path: root/doc/uImage.FIT
2008-10-08update uImage FIT multi documentationJean-Christophe PLAGNIOL-VILLARD
2008-09-09Add support for booting of INTEGRITY operating system uImagesPeter Tyser
2008-09-09Remove support for booting ARTOS imagesKumar Gala
Pantelis Antoniou stated: AFAIK, it is still used but the products using PPC are long gone. Nuke it plz (from orbit). So remove it since it cleans up a usage of env_get_char outside of the environment code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-03-26Cleanup coding style, update CHANGELOGWolfgang Denk
2008-03-20[new uImage] Fix *.its files location in documentationBartlomiej Sieka
Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-03-12[new uImage] Add new uImage format documentation and examplesMarian Balakowicz
Create doc/uImage.FIT documentation directory with the following files: - command_syntax_extensions.txt : extended command syntax description - howto.txt : short usage howto - source_file_format.txt : internal new uImage format description Add example image source files: - kernel.its - kernel_fdt.its - multi.its Update README appropriately. Signed-off-by: Marian Balakowicz <m8@semihalf.com> Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
