path: root/doc/imx
2019-10-08imx: replace CONFIG_SECURE_BOOT with CONFIG_IMX_HABStefano Babic
CONFIG_SECURE_BOOT is too generic and forbids to use it for cross architecture purposes. If Secure Boot is required for imx, this means to enable and use the HAB processor in the soc. Signed-off-by: Stefano Babic <sbabic@denx.de>
2019-10-08imx: mxs: Fix location for the elftosb toolFabio Estevam
The Denx FTP location is no longer reachable. Switch to the Timesys repository instead. Signed-off-by: Fabio Estevam <festevam@gmail.com>
2019-10-08doc: imx: mkimage: introduce i.MX8 image formatPeng Fan
Introduce i.MX8 container set configuration file and add example Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-07-19doc: imx: Add documentation for nandbcb commandShyam Saini
Signed-off-by: Shyam Saini <shyam.saini@amarulasolutions.com>
2019-07-19clk: doc: Add documentation entry for Common Clock Framework [CCF] (i.MX)Lukasz Majewski
This patch describes the design decisions considerations and taken approach for porting in a separate documentation entry. Signed-off-by: Lukasz Majewski <lukma@denx.de>
2019-02-15doc: imx: habv4: Remove secure_boot.txt guideBreno Matheus Lima
The secure_boot.txt guide was replaced by mx6_mx7_secure_boot.txt and mx6_mx7_spl_secure_boot.txt documents. Both documents covers all steps needed for SPL and non-SPL tagets, so remove secure_boot.txt file to avoid duplicated content. Signed-off-by: Breno Lima <breno.lima@nxp.com>
2019-02-15doc: imx: habv4: Move encrypted boot guideBreno Matheus Lima
All guides are currently located at doc/imx/habv4/guides/ directory. Move encrypted_boot.txt document to guides directory. Signed-off-by: Breno Lima <breno.lima@nxp.com>
2019-02-15doc: imx: habv4: Add Secure Boot guide for i.MX6 and i.MX7 SPL targetsBreno Matheus Lima
The current U-Boot implementation includes SPL targets for some NXP development boards: - mx6sabreauto_defconfig - mx6sabresd_defconfig - mx6ul_14x14_evk_defconfig - mx6ul_9x9_evk_defconfig Add additional steps needed to completly secure the bootloader image. Signed-off-by: Breno Lima <breno.lima@nxp.com>
2019-02-15doc: imx: habv4: Add Secure Boot guide for i.MX6 and i.MX7 non-SPL targetsBreno Matheus Lima
Add HABv4 documentation for non-SPL targets covering the following topics: - How to sign an securely boot an u-boot-dtb.imx image. - How to extend the root of trust for additional boot images. - Add 3 CSF examples. - Add IVT generation script example. Reviewed-by: Ye Li <ye.li@nxp.com> Reviewed-by: Utkarsh Gupta <utkarsh.gupta@nxp.com> Signed-off-by: Breno Lima <breno.lima@nxp.com>
2019-02-15doc: imx: habv4: Add HABv4 introductionBreno Matheus Lima
The HABv4 is supported in i.MX50, i.MX53, i.MX6, i.MX7, series and i.MX 8M, i.MX8MM devices. Add an introductory document containing the following topics: - HABv4 Introduction - HABv4 Secure Boot - HABv4 Encrypted Boot - HAB PKI tree generation - HAB Fast Authentication PKI tree generation - SRK Table and SRK Hash generation Reviewed-by: Ye Li <ye.li@nxp.com> Reviewed-by: Utkarsh Gupta <utkarsh.gupta@nxp.com> Signed-off-by: Breno Lima <breno.lima@nxp.com>
2019-02-15doc: imx: habv4: Remove extra hab directory for a cleaner documentation ↵Breno Matheus Lima
structure There is no need to have an extra hab directory under doc/imx/. Habv4 and AHAB documentation can be added directly in doc/imx/ for a cleaner documentation structure. Signed-off-by: Breno Lima <breno.lima@nxp.com>
2019-01-01doc: imx: fix typos in mxsimage.txtMichael Heimpold
This fixes two small typos in mxsimage.txt. Signed-off-by: Michael Heimpold <mhei@heimpold.de> Reviewed-by: Breno Lima <breno.lima@nxp.com>
2019-01-01doc: imx: fix typo in imximage.txtMichael Heimpold
2018-10-22doc: imx: Improve i.MX documentation namingBreno Matheus Lima
There is no need to have README in all i.MX documents name. Remove README from i.MX docs name and add .txt file extension. Signed-off-by: Breno Lima <breno.lima@nxp.com> Reviewed-by: Ye Li <ye.li@nxp.com>
2018-10-22doc: imx: misc: Reorganize miscellaneous documentationBreno Matheus Lima
The Serial Download Protocol feature is availible in various i.MX SoCs. Move README.sdp document to imx/misc directory. Signed-off-by: Breno Lima <breno.lima@nxp.com>
2018-10-22doc: imx: hab: Reorganize High Assurance Boot documentationBreno Matheus Lima
The current High Assurance Boot document README.mxc_hab include details for the following features in a single file: - HAB Secure Boot - HAB Encrypted Boot Split HAB documentation in a specific directory for a cleaner documentation structure, subsequent patches will include more content in HAB documentation. Signed-off-by: Breno Lima <breno.lima@nxp.com>
2018-10-22doc: imx: Reorganize i.MX SoC common documentationBreno Matheus Lima
The following documents describe device details according to the i.MX family: - README.imx25 - README.imx27 - README.imx5 - README.imx6 - README.mxs Move all device common related document to doc/imx/common for a better directory structure. Signed-off-by: Breno Lima <breno.lima@nxp.com>
2018-10-22doc: imx: mkimage: reorganize i.MX mkimage documentationBreno Matheus Lima
The following documents describe the image type used by the mkimage tool to generate U-Boot images for i.MX devices. - README.imximage - README.mxsimage Move all mkimage related document to doc/imx/mkimage for a better directory structure. Signed-off-by: Breno Lima <breno.lima@nxp.com>
2018-10-22doc: imx: Move SPD related info to the appropriate docBreno Matheus Lima
Currently the Serial Download Protocol tools and procedure are documented in two places: - doc/imx/README.sdp - doc/imx/README.imx6 It is better to consolidate all SDP related information into README.sdp file, so move the content from README.imx6 to README.sdp. Signed-off-by: Breno Lima <breno.lima@nxp.com>
2018-10-22doc: imx: reorganize i.MX documentationBreno Matheus Lima
Currently the U-Boot doc/ directory contains the following files that are only relevant for i.MX devices: - doc/README.imx25 - doc/README.imx27 - doc/README.imx5 - doc/README.imx6 - doc/README.imximage - doc/README.mxc_hab - doc/README.mxs - doc/README.mxsimage - doc/README.sdp Move all content to a common i.MX folder for a better documentation structure. Signed-off-by: Breno Lima <breno.lima@nxp.com>
