path: root/doc
2015-11-23part:efi: add bootable parameter in gpt commandPatrick Delaunay
The optional parameter bootable is added in gpt command to set the partition attribute flag "Legacy BIOS bootable" This flag is used in extlinux and so in with distro to select the boot partition where is located the configuration file (please check out doc/README.distro for details). With this parameter, U-Boot can be used to create the boot partition needed for device using distro. example of use: setenv partitions "name=u-boot,size=60MiB;name=boot,size=60Mib,bootable;\ name=rootfs,size=0" > gpt write mmc 0 $partitions > part list mmc 0 Partition Map for MMC device 0 -- Partition Type: EFI Part Start LBA End LBA Name Attributes Type GUID Partition GUID 1 0x00000022 0x0001e021 "u-boot" attrs: 0x0000000000000000 type: ebd0a0a2-b9e5-4433-87c0-68b6b72699c7 guid: cceb0b18-39cb-d547-9db7-03b405fa77d4 2 0x0001e022 0x0003c021 "boot" attrs: 0x0000000000000004 type: ebd0a0a2-b9e5-4433-87c0-68b6b72699c7 guid: d4981a2b-0478-544e-9607-7fd3c651068d 3 0x0003c022 0x003a9fde "rootfs" attrs: 0x0000000000000000 type: ebd0a0a2-b9e5-4433-87c0-68b6b72699c7 guid: 6d6c9a36-e919-264d-a9ee-bd00379686c7 > part list mmc 0 -bootable devplist > printenv devplist devplist=2 Then the distro scripts will search extlinux in partition 2 and not in the first partition. Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
2015-11-23gpt: doc: README: Update README entry for gpt verify extensionLukasz Majewski
./doc/README.gpt entry has been updated to explain usage of "gpt verify" command. Signed-off-by: Lukasz Majewski <l.majewski@majess.pl> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-11-20dm: Add timeline and guide for porting serial driversSimon Glass
Add a README with a brief guide to porting serial drivers over to use driver model. Add a timeline also. All serial drivers should be converted by the end of January 2016. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-11-19x86: Add an i8042 device for boards that have itSimon Glass
Some boards have an i8042 device. Enable the driver for all x86 boards, and add a device tree node for those which may have this keyboard. Also adjust the configuration so that i8042 is always separate from the VGA, and rename the stdin driver accordingly. With this commit the keyboard will not work, but it is fixed in the next commit. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-11-19sandbox: add a sandbox timer and basic testThomas Chou
Add a sandbox timer which get time from host os and a basic test. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-11-18git-mailrc: Add Bin as a maintainer of x86Bin Meng
This updates git-mailrc to add me as a maintainer of x86. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-16Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-11-16splash_source: add support for filesystem formatted mmcNikita Kiryanov
Add support for loading splash image from an SD card formatted with a filesystem. Update boards to maintain original behavior where needed. Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Tom Rini <trini@konsulko.com> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2015-11-13sparc: Update the maintainer for SPARC architectureFrancois Retief
Signed-off-by: Francois Retief <fgretief@spaceteq.co.za>
2015-11-12uuid: add selection by string for known partition type GUIDPatrick Delaunay
short strings can be used in type parameter of gpt command to replace the guid string for the types known by u-boot partitions = name=boot,size=0x6bc00,type=data; \ name=root,size=0x7538ba00,type=linux; gpt write mmc 0 $partitions and they are also used to display the type of partition in "part list" command Partition Map for MMC device 0 -- Partition Type: EFI Part Start LBA End LBA Name Attributes Type GUID Partition GUID 1 0x00000022 0x0000037f "boot" attrs: 0x0000000000000000 type: ebd0a0a2-b9e5-4433-87c0-68b6b72699c7 type: data guid: d117f98e-6f2c-d04b-a5b2-331a19f91cb2 2 0x00000380 0x003a9fdc "root" attrs: 0x0000000000000000 type: 0fc63daf-8483-4772-8e79-3d69d8477de4 type: linux guid: 25718777-d0ad-7443-9e60-02cb591c9737 Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
2015-11-12gpt: add optional parameter type in gpt commandPatrick Delaunay
code under flag CONFIG_PARTITION_TYPE_GUID add parameter "type" to select partition type guid example of use with gpt command : partitions = uuid_disk=${uuid_gpt_disk}; \ name=boot,size=0x6bc00,uuid=${uuid_gpt_boot}; \ name=root,size=0x7538ba00,uuid=${uuid_gpt_root}, \ type=0fc63daf-8483-4772-8e79-3d69d8477de4; gpt write mmc 0 $partitions Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
2015-11-12part:efi: add GUID for linux file system dataPatrick Delaunay
Previously, Linux used the same GUID for the data partitions as Windows (Basic data partition: EBD0A0A2-B9E5-4433-87C0-68B6B72699C7). This created problems when dual-booting Linux and Windows in UEFI-GPT Setup, so a new GUID (Linux filesystem data: 0FC63DAF-8483-4772-8E79-3D69D8477DE4) was defined jointly by GPT fdisk and GNU Parted developers. Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
2015-11-12nios2: change README.nios2 to use 10m50 as templateThomas Chou
The 10m50 devboard becomes the new golden reference design of Nios II Linux. So change README.nios2 to use 10m50 as template. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Marek Vasut <marex@denx.de>
2015-11-12mtd: add altera quadspi driverThomas Chou
