Signed-off-by: Horst Kronstorfer <hkronsto@frequentis.com>
Fix trailing white space, indentation by spaces instead of TABs,
excessive blank lines, trailing blank lines.
The "tb0229" board has long been unmaintained, and is broken.
Remove it.
The "rmu" board has long been unmaintained, and is broken.
Remove it.
The OXC board has long been unmaintained, and is broken.
Remove it.
The BAB7xx boards are almost deceased. They cause build warnings, an
it's not worth the effort to fix these. Remove the dead body.
Cc: Frank Gottschling <fgottschling@eltec.de>
The board is unmaintained and maintainer doesn't respond.
This should make sending out e-mails to the right people easier.
We want to move everything to phylib, and we definitely don't want
new drivers using the miiphy infrastructure.
Signed-off-by: Andy Fleming <afleming@freescale.com>
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
The P3060QDS is a Freescale reference board for the six-core P3060 SOC.
P3060QDS Board Overview:
Memory subsystem:
- 2G Bytes unbuffered DDR3 SDRAM SO-DIMM(64bit bus)
- 128M Bytes NOR flash single-chip memory
- 16M Bytes SPI flash
- 8K Bytes AT24C64 I2C EEPROM for RCW
Ethernet:
- Eight Ethernet controllers (4x1G + 4x1G/2.5G)
- Three VSC8641 PHYs on board (2xRGMII + 1xMII)
- Suport multiple Vitesse VSC8234 SGMII Cards in Slot1/2/3
PCIe: Two PCI Express 2.0 controllers/ports
USB: Two USB2.0, USB1(TYPE-A) and USB2(TYPE-AB) on board
I2C: Four I2C controllers
UART: Supports two dUARTs up to 115200 bps for console
RapidIO: Two RapidIO, sRIO1 and sRIO2
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
Signed-off-by: York Sun <yorksun@freescale.com>
Change my old email address which is no longer valid.
Signed-off-by: Stelian Pop <stelian@popies.net>
Cc: Detlev Zundel <dzu@denx.de>
* 'master' of git://git.denx.de/u-boot-mpc83xx:
powerpc/mpc83xx: Add 33.33MHz support for mpc8360emds
powerpc/mpc83xx: Add 512MB DDR support for mpc8360emds
mpc83xx: Rename CONFIG_SYS_DDR_CONFIG and cleanup DDR csbnds code
mpc83xx: Cleanup usage of LBC constants
mpc83xx: Cleanup usage of DDR constants
mpc83xx: Cleanup usage of BAT constants
mpc83xx: cosmetic: vme8349.h checkpatch compliance
mpc83xx: cosmetic: ve8313.h checkpatch compliance
mpc83xx: cosmetic: sbc8349.h checkpatch compliance
mpc83xx: cosmetic: mpc8308_p1m.h checkpatch compliance
mpc83xx: cosmetic: kmeter1.h checkpatch compliance
mpc83xx: cosmetic: TQM834x.h checkpatch compliance
mpc83xx: cosmetic: SIMPC8313.h checkpatch compliance
mpc83xx: cosmetic: MVBLM7.h checkpatch compliance
mpc83xx: cosmetic: MPC837XERDB.h checkpatch compliance
mpc83xx: cosmetic: MPC837XEMDS.h checkpatch compliance
mpc83xx: cosmetic: MPC8360ERDK.h checkpatch compliance
mpc83xx: cosmetic: MPC8360EMDS.h checkpatch compliance
mpc83xx: cosmetic: MPC8349ITX.h checkpatch compliance
mpc83xx: cosmetic: MPC8349EMDS.h checkpatch compliance
mpc83xx: cosmetic: MPC832XEMDS.h checkpatch compliance
mpc83xx: cosmetic: MPC8323ERDB.h checkpatch compliance
mpc83xx: cosmetic: MPC8315ERDB.h checkpatch compliance
mpc83xx: cosmetic: MPC8313ERDB.h checkpatch compliance
mpc83xx: cosmetic: MPC8308RDB.h checkpatch compliance
mpc83xx: cosmetic: MERGERBOX.h checkpatch compliance
mpc83xx: Fix ipic structure definition
powerpc, mpc83xx: add DDR SDRAM Timing Configuration 3 definitions
cosmetic, powerpc, mpc83xx: checkpatch cleanup
powerpc/83xx: move km 83xx specific i2c code to km83xx_i2c
mpc83xx: fix global timer structure definition
The new MPC8360EMDS board changes the oscillator to 33.33MHz
in order to support QE 500MHz since 2008.
Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
Add support for the MATRIX VISION mvBlueLYNX-X, an OMAP3-based
intelligent camera.
Signed-off-by: Michael Jones <michael.jones@matrix-vision.de>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
- DM368 SOC
- booting with spl not with UBL from TI
- before loading u-boot from NAND into RAM, test
the RAM with the post memory test. If error
is found, switch all LEDs on and halt system.
- SPI Flash
Dataflash Typ: M25PE80
- Ethernet DM9161BI
- MMC
- USB
Cc: Sandeep Paulraj <s-paulraj@ti.com>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Cc: Scott Wood <scottwood@freescale.com>
Cc: Sergei Shtylyov <sshtylyov@mvista.com>
Adding a DMA library to the SPL. It is used if CONFIG_SPL_DMA_SUPPORT is
defined.
Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com>
Adds an interface to use the OMAP3 DMA.
This adds support for a new environment variable called 'fdtcontroladdr'. If
defined, the hex address is used as the address of the control fdt for U-Boot.
Note: I have not changed CONFIG_PRAM section as I already have an
outstanding patch on that.
This new option allows U-Boot to embed a binary device tree into its image
to allow run-time control of peripherals. This device tree is for U-Boot's
own use and is not necessarily the same one as is passed to the kernel.
The device tree compiler output should be placed in the $(obj)
rooted tree. Since $(OBJCOPY) insists on adding the path to the
generated symbol names, to ensure consistency it should be
invoked from the directory where the .dtb file is located and
given the input file name without the path.
This commit contains my entry for the ugliest Makefile / shell interaction
competition.
This macro is used to allocate cache line size aligned stack
buffers for use with DMA hardware.
Signed-off-by: Anton Staaf <robotboy@chromium.org>
Cc: Lukasz Majewski <l.majewski@samsung.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Aneesh V <aneesh@ti.com>
The board stopped building some time ago, and the board maintainer
agrtees to drop it - see
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/112674
Cc: Alex Dubov <oakad@yahoo.com>
Cc: Andy Fleming <afleming@gmail.com>
Cc: Kumar Gala <galak@kernel.crashing.org>
Remove MK_STR from places that consume CONFIG_BOOTFILE to force all definitions to be string literals.
Cc: Joe Hershberger <joe.hershberger@gmail.com>
Documents and READMEs for NDS32 architecture.
It patch also provides usage of SoC AG101 and board ADP-AG101.
Signed-off-by: Macpaul Lin <macpaul@andestech.com>
This adds required header files for the sandbox architecture, and a basic
description of what sandbox is (README.sandbox).
Add pxe command, which is intended to mimic PXELINUX functionality.
'pxe get' uses tftp to retrieve a file based on UUID, MAC address or IP
address. 'pxe boot' interprets the contents of PXELINUX config like file
to boot using a specific initrd, kernel and kernel command line.
This patch also adds a README.pxe file - see it for more details on the
pxe command.
Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com>
This will be used first by the pxe code, but is intended to be
generic and reusable for other jobs in U-boot.
Interactive DDR debugging provides a user interface to view and modify SPD,
DIMM parameters, board options and DDR controller registers before DDR is
initialized. With this feature, developers can fine-tune DDR for board
bringup and other debugging without frequently having to reprogram the flash.
To enable this feature, define CONFIG_FSL_DDR_INTERACTIVE in board header
file and set an environment variable to activate it. Syntax:
setenv ddr_interactive on
After reset, U-boot prompts before initializing DDR controllers
FSL DDR>
The available commands are
print print SPD and intermediate computed data
reset reboot machine
recompute reload SPD and options to default and recompute regs
edit modify spd, parameter, or option
compute recompute registers from current next_step to end
next_step shows current next_step
help this message
go program the memory controller and continue with u-boot
The first command should be "compute", which reads data from DIMM SPDs and
board options, performs the calculation then stops before setting DDR
controller. A user can use "print" and "edit" commands to view and modify
anything. "Go" picks up from current step with any modification and
compltes the calculation then enables the DDR controller to continue u-boot.
