path: root/doc
2014-06-08Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-06-06am335x: update README for BCH16pekon gupta
updates documentation with explanation on how to select ECC schemes. Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-06-06mtd: nand: omap: add CONFIG_SYS_NAND_BUSWIDTH_16BIT to indicate NAND device ↵pekon gupta
bus-width GPMC controller needs to be configured based on bus-width of the NAND device connected to it. Also, dynamic detection of NAND bus-width from on-chip ONFI parameters is not possible in following situations: SPL: SPL NAND drivers does not support ONFI parameter reading. U-boot: GPMC controller iniitalization is done in omap_gpmc.c:board_nand_init() which is called before probing for devices, hence any ONFI parameter information is not available during GPMC initialization. Thus, OMAP NAND driver expected board developers to explicitely write GPMC configurations specific to NAND device attached on board in board files itself. But this was troublesome for board manufacturers as they need to dive into lengthy platform & SoC documents to find details of GPMC registers and appropriate configurations to get NAND device working. This patch instead adds existing CONFIG_SYS_NAND_BUSWIDTH_16BIT to board config hich indicates that connected NAND device has x16 bus-width. And then based on this config GPMC driver itself initializes itself based on NAND bus-width. This keeps board developers free from knowing GPMC controller specific internals. Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-06-05nand_spl: remove simpc8313 supportMasahiro Yamada
Commit 3d5a335c announced that all the nand_spl boards would be removed before v2014.07 release. Also update README.scrapyard. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-06-05bootm: make use of legacy image format configurableHeiko Schocher
make the use of legacy image format configurable through the config define CONFIG_IMAGE_FORMAT_LEGACY. When relying on signed FIT images with required signature check the legacy image format should be disabled. Therefore introduce this new define and enable legacy image format if CONFIG_FIT_SIGNATURE is not set. If CONFIG_FIT_SIGNATURE is set disable per default the legacy image format. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Lars Steubesand <lars.steubesand@philips.com> Cc: Mike Pearce <mike@kaew.be> Cc: Wolfgang Denk <wd@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Michal Simek <monstr@monstr.eu> Acked-by: Simon Glass <sjg@chromium.org>
2014-06-05FDT: Fix DTC repository referencesJon Loeliger
The Device Tree Compiler (DTC) used to have its master repository located on jdl.com. While it is still there, its official, new, shiny location is on kernel.org here: git://git.kernel.org/pub/scm/utils/dtc/dtc.git Update a few references to point there instead. Signed-off-by: Jon Loeliger <jdl@jdl.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-06-02Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-05-30powerpc: hiddendragon: remove orphan boardMasahiro Yamada
This board has been orphan for a while. (Emails to its maintainer have been bouncing.) Because MPC82xx family is old enough, nobody would pick up the maintainership on it. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denx <wd@denx.de>
2014-05-30powerpc: debris: remove orphan boardMasahiro Yamada
2014-05-30powerpc: kvme080: remove orphan boardMasahiro Yamada
2014-05-30powerpc: ep8248: remove orphan boardMasahiro Yamada
2014-05-30powerpc: ispan: remove orphan boardMasahiro Yamada
2014-05-30powerpc: rattler: remove orphan boardMasahiro Yamada
2014-05-30powerpc: zpc1900: remove orphan boardMasahiro Yamada
2014-05-30powerpc: mpc8260ads: remove orphan boardMasahiro Yamada
2014-05-30powerpc: adder: remove orphan boardMasahiro Yamada
This board has been orphan for a while. (Emails to its maintainer have been bouncing.) Because MPC8xx family is old enough, nobody would pick up the maintainership on it. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denx <wd@denx.de>
2014-05-30PPC4xx: Remove quad100hd boardWolfgang Denk
The quad100hd has been unmaintained and dead ever since it's been added some 6 years ago. Remove it. Also update README.scrapyard and insert some commit IDs for removed boards. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Gary Jennejohn <gljennjohn@googlemail.com>
2014-05-30Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-05-28power: Add support for TPS65090 PMU chip.Tom Wai-Hong Tam
This adds driver support for the TPS65090 PMU. Support includes hooking into the pmic infrastructure so that the pmic commands can be used on the console. The TPS65090 supports the following functionality: - fet enable/disable/querying - getting and setting of charge state Even though it is connected to the pmic infrastructure it does not hook into the pmic charging charging infrastructure. The device tree binding is from Linux, but only a small subset of functionality is supported. Signed-off-by: Tom Wai-Hong Tam <waihong@chromium.org> Signed-off-by: Hatim Ali <hatim.rv@samsung.com> Signed-off-by: Katie Roberts-Hoffman <katierh@chromium.org> Signed-off-by: Rong Chang <rongchang@chromium.org> Signed-off-by: Sean Paul <seanpaul@chromium.org> Signed-off-by: Vincent Palatin <vpalatin@chromium.org> Signed-off-by: Aaron Durbin <adurbin@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-05-27dm: rename device struct to udeviceHeiko Schocher
