path: root/doc/uImage.FIT
2013-06-26Add verified boot information and testSimon Glass
Add a description of how to implement verified boot using signed FIT images, and a simple test which verifies operation on sandbox. The test signs a FIT image and verifies it, then signs a FIT configuration and verifies it. Then it corrupts the signature to check that this is detected. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26image: Add support for signing of FIT configurationsSimon Glass
While signing images is useful, it does not provide complete protection against several types of attack. For example, it it possible to create a FIT with the same signed images, but with the configuration changed such that a different one is selected (mix and match attack). It is also possible to substitute a signed image from an older FIT version into a newer FIT (roll-back attack). Add support for signing of FIT configurations using the libfdt's region support. Please see doc/uImage.FIT/signature.txt for more information. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26image: Support signing of imagesSimon Glass
Add support for signing images using a new signature node. The process is handled by fdt_add_verification_data() which now takes parameters to provide the keys and related information. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26image: Add signing infrastructureSimon Glass
Add a structure to describe an algorithm which can sign and (later) verify images. Signed-off-by: Simon Glass <sjg@chromium.org>
2010-08-09net ppc: fix ethernet device names with spacesHeiko Schocher
since commit 1384f3bb8a4f9066805b70c1418eda78ecb73fdd ethernet names with spaces drop a Warning: eth device name has a space! message. This patch fix it for: - "FEC ETHERNET" devices found on mpc512x, mpc5xxx, mpc8xx and mpc8220 boards. renamed to "FEC". - "SCC ETHERNET" devices found on mpc8xx, mpc82xx based boards. Renamed to "SCC". - "HDLC ETHERNET" devices found on mpc8xx boards Renamed to "HDLC" - "FCC ETHERNET" devices found on mpc8260 and mpc85xx based boards. Renamed to "FCC" Tested on the kup4k board. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-05-28nios: remove nios-32 archThomas Chou
The nios-32 arch is obsolete and broken. So it is removed. Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2010-03-31doc: Fix ramdisk examples in doc/uImage.FIT/multi.itsFelix Radensky
The ramdisk sections in doc/uImage.FIT/multi.its lack load address and entry point properties. Using examples from this file will result in unbootable image, u-boot will issue the following error messages: Can't get ramdisk subimage load address! Ramdisk image is corrupt or invalid This patch adds missing properties to ramdisk sections. Signed-off-by: Felix Radensky <felix@embedded-sol.com>
2009-11-24Fix example FIT image source filesIra W. Snyder
The example FIT image source files do not compile with the latest dtc and mkimage. The following error message is produced: DTC: dts->dtb on file "kernel.its" Error: kernel.its 7:0 - 1:0 syntax error FATAL ERROR: Unable to parse input tree ./mkimage: Can't read kernel.itb.tmp: Invalid argument The FIT image source files are missing the "/dts-v1/;" directive at the beginning of the file. Add the directive to the examples. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu>
2008-10-18Automatic software update from TFTP serverBartlomiej Sieka
The auto-update feature allows to automatically download software updates from a TFTP server and store them in Flash memory during boot. Updates are contained in a FIT file and protected with SHA-1 checksum. More detailed description can be found in doc/README.update. Signed-off-by: Rafal Czubak <rcz@semihalf.com> Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-10-08update uImage FIT multi documentationJean-Christophe PLAGNIOL-VILLARD
2008-09-09Add support for booting of INTEGRITY operating system uImagesPeter Tyser
2008-09-09Remove support for booting ARTOS imagesKumar Gala
Pantelis Antoniou stated: AFAIK, it is still used but the products using PPC are long gone. Nuke it plz (from orbit). So remove it since it cleans up a usage of env_get_char outside of the environment code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-03-26Cleanup coding style, update CHANGELOGWolfgang Denk
2008-03-20[new uImage] Fix *.its files location in documentationBartlomiej Sieka
2008-03-12[new uImage] Add new uImage format documentation and examplesMarian Balakowicz
Create doc/uImage.FIT documentation directory with the following files: - command_syntax_extensions.txt : extended command syntax description - howto.txt : short usage howto - source_file_format.txt : internal new uImage format description Add example image source files: - kernel.its - kernel_fdt.its - multi.its Update README appropriately. Signed-off-by: Marian Balakowicz <m8@semihalf.com> Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
