path: root/doc/device-tree-bindings
2013-01-08EXYNOS5: FDT: Add SPI device node dataRajeshwari Shinde
Add SPI device node data for exynos. Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-01-08EXYNOS5: FDT: Add sound device node dataRajeshwari Shinde
Add sound device node data for exynos Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-11-19tegra: fdt: Add LCD definitions for TegraSimon Glass
Add LCD definitions and also a proposed binding for LCD displays. The PWM is as per what will likely be committed to linux-next soon. The displaymode binding comes from a proposal here: http://lists.freedesktop.org/archives/dri-devel/2012-July/024875.html The panel binding is new, and fills a need to specify the panel timings and other tegra-specific information. Should a binding appear that allows the pwm to handle this automatically, we can revisit this. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19tegra: fdt: Add pwm binding and nodeSimon Glass
This binding will apparently soon be in linux-next. Bring it in now since we need to do something, and may as well try to target what Linux will have. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-09-07tegra: fdt: Add NAND controller binding and definitionsSimon Glass
Add a NAND controller along with a bindings file for review. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-04-16Prepare v2012.04-rc2; minor Coding Style cleanupv2012.04-rc2Wolfgang Denk
2012-03-29tegra: fdt: i2c: Add extra I2C bindings for U-BootSimon Glass
Add U-Boot's peripheral clock information to the Tegra20 device tree file. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-03-29tegra: fdt: Add clock bindingsSimon Glass
This adds a basic binding for the oscillator and peripheral clocks. The second cell is the clock number, defined as the bit number within the clock enable register if the peripheral clock. This uses the RFC clock bindings from Grant Likely so may change later: https://lkml.org/lkml/2011/12/12/498 It is taken from Stephen Warren's patch here: http://patchwork.ozlabs.org/patch/141359/ Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-03-29tegra: fdt: Add additional USB bindingSimon Glass
This adds a property to indicate a port which can switch between host and device mode. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-03-29fdt: Add tegra-usb bindings file from linuxSimon Glass
This file is taken from the Linux mailing list. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-03-29fdt: Add staging area for device tree binding documentationSimon Glass
Add a directory to hold device tree binding files, to permit easy review of this material in U-Boot patches. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