using UBI and DM together leads in compiler error, as both define a "struct device", so rename "struct device" in include/dm/device.h to "struct udevice", as we use linux code (MTD/UBI/UBIFS some USB code,...) and cannot change the linux "struct device" Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Marek Vasut <marex@denx.de>
2014-05-27arm:at91: enable ROM loadable atmel imageAndreas Bießmann
For sama5d3xek we need to modify the SPL image for correct detection by ROM code. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Tested-by: Bo Shen <voice.shen@atmel.com>
2014-05-23doc:git-mailrc: Add entry for dfu subsystemŁukasz Majewski
Entry for dfu subsystem have been added to doc/git-mailrc file Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
2014-05-22Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
2014-05-16Revert "sandbox: move source files from board/ to arch/sandbox/"Masahiro Yamada
This reverts commit 258060905e04fe2eb509756ef3b37e23e220a2d6. Conflicts: boards.cfg Wrong patch 25806090 was applied by accident. Revert it. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2014-05-16ARM: dts: exynos: rename from EXYNOS5_DWMMC to EXYNOS_DWMMCJaehoon Chung
Exynos serise can be supported the dw-mmc controller. So, it's good that used the general prefix as "_EXYNOS_DWMMC". Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-05-12disk: part_efi: add support for the Backup GPTSteve Rae
Check the Backup GPT table if the Primary GPT table is invalid. Renamed "Secondary GPT" to "Backup GPT" as per: UEFI Specification (Version 2.3.1, Errata A) Signed-off-by: Steve Rae <srae@broadcom.com>
2014-05-12doc: README.generic-board: Fix typoFabio Estevam
Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-05-09Merge branch 'tom' of git://git.denx.de/u-boot-x86Tom Rini
2014-05-09sandbox: move source files from board/ to arch/sandbox/Masahiro Yamada
Prior to commit 33a02da0, all boards must have board/${BOARD}/ or board/${VENDOR}/${BOARD}/ directory. Now this rule is obsolete. It looks weird that sandbox defines "vendor" and "board" just for meeting the old U-Boot directory structure. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org>
2014-05-09Merge branch 'u-boot/master'Albert ARIBAUD
Conflicts: drivers/net/Makefile (trivial merge)
2014-05-08usb/gadget: add the fastboot gadgetSebastian Siewior
This patch contains an implementation of the fastboot protocol on the device side and documentation. This is based on USB download gadget infrastructure. The fastboot function implements the getvar, reboot, download and reboot commands. What is missing is the flash handling i.e. writting the image to media. v3 (Rob Herring): This is based on http://patchwork.ozlabs.org/patch/126798/ with the following changes: - Rebase to current mainline and updates for current gadget API - Use SPDX identifiers for licenses - Traced the history and added missing copyright to cmd_fastboot.c - Use load_addr/load_size for transfer buffer - Allow vendor strings to be optional - Set vendor/product ID from config defines - Allow Ctrl-C to exit fastboot mode v4: - Major re-write to use the USB download gadget. Consolidated function code to a single file. - Moved globals into single struct. - Use puts and putc as appropriate. - Added CONFIG_USB_FASTBOOT_BUF_ADDR and CONFIG_USB_FASTBOOT_BUF_SIZE to set the fastboot transfer buffer. v5: - Add CONFIG option documentation to README - Rebase using new downloader registration Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Rob Herring <robh@kernel.org>
2014-04-25Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
2014-04-22powerpc/T4QDS: add two stage boot of nand/sdShaohui Xie
Add support of 2 stage NAND/SD boot loader using SPL framework. PBL initialise the internal SRAM and copy SPL, this further initialise DDR using SPD and environment and copy u-boot from NAND/SD to DDR, finally SPL transfer control to u-boot. NOR uses CS1 instead of CS2 when NAND boot, fix it. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-04-22board/b4qds:Add support of 2 stage NAND boot-loaderPrabhakar Kushwaha
Add support of 2 stage NAND boot loader using SPL framework. here, PBL initialise the internal SRAM and copy SPL(160KB). This further initialise DDR using SPD and environment and copy u-boot(768 KB) from NAND to DDR. Finally SPL transer control to u-boot. Initialise/create followings required for SPL framework - Add spl.c which defines board_init_f, board_init_r - update tlb and ddr accordingly Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-04-20MIPS: drop incaip boardDaniel Schwierzeck
This is dead hardware and no one is interested in making the necessary changes for upcoming features like generic board or driver model. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Cc: Wolfgang Denk <wd@denx.de>