Add Altera Generic Quad SPI Controller support. The controller converts SPI NOR flash to parallel flash interface. So it is not like other SPI flash, but rather like CFI flash. Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2015-11-12cfi_flash: convert to driver modelThomas Chou
Convert cfi flash to driver model. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-11-10Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2015-11-10Various Makefiles: Add SPDX-License-Identifier tagsTom Rini
After consulting with some of the SPDX team, the conclusion is that Makefiles are worth adding SPDX-License-Identifier tags too, and most of ours have one. This adds tags to ones that lack them and converts a few that had full (or in one case, very partial) license blobs into the equivalent tag. Cc: Kate Stewart <kstewart@linuxfoundation.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2015-11-10Revive OpenRD targetsAlbert ARIBAUD
Revert commit 7a2c1b13 which dropped OpenRD boards. Assume maintainership of OpenRD. Remove OpenRD from scrapyard. Switch OpenRD to generic board. Switch to Thumb build. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2015-11-02dm: adc: add simple ADC uclass implementationPrzemyslaw Marczak
This commit adds: - new uclass id: UCLASS_ADC - new uclass driver: drivers/adc/adc-uclass.c The new uclass's API allows for ADC operation on: * single-channel with channel selection by a number * multti-channel with channel selection by bit mask ADC uclass's functions: * single-channel: - adc_start_channel() - start channel conversion - adc_channel_data() - get conversion data - adc_channel_single_shot() - start/get conversion data * multi-channel: - adc_start_channels() - start selected channels conversion - adc_channels_data() - get conversion data - adc_channels_single_shot() - start/get conversion data for channels selected by bit mask * general: - adc_stop() - stop the conversion - adc_vdd_value() - positive reference Voltage value with polarity [uV] - adc_vss_value() - negative reference Voltage value with polarity [uV] - adc_data_mask() - conversion data bit mask The device tree can provide below constraints/properties: - vdd-polarity-negative: if true: Vdd = vdd-microvolts * (-1) - vss-polarity-negative: if true: Vss = vss-microvolts * (-1) - vdd-supply: phandle to Vdd regulator's node - vss-supply: phandle to Vss regulator's node And optional, checked only if the above corresponding, doesn't exist: - vdd-microvolts: positive reference Voltage [uV] - vss-microvolts: negative reference Voltage [uV] Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-11-02dm: pmic: add s2mps11 PMIC I/O driverPrzemyslaw Marczak
This driver allows I/O operations on the Samsung S2MPS11 PMIC, which provides lots of LDO/BUCK outputs. To enable it, update defconfig with: - CONFIG_PMIC_S2MPS11 and additional, if were not defined: - CONFIG_CMD_PMIC - CONFIG_ERRNO_STR The binding info: doc/device-tree-bindings/pmic/s2mps11.txt Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Anand Moon <linux.amoon@gmail.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-11-02s5p: cpu_info: print "cpu-model" if exists in dtsPrzemyslaw Marczak
The CPU name for Exynos was concatenated with cpu id, but for new Exynos platforms, like Chromebook Peach Pi based on Exynos5800, the name of SoC variant does not include the real SoC cpu id (0x5422). For such case, the CPU name should be defined in device tree. This commit introduces new device-tree property for Exynos: - "cpu-model" - with cpu name string If defined, then the cpu id is not printed. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Anand Moon <linux.amoon@gmail.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-10-30Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
2015-10-30README.scrapyard: Populate recent ppc4xx removalsTom Rini
2015-10-29armv8/ls1043a: Add Fman supportShaohui Xie
Signed-off-by: Hou Zhiqiang <B48286@freescale.com> Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Mingkai Hu <Mingkai.Hu@freescale.com> Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-10-29common/board_f.c: change the macro name and remove it for PPC platformsGong Qianyu
For most PPC platforms, they will call the first get_clocks() in init_sequence_f[] as they define CONFIG_PPC. CONFIG_SYS_FSL_CLK is then defined to call the second get_clocks(), which should be redundant for PPC. Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-10-28Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
2015-10-27Merge git://www.denx.de/git/u-boot-ppc4xxTom Rini
2015-10-27Merge git://git.denx.de/u-boot-dmTom Rini
2015-10-27ocotea: DropTom Rini
This board has not compiled for me for quite some time due to size constraints, remove. Cc: Stefan Roese <sr@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2015-10-27taishan: DropTom Rini
2015-10-27ebony: DropTom Rini
2015-10-27taihu: RemoveTom Rini
This board has not compiled for me for quite some time due to size constraints, remove. Cc: John Otken <jotken@softadvances.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2015-10-25doc: device-tree-bindings: spi: Add zynq qspi infoJagan Teki
Added device-tree-binding information for zynq qspi controller driver. Signed-off-by: Jagan Teki <jteki@openedev.com> Cc: Simon Glass <sjg@chromium.org> Cc: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Acked-by: Michal Simek <michal.simek@xilinx.com> Tested-by: Jagan Teki <jteki@openedev.com>
