path: root/doc
2010-10-29Drop support for CONFIG_SYS_ARM_WITHOUT_RELOCWolfgang Denk
When this define was introduced, the idea was to provide a soft migration path for ARM boards to get adapted to the new relocation support. However, other recent changes led to a different implementation (ELF relocation), where this no longer works. By now CONFIG_SYS_ARM_WITHOUT_RELOC does not only not help any more, but it actually hurts because it obfuscates the actual code by sprinkling it with lots of dead and non-working debris. So let's make a clean cut and drop CONFIG_SYS_ARM_WITHOUT_RELOC. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-10-29Replace CONFIG_RELOC_FIXUP_WORKS by CONFIG_NEEDS_MANUAL_RELOCWolfgang Denk
By now, the majority of architectures have working relocation support, so the few remaining architectures have become exceptions. To make this more obvious, we make working relocation now the default case, and flag the remaining cases with CONFIG_NEEDS_MANUAL_RELOC. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-10-27Coding Style cleanupWolfgang Denk
2010-10-24VoVPN-GW_100MHz: drop unsupported board configurationWolfgang Denk
The 100MHz configuation of the VoVPN-GW has never been supported, so drop it now. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-10-23Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
2010-10-22post/i2c: Add ability to ignore I2C devicesPeter Tyser
Add the ability to not report an I2C POST error for a set of given I2C addresses on bootup. This is useful for cases when a device may or may not be present, and neither case is considered an error. For example: - Some form factors such as XMC and Compact PCI Express have an I2C EEPROM whose address changes based on geographical address. Eg installed in one slot its EEPROM address is, 0x50, in another its 0x51, etc. This allows multiple devices to have their EEPROMs present on the same I2C bus. Thus the I2C devices present for an XMC or CPCIe card depend on if and where other cards are installed in the same system. - Some cards have optional I2C devices. Eg one hardware build configuration has different I2C devices than another and software can't determine if the optional device should be present or not. - Some cards have optional daughtercards with I2C devices on them. - I2C EEPROMs address range depends on their size. Its possible to support differently size EEPROMs by only probing the EEPROM's base address and ignoring the other addresses that are impacted by its size. A new CONFIG_SYS_POST_I2C_IGNORES define has been added which specifies a list of I2C addresses for the I2C POST to ignore. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-22post/i2c: Rename I2C_ADDR_LIST to CONFIG_SYS_POST_I2C_ADDRSPeter Tyser
2010-10-21led_display: remove unused DISPLAY_MARK defineIlya Yanok
DISPLAY_MARK subcommand of display_set() is not used anywhere so we can remove it safely. Signed-off-by: Ilya Yanok <yanok@emcraft.com>
2010-10-20Add memory test feature for mpc85xx POST.York Sun
The memory test is performed after DDR initialization when U-boot stills runs in flash and cache. On recent mpc85xx platforms, the total memory can be more than 2GB. To cover whole memory, it needs be mapped 2GB at a time using a sliding TLB window. After the testing, DDR is remapped with up to 2GB memory from the lowest address as normal. If memory test fails, DDR DIMM SPD and DDR controller registers are dumped for further debugging. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-20Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2010-10-19Add UBI READMEStefan Roese
This patch adds a small README to describe the usage of the U-Boot UBI commands. Signed-off-by: Stefan Roese <sr@denx.de>
2010-10-19doc/README.scrapyard: add documentation for abandoned boardsWolfgang Denk
Add a document to maintain a list of boards removed from the current source tree, so archeologists can check more easily if here is something they might want to dig for... Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-10-19Merge branch 'elf_reloc'Wolfgang Denk
Conflicts: arch/arm/include/asm/config.h board/LaCie/edminiv2/config.mk board/karo/tx25/config.mk board/logicpd/imx27lite/config.mk doc/README.arm-relocation Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-10-18Rename TEXT_BASE: fix merge conflictsWolfgang Denk
