path: root/doc/uImage.FIT/multi.its
2010-03-31doc: Fix ramdisk examples in doc/uImage.FIT/multi.itsFelix Radensky
The ramdisk sections in doc/uImage.FIT/multi.its lack load address and entry point properties. Using examples from this file will result in unbootable image, u-boot will issue the following error messages: Can't get ramdisk subimage load address! Ramdisk image is corrupt or invalid This patch adds missing properties to ramdisk sections. Signed-off-by: Felix Radensky <felix@embedded-sol.com>
2009-11-24Fix example FIT image source filesIra W. Snyder
The example FIT image source files do not compile with the latest dtc and mkimage. The following error message is produced: DTC: dts->dtb on file "kernel.its" Error: kernel.its 7:0 - 1:0 syntax error FATAL ERROR: Unable to parse input tree ./mkimage: Can't read kernel.itb.tmp: Invalid argument The FIT image source files are missing the "/dts-v1/;" directive at the beginning of the file. Add the directive to the examples. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu>
2008-10-08update uImage FIT multi documentationJean-Christophe PLAGNIOL-VILLARD
2008-03-12[new uImage] Add new uImage format documentation and examplesMarian Balakowicz
Create doc/uImage.FIT documentation directory with the following files: - command_syntax_extensions.txt : extended command syntax description - howto.txt : short usage howto - source_file_format.txt : internal new uImage format description Add example image source files: - kernel.its - kernel_fdt.its - multi.its Update README appropriately. Signed-off-by: Marian Balakowicz <m8@semihalf.com> Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
