Introduce 'mx28evk_nand' target for saving environment variables into NAND.
The mx28evk board does not come with a NAND flash populated from the
factory. It comes with an empty slot (U23), which allows the insertion of a
48-pin TSOP flash device.
Tested with a K9LBG08U0D.
Reviewed-by: Otavio Salvador <otavio@ossystems.com.br>
Add DT node and bindings documentaion for DP.
Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com>
Add DT node and bindings documentation for FIMD.
Albert's rework of the linker scripts conflicted with Simon's making
everyone use __bss_end. We also had a minor conflict over
README.scrapyard being added to in mainline and enhanced in
u-boot-arm/master with proper formatting.
arch/arm/cpu/ixp/u-boot.lds
arch/arm/cpu/u-boot.lds
arch/arm/lib/Makefile
board/actux1/u-boot.lds
board/actux2/u-boot.lds
board/actux3/u-boot.lds
board/dvlhost/u-boot.lds
board/freescale/mx31ads/u-boot.lds
doc/README.scrapyard
include/configs/tegra-common.h
Build tested for all of ARM and run-time tested on am335x_evm.
Refactor linker-generated array code so that symbols
which were previously linker-generated are now compiler-
generated. This causes relocation records of type
R_ARM_ABS32 to become R_ARM_RELATIVE, which makes
code which uses LGA able to run before relocation as
well as after.
Note: this affects more than ARM targets, as linker-
lists span possibly all target architectures, notably
PowerPC.
arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds
arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds
arch/arm/cpu/armv7/omap-common/u-boot-spl.lds
board/ait/cam_enc_4xx/u-boot-spl.lds
board/davinci/da8xxevm/u-boot-spl-da850evm.lds
board/davinci/da8xxevm/u-boot-spl-hawk.lds
board/vpac270/u-boot-spl.lds
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
This adds a member to TMU FDT node for providing hardware
tripping temperature threshold.
Signed-off-by: Akshay Saraswat <akshay.s@samsung.com>
Fdt entry for Exynos TMU driver specific pre-defined values used for
calibration of current temperature and defining threshold values.
That's a bit presumptuous of you, u-boot!
These boards seem to be unmaintained for quite some time. So lets
remove support for them completely. This also cleans up some
common drivers/files.
Cc: Guillaume Alexandre <guillaume.alexandre@gespac.ch>
Acked-by: Wolfgang Denk <wd@denx.de>
The "mtest" command is of little practical use (if any), and
experience has shown that a large number of board configurations
define useless or even dangerous start and end addresses. If not even
the board maintainers are able to figure out which memory range can be
reliably tested, how can we expect such from the end users? As this
problem comes up repeatedly, we rather do not enable this command by
default, so only people who know what they are doing will be
confronted with it.
As this changes the user interface, we allow for a grace period
before this change takes effect. For now, we make "mtest"
configurable through the CONFIG_CMD_MEMTEST variable, which is defined
in include/config_cmd_default.h; we also add an entry to
doc/feature-removal-schedule.txt which announces the removal of this
default setting in two releases from now, i. e. with v2013.07.
Cc: Tom Rini <trini@ti.com>
In master we had already taken a patch to fix the davinci GPIO code for
CONFIG_SOC_DM646X and in u-boot-ti we have additional patches to support
DA830 (which is CONFIG_SOC_DA8XX && !CONFIG_SOC_DA850). Resolve these
conflicts manually and comment the #else/#endif lines for clarity.
arch/arm/include/asm/arch-davinci/gpio.h
drivers/gpio/da8xx_gpio.c
On some architectures certain values of splashimage will lead to
a data abort exception.
Document the problem, and implement a callback for splashimage to
reject such values.
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
Signed-off-by: Sonic Zhang <sonic.adi@gmail.com>
Simple howto to add support to a board
for booting the kernel from SPL ("Falcon" mode).
Reviewed-by: Tom Rini <trini@ti.com>
Commit 8b710b1 started removing code for the unmaintained "ns9750dev"
board; the board support is still broken, and not included anywhere in
the Makefile or boards.cfg. Remove the remaining dead code.
Now that the patches have made it into mainline, we can also add the
commit IDs.
Added README file with the description of required options and host
configuration to use network SPL with am335x targets. Briefly discuss
how to use this configuration to program empty boards.
Signed-off-by: Ilya Yanok <ilya.yanok@cogentembedded.com>
Documentation fix to README.fsl-ddr to fix typos and
to reflect use of 'd' hotkey to enter the FSL DDR debugger.
Signed-off-by: James Yang <James.Yang@freescale.com>
Signed-off-by: Andy Fleming <afleming@freescale.com>
Add copy command which allows copying of DIMM/controller settings.
This saves tedious retyping of parameters for each identical DIMM
or controller.
Using environmental variable "ddr_interactive" to activate interactive DDR
debugging seomtiems is not enough. For example, after updating SPD with a
valid but wrong image, u-boot won't come up due to wrong DDR configuration.
By enabling key press method, we can enter debug mode to have a chance to
boot without using other tools to recover the board.
CONFIG_FSL_DDR_INTERACTIVE needs to be defined in header file. To enter the
debug mode by key press, press key 'd' shortly after reset, like one would
do to abort auto booting. It is fixed to lower case 'd' at this moment.