"Recompute" does it over from fresh reading.
This is long over due. All but two net drivers have been converted, but
those have now been dropped.
The only thing left to do is actually delete all references to NET_MULTI
and code that is compiled when that is not defined. So here we scrub the
core code.
Now that we've got boards.cfg and most people have converted over,
start warning people who have yet to so we can phase board configs
completely out of the Makefile.
* 'master' of git://git.denx.de/u-boot-nand-flash:
PPC: Fix socrates NAND problem
PPC: Fix fsl_upm.c by renaming nand handling functions
NAND: Make page, erase, oob size available via cmd_nand
mtd: eLBC NAND: remove elbc_fcm_ctrl->oob_poi
NAND: Add -y option to nand scrub command
NAND: Add nand read.raw and write.raw commands
NAND: Really ignore bad blocks when scrubbing
spl, nand: add 4bit HW ecc oob first nand_read_page function
mxc_nand: fix a problem writing more than 32MB
mxc_nand: fixed some typos (cosmetic)
nand: increase chip_delay in mv kirkwood nand driver
* 'master' of git://git.denx.de/u-boot-mpc85xx:
powerpc/p3060: Add SoC related support for P3060 platform
powerpc/85xx: Add support for setting up RAID engine liodns on P5020
powerpc/85xx: Refactor some defines out of corenet_ds.h
fm-eth: Add ability for board code to disable a port
powerpc/mpc8548: Add workaround for erratum NMG_LBC103
powerpc/mpc8548: Add workaround for erratum NMG_DDR120
powerpc/mpc85xxcds: Fix PCI speed
powerpc/mpc8548cds: Fix booting message
powerpc/p4080: Add support for secure boot flow
powerpc/85xx: Add Secure Boot support on P1010RDB for NOR, NAND & SPIFLASH
powerpc/85xx: Add PBL & SECUREBOOT support on P3041/P5020DS boards
powerpc/p2041rdb: remove watch dog related codes
powerpc/p2041rdb: updated description of cpld command
powerpc/p2041rdb: add more ddr frequencies support
powerpc/p2041rdb: set sysclk according to status of physical switch SW1
powerpc/p2041rdb: update cpld reset command according to CPLD 2.0
powerpc/mpc8349emds: Migrate from spd_sdram to unified DDR driver
powerpc/mpc83xx: Migrate from spd_sdram to unified DDR driver
powerpc/mpc8xxx: Add DDR2 to unified DDR driver
powerpc/mpc8xxx: Fix picos_to_mclk() and get_memory_clk_period_ps()
powerpc/mpc8xxx: Add SPD EEPROM address for single controller 2 slots
powerpc/mpc8xxx: Fix DDR code for empty first DIMM slot and enable DQS_en
powerpc/85xx: Refactor P2041RDB to use common p_corenet files
powerpc/85xx: refactor common P-Series CoreNet files for FSL boards
powerpc/85xx: Enable CMD_REGINFO on corenet boards
powerpc/85xx: p2041rdb - Remove unused 'execute' perm in TLB entries
powerpc/85xx: Fix USB protocol definitions for P1020RDB
powerpc/corenet_ds: Use separated speed tables for UDIMM and RDIMM
powerpc/mpc8xxx: Move DDR RCW overriding to common code
powerpc/mpc8xxx: Extend CWL table
powerpc/85xx: Cleanup how SVR_MAJ() is defined on MPC8536
powerpc/85xx: Cleanup extern in corenet_ds board code
powerpc/p2041rdb: Add ethernet support on P2041RDB board
powerpc/85xx: Add networking support to P1023RDS
powerpc/hydra: Add ethernet support on P5020/P3041 DS boards
powerpc/85xx: Add FMan ethernet support to P4080DS
powerpc/85xx: Add support for FMan ethernet in Independent mode
powerpc/mpc8548cds: Cleanup mpc8548cds.c
powerpc/mp: add support for discontiguous cores
powerpc/85xx: corenet_ds - Remove unused 'execute' perm in TLB entries
fdt: Add new fdt_create_phandle helper
fdt: Rename fdt_create_phandle to fdt_set_phandle
powerpc/85xx: Fix compile warnings/errors if CONFIG_SYS_DPAA_FMAN isn't set
fsl_ifc: Add the workaround for erratum IFC A-003399(enabled on P1010)
powerpc/P1010: Add workaround for erratum P1010-A003549 (related to IFC)
fsl_ifc: Add the workaround for erratum IFC-A002769 (enable on P1010)
powerpc/85xx: Expanding the window of CCSRBAR in AS=1 from 4k to 1M
powerpc/85xx: Add NAND/NAND_SPL support to P1010RDB
nand: Freescale Integrated Flash Controller NAND support
powerpc/85xx: Add basic support for P1010RDB
powerpc/85xx: Add support for new P102x/P2020 RDB style boards
powerpc/85xx: relocate CCSR before creating the initial RAM area
powerpc/85xx: introduce and document CONFIG_SYS_CCSRBAR macros
powerpc/85xx: Enable internal USB UTMI PHY on p204x/p3041/p50x0
powerpc/85xx: Add ULPI and UTMI USB Phy support for P1010/P1014
These commands should work around various "hardware" ECC and BCH methods.
