path: root/doc
2009-04-03Noisily disable the legacy NAND subsystem.Scott Wood
Legacy NAND is marked for feature removal after April 2009 (i.e. this upcoming release). There are still several boards that reference it (though many do so only for disk-on-chip support which has been silently disabled for a while now). These boards will now fail to build with #error, though the code is still there if the user removes #error. The plan is to remove the code outright in the next release, along with any board code that refers to it (such as board/esd/common/auto_update.c). Also, remove the legacy NAND API description from README.nand. Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-04-03Add "source" command; prepare removal of "autoscr" commandWolfgang Denk
According to the doc/feature-removal-schedule.txt, the "autoscr" command will be replaced by the "source" command in approximately 6 months from now. This patch prepares this change and starts a 6 month transition period as follows: - The new "source" command has been added, which implements exactly the same functionlaity as the old "autoscr" command before - The old "autoscr" command name is kept as an alias for compatibility - Command sequences, script files atc. have been adapted to use the new "source" command - Related environment variables ("autoscript", "autoscript_uname") have *not* been adapted yet; these will be renamed resp. removed in a separate patch when the support for the "autoscr" command get's finally dropped. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-04-03Add "GPL cleanup" task to feature-removal-schedule.txtWolfgang Denk
Announce removal of all non-GPL or GPL-incompatible files after August 2009. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-03-26Merge branch 'master' of git://git.denx.de/u-boot-at91Wolfgang Denk
2009-03-23Merge branch 'mimc200'Haavard Skinnemoen
2009-03-22at91: Support for the at91sam9g20 : Atmel 400Mhz ARM 926ej-s SOC.Nicolas Ferre
AT91sam9g20 is an evolution of the at91sam9260 with a faster clock speed. The AT91SAM9G20-EK board is an updated revision of the AT91SAM9260-EK board. It is essentially the same, with a few minor differences. Here is the chip page on Atmel website: http://www.atmel.com/dyn/products/product_card.asp?part_id=4337 Signed-off-by: Justin Waters <justin.waters@timesys.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-03-20doc/README.enetaddr: document proper MAC usageMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-12sh: Add support 32-Bit Extended Address Mode to sh7785lcrYoshihiro Shimoda
We can built 'make sh7785lcr_32bit_config'. And add new command "pmb" for this mode. This command changes PMB for using 512MB system memory. Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-02-23Merge branch 'cleanups' into nextHaavard Skinnemoen
2009-02-12Coding style cleanup; update CHANGELOGWolfgang Denk
2009-02-11Add feature-removal-schedule.txtPeter Tyser
2009-02-01Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2009-01-29ppc4xx: Add variable "korat_usbcf" for Korat boardLarry Johnson
The new environment variable "korat_usbcf" selects the USB port used by the Korat board's CompactFlash controller. Signed-off-by: Larry Johnson <lrj@acm.org> Signed-off-by: Stefan Roese <sr@denx.de>
2009-01-28OMAP3: Add Zoom1 board supportDirk Behme
Support for Zoom MDK with OMAP3430. Details of Zoom MDK available here: http://www.logicpd.com/products/devkit/ti/zoom_mobile_development_kit Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Jason Kridner <jkridner@beagleboard.org>
2009-01-28OMAP3: Add Pandora supportDirk Behme
Add Pandora support. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Signed-off-by: Dirk Behme <dirk.behme@googlemail.com> Signed-off-by: Jason Kridner <jkridner@beagleboard.org>
2009-01-28OMAP3: Add EVM boardDirk Behme
Add EVM board support. Signed-off-by: Manikandan Pillai <mani.pillai@ti.com> Signed-off-by: Dirk Behme <dirk.behme@googlemail.com> Signed-off-by: Jason Kridner <jkridner@beagleboard.org>
2009-01-28OMAP3: Add Overo boardDirk Behme
Add Overo board support. Signed-off-by: Steve Sakoman <sakoman@gmail.com> Signed-off-by: Dirk Behme <dirk.behme@googlemail.com> Signed-off-by: Jason Kridner <jkridner@beagleboard.org>
2009-01-28OMAP3: Add common power code, README, and BeagleBoardDirk Behme
Add BeagleBoard support, common power code and README. Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
2009-01-28Update CHANGELOG, tiny coding style cleanup.Wolfgang Denk
