path: root/doc/driver-model
2013-07-24block: constify sect_buf argument of ide_write_dataGabor Juhos
Add a const keyword to the sect_buf argument of ide_write_data to fix the following warning: cmd_ide.c: In function '__ide_output_data': cmd_ide.c:548: warning: passing argument 2 of 'ide_write_data' discards qualifiers from pointer target type /devel/u-boot.git/include/ide.h:76: note: expected 'ulong *' but argument is of type 'const ulong *' Also modify the driver-model documentation to match with the new prototype. Compile tested only. Cc: Macpaul Lin <macpaul@andestech.com> Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
2013-05-15Power: remove support for Freescale MPC8220Wolfgang Denk
The Freescale MPC8220 Power Architecture processors have long reached EOL; Freescale does not even list these any more on their web site. Remove the code to avoid wasting maitaining efforts on dead stuff. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Andy Fleming <afleming@gmail.com>
2013-04-12arm: Remove support for unused s3c64xxBenoît Thébaudeau
Following the removal of the smdk6400 board, the s3c64xx SoC becomes unused, so remove associated code. It will still be possible to restore it later from the Git history if necessary. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-03-18Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Albert's rework of the linker scripts conflicted with Simon's making everyone use __bss_end. We also had a minor conflict over README.scrapyard being added to in mainline and enhanced in u-boot-arm/master with proper formatting. Conflicts: arch/arm/cpu/ixp/u-boot.lds arch/arm/cpu/u-boot.lds arch/arm/lib/Makefile board/actux1/u-boot.lds board/actux2/u-boot.lds board/actux3/u-boot.lds board/dvlhost/u-boot.lds board/freescale/mx31ads/u-boot.lds doc/README.scrapyard include/configs/tegra-common.h Build tested for all of ARM and run-time tested on am335x_evm. Signed-off-by: Tom Rini <trini@ti.com>
2013-03-11ppc: Remove PCIPPC2 and PCIPPC6 boardsStefan Roese
These boards seem to be unmaintained for quite some time. So lets remove support for them completely. This also cleans up some common drivers/files. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Guillaume Alexandre <guillaume.alexandre@gespac.ch> Acked-by: Wolfgang Denk <wd@denx.de>
2013-02-28ARM: ns9750dev: remove remainders of dead boardWolfgang Denk
Commit 8b710b1 started removing code for the unmaintained "ns9750dev" board; the board support is still broken, and not included anywhere in the Makefile or boards.cfg. Remove the remaining dead code. Signed-off-by: Wolfgang Denk <wd@denx.de>
2012-10-26arm: Remove support for lpc2292Marek Vasut
This stuff has been rotting in the tree for a year now. Remove it. Signed-off-by: Marek Vasut <marex@denx.de>
2012-10-16Remove lh7a40x cpu and serial driverAlbert ARIBAUD
Since commit 957731ed (ARM: remove broken "lpd7a40x" boards), lh7a40x cpu and serial driver have become unused. Remove them. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-09-02dm: Add twserial device documentTomáš Hlaváček
Signed-off-by: Tomas Hlavacek<tmshlvck@gmail.com>
2012-09-02dm: RTC subsystem analysis added.Tomas Hlavacek
Signed-off-by: Tomas Hlavacek <tmshlvck@gmail.com>
2012-09-02dm: Add pcmcia design documentViktor Krivak
Signed-off-by: Viktor Krivak <viktor.krivak@gmail.com>
2012-09-02dm: add PCI design documentPavel Herrmann
Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com>
2012-09-02dm: Driver model analysis document for Watchdog subsystem has been added.Tomas Hlavacek
2012-09-02dm: Hwmon UDM subsystem analysis added.Tomas Hlavacek
2012-09-02dm: Add POWER API transition documentViktor Krivak
2012-09-02dm: Add block device documentPavel Herrmann
2012-09-02dm: Add SPI API transition documentViktor Krivak
2012-09-02dm: Add networking subsystem analysisMarek Vasut
2012-09-02dm: Add MMC subsystem analysisMarek Vasut
2012-09-02dm: Add GPIO API transition documentViktor Křivák
Signed-off-by: Viktor Křivák <viktor.krivak@gmail.com>
2012-09-02dm: Add Driver cores design documentPavel Herrmann
2012-09-02dm: Initial import of design documentsMarek Vasut
This patch contains UDM-design.txt, which is document containing general description of the driver model. The remaining files contains descriptions of conversion process of particular subsystems. Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