2015-10-23env: export fdt_blob to the environment variableThomas Chou
Export fdt_blob to the environment variable. So that we may use it to boot Linux. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Simon Glass <sjg@chromium.org>
2015-10-23dm: Rename dev_get_parentdata() to dev_get_parent_priv()Simon Glass
The current name is inconsistent with other driver model data access functions. Rename it and fix up all users. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2015-10-23net: convert altera_tse to driver model and phylibThomas Chou
Convert altera_tse to driver model and phylib. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Marek Vasut <marex@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-10-23nios2: add README.nios2Thomas Chou
Add README.nios2 about how to add nios2 boards to u-boot. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Marek Vasut <marex@denx.de>
2015-10-23nios2: convert altera sysid to driver modelThomas Chou
Convert altera sysid to driver model with misc uclass. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Chin Liang See <clsee@altera.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-10-23nios2: convert altera timer to driver modelThomas Chou
Convert altera timer to driver model. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Chin Liang See <clsee@altera.com>
2015-10-23nios2: convert nios2 cpu to driver modelThomas Chou
Convert nios2 cpu to driver model. The cpu parameters are extracted from device tree and saved to global data structure. We will use them to replace the custom_fpga.h . Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-10-23nios2 : convert altera_pio to driver modelThomas Chou
Convert altera_pio to driver model. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Chin Liang See <clsee@altera.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-10-23spi : convert altera_spi to driver modelThomas Chou
Convert altera_spi to driver model Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-10-23nios2: convert altera_uart to driver modelThomas Chou
Convert altera_uart to driver model. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de>
2015-10-23nios2: convert altera_jtag_uart to driver modelThomas Chou
Convert altera_jtag_uart to driver model. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Marek Vasut <marex@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-10-22drivers: Introduce a simplified remoteproc frameworkNishanth Menon
Many System on Chip(SoC) solutions are complex with multiple processors on the same die dedicated to either general purpose of specialized functions. Many examples do exist in today's SoCs from various vendors. Typical examples are micro controllers such as an ARM M3/M0 doing a offload of specific function such as event integration or power management or controlling camera etc. Traditionally, the responsibility of loading up such a processor with a firmware and communication has been with a High Level Operating System(HLOS) such as Linux. However, there exists classes of products where Linux would need to expect services from such a processor or the delay of Linux and operating system being able to load up such a firmware is unacceptable. To address these needs, we need some minimal capability to load such a system and ensure it is started prior to an Operating System(Linux or any other) is started up. NOTE: This is NOT meant to be a solve-all solution, instead, it tries to address certain class of SoCs and products that need such a solution. A very simple model is introduced here as part of the initial support that supports microcontrollers with internal memory (no MMU, no execution from external memory, or specific image format needs). This basic framework can then (hopefully) be extensible to other complex SoC processor support as need be. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Nishanth Menon <nm@ti.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-10-21x86: Enable mrc cache for bayleybay and minnowmaxBin Meng
Now that we have added MRC cache for Intel FSP and BayTrail codes, enable it for all BayTrail boards (Bayley Bay and Minnow Max). Note it turns out that FSP for Intel Atom E6xx does not produce the HOB for NV storage, so we don't have such functionality on Intel Crown Bay board. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-10-21x86: fsp: Make hob command a sub-command to fspBin Meng
Introduce a new fsp command and make the existing hob command a sub-command to fsp for future extension. Also move cmd_hob.c to the dedicated fsp sub-directory in arch/x86/lib. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-10-21x86: Add SMBIOS table supportBin Meng
System Management BIOS (SMBIOS) is a specification for how motherboard and system vendors present management information about their products in a standard format by extending the BIOS interface on Intel architecture systems. As of today the latest spec is 3.0 and can be downloaded from DMTF website. This commit adds a simple and minimum required implementation. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-10-21doc: Complement document about booting VxWorksBin Meng
Current document about how to boot VxWorks is limited. Add several chapters in README.vxworks to document this. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-10-19doc/README.scrapyard: Add more entriesTom Rini
- Add deletions from August 30 2015. - A few from Sept 12, one from Oct 2nd. Signed-off-by: Tom Rini <trini@konsulko.com>