Commit 14d0a02a "Rename TEXT_BASE into CONFIG_SYS_TEXT_BASE" missed a few places, especially for boards that were added inbetween. Fix the remaining issues. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-10-13arm: implement ELF relocationsAlbert Aribaud
ELF relocation tables generated with linker option -pie can be used to fixup code and data in a single loop at relocation, removing the need for manual fixups anywhere else in the code. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
2010-10-12led_display: split led display support into generic and hw-dependent partsIlya Yanok
Split the display command into generic interface and hardware-specific realization for PDSP188x LED display found on hmi1001 and manroland boards. Simple interface for LED displays is defined in include/led-display.h and described in doc/README.LED_display. Driver-specific implementation was moved into drivers/misc/pdsp188x.c file (enabled with CONFIG_PDSP188x set). Signed-off-by: Ilya Yanok <yanok@emcraft.com>
2010-10-07p1022ds: add audclk hwconfig setting to enable codec reference clockTimur Tabi
The Freescale P1022DS can use either a 12.288MHz or a 11.2896MHz reference clock for the audio codec, but by default both are disabled. Add a 'audclk' hwconfig option that allows the user to choose which clock he wants. The 12.288MHz clock allows the codec to use sampling rates of 16, 24, 32, 48, 64, and 96KHz. The 11.2896 clock allows 14700, 22050, 29400, 44100, 58800, and 88200Hz. Also configure a pin muxing to select some SSI signals, which will disable I2C1. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-04CONFIG_SYS_ARM_WITHOUT_RELOC: document feature removalWolfgang Denk
2010-09-23Remove unused CONFIG_SERIAL_SOFTWARE_FIFO featureStefan Roese
This patch removes the completely unused CONFIG_SERIAL_SOFTWARE_FIFO feature from U-Boot. It has only been implemented for PPC4xx and was not used at all. So let's remove it and make the code smaller and cleaner. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-09-19ARM: implement relocation for ARM926Heiko Schocher
Change the implementation for arm926 to relocate the code to an arbitrary address in RAM. Adapt the TX25 (i.MX25), magnesium board to test the changes. On the tx25 board TEXT_BASE is set to the final relocation address to prevent one more copying of u-boot code when relocating. More info see: doc/README.arm-relocation da850 board: Tested-by: Ben Gardiner <bengardiner@nanometrics.ca> Portions of this work were supported by funding from the CE Linux Forum. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Ben Gardiner <bengardiner@nanometrics.ca>
2010-09-19ARM: add relocation supportHeiko Schocher
!! This breaks support for all arm boards !! To compile in old style, you must define CONFIG_SYS_ARM_WITHOUT_RELOC or you can compile with "CONFIG_SYS_ARM_WITHOUT_RELOC=1 ./MAKEALL board" !! This define will be removed soon, so convert your board to use relocation support Portions of this work were supported by funding from the CE Linux Forum. Signed-off-by: Heiko Schocher <hs@denx.de> Fix boot from NAND for non-ARM systems Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-10Prepare v2010.09-rc1v2010.09-rc1Wolfgang Denk
Coding style cleanup. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-03AT91: MCI: add SD/MMC driver using mmc frameworkReinhard Meyer
Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-08-10Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2010-08-10Merge branch 'master' of git://git.denx.de/u-boot-marvellWolfgang Denk
2010-08-09net: rename "FSL UECx" net interfaces "UECx"Kim Phillips
continuation of commit 2ecc2262d66a286e3aac79005bcb5f461312dea8 "net ppc: fix ethernet device names with spaces" (currently in u-boot-net.git) for QE based parts. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Acked-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-08-09net ppc: fix ethernet device names with spacesHeiko Schocher
