrc cache for bayleybay and minnowmaxBin Meng
Now that we have added MRC cache for Intel FSP and BayTrail codes, enable it for all BayTrail boards (Bayley Bay and Minnow Max). Note it turns out that FSP for Intel Atom E6xx does not produce the HOB for NV storage, so we don't have such functionality on Intel Crown Bay board. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-10-21x86: fsp: Make hob command a sub-command to fspBin Meng
Introduce a new fsp command and make the existing hob command a sub-command to fsp for future extension. Also move cmd_hob.c to the dedicated fsp sub-directory in arch/x86/lib. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-10-21x86: Add SMBIOS table supportBin Meng
System Management BIOS (SMBIOS) is a specification for how motherboard and system vendors present management information about their products in a standard format by extending the BIOS interface on Intel architecture systems. As of today the latest spec is 3.0 and can be downloaded from DMTF website. This commit adds a simple and minimum required implementation. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-10-21doc: Complement document about booting VxWorksBin Meng
Current document about how to boot VxWorks is limited. Add several chapters in README.vxworks to document this. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-10-19doc/README.scrapyard: Add more entriesTom Rini
- Add deletions from August 30 2015. - A few from Sept 12, one from Oct 2nd. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-10-19doc/README.scrapyard: Populate recent removalsTom Rini
Add in the commit IDs / dates for boards removed on Sept 2nd. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-10-15ARM: uniphier: fix address mapping in README.uniphierMasahiro Yamada
2015-10-11Revert "powerpc: ppc4xx: remove lwmon5 support"Stefan Roese
This reverts commit 8fe11b8901a31d11990488c82bc23612589d57be. I'll add support to lwmon5 in the next patch and will remove support for the broken lcd4_lwmon5 as well. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-09-25ARM: uniphier: add ProXstream2 and PH1-LD6b supportMasahiro Yamada
The DDR SDRAM initialization code has not been mainlined yet, but U-Boot proper should work. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-09-25ARM: uniphier: add PH1-Pro5 supportMasahiro Yamada
2015-09-16x86: doc: Add DMI to the TODO listBin Meng
Desktop Management Interface (DMI) is not supported by U-Boot now. Add it to the TODO list. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-09-16x86: doc: Document some porting hints about Intel QuarkBin Meng
Document porting considerations for Intel Quark based board, including MRC parameters and PCIe initialization. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-09-11arm: Remove vision2 boardSimon Glass
This board has not been converted to generic board by the deadline. Remove it. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Stefano Babic <sbabic@denx.de>
2015-09-11arm: Remove omap3_mvblx boardSimon Glass
2015-09-11arm: Remove enbw_cmc boardSimon Glass
2015-09-11git-mailrc: add Alexey as ARC maintainerMasahiro Yamada
It's easier to Cc him on ARC-releated patches. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-09-09x86: doc: Change to use CONFIG_VGA_BIOS_ADDRBin Meng
CONFIG_X86_OPTION_ROM_ADDR has been renamed to CONFIG_VGA_BIOS_ADDR. Update the doc to refer to the new name. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2015-09-07doc: dfu: tftp: README entry for TFTP extension of DFULukasz Majewski
Documentation file for DFU extension. With this functionality it is now possible to transfer FIT images with firmware updates via TFTP and use DFU backend for storing them. Signed-off-by: Lukasz Majewski <l.majewski@majess.pl> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-09-03doc: document the fdtdir PXE commandStefan Brüns
Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de>
2015-09-03doc: Fix inconsistent filename in PXE config exampleStefan Brüns
The default config includes base.menu, not linux.list Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de>
2015-09-03Merge git://git.denx.de/u-boot-rockchipTom Rini
2015-09-02rockchip: Put README image creation commands on one lineSimon Glass
It is easier to paste these into the command line if they are a single common. Use line continuation instead of separate lines. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-02rockchip: Update todo in README.rockchipSjoerd Simons
MMC support works now, so it can be dropped from the todo Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-02rockchip: Drop first 32kb of zeros from the rkSD image typeSjoerd Simons
Instead of creating a rockchip SPL SD card image with 32KB of zeros which can be written to the start of an SD card, create the images with only the useful data that should be written to an offset of 32KB on the SD card. The first 32 kilobytes aren't needed for bootup and only serve as convenient way of accidentally obliterating your partition table. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-02doc: Fix reference to Rock pro when Rock 2 is meantSjoerd Simons
The Radxa Rock pro board is rk3188 based and thus won't work with U-Boot built for RK3288. Change the documentation to refer to the intended board, the Radxa Rock 2, which is an RK3288-based design very similar to the firefly Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-02rockchip: Add a simple READMESimon Glass
Add a few notes on how to try out the Rockchip support so far. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-02rockchip: Bring in RK3288 device tree file includes and bindingsSimon Glass
Bring in required device tree files from Linux. Since mainline Linux is somewhat behind, use the files from the Chromium tree. We can re-sync once further code is acccepted upstream. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-02powerpc: mpc85xx: remove stxgp3, stxssa supportMasahiro Yamada
These have not been converted to Generic Board, so should be removed. (See doc/README.generic-board for details.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Dan Malek <dan@embeddedalley.com>
2015-09-02powerpc: mpc5xx: remove cmi_mpc5xx supportMasahiro Yamada
This has not been converted to Generic Board, so should be removed. (See doc/README.generic-board for details.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-09-02powerpc: ppc4xx: remove zeus supportMasahiro Yamada
This has not been converted to Generic Board, so should be removed. (See doc/README.generic-board for details.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Stefan Roese <sr@denx.de>
2015-09-02powerpc: ppc4xx: remove sbc405 supportMasahiro Yamada
2015-09-02powerpc: ppc4xx: remove pcs440ep supportMasahiro Yamada
2015-09-02powerpc: ppc4xx: remove p3p440 supportMasahiro Yamada
2015-09-02powerpc: ppc4xx: remove lwmon5 supportMasahiro Yamada
This has not been converted to Generic Board, so should be removed. (See doc/README.generic-board for details.) Remove CONFIG_LWMON5 references. (Also, remove undefined CONFIG_WD_MAX_RATE while I am here.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Stefan Roese <sr@denx.de>
2015-09-02powerpc: ppc4xx: remove csb272, csb472 supportMasahiro Yamada
These have not been converted to Generic Board, so should be removed. (See doc/README.generic-board for details.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Tolunay Orkun <torkun@nextio.com>
2015-09-02powerpc: ppc4xx: remove alpr supportMasahiro Yamada
2015-09-02imx: fec: add MAC reading from eFuses to READMEOlaf Mandel
Extend the documentation of the fec_mxc configuration by describing its ability to read the ethaddr MAC address from the SoC eFuses. Also add an example how to program the fuses for an imx5 to clarify the byte order. Cc: Stefano Babic <sbabic at denx.de> Cc: Marek Vasut <marex at denx.de> Signed-off-by: Olaf Mandel <o.mandel at menlosystems.com>
2015-08-31ARM: uniphier: enable SPL_OF_CONTROLMasahiro Yamada
Device Tree really improves code maintainability and is now available for SPL too. This is the state-of-the-art implementation in U-boot. The board files (platform data) are no longer needed. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-08-28NDS32: Generic Board Support and UnsupportKun-Hua Huang
Remove ag101 and ag102 support Signed-off-by: Kun-Hua Huang <kunhua@andestech.com>
Add nds32 ag101p generic board support. Signed-off-by: Kun-Hua Huang <kunhua@andestech.com>
