path: root/doc/feature-removal-schedule.txt
2009-04-05Update CHANGELOG, coding style cleanup.Wolfgang Denk
2009-04-03Add "source" command; prepare removal of "autoscr" commandWolfgang Denk
According to the doc/feature-removal-schedule.txt, the "autoscr" command will be replaced by the "source" command in approximately 6 months from now. This patch prepares this change and starts a 6 month transition period as follows: - The new "source" command has been added, which implements exactly the same functionlaity as the old "autoscr" command before - The old "autoscr" command name is kept as an alias for compatibility - Command sequences, script files atc. have been adapted to use the new "source" command - Related environment variables ("autoscript", "autoscript_uname") have *not* been adapted yet; these will be renamed resp. removed in a separate patch when the support for the "autoscr" command get's finally dropped. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-04-03Add "GPL cleanup" task to feature-removal-schedule.txtWolfgang Denk
Announce removal of all non-GPL or GPL-incompatible files after August 2009. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-02-11Add feature-removal-schedule.txtPeter Tyser