[scottwood@freescale.com: s/write the page/access the page/]
to add the "NOR Boot Configuration Word" on AM18xx based boards,
define CONFIG_SYS_DV_NOR_BOOT_CFG.
Cc: Paulraj Sandeep <s-paulraj@ti.com>
Adds power library to the new spl
Adds NAND library to SPL.
Acked-by: Scott Wood <scottwood@freescale.com>
DDR2 has different ODT table and values. Adding table according to Samsung
application note.
Fix additive latency calculation to avoid interger underflow.
Also converted typedef dynamic_odt_t to struct dynamic_odt.
The following boards share a common design but with minor variations
between them:
P1020MSBG-PC
P1020RDB-PC
P1020UTM-PC
P1021RDB-PC
P1024RDB
P1025RDB
P2020RDB-PC
The P1020RDB-PC shares its roots in the existing P1020RDB board design,
however uses DDR3 instead of DDR2.
P2020RDB-PC differs from the P102x RDB-PC with 64-bit DDR and 100Mhz SYSCLK.
Key features on these boards include:
* DDR3
* NOR flash
* NAND flash (on RDB's only)
* SPI flash (on RDB's only)
* SDHC/MMC card slot
* VSC7385 Ethernet switch (on P1020MBG, P1020RDB, & P1021RDB)
* PCIE slot and mini-PCIE slots
As these boards use soldered DDR chips not regular DIMMs, an on-board EEPROM
is used to store SPD data. In case of absent or corrupted SPD, falling back
to timing data embedded in the source code will be used. Raw timing data is
extracted from DDR chip datasheet. Different speeds of DDR are supported
with this approach. ODT option is forced to fit this set of boards, again
because they don't have regular DIMMs.
CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS is defined as 5ms to meet
specification for writing timing.
VSC firmware Address is defined by default in config file for eTSEC1.
SD width is based off DIP switch. DIP switch is detected on the
board by reading i2c bus and setting the appropriate mux values.
Some boards have QE module in the silicon (P1021 and P1025). QE and eLBC
have pins multiplexing. QE function needs to be disabled to access Nor Flash
and CPLD. QE-UEC and QE-UART can be enabled for linux kernel by setting "qe"
in hwconfig. In addition, QE-UEC and QE-TDM also have pins multiplexing, to
enable QE-TDM for linux kernel, set "qe;tdm" in hwconfig. Syntax is as below
'setenv hwconfig qe' to enable QE UEC/UART and disable Nor-Flash/CPLD.
'setenv hwconfig 'qe;tdm'' to enalbe QE TDM and disable Nor-Flash/CPLD.
Signed-off-by: Li Yang <leoli@freescale.com>
Signed-off-by: Zhao Chenhui <b26998@freescale.com>
Signed-off-by: Matthew McClintock <msm@freescale.com>
Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com>
Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
Signed-off-by: Tang Yuantian <b29983@freescale.com>
Signed-off-by: ramneek.mehresh <ramneek.mehresh@freescale.com>
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
Signed-off-by: Xie Xiaobo <X.Xie@freescale.com>
Signed-off-by: Akhil Goyal <akhil.goyal@freescale.com>
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
This is a trivial fix in the documentation, which corrects
board_init_r() source reference.
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
This patch contains the generic changes required after
change to generic API in the previous patch.
Signed-off-by: Sanjeev Premi <premi@ti.com>