Signed-off-by: York Sun <yorksun@freescale.com>
B4860QDS is a high-performance computing evaluation, development and
test platform supporting the B4860 QorIQ Power Architecture processor.
B4860QDS Overview
- DDRC1: Ten separate DDR3 parts of 16-bit to support 72-bit (ECC) at 1866MT/s,
ECC, 4 GB of memory in two ranks of 2 GB.
- DDRC2: Five separate DDR3 parts of 16-bit to support 72-bit (ECC) at 1866MT/s, ECC, 2 GB of memory. Single rank.
- SerDes 1 multiplexing: Two Vitesse (transmit and receive path) cross-point
16x16 switch VSC3316
- SerDes 2 multiplexing: Two Vitesse (transmit and receive path) cross-point
8x8 switch VSC3308
- USB 2.0 ULPI PHY USB3315 by SMSC supports USB port in host mode.
- B4860 UART port is available over USB-to-UART translator USB2SER or over
RS232 flat cable.
- A Vitesse dual SGMII phy VSC8662 links the B4860 SGMII lines to 2xRJ-45 copper
connectors for Stand-alone mode and to the 1000Base-X over AMC MicroTCA
connector ports 0 and 2 for AMC mode.
- The B4860 configuration may be loaded from nine bits coded reset
configuration reset source. The RCW source is set by appropriate
DIP-switches:
- 16-bit NOR Flash / PROMJet
- QIXIS 8-bit NOR Flash Emulator
- 8-bit NAND Flash
- 24-bit SPI Flash
- Long address I2C EEPROM
- Available debug interfaces are:
- On-board eCWTAP controller with ETH and USB I/F
- JTAG/COP 16-pin header for any external TAP controller
- External JTAG source over AMC to support B2B configuration
- 70-pin Aurora debug connector
- QIXIS (FPGA) logic:
- 2 KB internal memory space including
- IDT840NT4 clock synthesizer provides B4860 essential clocks : SYSCLK,
DDRCLK1, 2 and RTCCLK.
- Two 8T49N222A SerDes ref clock devices support two SerDes port clocks
- total four refclk, including CPRI clock scheme
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
Signed-off-by: Shaveta Leekha <shaveta@freescale.com>
Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com>
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
Signed-off-by: Sandeep Singh <Sandeep@freescale.com>
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Use a common watchdog driver for all these cpus.
Add SPI device node data for exynos.
Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com>
Add sound device node data for exynos
The R0P7752C00000RZ board has SH7752, 512MB DDR3-SDRAM, SPI ROM,
Gigabit Ethernet, and eMMC.
This patch supports the following functions:
- 512MB DDR3-SDRAM, SCIF4, SPI ROM, Gigabit Ethernet, eMMC
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
README
arch/arm/cpu/armv7/exynos/clock.c
board/samsung/universal_c210/universal.c
drivers/misc/Makefile
drivers/power/power_fsl.c
include/configs/mx35pdk.h
include/configs/mx53loco.h
include/configs/seaboard.h
Signed-off-by: Richard Genoud <richard.genoud@gmail.com>
The silent variable now updates the global data flag anytime it is
changed as well as after the env relocation (in case its value is
different from the default env in such cases as NAND env)
Documentation of the GPT format.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Change e-mail address of Luka Perkov.
Signed-off-by: Luka Perkov <luka@openwrt.org>
CC: Luka Perkov <uboot@lukaperkov.net>
This adds a docbook template for fs, and makes CBFS use it.
This patch adds a NAND Flash torture feature, which is useful as a block stress
test to determine if a block is still good and reliable (or should be marked as
bad), e.g. after a write error.
This code is ported from mtd-utils' lib/libmtd.c.
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Cc: Scott Wood <scottwood@freescale.com>
[scottwood@freescale.com: removed unnec. ifdef and unwrapped error strings]
Update CONFIG_RAMBOOT and CONFIG_NAND_SPL references to accept CONFIG_SPL
and CONFIG_SPL_BUILD, respectively. CONFIG_NAND_SPL can be removed once
the last mpc85xx nand_spl target is gone.
CONFIG_RAMBOOT will need to remain for other use cases, but it doesn't
seem right to overload it for meaning SPL as well as nand_spl does. Even
if it's somewhat appropriate for the main u-boot, the SPL itself isn't
(necessarily) ramboot, and we don't have separate configs for SPL and
main u-boot. It was also inconsistent, as other platforms such as
mpc83xx didn't use CONFIG_RAMBOOT in this way.
Cc: Andy Fleming <afleming@freescale.com>
Add LCD definitions and also a proposed binding for LCD displays.
The PWM is as per what will likely be committed to linux-next soon.
The displaymode binding comes from a proposal here:
http://lists.freedesktop.org/archives/dri-devel/2012-July/024875.html
The panel binding is new, and fills a need to specify the panel
timings and other tegra-specific information. Should a binding appear
that allows the pwm to handle this automatically, we can revisit
this.
Signed-off-by: Tom Warren <twarren@nvidia.com>
This binding will apparently soon be in linux-next. Bring it in now
since we need to do something, and may as well try to target what
Linux will have.
The mx5 lowlevel_init.S contains board-specific code based on the reference
design. Let's keep it since it avoids creating new lowlevel_init files and it
may be used by many boards. But add a config to make it optional in order not to
cause issues on boards not following this part of the reference design.
Cc: Matt Sealey <matt@genesi-usa.com>