2009-01-24Initial support for Nomadik 8815 development boardAlessandro Rubini
The NMDK8815 board is distributed by ST Microelectornics. Other (proprietary) code must be run to unlock the CPU before U-Boot runs. doc/README.nmdk8815 outlines the boot sequence. This is the initial port, with basic infrastructure and a working serial port. Signed-off-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Andrea Gallo <andrea.gallo@stnwireless.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-01-24Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
2009-01-24Merge branch 'master' of git://git.denx.de/u-boot-mpc83xxWolfgang Denk
2009-01-24nios: Move README.nios_CONFIG_SYS_NIOS_CPU to doc/ dirShinya Kuribayashi
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2009-01-23Merge branch 'next'Kim Phillips
2009-01-24powerpc: 83xx: add support for the kmeter1 boardHeiko Schocher
This patch adds support for the kmeter1 board from Keymile, based on a Freescale MPC8360 CPU. - serial console on UART 1 - 256 MB DDR2 RAM - 64 MB NOR Flash - Ethernet RMII Mode over UCC4 - PHY SMSC LAN8700 Signed-off-by: Heiko Schocher <hs@denx.de>
2009-01-23Add README file for MPC8572DS boardHaiying Wang
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Acked-by: Andy Fleming <afleming@freescale.com>
2009-01-23mpc83xx: New board support for SIMPC8313Ron Madrid
This patch will create a new board, SIMPC8313, from Sheldon Instruments. This board boots from NAND devices and is configureable for either large or small page devices. The board supports non-soldered DDR2, one ethernet port, a Marvell 88E1118 PHY, and PCI host support. The board also has a FPGA connected to the eLBC providing glue logic to a TMS320C67xx DSP. Signed-off-by: Ron Madrid <ron_madrid@sbcglobal.net> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-01-23NAND: rename NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPSWolfgang Grandegger
This patch renames NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPS and changes the default from 8 to 1 for the legacy and the new MTD NAND layer. This allows to remove all NAND_MAX_CHIPS definitions in the board config files because none of the boards use multi chip support (NAND_MAX_CHIPS > 1) so far. The bamboo and the DU440 define #define NAND_MAX_CHIPS CONFIG_SYS_MAX_NAND_DEVICE but that's bogus and did not work anyhow. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-01-21Merge branch 'master' into nextKim Phillips
2009-01-06at91: add at91sam9xeek board supportNicolas Ferre
At91sam9xe is basically an at91sam9260 with embedded flash. We can manage it as another entry for at91sam9260 in the Makefile. Check documentation at : http://www.atmel.com/dyn/products/product_card.asp?part_id=4263 Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-12-17Merge branch 'fixes' into cleanupsHaavard Skinnemoen
Conflicts: board/atmel/atngw100/atngw100.c board/atmel/atstk1000/atstk1000.c cpu/at32ap/at32ap700x/gpio.c include/asm-avr32/arch-at32ap700x/clk.h include/configs/atngw100.h include/configs/atstk1002.h include/configs/atstk1003.h include/configs/atstk1004.h include/configs/atstk1006.h include/configs/favr-32-ezkit.h include/configs/hammerhead.h include/configs/mimc200.h
2008-12-17MIPS: qemu_mips: update doc to generate and to use qemu flash, ide fileJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2008-12-17MIPS: qemu_mips: update doc to use all disk and boot linux kernelJean-Christophe PLAGNIOL-VILLARD
2008-12-10tools/netconsole: new script for working with netconsole over UDPMike Frysinger
While the doc/README.NetConsole does have a snippet for people to create their own netcat script, it's a lot easier to make a simple dedicated script and tell people to use it. Also spruce it up a bit to make it user friendly. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-12-09Merge branch 'master' of git://git.denx.de/u-boot-at91Wolfgang Denk
2008-12-07IOMUX: Add console multiplexing support.Gary Jennejohn
Modifications to support console multiplexing. This is controlled using CONFIG_SYS_CONSOLE_MUX in the board configuration file. This allows a user to specify multiple console devices in the environment with a command like this: setenv stdin serial,nc. As a result, the user can enter text on both the serial and netconsole interfaces. All devices - stdin, stdout and stderr - can be set in this manner. 1) common/iomux.c and include/iomux.h contain the environment setting implementation. 2) doc/README.iomux contains a somewhat more detailed description. 3) The implementation in (1) is called from common/cmd_nvedit.c to handle setenv and from common/console.c to handle initialization of input/output devices at boot time. 4) common/console.c also contains the code needed to poll multiple console devices for input and send output to all devices registered for output. 5) include/common.h includes iomux.h and common/Makefile generates iomux.o when CONFIG_SYS_CONSOLE_MUX is set. Signed-off-by: Gary Jennejohn <garyj@denx.de>
