path: root/doc
2008-01-16mpc83xx: Add the support for MPC8315ERDB boardDave Liu
The features list: - Boot from NOR Flash - DDR2 266MHz hardcoded configuration - Local bus NOR Flash R/W operation - I2C, UART, MII and RTC - eTSEC0/1 support - PCI host Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-09mpc85xx: Add support for ATUM8548 (updated)robert lazarski
Add support for Instituto Atlantico's ATUM8548 board Signed-off-by: robert lazarski <robertlazarski@gmail.com>
2008-01-09mpc85xx: Add support for SBC8548 (updated)Joe Hamman
Add support for Wind River's SBC8548 reference board. Signed-off by: Joe Hamman <joe.hamman@embeddedspecialties.com>
2008-01-09fix various commentsMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
2008-01-09fix comments with new drivers organizationMarcel Ziswiler
2008-01-08mpc83xx: Add the MPC837xEMDS board readmeDave Liu
Add the README.mpc837xemds to /doc Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-01-03Merge commit 'wd/master'Jon Loeliger
2007-12-27Fix coding style issues; update CHANGELOG.Wolfgang Denk
2007-11-29sh: Add document for SuperH.Nobuhiro Iwamatsu
This document is a summary of information concerning SuperH of U-Boot. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2007-11-29sh: Add marubun's pcmcia driverNobuhiro Iwamatsu
Marubun pcmcia is a chip for PCMCIA used with SuperH. Of course, this can be used even by other architectures. When use this driver, came to be able to use CompactFlash and Ethernet. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2007-10-17Initial mpc8610hpcd cpu/, README and include/ files.Jon Loeliger
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Signed-off-by: Mahesh Jade <mahesh.jade@freescale.com> Signed-off-by: Jason Jin <Jason.jin@freescale.com> Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-08-18ColdFire: Fix some remaining problems with CFG_CMD_Stefan Roese
2007-08-18Coding style cleanupStefan Roese
2007-08-16ColdFire: Add M54455EVB for MCF5445xTsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
2007-08-16ColdFire: Add M5253EVBE platform for MCF52x2TsiChungLiew
2007-08-14Merge with git://www.denx.de/git/u-boot.gitStefan Roese
2007-08-14Merge with /home/stefan/git/u-boot/zeusStefan Roese
2007-08-14ppc4xx: Add initial Zeus (PPC405EP) board supportStefan Roese
2007-08-14Coding style cleanup, update CHANGELOGWolfgang Denk
2007-08-14Add MPC8544DS READMEAndy Fleming
Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-08-13Merge with /home/wd/git/u-boot/custodian/u-boot-mpc86xxWolfgang Denk
2007-08-13Minor coding style cleanup. Update CHANGELOG.Wolfgang Denk
2007-08-10Add support for SBC8641D. Config files.Joe Hamman
Add support for Wind River's SBC8641D reference board. Signed-off by: Joe Hamman <joe.hamman@embeddedspecialties.com> Acked-by: Wolfgang Denk <wd@denx.de> Acked-by: Jon Loeliger <jdl@freescale.com>
2007-08-10mpc83xx: Correct the README for DDR ECCDave Liu
Update the README for DDR ECC, change the name to README.mpc83xx.ddrecc. Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-10mpc83xx: add support for the MPC8323E RDBKim Phillips
MPC8323E based board with 64MB fixed SDRAM, 16MB flash, five 10/100 ethernet ports connected via an ICPlus IP175C switch, one PCI slot, and serial. Features not supported in this patch are SD card interface, 2 USB ports, and the two phone ports. Signed-off-by: Michael Barkowski <michael.barkowski@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-10mpc83xx: Revise the MPC8360EMDS readme docDave Liu
When the rev2.x silicon mount on the MPC8360EMDS baord, and if you are using the u-boot version after the commit 3fc0bd159103b536e1c54c6f4457a09b3aba66ca. to make the ethernet interface usable, we have to setup the jumpers correctly. Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-07Merge with git://www.denx.de/git/u-boot.gitMarkus Klotzbuecher
2007-08-06ppc4xx: Update AMCC Bamboo README doc/README.bambooStefan Roese
As suggested by Eugene O'Brien <Eugene.O'Brien@advantechamt.com>, here an updated Bamboo README. Signed-off-by: Stefan Roese <sr@denx.de>
2007-08-06Merge with /home/wd/git/u-boot/custodian/u-boot-testingWolfgang Denk
2007-07-12Update CHANGELOG, minor coding style cleanup.Wolfgang Denk
2007-07-11[PCS440EP] - Show on the DIAG LEDs, if the SHA1 check failedHeiko Schocher
- now the Flash ST M29W040B is supported (not tested) - fix the "led" command - fix compile error, if BUILD_DIR is used Signed-off-by: Heiko Schocher <hs@denx.de>
2007-07-10disk/ doc/ lib_*/ and tools/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09Update README.* to reference new CONFIG_CMD_* names now.Jon Loeliger
2007-07-08Remove references to the old cmd_confdefs.h include file.Jon Loeliger
2007-06-25ppc4xx: Add pci_pre_init() for 405 boardsStefan Roese
This patch removes the CFG_PCI_PRE_INIT option completely, since it's not needed anymore with the patch from Matthias Fuchs with the "weak" pci_pre_init() implementation. Signed-off-by: Stefan Roese <sr@denx.de>
2007-06-06Merge with /home/wd/git/u-boot/custodian/u-boot-mpc86xxWolfgang Denk
2007-06-06USB/OHCI: endianness cleanup in the generic ohci driverMarkus Klotzbuecher
2007-06-05Merge branch 'mpc8641'Jon Loeliger
2007-06-05mpc8641 image size cleanupEd Swarthout
e600 does not have a bootpg restriction. Move the version string to beginning of image at fff00000. Resetvec.S is not needed. Update flash copy instructions. Add tftpflash env variable Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-05-29Merge git://www.denx.de/git/u-boot into 2007_05_15-testingMarkus Klotzbuecher
2007-05-16Merge with /home/wd/git/u-boot/custodian/u-boot-mpc83xxWolfgang Denk
2007-05-07Get rid of duplicated file (see doc/README.SBC8560 instead)Wolfgang Denk
2007-05-07Merge with git://www.denx.de/git/u-boot.gitMarkus Klotzbuecher
2007-04-23mpc83xx: Add MPC8313ERDB support.Scott Wood
2007-04-23Merge with git://www.denx.de/git/u-boot.gitMarkus Klotzbuecher
2007-04-23Remove BOARDLIBS usage completelyStefan Roese
2007-04-18Merge with /home/wd/git/u-boot/custodian/u-boot-mpc86xxWolfgang Denk
2007-04-18Merge with /home/wd/git/u-boot/custodian/u-boot-netWolfgang Denk
2007-04-18Merge with /home/wd/git/u-boot/custodian/u-boot-74xx-7xxWolfgang Denk
2007-04-18[PATCH] icecube/lite5200b: document wakeup from low-power supportDomen Puncer
Signed-off-by: Domen Puncer <domen.puncer@telargo.com>
