path: root/doc/driver-model/fs_firmware_loader.txt
2019-04-22misc: fs_loader: Replace label with DT phandleTien Fong Chee
In previously label which will be expanded to the node's full path was used, and now replacing label with most commonly used DT phandle. The codes were changed accordingly to the use of DT phandle and supporting multiple instances. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com>
2019-01-15misc: fs_loader: Switching private data allocation to DM auto allocationTien Fong Chee
Switching private data manual allocation to driver model auto allocation so users no longer need to deallocate themself because this would be deallocated by driver model when the device is no longer required. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-09-28doc: Add new doc for file system firmware loader driver modelTien Fong Chee
Provide information about - overview of file system firmware loader driver model - describe storage device and partition in device tree source - describe fie system firmware loader API Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