2008-12-06at91: Choose environment variables location within make config targetNicolas Ferre
This patch adds the possiblity to choose the media where the environment will be located. This allow to choose this fundamental configuration without editing config files. Documentation file added. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Stelian Pop <stelian@popies.net> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-12-01mpc8641: Fix error in READMEBecky Bruce
I made some updates to the code that didn't make it into the README - fix this Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-11-20powerpc: 83xx: add support for the kmeter1 boardHeiko Schocher
This patch adds support for the kmeter1 board from Keymile, based on a Freescale MPC8360 CPU. - serial console on UART 1 - 256 MB DDR2 RAM - 64 MB NOR Flash - Ethernet RMII Mode over UCC4 - PHY SMSC LAN8700 Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-11-10mpc8641: Support 36-bit physical addressingBecky Bruce
This patch creates a memory map with all the devices in 36-bit physical space, in addition to the 32-bit map. The CCSR relocation is moved (again, sorry) to allow for the physical address to be 36 bits - this requires translation to be enabled. With 36-bit physical addressing enabled, we are no longer running with VA=PA translations. This means we have to distinguish between the two in the config file. The existing region name is used to indicate the virtual address, and a _PHYS variety is created to represent the physical address. Large physical addressing is not enabled by default. Set CONFIG_PHYS_64BIT in the config file to turn this on. Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-11-10mpc8641: Change 32-bit memory mapBecky Bruce
The memory map on the 8641hpcn is modified to look more like the 85xx boards; this is a step towards a more standardized layout going forward. As part of this change, we now relocate the flash. The regions for some of the mappings were far larger than they needed to be. I have reduced the mappings to match the actual sizes supported by the hardware. In addition I have removed the comments at the head of the BAT blocks in the config file, rather than updating them. These get horribly out of date, and it's a simple matter to look at the defines to see what they are set to since everything is right here in the same file. Documentation has been changed to reflect the new map, as this change is user visible, and affects the OS which runs post-uboot. Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-11-03ColdFire: Add MCF5301x CPU and M53017EVB supportTsiChung Liew
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-10-31Fix to the auto-update feature documentation (CONFIG_UPDATE_TFTP_MSEC_MAX)Bartlomiej Sieka
Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-10-29mpc8313erdb: Document NAND boot.Scott Wood
Previously, the documentation claimed that NAND boot is not supported. This is no longer true. Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-10-18Check DDR interleaving modeHaiying Wang
* Check DDR interleaving mode from environment by reading memctl_intlv_ctl and ba_intlv_ctl. * Print DDR interleaving mode information * Add doc/README.fsl-ddr to describe the interleaving setting Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
2008-10-18Automatic software update from TFTP serverBartlomiej Sieka
The auto-update feature allows to automatically download software updates from a TFTP server and store them in Flash memory during boot. Updates are contained in a FIT file and protected with SHA-1 checksum. More detailed description can be found in doc/README.update. Signed-off-by: Rafal Czubak <rcz@semihalf.com> Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-10-14Remove unused CFG_EEPROM_PAGE_WRITE_ENABLE referencesPeter Tyser
2008-10-08update uImage FIT multi documentationJean-Christophe PLAGNIOL-VILLARD
2008-10-08move README.imx31 to doc/ and merge with README.mx31Jean-Christophe PLAGNIOL-VILLARD