since commit 1384f3bb8a4f9066805b70c1418eda78ecb73fdd ethernet names with spaces drop a Warning: eth device name has a space! message. This patch fix it for: - "FEC ETHERNET" devices found on mpc512x, mpc5xxx, mpc8xx and mpc8220 boards. renamed to "FEC". - "SCC ETHERNET" devices found on mpc8xx, mpc82xx based boards. Renamed to "SCC". - "HDLC ETHERNET" devices found on mpc8xx boards Renamed to "HDLC" - "FCC ETHERNET" devices found on mpc8260 and mpc85xx based boards. Renamed to "FCC" Tested on the kup4k board. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-08-08Add mkimage manpageNobuhiro Iwamatsu
Some Linux distributions include the "mkimage" as a package. This commit provides a manual page for mkimage. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Added documentation for FIT images and examples. Moved to doc/ directory. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-08-08ide: add configurationAlbert Aribaud
CONFIG_IDE_SWAP_IO This configuration option replaces a complex conditional in cmd_ide.c with an explicit define to be added to SoC or board configs. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
2010-07-26powerpc/8xxx: Enabled address hashing for 85xxyork
For 85xx silicon which supports address hashing, it can be activated by hwconfig. Signed-off-by: York Sun <yorksun@freescale.com>
2010-07-26powerpc/8xxx: Fix bug in memctrl interleaving & bank interleaving on cs0~cs4york
Verified on MPC8641HPCN with four DDR2 dimms. Each dimm has dual rank with 512MB each rank. Also check dimm size and rank size for memory controller interleaving Signed-off-by: York Sun <yorksun@freescale.com>
2010-07-26powerpc/8xxx: Enabled hwconfig for memory interleavingKumar Gala
Replace environmental variables memctl_intlv_ctl and ba_intlv_ctl with hwconfig parameters. The syntax is setenv hwconfig "fsl_ddr:ctlr_intlv=<mode>,bank_intlv=<mode>" The mode values for memory controller interleaving are cacheline page bank superbank The mode values for bank interleaving are cs0_cs1 cs2_cs3 cs0_cs1_and_cs2_cs3 cs0_cs1_cs2_cs3 Signed-off-by: York Sun <yorksun@freescale.com>
2010-07-12SPEAr : Network driver support addedVipin KUMAR
Designware network driver support added. This is a Synopsys ethernet controller Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-05-28nios: remove nios-32 archThomas Chou
The nios-32 arch is obsolete and broken. So it is removed. Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2010-05-28nios2: fix r15 issue for gcc4Thomas Chou
The "-ffixed-r15" option doesn't work well for gcc4. Since we don't use gp for small data with option "-G0", we can use gp as global data pointer. This allows compiler to use r15. It is necessary for gcc4 to work properly. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2010-05-21Fix "par[t]ition" typo.Wolfgang Denk
2010-05-03Program net device MAC addresses after initializingBen Warren
Add a new function to the eth_device struct for programming a network controller's hardware address. After all network devices have been initialized and the proper MAC address for each has been determined, make a device driver call to program the address into the device. Only device instances with valid unicast addresses will be programmed. Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Detlev Zundel <dzu@denx.de> Tested-by: Prafulla Wadaskar <prafulla@marvell.com> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Thomas Chou <thomas@wytron.com.tw>
2010-04-13nios: Move cpu/nios/* to arch/nios/cpu/*Peter Tyser
2010-04-13i386: Move cpu/i386/* to arch/i386/cpu/*Peter Tyser
2010-04-13m68k: Move cpu/$CPU to arch/m68k/cpu/$CPUPeter Tyser
2010-04-13arm: Move cpu/$CPU to arch/arm/cpu/$CPUPeter Tyser
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Create CPUDIR variablePeter Tyser
The CPUDIR variable points to the location of a target's CPU directory. Currently, it is set to cpu/$CPU. However, using $CPUDIR will allow for more flexibility in the future. It lays the groundwork for reorganizing U-Boot's directory structure to support a layout such as: arch/$ARCH/cpu/$CPU/* (architecture with multiple CPU types) arch/$ARCH/cpu/* (architecture with one CPU type) Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-10Add initial support for Matrix Vision mvSMR board based on MPC5200B.Andre Schwarz
Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
2010-04-03s5pc1xx: update the README fileMinkyu Kang
Because adds support the GPIO Interface, README file is updated. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