2014-04-18kbuild: docbook: sync with Linux Kernel v3.15-rc1Masahiro Yamada
This commit imports DocBook-related updates from v3.14 to v3.15-rc1. - commit ec3fadd64b9940baa2a369bf978e8561837db3f5 kbuild: docbook: use $(obj) and $(src) rather than specific path - commit 100da4c0150c97ce34d4d3b38bf2f5449b05ae4f kbuild: docbook: specify KERNELDOC dependency correctly - commit 6f89b9c1d6b29eaa600ac4a8ac1314b0d06f15e3 kbuild: docbook: include cmd files more simply - commit ac6d662a95a6989d83b259ccf8ec01dd7903af73 doc: Add "*.svg" to DocBook/.gitignore - commit 832919bfcf0cfd75767c68b0c61f7cf48be860a8 DocBook: Make mandocs parallel-safe - commit c4d79a4799719f2b0cd354ee498aad605730c97e work around xmlto bug in htmldocs Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-04-18doc:power:pmic: Add doc entry for PMIC(v2) frameworkŁukasz Majewski
Well written documentation for PMIC framework was missing and hence it has been probably difficult and time consuming for other developers to understand rationale for key design decisions and overall design structure. This commit provides proper documentation entry. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-04-18arm: remove lubbock board supportMasahiro Yamada
Enough time has passed since this board was moved to Orphan. Remove. - Remove board/lubbock/* - Remove include/configs/lubbock.h - Cleanup defined(CONFIG_LUBBOCK) - Move the entry from boards.cfg to doc/README.scrapyard Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-04-18powerpc: remove MOUSSE board supportMasahiro Yamada
Enough time has passed since this board was moved to Orphan. Remove. - Remove board/mousse/* - Remove include/configs/MOUSSE.h - Clean-up defined(CONFIG_MOUSSE) - Move the entry from boards.cfg to doc/README.scrapyard Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-04-18powerpc: remove rsdproto board supportMasahiro Yamada
Enough time has passed since this board was moved to Orphan. Remove. - Remove board/rsdproto/* - Remove include/configs/rsdproto.h - Move the entry from boards.cfg to doc/README.scrapyard Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-04-18powerpc: remove RPXsuper board supportMasahiro Yamada
Enough time has passed since this board was moved to Orphan. Remove. - Remove board/rpxsuper/* - Remove include/configs/RPXsuper.h - Move the entry from boards.cfg to doc/README.scrapyard Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-04-18powerpc: remove RPXClassic, RPXlite boards supportMasahiro Yamada
Enough time has passed since these boards were moved to Orphan. Remove. - Remove board/RPXlite/* - Remove board/RPXClassic/* - Remove include/configs/RPXlite.h - Remove include/configs/RPXClassic.h - Clean-up defined(CONFIG_RPXCLASSIC) - Move the entry from boards.cfg to doc/README.scrapyard Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-04-18powerpc: remove genietv board supportMasahiro Yamada
Enough time has passed since this board was moved to Orphan. Remove. - Remove board/genietv/* - Remove include/configs/GENIETV.h - Clean-up if defined(CONFIG_GENIETV) - Move the entry from boards.cfg to doc/README.scrapyard Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-04-18powerpc: remove MBX and MBX860T boards supportMasahiro Yamada
Enough time has passed since these boards were moved to Orphan. Remove. - Remove board/mbx8xx/* - Remove include/configs/{MBX.h,MBX860T.h} - Clean-up if defined(CONFIG_MBX) - Move the entries from boards.cfg to doc/README.scrapyard Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-04-18powerpc: remove NX823 board supportMasahiro Yamada
Enough time has passed since this board was moved to Orphan. Remove. - Remove board/nx823/* - Remove include/configs/NX823.h - Clean-up ifdef(CONFIG_NX823) - Move the entry from boards.cfg to doc/README.scrapyard Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-04-17powerpc: mpc8xx: delete an unused source fileMasahiro Yamada
References to the wireless keyboard should also be removed from README.console. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Wolfgang Denk <wd@denx.de>
2014-04-17spl_mmc/CONFIG_SPL_OS_BOOT: Allow environment to determine what to bootTom Rini
We add two new environment variables, falcon_args_file and falcon_image_file, which when set will override the compiled in default values for falcon mode. Signed-off-by: Tom Rini <trini@ti.com>
2014-04-17README.falcon: Document environment variables for falcon modeTom Rini
2014-04-17board: esd: remove remainders of dead boardsMasahiro Yamada
Commit 99bcad18 deleted ADCIOP and DASA_SIM board support but missed to delete board/esd/adciop and board/esd/dasa_sim. It also missed to add entries to doc/README.scrapyard. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Stefan Roese <sr@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2014-04-17cosmetic: README.scrapyard: fix false removed date and commitMasahiro Yamada
Describe removed date in the form of YYYY-MM-DD, not YYYY-DD-MM. And wrong commit hash also should be fixed. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Marek Vasut <marex@denx.de> Acked-by: Marek Vasut <marex@denx.de>
