path: root/doc/uImage.FIT/update_uboot.its
2009-11-24Fix example FIT image source filesIra W. Snyder
The example FIT image source files do not compile with the latest dtc and mkimage. The following error message is produced: DTC: dts->dtb on file "kernel.its" Error: kernel.its 7:0 - 1:0 syntax error FATAL ERROR: Unable to parse input tree ./mkimage: Can't read kernel.itb.tmp: Invalid argument The FIT image source files are missing the "/dts-v1/;" directive at the beginning of the file. Add the directive to the examples. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu>
2008-10-18Automatic software update from TFTP serverBartlomiej Sieka
The auto-update feature allows to automatically download software updates from a TFTP server and store them in Flash memory during boot. Updates are contained in a FIT file and protected with SHA-1 checksum. More detailed description can be found in doc/README.update. Signed-off-by: Rafal Czubak <rcz@semihalf.com> Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
